any help is much appreciated. we have replaced fuel filter, in-tank fuel pump and fuel rail pressure sensor. have removed solenoid on high pressure pump for swarf and small metal fillings but not visible. any help will be much appreciated to daiag if the high pressure pump is at fault. symptoms described by customer is coil light flashing and limp mode and occasionally struggles to start. replaced fuel filter first as not been replaced yet by dealer. after replaced the filter housing would not prime so tested the in tank pump wasnt working replaced the in-tank pump and the vehicle starts better but still goes to limp mode.
Friday,01,September,2017,08:57:37:11898
VCDS Version: 17.8.0.1 (x64)
Dealer/Shop Name: Sterling Garage Ltd
VIN: WVWZZZ1KZDW005536 License Plate: OV62GGE
Mileage: 91620km-56930mi Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 61
VIN: WVWZZZ1KZDW005536 Mileage: 91620km-56930miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 MN HW: 03L 907 425 C
Component: R4 1.6l TDI H43 9979
Revision: --H43--- Serial number: 00000000000000
Coding: 08114014030501080000
ASAM Dataset: EV_ECM16TDI02103L906023MN 003014
ROD: EV_ECM16TDI02103L997557B.rod
VCID: 7EF9CC85E1D90FB6F8-802A
10116 - Fuel Rail/System Pressure
P0087 00 [096] - Too Low
Mileage: 91619 km
Date: 2017.08.31
Time: 14:20:36
Engine speed: 1664.00 /min
Normed load value: 72.5 %
Vehicle speed: 49 km/h
Coolant temperature: 88 °C
Intake air temperature: 38 °C
Voltage terminal 30: 13.440 V
Fuel high pressure: actual value-FUP_FIL: 6.628 MPa
Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000000
Fuel level-FTL_CAN: 31 l
Fuel temperature-TFU: 54 °C
Fuel Metering Valve-VCV: 33.757 %
Fuel Pressure Regulator Valve-PCV: 38.693 %
Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 123999.023 kPa
7478 - Fuel Metering Valve 1 Control Difference
P228C 00 [096] - Pressure too Low
Mileage: 91619 km
Date: 2017.08.31
Time: 14:20:36
10119 - High Pressure Fuel Rail
P00C6 00 [101] - Minimum Pressure Not Reached
Fault Frequency: 9
Mileage: 91619 km
Date: 2017.08.31
Time: 18:09:06
Engine speed: 354.75 /min
Normed load value: 8.6 %
Coolant temperature: 59 °C
Intake air temperature: 29 °C
Voltage terminal 30: 11.407 V
Fuel high pressure: actual value-FUP_FIL: 10.400 MPa
Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000001
Fuel level-FTL_CAN: 32 l
Time since engine start: 0 s
Fuel Metering Valve-VCV: 24.763 %
Fuel Pressure Regulator Valve-PCV: 42.184 %
Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 25610.352 kPa
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 133B200D092200FFC81004E7901F0091310000
VCID: 7DFBCB89E4DF14AEE1-8028
Part No SW: 7N0 907 426 BG HW: 7N0 907 426 BG
Component: AC Manuell H20 0505
Revision: 00001018
Coding: 0010004003
VCID: 7AF1C095FDF12396C4-802E
Part No SW: 1K0 937 085 P HW: 1K0 937 085 P
Component: BCM PQ35 B+ 111 0709
Revision: AB111709
Coding: 48180A3A8025F190408800C0100400644B010288424D8160648087200041
VCID: 3C7D068DBF45DDA696-8068
Subsystem 1 - Part No: 5K2 955 119
Component: Wischer 14051 26 0512
Coding: 009795
Subsystem 2 - Part No: 1K8 951 171
01598 - Drive Battery Voltage
Fault Status: 00101011
Fault Frequency: 48
Reset counter: 186
Mileage: 88457 km
Date: 2017.07.01
Time: 08:22:29
Voltage: 13.05 V
Term 50 On
Reset counter: 186
Mileage: 91493 km
Date: 2017.08.22
Time: 23:05:55
Term 15 Off
Voltage: 6.75 V
Term 50 Off
Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
Component: AirbagVW10 013 0613
Serial number: 003G5RAKJN2$
Coding: 00004432
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 316327B9600720CE35-8064
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Serial number: 3572MSME30294268ZZZR
Serial number: 3582MSME4E617268ZZZ%
Serial number: 3512QSME683D161AZZZ$
Serial number: 3522QSME4606160FZZZU
Part No SW: 5K0 953 507 AS HW: 5K0 953 549 C
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422LEH0016K
Coding: 5080040000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 0103B7799027704E85-8054
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 5K0 920 973 A HW: 5K0 920 973 A
Component: KOMBI H05 0705
Coding: 470B00
VCID: 2F6721C17633363E23-807A
9453074 - Fuel Level Sensor 1
B103E 1B [008] - Resistance Too High
Reset counter: 194
Part No SW: 7N0 907 530 S HW: 7N0 907 530 J
Component: J533 Gateway H43 1632
Revision: H43 Serial number: 140512F2003633
Coding: 350003
VCID: 4085727DD3ADB946CA-8014
Component: IMMO H05 0705
VCID: 6AD1F0D58D51931634-803E
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2120
Coding: 0131636
VCID: 316327B9A80720CE35-8064
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 69 3305
Revision: 00H22000
VCID: 377719A14663FEFE7B-8062
Part No SW: 5K0 959 702 H HW: 5K0 959 702 H
Component: Tuer-SG 009 2106
Coding: 0131636
VCID: 38751A9D4B7DF18672-806C
Part No SW: 1K0 035 186 AN HW: 1K0 035 186 AN
Component: Radio RCD310 042 0082
Revision: 00000001 Serial number: VWZ1Z2M4354625
Coding: 05000400040005
VCID: 72E1E8B5AD815BD68C-8026
Part No SW: 7N0 907 534 HW: 7N0 907 530 J
Component: Batt.regelung H43 1632
Coding: 030F1859
VCID: 71E3E7B9A88760CE75-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900213002
Fault Status: 00100011
Fault Frequency: 53
Reset counter: 186
Mileage: 88457 km
Date: 2017.07.01
Time: 08:22:30
End-------------------------(Elapsed Time: 02:04)--------------------------
