Page 1 of 10 123 ... LastLast
Results 1 to 10 of 92
Thread: Secondary Air readiness
    Banned
    Sep 2017
    2003 Jetta GTI Vr6
    My secondary air system is not ready, so I cannot smog my vehicle. That's why I bought Ross-Tech.
    The air pump runs when the engine is doing a cold start - it blows lots of air through its discharge hose.
    When I run the set readiness routine it hangs.
    When I run block 077 it says "abort"
    There are no DTCs set.
    What can I do to get readiness set or at least get some information as to why it the Ross-Tech software aborts?
    TY
    United States
    VCDS isn't aborting, the green text you see is from the control module in the car. Abort can happen for a number of reasons but prerequisites that aren't met, pending DTCs or sensor readings (perhaps MAF in this case) that are implausible would be most likely. In less common cases tuning (chipped control unit) may prevent a test from running.
    Please let us know which DTCs were stored before the readiness was cleared in addition to any new parts that may be installed. The Auto-Scan would be helpful as well.
    Hello and welcome to the VCDS forum, I am NostraJackAss........ the forums resident asshole .....I'm pleased to meet you....
    I have some ideas .........PLEASE start with posting an auto-scan.
    The JPPSG
    The VR6 SAI is funny and depending on AFP ME7.1 or BDF ME7.1.1 can be in a learn loop or be difficult.
    Sometimes some jerkoff reverses the vacuum lines for the intake flap with the SAI noids to combi valve..........and doing exactly what you describe but so does a MAF or brake light switch like Dana aforementioned.
    Banned
    Sep 2017
    There were some DTCs a week or so ago that were meaningless for this question. But today (after replacing the stick transmission) when I returned to the readiness problem there were no codes set at all.
    All the other readiness components come up OK. The MAF flow shows and it's something like 3.5 GPM, that seems OK.
    I just ran a scan so now I'll retrieve it from my laptop and set out to posting it here. (I notice that it stopped at test 76)
    Thanks for your reply
    Banned
    Sep 2017
    Jack, here's the scan
    Tuesday,05,September,2017,16:00:48:34562
    VIN: 3VWVH69M23M147751   License Plate:
    Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
              75 76
    VIN: 3VWVH69M23M147751   Mileage: 273460km-169920miles
    Address 03: ABS Brakes        Labels:
       VCID: 55F489D4DD19268F58C-5184
       Part No: 1C0 909 605 F
       Component: 04 AIRBAG VW61 0202 0001
       Coding: 12340
       Shop #: WSC 00066
       VCID: 2708F31CB6F5641F3A0-5160
       Part No: 1J0 920 906 J
       Component: KOMBI+WEGFAHRSP VDO V64
       Coding: 07234
       VCID: 2F381B3C9E053C5FF20-5160
       3VWVH69M23M147751     VWZ7Z0C6853944
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 00066
       VCID: 70BAD84043BB63A7ABA-5160
       Part No: 1C0 959 799 C
       Component: 1H Komfortgerát HLO 0003
       Coding: 00258
       Shop #: WSC 00066
       VCID: 3728235C6655F49FAA0-4B1E
       Component: 1H Tõrsteuer.FS KLO 0009
       Component: 1H Tõrsteuer.BF KLO 0009
       Component: 1H Tõrsteuer.HL KLO 0009
       Component: 1H Tõrsteuer.HR KLO 0009
                27-00 - Implausible Signal
    Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
       Part No: 3B7 035 180 E
       Component:    Radio ZSW        0010
       Coding: 00031
       Shop #: WSC 00066
       VCID: 221EE208DDD781376DE-5160
    End----(Elapsed Time: 05:15, VBatt start/end: 11.9V/11.6V. VIgn 11.6V)-----
  7. Likes Jack@European_Parts liked this post
    -YO yo yo....no Engine 0x01 or ABS 0x03 in the scan dude...........
    Is this car modified..........?
