Results 1 to 10 of 16
Thread: 2013 4H A8L 4.0t 34 Level Control Faults - not able to overcome
    Aug 2017
    This is my first post although I have owed VCDS for many years. Please excuse my incompetence regarding posts.
    As the title states above and here is my scan. Hope I wrapped it [CODE] properly?
    I have gone through the many previous posts regarding my problem and each post ends without resolution; at least that I am able to find.
    I have done the procedure shown by DrPete, and like others, was stopped by ERROR sequence out of order or something like that, when I hit GO - Calibrate Level Control
    I tried several times all with same result. I'm stuck. Must I really go to dealer?? I always end up winning. Maybe not this time?
    I am also hoping that with Level Control working properly the other modules that are pissed will become happy.... except the knock sensor issue.
    One problem at a time as they say at the meetings, so I'm told.
    Tuesday,29,August,2017,16:43:53:47273
    VCDS Version: 17.8.0.1 (x64)
    VIN: WAUR2AFD8DN011092   License Plate: RICK
    Mileage: 61249km-38058mi   Repair Order: 28082017
    Chassis Type: FD-AU64 (4H0)
    Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 20 28 34 36 3B 3C 42
              46 47 52 53 56 5F 62 6C 6D 6F 72 81 85 88 89 8B 8E 8F 90 BA
    VIN: WAUR2AFD8DN011092   Mileage: 61249km-38058miles
    BA-Motor Mounts -- Status: OK 0000
    Address 01: Engine (------CEUA)       Labels: None
       Part No SW: 4H0 906 014 B    HW: 4H0 906 014
       Component: 4.0l V8TFSI / H61 0003
       Revision: NCH61---
       Coding: 022A00326546010E1000
       Shop #: WSC 01114 444 123976
       ASAM Dataset: EV_ECM40TFS0114H0906014B 001003
       ROD: EV_ECM40TFS0114H0906014B.rod
       VCID: 2241867035775856BC-8076
    4596 - Knock Sensor 4 (G199)
              P1323 00 [101] - Signal too Small
                        Mileage: 61249 km
                        Date: 2017.08.26
                        Time: 17:54:34
                        Engine speed: 1156.00 /min
                        Normed load value: 6.7 %
                        Vehicle speed: 22 km/h
                        Coolant temperature: 98 °C
                        Intake air temperature: 45 °C
                        Voltage terminal 30: 13.311 V
                        AFS dm: 31.7 kg/h
                        Median injection timing: 0.757 ms
                        Engine operating condition-Channel 87: Deceleration
                        Relative load value: 18.09 %
                        Tumg: 22.5 °C
                        Psr w: 291.80 hPa
                        Engine torque: 0.0 Nm
    4598 - Knock Sensor 4 (G199)
                        Mileage: 61248 km
                        Date: 2017.08.26
                        Time: 17:54:12
                        Engine speed: 2287.00 /min
                        Normed load value: 10.2 %
                        Vehicle speed: 44 km/h
                        Coolant temperature: 99 °C
                        Voltage terminal 30: 12.557 V
                        AFS dm: 44.8 kg/h
                        Median injection timing: 0.952 ms
                        Engine operating condition-Channel 87: Part. load
                        Relative load value: 25.34 %
                        Tumg: 22.5 °C
                        Psr w: 388.67 hPa
                        Engine torque: 58.2 Nm
    Readiness: 0010 1101
       Part No SW: 4H1 927 158 BK    HW: 0BK 927 156 AG
       Component: 0BK 40TFSIUSA H16 1005
       Revision: --H16---
       Coding: 000002
       ASAM Dataset: EV_TCMALX51011 002020
       ROD: EV_TCMALX51011.rod
