Results 1 to 9 of 9
Thread: DSG 0D9 Intermittent faults after suggested adaptation process
    Aug 2017
    Qatar
    Question DSG 0D9 Intermittent faults after suggested adaptation process
    I had a bit of rough downshifts on my 2015 MQB Golf R, so I followed the adaptation reset process posted here and it finished successfully:
    http://forums.ross-tech.com/showthre...ll=1#post76381
    Car drives the same after adaption, its smooth for the most part, but 4-3 downshift is a bit rough. Anyway, my main concern now is the faults only.
    Now whenever I put it in D i get the following faults immediately:
    Sunday,27,August,2017,20:17:25:63624
    VCDS Version: 17.8.0.1 (x64)
    VIN: WVWGR2AU7FW121891   License Plate:
                    Address 02: Auto Trans       Labels: 0D9-927-770.clb
    Control Module Part Number: 0D9 300 012 L    HW: 02E 927 770 AQ
      Component and/or Version: DQ250-6A MQB  H53 4516
               Software Coding: 0014
                Work Shop Code: WSC 01357 011 00200
                  ASAM Dataset: EV_TCMDQ250021 001001 (VW37)
                           ROD: EV_TCMDQ250021_VW37.rod
                          VCID: 1F4DFFED064554BE93-804A
    21153 - Gear 1
              P072C 00 [002] - Not Selectable
    21159 - Gear R
              P072B 00 [002] - Not Selectable
    10906 - Cooling Oil Valve
              P179D 00 [002] - Electrical Malfunction
    And after I drive around I get the following:
    Wednesday,16,August,2017,00:38:23:63624
    11 Faults Found:
    21153 - Gear 1
    21154 - Gear 2
              P072D 00 [002] - Not Selectable
    21155 - Gear 3
              P072E 00 [002] - Not Selectable
    21156 - Gear 4
              P072F 00 [002] - Not Selectable
    21157 - Gear 5
              P073A 00 [002] - Not Selectable
    21158 - Gear 6
              P073B 00 [002] - Not Selectable
    21159 - Gear R
    10731 - Valve 3 in Transmission Part 1
              P174A 00 [002] - Electrical malfunction
    10732 - Valve 3 in Transmission Part 2
              P174E 00 [002] - Electrical malfunction
    10657 - RPM Signal from ECU
              P0726 00 [002] - Implausible Signal
    Any help would be very appreciated. Thank you!
    Aug 2017
    Qatar
    Any help, please?
    How many miles on this car?
    Has appropriate fluid maintenance been done?
    Aug 2017
    Qatar
    It has 15k miles on it only. The faults were not there before I attempted the adaptation reset. Thanks
    Aug 2017
    Qatar
    Here is a full scan..for some reason the faults don't appear in the full scan, but they do when I go to the module itself (Auto trans) and check faults
    Friday,01,September,2017,22:10:25:63624
    Mileage: 26112km-16225mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 42 44 52 55 5F A9
    VIN: WVWGR2AU7FW121891   Mileage: 26112km-16225miles
    Address 01: Engine (J623-CJXB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 E    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0003
       Revision: --H13---
       Coding: 091D1032242604083004
       ASAM Dataset: EV_ECM20TFS0205G0906259E 001003
       ROD: EV_ECM20TFS0205G0906259E.rod
       VCID: 306F0C516BDBDBC63A-8064
       Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H53 4516
       Revision: 03253104    Serial number: TFK01409050522
       Revision: 00000000    Serial number: 62574000004796
       Coding: 01FA6BA15422096D037F070941C46980D62A90C0E08296B700400038C208
       VCID: 45814D85C4596E6EF9-8010
       Revision: 00021000    Serial number: 0346810954
       Coding: 030C0C
       ROD: EV_KessyHellaMQBAB_002_VW37.rod
       VCID: 3A7B2E79BDA7119684-806E
       Part No SW: 5G0 907 044 AN    HW: 5G0 907 044 AN
       Component: Climatronic   H03 0907
       Revision: 00001K08
       Coding: 00020014100100000005004012101800
       VCID: 73E5C35DDA4DA0DE87-8026
       Component: BCM MQBAB H   H18 0134
       Serial number: 01011425901559
       Coding: 00111A46C04122F30BA44080B10C07001800000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 000F9C919BFB8B468A-8054
       Component: WWS    140822  043 0551
       Serial number:         140902200625
       Component: RLHS  037 0059
       Serial number: S5Y14M09D24H01M26S14
       Coding: 06A8DD
       Serial number: 000000000ZY142320T84
       Serial number: 00000000000030644710
       Sun Roof:
       Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
       Component: J245 PS73.014  H02 0007
       Serial number:     WOO32464946
       Coding: 181801
       Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0048
       Revision: --------    Serial number: 39331425901157
       Coding: 0031151011