    BDF it is ...... 022-906-032CS ME 7.1.1
    Activated carbon canister 1E4 Activated charcoal canister acc. to ORVR and siphoning device for filling up
    Additional body covers, side 6EA Without additional side body covers (stone guard)
    Additional child seat anchors 3B3 Child seat anchor
    Additional dust seals 6U0 Without additional seals outside
    Additional tunnel cover 4J1 Floor tray, extension center console
    Additional warning lights 9TB Additional warning lights (door area)
    Air bag 4UB Air bag for NAR
    Air duct, front area VK1 Air duct, type 1
    Antennas 8L3 Roof antenna
    Anti-theft protection system 7AG Electronic alarm system with vehicle immobilization device (for USA)
    Antifreeze 1C2 Antifreeze up to -35 degree celsius tolerance up to -40 degree C
    Automatic transmission indicator light 9FA Without automatic transmission indicator light
    Backrest release 3H0 Without backrest release for front seats
    Base engine T9T 6-cylinder gasoline engine 2.8 L unit 022.A
    Batteries J1L Battery 280 A (60 Ah)
    Body measures 5C1 Body measures for increased safety requirements
    Body style K8B Notchback
    Brackets 3P0 Without bracket for first aid kit and warning triangle
    Brake pad wear indicator 9U1 Brake pad wear indicator
    Brake type, front 1ZD Disc brakes, front (Geomet D)
    Brake type, rear 1KX Disc brakes, rear (Geomet D)
    Braking systems 1AT Electronic stabilization program (ESP)
    Breakaway interior mirror 4L2 Dipping breakaway interior rear view mirror
    Bumper 2JL Comfort bumpers
    Carrier frequency for radio remote control 5D2 Carrier frequency 315 MHz
    Cassette and CD storage unit 4W0 Without cassette and CD storage unit
    Catalytic converter control 8KA W/o catalytic converter warning light
    CD changer/CD player 7A1 CD changer preparation
    Cd enhancing underbody panel 2D1 Complete cd enhancing underbody panel
    Center armrest 6E3 Front center armrest
    Center rear seat belts 3C8 3-point seat belt, center rear with US label
    Chassis 2E0 Base chassis
    Child seats QA0 Without child seat
    Chrome work package QJ0 Without aluminum/chrome work package
    Component part sets with country-specific design requirements B0D Component parts set, complying with vehicle type for USA (without California), various parts
    Components with special surface appearance 6FF Body-colored exterior mirror housings and various add-on parts
    Controls (steering wheels/steering column) 4LA Without controls
    Cruise control 8T2 Cruise control system (CCS) electronic
    Cup holder 4M2 Cup holder in center console front and in tray rear
    Door and lid locking system 4K0 Radio remote controlled central locking operated from inside
    Door and side trim panels 4AF Door and side trim panel in foam film and woven fabric
    Door pockets, front 3YR Door pockets with insert mats
    Doors 0A2 4 doors
    Drive layout 1X0 Front wheel drive
    Electronic map cooling system QS0 Without electronic map cooling system
    Emission standard 0GM Emission standard LEV 1
    Engine compartment lighting 9L0 Without engine compartment lighting
    Engine cooling system 8Z7 Cold country
    Engine specifications MR0 6-cyl. gasoline eng. 2.8 L/147 kW 24V VR6 LEV base engine is T9T
    Equipment levels A8W Luxury equipment
    Exterior mirror setting 6XN Exterior mirrors: electrically adjustable, separately heated
    Exterior noise suppression measures 2B8 Additional exterior noise suppression
    Fire extinguisher 6A0 Without fire extinguisher
    Flame retardent materials 4Q1 Flame retardent materials
    Floor coverings 3MH Dilours floor covering w/o scuff guard
    Floor mats 0TD Front and rear floor mats
    Fresh air intake for passenger compartment (with particulate filter) 2V5 Fresh air intake system with activated charcoal canister
    Front fog light/additional headlight 8WA Without front fog light
    Front license plate bracket 6W3 License plate bracket front (small, NAR)
    Front seats Q4P Sports front seats
    Front stabilizer 0AE Front stabilizer
    Fuel filler cap/door, locking option 2W2 Fuel filler cap, attached (NAR)
    Fuel quantity for initial filling 1Z0 Initial standard fuel filling
    Fuel systems 0F2 Fuel system for carburetor gasoline engine
    Fuel tank treatment 2LC Fuel tank with special material treatment (coextrusion)