       VCID: 7AF19E10FD67F096C4-802E
    Address 03: ABS Brakes (J104)       Labels:. 4H0-907-379.clb
       Part No SW: 4H0 907 379 E    HW: 4H0 907 379 E
       Component: ESP PREMIUM   H10 0352
       Coding: C4E5F30023A7CF00E200
       ASAM Dataset: EV_ESPPremi 005013
       ROD: EV_ESPPremi_005_AU64.rod
       VCID: 346D70289F83C6E65E-8060
       Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 CD
       Component: BCM2 2.0      H32 0510
       Coding: 0DA72046000000000000
       Shop #: WSC 54625 000 1048576
       VCID: 6ED9A240B92FAC3668-803A
       Serial number: 2312000054221008
    00955 - Key 1
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 215
                        Mileage: 61249 km
                        Date: 2017.08.27
                        Time: 00:18:46
       Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
       Revision: AA000000    Serial number: 00000033701068
       Coding: C018320085047201010001010101112131313333283333
       Shop #: WSC 02313 785 00200
       VCID: 356B4D2C9CF9DFEE69-8060
    Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
       Part No SW: 4H0 820 043 H    HW: 4H0 820 043 H
       Component: Klima 4 Zonen H20 0121
       Coding: 688123BE7C
       VCID: 254B9D6C2459AF6ED9-8070
       Revision: 11012002    Serial number: 00000001403579
       Coding: 09072091077C9FE38B000804A0003800009CD3088E0001218001085C7B00
       VCID: 6FE7BF44BE25A53E63-803A
       Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS641 120615  H35 0080
       Serial number:         120725101601
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 20065942
       Coding: 025523
       Component: E1 - LDS  H07 0044
       Serial number: 13 08 2012  00000651
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R2NK402
       Serial number: 00000021081200010488
       Coding: 100000
       Serial number: 00000022081200010334
       Coding: 100000
       Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA103988000001759742
       Coding: 020300
       Serial number: 8B584346000000000001
       Part No SW: 4H0 919 475 AG    HW: 4H0 919 475 AG
       Component: PARKHILFE ACC H01 0072
       Revision: 11001001    Serial number: 61061224001321
       Coding: A80B02
       ASAM Dataset: EV_EPHVA18AU57X0000 003008
       VCID: 77F78724CE75EDFEBB-8022
       Part No SW: 4H0 907 561 B    HW: 4H0 907 561
       Component: ACC3          H17 0400
       Coding: 7E01020101
       ASAM Dataset: EV_AdaptCruisContrAU64X 002021
       ROD: EV_AdaptCruisContrAU64X_002.rod
       VCID: 2A516E504D478016F4-807E
    93440 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                        Reset counter: 215
                        Mileage: 61242 km
                        Date: 2017.08.26
                        Time: 16:32:29
                        Control Module temperature: 41 °C
                        Voltage terminal 15: 13.075 V
                        Velocity_vehicle_reference: -0.01 m/s
    Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
       Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
       Component: Airbag10.43   H44 0041
       Revision: --------    Serial number: 003JS001C53S
       Coding: 303143303230303030314A55304C34483053
       VCID: 377747248EF52DFE7B-8062
       Subsystem 1 - Part No SW: 4H0 959 339 A    HW: 4H0 959 339 A
       Component: BF-Gewichtss.  H03 0040
       Serial number: 5850000R1272705G2Q
       Serial number: 3575HRB405R1HAR491U
       Serial number: 3585HRB405P1HAR420UT
       Serial number: 3515JRB40551D2ASD1F$
       Serial number: 3525JRB404V1D2ASJOHA
       Serial number: 3554VRB405P1EVLGEOK3
       Serial number: 3564VRB405P1EVLGCGK.
