Results 1 to 10 of 16
Thread: Error 31 : Request out of range
    Nov 2016
    Scotland
    Hi All
    I am trying to add the oil temp display onto the dash on my 2016 Audi A3 8V S-Line Quattro TDI but it will not take the coding. It just keeps saying Error 31 : Request out of range.
    [17] Instruments -> Long Coding -> Byte 10
    CHANGE: Tick Bit 1. Display Oil Temperature
    The VCDS version is 17.8.0
    Can anyone help me fix this?
    Regards
    Dave
    Please post an Auto-Scan so people can see exactly what modules are fitted to this car and how they are configured.
    Nov 2016
    Scotland
    Hi, here is the one I took when I got the vehicle a few weeks ago. The only changes I have made so far is it lowers the passenger mirror when reversing and the needle sweep is enabled.
    Wednesday,09,August,2017,17:50:26:62090
    VCDS Version: 17.8.0.1 (x64)
    VIN: WAUZZZ8V9HA0XXXXX   License Plate:
    Mileage: 15265km-9485mi   Repair Order:
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 03 08 09 15 16 17 19 22 42 44 52 55 5F BB BC
    VIN: WAUZZZ8V9HAXXXXX   Mileage: 15265km-9485miles
    Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 BQ    HW: 04L 907 309 R
       Component: R4 2,0L EDC   H23 1199
       Revision: B5H23---
       Coding: 02190012032701082000
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_ECM20TDI01104L906026BQ 002002
       ROD: EV_ECM20TDI01104L906026BN_002.rod
       VCID: 7AFA7044FD2DD396C4-802E
       Part No SW: 5Q0 614 517 AR    HW: 5Q0 614 517 AG
       Component: ESC           H62 0642
       Revision: 00000000    Serial number: 61956000000022
       Coding: 12F18AA224230A6F497D0F0440CA294851245092F0029472026100788008420000000012121212B835351919323200
       ROD: EV_Brake1UDSContiMK100IPB_036_AU37.rod
       VCID: 010807A890FB804E85-8054
    8400 - Databus
                        Reset counter: 248
                        Mileage: 14938 km
                        Date: 2017.07.30
                        Time: 21:36:06
                        Extended Freeze Frames:
       Part No SW: 8V0 820 043 M    HW: 8V0 820 043 M
       Component: AC Automat    H03 0110
       Revision: 20001000    Serial number: 00000001006464
       Coding: 03100104002000011000000000001100
       ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
       VCID: 3C76B65CB7992DA696-8068
       Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Serial number: A109C04800PAG0MUFU03
       Part No SW: 5Q0 937 084 CF    HW: 5Q0 937 084 CF
       Component: BCM MQBAB M+  H34 0236
       Serial number: 02001621104047
       ROD: EV_BCMBOSCH_017_VW27.rod
       VCID: 7EF27C54E105FFB6F8-802A
       Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 160717  043 0580
       Serial number:         160727095341
       Coding: 0A47F7
       Serial number: 62119713
       Coding: 00006C
       Serial number: 12 06 2016  00000467
       Serial number: 000000000ZY161872HP9
       Component: Sirene, DWA  005 0313
       Serial number: 00000000000065865512
              U1101 00 [008] - Active
                        Reset counter: 235
                        Mileage: 14771 km
                        Date: 2017.06.22
                        Time: 15:36:03
       Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
       Component: AirbagVW21    003 0315
       Serial number: 003TDR1ZDKY3
       VCID: 102E32ECCB91F9C61A-8044
       Subsystem 1 - Part No SW: -----------    HW: 480 003 007 16
       Serial number: 35700000000CD1596D1W
       Subsystem 2 - Part No SW: -----------    HW: 480 003 007 16
       Serial number: 35800000000AD41D6D1Y
       Subsystem 3 - Part No SW: -----------    HW: 480 400 408 16
       Serial number: 3510001C121DBA14A31-
       Subsystem 4 - Part No SW: -----------    HW: 480 400 408 16
       Serial number: 3520001C121DBA1455A0
       Subsystem 5 - Part No SW: -----------    HW: 480 402 706 16
       Serial number: 3550002AF20FC4C3704D
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 480 402 507 16
       Component: PedP_Sensor_D  000 6149
       Serial number: 2280001AD210BB03C23
       Subsystem 7 - Part No SW: -----------    HW: 480 402 507 16
       Component: PedP_Sensor_P  000 6149
       Serial number: 2290001AD210BB0164F2