    Gearshift boot/cover 6R2 Leather gearshift boot
    Gearshift knob/handle 6Q2 Leather gearshift knob/handle
    Generators 8GL Alternator 120 A
    Grab handles at roof frame 5N6 Folding grab handles at roof frame soft fold-away
    Hand brake lever handle 6PC Leather hand brake lever handle
    Headlight 8BL Halogen headlight for driving on the right US design
    Headlight activation 8K4 Separate daytime running lights NAR
    Headlight washer system 8X0 Without headlight washer system
    Headlight-range adjustment 8Q0 Without headlight-range adjustment
    Headrests 5ZH Headrests for front seats, articulated and height-adjustable with integrated release function
    Heat accumulator system/additional heater 7E2 Heated crankcase ventilation system
    Heated washer nozzles 9T0 Without heated washer nozzles
    Heating and air conditioning system 9AB Manually controlled air conditioning
    Horns 8Y1 Two-tone horn
    Identification plates 1EB Without identification plate
    Ignition/starter switch locking system 0RB Ignition/starter switch locking system
    Insert for the filling up of unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
    Inserts 5MA Decorative inserts
    Installation differentiation for vehicle components 0EN Installation differentiation for transmission MQ 350 vehicle components
    Instrument inserts U0F Instrument insert with tachometer clock and mph speedometer
    Interference suppression 8E2 Local interference suppression for FM/AM radio reception
    Key for locking system 8QE Key for locking system with remote control
    Left exterior mirror 5SH Left exterior mirror: flat (US)
    Left vanity mirror 4SQ Left vanity mirror illuminated with cover and special mirror imprint (NAR)
    Lock operation for tailgate/trunk lid 4E2 Tailgate/trunk lid release from inside (electrically)
    Lockable wheel bolts 1PC Wheel bolts with anti-theft protection (unlockable)
    Luggage compartment cover 3U0 Without luggage compartment cover
    Luggage compartment floor covering 6SC Tufted trunk floor covering
    Luggage compartment lining 5A7 Gepäckraumauskleidung Komfort mit Serviceklappe
    Luggage net/pocket on backrest(s) 4U5 Luggage pockets on backrest
    Lumbar support 7P0 Without lumbar support in seat backrests
    Manufacturing sequence differentiation 0FL Mexico manufacturing sequence
    Mass damper for steering wheels 1Q0 Without mass damper for steering wheel
    Molding roof liner 6NG Molding roof liner unsplit roof cutout rear (radio antenna)
    Multi-function display/trip computer 9Q0 Without multi-function display/ on-board computer
    Nameplate set 0NQ Nameplate set "GLI"
    Nameplates for sales name QD3 Schriftzug f. Verkaufsbezeichnung
    Navigation device 7Q0 Without navigation device
    Outer rear seat belts 3ZM 3-point seat belts, outer rear
    Owner's manuals 0VM Information kit in American English
    Paint coating FB0 Standard paint coating
    Paint preservative/transit coating 5K5 Transportschutzfolie (anstelle Lackkonservierung)
    Park distance control 7X0 Without park distance control
    Partition 3CA Without partition
    Platform group class 7PA Platform group class 1
    Platform module floor pan, rear 4P1 Rear floor panel module, type 2
    Preparation for sound combination for rotating emergency light 9F0 Without sound combination for rotating emergency light and radio antenna preparation
    Preparation for two-way radio installation 9D0 Without preparation for two-way radio installation
    Proportioning valve 1H0 Without proportioning valve
    Protective side molding 4B2 Body-colored protective side molding
    Radiator grille 6KC Radiator grille
    Radios 8US Radio "Premium" (double-size standard radio)
    Reading light 8S2 One reading light front, two reading lights rear
    Rear axle 0N5 Standard rear axle
    Rear cargo area 3GA Without cargo area
    Rear fog light 8TA Without rear fog light
    Rear headrests 3Q6 Three rear headrests
    Rear license plate bracket 6P2 License plate bracket, rear (NAR)
    Rear seat catch 6QB Locking rear seat catch
    Rear seats 3NF Rear seat bench/backrest, split folding locking
    Rear stabilizer 0BB Rear stabilizer
    Rear window wiper and washer system 8M0 W/o rear window wiper and washer system