       Revision: --------    Serial number: 90815LHB00022
       Coding: 0004BC
       VCID: 387544188BEB228672-806C
       Subsystem 1 - Part No SW: 4H0 951 528 L    HW: 4H0 951 528 L
       Component: E221 - MFL  H09 0009
       Serial number: 11 06 2012  B1051553
    Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb
       Part No SW: 4H0 920 980 K    HW: 4H0 920 980 K
       Component: TBenUSAACC--- H71 0515
       Revision: 35081077    Serial number: 658280712592008
       Coding: 0B4608015740D705020000
       ASAM Dataset: EV_RBD4K 004046
       ROD: EV_RBD4K.rod
       VCID: 336F73349A8DC1DE47-8066
       Analog_clock:
       Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
       Component: Analoguhr D4  H05 0224
       Serial number: 1120626002028
       Part No SW: 4H0 907 468 AC    HW: 4H0 907 468 AA
       Component: J533--Gateway H11 0035
       Revision: --------    Serial number: 00000000652495
       Coding: 00ED074800
       ASAM Dataset: EV_GatewPkoUDS 001016
       ROD: EV_GatewPkoUDS_001.rod
       VCID: 72E1B630A51788D68C-8026
       Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
       Component: J367-BDM  H08 0181
       Serial number: 00000000004970769271
       Voltage stabilizer:
       Part No SW: 8K0 857 511 G    HW: 8K0 857 511 G
       Component: FLA           H04 0020
       Revision: AB001001
       Coding: 04018B6B74745D545420363E00
    Address 28: HVAC, Rear (E265)       Labels:* None
       Part No SW: 4H0 919 158 D    HW: 4H0 919 158 D
       Component: Klima Fond    H16 0121
       Coding: 2000000000
       ROD: EV_AirCondiHeck.rod
       VCID: 3163793C6091F3CE35-8064
       Part No SW: 4H0 907 553 E    HW: 4H0 907 553
       Component: LUFE-DAEMPFER H17 0099
       Coding: 008002
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2E59624071AFEC3628-807A
              C10C8 00 [008] -  -
                        Reset counter: 254
                        Mileage: 61242 km
                        Date: 2017.08.26
                        Time: 16:32:29
    367877 - Ride Height Not Learned
              C1044 00 [009] -  -
                        Reset counter: 214
                        Mileage: 61242 km
                        Date: 2017.08.26
                        Time: 16:32:29
    266752 - Control module not coded
              U1013 00 [009] - -
                        Reset counter: 214
                        Mileage: 61242 km
                        Date: 2017.08.26
                        Time: 16:32:34
    38144 - No End-of-Line Programming
              B2013 00 [009] -  -
                        Reset counter: 214
                        Mileage: 61242 km
                        Date: 2017.08.26
                        Time: 16:32:34
       Revision: AA000000    Serial number: 00000033704218
       Coding: C0183B0085057201010001010101112131313333203333
       Part No SW: 4H0 907 637 K    HW: 4H0 907 637 F
       Component: SARA 6D       H02 0053
       Revision: --------    Serial number: EJ1BPA770069ZF
       ASAM Dataset: EV_SARA2 005011
       ROD: EV_SARA2.rod
       Part No SW: 4H0 907 566 A    HW: 4G0 907 566
       Component: J769  SWA MasterH02 0040
       Revision: 00H02000    Serial number: 6PZ 010 287-07
       VCID: 2E596240B9AFEC3628-807A
       Subsystem 1 - Part No: 4H0 907 568 A
       Component: J770  SWA Slave H02 0040
       Subsystem 2 - Serial number: 6PZ 010 287-27
       Subsystem 3 - Serial number: 5F03.08.1200H02000AMS14289˙
       Subsystem 4 - Serial number: S14289˙
       Part No SW: 4H0 959 793 M    HW: 4H0 959 793 E
       Component: TSG FA        H02 0166
       Revision: --------    Serial number: 0000119787926
       Coding: 011F1F205E0062C202000017
       Shop #: WSC 02312 785 00200
       VCID: 438F23F4C22D715ED7-8016
    00532 - Supply Voltage B+
                        Reset counter: 214
                        Mileage: 61242 km
                        Date: 2017.08.26
                        Time: 16:32:28
       Revision: 00002001    Serial number: 0181660556
       Coding: 0106023A00FA7585B0B0C7C4020301070000000000000000000000000000
       Shop #: WSC 01114 444 12479
       Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
       Component: GTO BF  H01 0080
       Serial number: 00000000000000100432
       Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
       Component: J245 PS50.030  H07 0006
       Serial number:     WOO1753992A
       Coding: 020200
       Subsystem 4 - Part No SW: 4H0 947 135 BK    HW: 4H0 947 135 BK