       Subsystem 8 - Part No SW: -----------    HW: 480 001 607 16
       Serial number: I0M00000000D6C35CC1I
       Subsystem 9 - Part No SW: -----------    HW: 480 001 607 16
       Serial number: I0N00000000F39813D18
       Part No SW: 8V0 953 521 HB    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 07081604400280
       Coding: A408
       Part No SW: 8V0 920 972 L    HW: 8V0 920 972 L
       Component: KOMBI         H03 8316
       Coding: 27A408002B8026000100E8001000000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009054
       ROD: EV_DashBoardVDDMQBAB_009_AU37.rod
       VCID: 479CD9B0FE5F7E7E0B-8012
       Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1265
       Revision: --------    Serial number: 0005199594
       Coding: 030100041F0873005B000248080B00000001010000000000000000000000
       ROD: EV_GatewLear_013_VW37.rod
       VCID: 7CF6765CF719EDA6D6-8028
       Subsystem 2 - Part No SW: 81A 951 523     HW: 81A 951 523
       Component: J453 MFL  H04 0003
       Serial number: 20160722035934 00538
       Serial number: 75410803001608043960
       Serial number: HA1-00029.06.16
       Coding: 0001
       ROD: EV_AllWheelContrHA1VW37X_004_VW48.rod
       VCID: 4A9AE084ED4D831614-801E
       Serial number: 210716EGL11001
       Coding: 001C8A204001040000001002
       VCID: 4384CDA0CA67525ED7-8016
       Part No SW: 5Q0 909 144 T    HW: 5Q0 909 144 R
       Component: EPS_MQB_ZFLS  128 1072
       Coding: 8107
       ROD: EV_SteerAssisMQB_013_VW37.rod
       VCID: 4580D3B8C4536C6EF9-8010
       Serial number: 210716EGJ21696
       Coding: 001C82204001040000001002
       VCID: 428AC8A4D57D5B56DC-8016
    Address 55: Headlight Range (J745)       Labels:* None
       Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0230
       Coding: 0EEE00102B230200
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
       VCID: 3E72BC54A1853FB6B8-806A
       Part No SW: 81A 035 192     HW: 81A 035 192
       Component: MU-HS-LND-EU  045 0148
       Coding: 01730301FF00000011111101000A00102F0032C601F00100CE
       ASAM Dataset: EV_MUHigScl6C3DELP 001011
       ROD: EV_MUHigScl6C3DELP_AU37.rod
       VCID: 5EB21CD441C51FB6D8-800A
       Subsystem 1 - Part No SW: 8W0 919 866 C    HW: -----------
       Component: ECE 2016  --- 0009
       Component: DU High  H49 0014
       Serial number: AUZ8Z9GY206VBQ
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 BE    HW: 8V0 919 614 BE
       Component: ControlUnit_B  H50 0103
       Serial number: ALJAL121061600010800
       Serial number: 070716EG611011
       Coding: 000C82204001040000001002
       ROD: EV_DCURearDriveMAXCONT_VW37.rod
       Serial number: 070716EG61057B
       ROD: EV_DCURearPasseMAXCONT_VW37.rod
    End-------------------------(Elapsed Time: 03:49)--------------------------a
  4. Likes Uwe liked this post
    Feb 2017
    Request out of range usually means you need security access to perform an action.
    Nov 2016
    Scotland
    Do you know the security code for that section?
    Quote Originally Posted by ibis_white View Post
    I don't agree that it "usually" means that. While it can mean that, it can also mean that the software in the module simply doesn't support the functionality that would be enabled by that coding change.
    Verified VCDS User DJAlix's Avatar
    Apr 2015
    London, United Kingdom
    Reset counter: 235
    Mileage: 14771 km
    Date: 2017.06.22
    Time: 15:36:03
    Changed your BCM?
    Try 20103 for the 17 - Instruments Security Access Code.
    VAG Car Coding
    Adaptation | Coding | Diagnostic | Retrofit - London, United Kingdom
    Authorised VW Group Services Provider and Independent Repairer
    @vagcarcoding
  9. Likes Uwe, Derek, PetrolDave liked this post
  10. #8
    Feb 2017
    I sit corrected. My brain was ready for bed, my hands should have done the same. Apologies.
  11. #9
    No worries, I did something similar myself yesterday.
  12. #10
    Nov 2016
    Scotland
    Quote Originally Posted by DJAlix View Post
    Reset counter: 235
    Mileage: 14771 km
    Date: 2017.06.22
    Time: 15:36:03
    Changed your BCM?
    I have only had the car a few weeks. What is the BCM and why would it have been changed?
    Do I need to worry about this?
    I will try that code DJAlix. Cheers.