    Restraint systems, front 4QQ 3-point seat belts with tensioner height adjustment and US label front
    Right exterior mirror 5RR Right exterior mirror: convex (US)
    Right vanity mirror 4TQ Right vanity mirror illuminated with cover and special mirror imprint (NAR)
    Roll-up sun screen for rear and side windows 3Y0 Without roll-up sun screen
    Roof insert/convertible top 3FE Electric slide/tilt sunroof with sun screen/sunblind
    Roof rails/roof load rack 3S0 Without roof rails/roof load rack
    Rough-road/sports version 2UA Standard design
    Seat adjustment 3L3 Manual height adjustment for front seats
    Seat belt check 9P7 Seat belt reminder, optical and acoustic electric contact in buckle
    Seat covering N6C Fabric seat covering (NAR/Mexico)
    Seat heater 4A0 Without seat heater
    Service interval prolongation QG0 Without service interval prolongation
    Shock absorption, chassis, front G77 Front shock absorption
    Shock absorption, chassis, rear UA9 Rear shock absorption, sports version
    Side air bag 4X8 Side air bag front with head air bag and optimized head impact elements (USA)
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    Side lights 7R4 Side turn signal and marker lights (turn signal lights with white lens)
    Smoking/non-smoking package 9JA Non-smoking package
    Socket 7B2 12-volt socket in luggage boot
    Spare wheel/breakdown set 1G1 Space-saving spare wheel
    Speaker installation 9VG Sound system "Monsoon"
    Special color trim 0UA Without special color trim
    Special editions E0A No special edition
    Special labels/plates 0SC Labels/plates in English
    Start/stop system/regenerative braking 7L0 Without inertia benefit system/ deceleration fuel cut-off/idle stop valve
    Steering QZ3 Power steering (limited steering lift mechanism)
    Steering column systems 2C5 Axial and vertical adjustable steering column
    Steering system arrangement L0L Left-hand drive vehicle
    Steering wheels 2PX Leather trimmed sports steering wheel
    Sticker (customized or special edition) 0KA Without stickers and badges
    Taillight assemblies 8SB Taillight assembly w/ dark colored lens
    Telephone/telematics 9W0 W/o car phone preparation/installation
    Throttle actuation 0L2 Electric throttle actuation
    Tire suppliers V0A Tires w/o specification of tire brand
    Tires H7K All-weather tires 225/45 R17 91H (NAR)
    Tool kit and jack 1S7 Tool kit and aluminum jack
    Trailer hitch 1D0 Without trailer hitch
    Transmission shafts 1WB Transmission shafts w/ 100 mm in diameter
    Transmission specifications G0K 6-speed manual transmission
    Transmission types/gearshift mechanisms 0G4 Cable gearshift
    Tray 7N0 Without tray on roof liner
    TV reception/digital radio reception QV0 W/o TV reception/digital radio reception
    Type approval countries/countries with special requirements B34 Legal requirements USA
    Vehicle class differentiation units/platform components 0CM Vehicle class differentiation 1JM
    Vehicle type AZ0 Vehicle with standard production scope
    Washer fluid level indicator 8W1 Washer fluid level indicator
    Weight category front axle L39 Suspension range 39 installation control only, no requirement forecast
    Wheel covers 1NL Covers for alloy wheels
    Wheels CD1 Leichtmetallräder 7J x 17 1J0 601 025 J, ET 38
    Window regulator 4R4 Power windows with comfort operation and circuit breaker
    Windshield glass type 4GC Windshield in heat-insulating glass with sunshield
    Windshield wiper intermittent control 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
    PS4 SOUND SYSTEM MONSOON AND SUNROOF
    Vehicle Identification No. 3VWVH69M23M147751
    Model Jetta GLS VR6 JEM
    Date of production 05.03.2003
    Year 2003
    Sales type 9M25W6
    Engine Code BDF
    Transmission Code FSR
    Axle drive 6S
    Equipment RD
    Roof color 2R
    Exterior color / Paint Code 2R / D7X
    Banned
    Sep 2017
    I don't know what this means.
  10. #8
    https://www.google.com/search?q=me+7...&bih=585#imgrc=_
    http://forums.ross-tech.com/showthre...ut-0x01-08-000
  11. #9
    Banned
    Sep 2017
    Not that I can tell
  12. #10
    You need to fix the communication error and I suspect something up with the ABS ....on K line please JPPSG check fuses and issues at hand with WD and RTFB.
    Get the manual at Erwin