       VCID: 3D712565AC8926AEA1-8068
       Component: AirbagVW20    014 0385
       Serial number: 003F6R0BC31Z
       VCID: 41895995D071424EC5-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 001 509 14
       Serial number: 3576700000060D011118
       Subsystem 2 - Part No SW: -----------    HW: 480 001 509 14
       Serial number: 358670000006CA70111O
       Subsystem 3 - Part No SW: -----------    HW: 480 400 509 14
       Serial number: 35165029B175A8D3513C
       Subsystem 4 - Part No SW: -----------    HW: 480 401 209 14
       Serial number: 3526502C7176A6C3D38P
       Subsystem 5 - Part No SW: -----------    HW: 480 401 209 14
       Serial number: 3556502C9176A6C5B2EZ
       Part No SW: 5Q0 953 507 EA    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 01091408490403
       Coding: 0410
       ROD: EV_SMLSKLOMQB_009_VW37.rod
       VCID: 79F9F175F821DA8ECD-802C
       Part No SW: 5G1 920 758     HW: 5G1 920 758
       Component: KOMBI         304 4270
       Coding: 07AD08182B80000801086A001400000000000000
       VCID: 6CD7D82187737F2646-8038
       Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1188
       Revision: --------    Serial number: 0002495734
       Coding: 0101000820085900EF00022A1C0F00000001050000000000000000000000
       ASAM Dataset: EV_GatewLear 011016
       ROD: EV_GatewLear_011.rod
       VCID: 428B5699D5775956DC-8016
       Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H10 0101
       Serial number: 29140002033200104377
       Coding: 29FFFF
       Component: Haldex4Motion H52 7081
       Serial number: HA1-00019.08.14
       Coding: 0001
       ASAM Dataset: EV_AllWheelContrHA1VW37X 002011
       ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
       VCID: 46834A89F95F6576F0-8012
       Revision: 00000000    Serial number: 14000256844004
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB_004_VW37.rod
       VCID: 346700419FC3E7E65E-8060
       Serial number: 09091406070440
       Coding: 003E1220D000040000001000
       VCID: 408F5C91DB7B4B46CA-8014
       Serial number: 00000000000003882860
       Coding: 0102
       ROD: EV_SteerAssisMQB_010.rod
       VCID: 35613D4594B9FEEE69-8060
       Serial number: 12091403111409
       Coding: 003E1020D400040000801000
       VCID: 3F8D5F6DA68534BEB3-806A
       Serial number: 00000000000003783294
       Coding: 190000
       Coding: 022A01000B010200
       Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
       Part No SW: 5G0 035 045 C    HW: 5G0 035 045 C
       Component: MU-H-N-RW     H43 0377
       Serial number: A311I0EB002457
       Coding: 0273000CFF00000011110001001800001F0207D40100010057
       ASAM Dataset: EV_MUHig4CHBAS 001040
       ROD: EV_MUHig4CHBAS_VW37.rod
       VCID: 204FFC113B3B6B46AA-8074
       Component: ABT_High  H61 0030
       Serial number: VWZ8Z9PS100LLR
       Subsystem 2 - Part No SW: V03 959 801 FE    HW: -----------
       Component: ROW 2014/2015  --- 0036
       Component: Gracenote  --- 4006
       Part No SW: 5G0 907 159 B    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0006
       Serial number: 140812202301
       ROD: EV_SoundActuaGen2AU64X_VW26.rod
       VCID: 2D5115257CE9B62E11-8078
    End-------------------------(Elapsed Time: 04:39)--------------------------
    Quote Originally Posted by xheartcoreboyx View Post
    Well that's a bit unusual.
    What happens if you go to directly to the module, check for fault codes, and then remove the check-mark from "Use Aggressive Mode" mode option?
    I'll note in the data you posted originally, they're all flagged "Intermittent - Not Confirmed".
    "Intermittent" means the condition that set the fault code did not exist (or could not be detected) at the time the scan was performed. "Not Confirmed" pretty much speaks for itself.
  7. #7
    Aug 2018
    Palestine
    Hi, today i checked Golf GTI with same Gearbox 0D9 and had the same faults on gearbox, (from gear 1 to 6 and R Not Selectable) + other faults. Sorry i do not have auto scan to post. I asked a local Gearbox specialist, he said these faults only appears when checking with VCDS, and when checking by ODIS or other scanner, no faults appears. I have VCDS 18.9.1, What do you think?
  8. #8
    You could try unticking the "aggressive"mode box in VCDS and scanning again - then please post the scan here.
  9. Likes Uwe liked this post
  10. #9
    Mar 2019
    Croatia
    21153 - Gear 1
    21159 - Gear R
    11 Faults Found:
    21153 - Gear 1
    21154 - Gear 2
    21155 - Gear 3
    21156 - Gear 4
    21157 - Gear 5
    21158 - Gear 6
    21159 - Gear R
    Any Info on this ?
    i have same problem !
