Page 3 of 10 FirstFirst 12345 ... LastLast
Results 21 to 30 of 92
Thread: Secondary Air readiness
  1. #21
    Please clarify:
    recode 0x01-07- code with 00032 + then go 0x01-10-00 clear save and Now also do a TV ADP 0x01-04-060
    RTFB this thread please.......
    http://forums.ross-tech.com/showthre...ut-0x01-08-000
  2. #22
    Wanna remote me in on team viewer...........?
  3. #23
    Banned
    Sep 2017
    Sure how do I do that?
    I'm going to have to change my approach. My laptop has wifi but the screen is so damn small (because I have to set the video settings to max in order to get Ross Tech to display correctly)
    So if it's something simple I'll put on an extra set of glasses and try to work through it.
    Right now I'm going to try to recode 0x01-07- code with 00032 + then go 0x01-10-00 clear save and Now also do a TV ADP 0x01-04-060
  4. #24
    Well in the meantime commence with what you have and read that thread on doing readiness individual tests........
    Let me know ........ Good luck
  5. #25
    Banned
    Sep 2017
    01 07 was already 00032
    01 10 was already zeroed
    And I don't get it, TV ADP 0x01-04-060 comes to me as the throttle body adjustment.
    Like the brakes, that has nothing at all to do with secondary air readiness.
  6. #26
    You are doing this to default the learned baseline settings and readapt everything.
    By changing the WSC + Coding: 00032
    Change Shop #: WSC 26078 to something else it verifies it was done like "34567".
    Just because 0x01-10-00 says zero don't mean the value is zero save it to clear the defaults.
    Then the TV gets done because you are reestablishing the baseline.
    This ensures a learned adaption loop is broken in the EEPROM much further than just a DTC reset.
  7. #27
    Banned
    Sep 2017
    Ok, I'll run another scan
  8. #28
    Banned
    Sep 2017
    Tuesday,05,September,2017,19:12:28:34562
    VIN: 3VWVH69M23M147751   License Plate:
    Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
              75 76
    VIN: 3VWVH69M23M147751   Mileage: 273460km-169920miles
    Address 01: Engine        Labels: 022-906-032-BDF.lbl
       Part No: 022 906 032 CS
       Component: MOTRONIC ME7.1.1G   0006
       Coding: 00032
       Shop #: WSC 26078
       VCID: 5EE696F8A92FE5D7096-5184
       3VWVH69M23M147751     VWZ7Z0C6853944
    Readiness: 0110 1101
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
       Part No: 1C0 907 379 M
       Coding: 0019970
       VCID: 3432145072231F878F2-5184
       Part No: 1C0 909 605 F
       Component: 04 AIRBAG VW61 0202 0001
       Coding: 12340
       Shop #: WSC 00066
       VCID: 2708F31CB6F5641F3A0-5160
       Part No: 1J0 920 906 J
       Component: KOMBI+WEGFAHRSP VDO V64
       Coding: 07234
       VCID: 2F381B3C9E053C5FF20-5160
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 00066
       VCID: 70BAD84043BB63A7ABA-5160
       Part No: 1C0 959 799 C
       Component: 1H Komfortgerát HLO 0003
       Coding: 00258
       Shop #: WSC 00066
       VCID: 3728235C6655F49FAA0-4B1E
       Component: 1H Tőrsteuer.FS KLO 0009
       Component: 1H Tőrsteuer.BF KLO 0009
       Component: 1H Tőrsteuer.HL KLO 0009
       Component: 1H Tőrsteuer.HR KLO 0009
                27-00 - Implausible Signal
    Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
       Part No: 3B7 035 180 E
       Component:    Radio ZSW        0010
       Coding: 00031
       Shop #: WSC 00050
       VCID: 221EE208DDD781376DE-5160
    End----(Elapsed Time: 05:08, VBatt start/end: 11.2V/11.2V. VIgn 11.2V)-----
  9. #29
    Shop #: WSC 26078 <<<<<<<<<<<<< change this
  10. #30
    Banned
    Sep 2017
    I believe that you're trolling me.
    Find a new hobby jack.