       Component: Dachelektroni  H11 0080
       Serial number: A2012000000000612633
       Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
       Component: V252 PS010  H05 0005
       Serial number:     WOO1000RVD3
       Subsystem 6 - Part No SW: 3AA 962 243     HW: 3AA 962 243
       Component: GEB.F.Heckoef  H12 0719
       Serial number: 84294272
       Part No SW: 4G1 035 223 A    HW: 4G1 035 223 A
       Component: BOSE-G3C7-ANC H02 0540
       Revision: CJ002700    Serial number: 00000000003814
       Coding: 030000
       Shop #: WSC 02311 785 00200
       VCID: 1C3DB8881F136EA676-8048
       Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
       Component: TSG BF        H06 0261
       Revision: --------    Serial number: 0000130204398
       Coding: 011F1F005E0062C202003007
       VCID: 3C7D5808BFD30EA696-8068
       Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
       Component: EPB-4         H03 0013
       Revision: --------    Serial number: 00000000450519
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2B5F6B5442BD991E0F-807E
       Part No SW: 4H0 035 082 D    HW: 4H0 035 082
       Component: Radio U SIRIU H60 0112
       Revision: AB001007    Serial number: 155HZ0C7523551
       Coding: 020007010000000001
       VCID: 224186703D775856BC-8076
       Part No SW: 4H0 035 746 C    HW: 4H0 035 746 C
       Component: H-BNT-NA      H49 0549
       Revision: --------    Serial number: 183H10C7502679
       Coding: 020200000001F9EF7D128B1E00000003140001000000000000
       VCID: 285594585B4BB206E2-807C
       Subsystem 1 - Part No: 8R0 060 884 AM
       Component: NAR 2012  0605
       Subsystem 2 - Part No SW: 4H0 919 604 F    HW: 4H0 919 604 F
       Component: DU8 D4 SV NB  H47 0021
       Serial number: AUZ8ZDC9300UTNM
       Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
       Component: E380 BDT D4  H09 0065
       Serial number: 00000000089687
       Subsystem 4 - Part No: 8R0 060 961 D
       Component: CD-Database  4353
       Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
       Component: TSG HL        H06 0262
       Revision: --------    Serial number: 0000130225533
       Coding: 010F1F00400062C202003007
       Part No SW: 4H0 907 428 A    HW: 7P6 907 441 D
       Component: TopView       H05 0111
       Revision: 11001001    Serial number: 82330JF0053466
       Coding: 020A000001010000000102000000
       ASAM Dataset: EV_CamerSysteTopViewAUDI 005022
       ROD: EV_CamerSysteTopViewAUDI_005.rod
    Address 6D: Trunk Elect. (----)       Labels:* None
       Part No SW: 4H0 959 107 R    HW: 4H0 959 107 M
       Component: HDSG-Modul    H11 0039
       Revision: 10011001    Serial number: 207200035
       Coding: 0210044100
       ROD: EV_DeckLidContrUnit.rod
       VCID: 3D7B550CACC907AEA1-8068
    Address 6F: Centr. Conv. II (J773)       Labels:* None
       Revision: --------    Serial number: 000000082780
       Coding: 200000
       ASAM Dataset: EV_Ambie 001008
       ROD: EV_Ambie.rod
       VCID: 63CFC3746AED115EF7-8036
    0050 - Front Left Door Sill Lighting
              B1133 01 [009] - Electrical Failure
                        Reset counter: 214
                        Mileage: 61242 km
                        Date: 2017.08.26
                        Time: 16:44:53
                        Terminal 15 status: OFF
                        Voltage terminal 30: 13.1 V
                        Control Module temperature: 42 °C
                        Processor load: 35.0 %
                        Status terminal 58s: OFF
       Component: TSG HR        H06 0262
       Revision: --------    Serial number: 0000130228928
       Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
       Component: GSM-LL        H08 0083
       Revision: 0L0D5014    Serial number: SN120702  0626
       ROD: EV_GSM2x3Mono.rod
    Address 85: On Board Cam. (J852)       Labels:* None
       Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
       Component: DPC-SG        H25 0038
       Coding: E9060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 26499A60595FA476D0-8072
    0793 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                        Reset counter: 214
                        Mileage: 61242 km
                        Date: 2017.08.26
                        Time: 16:32:31
                        Outside air temperature: -37.0 °C
                        Voltage terminal 15: 13.0 V
                        Control Module temperature: 52.0 °C
       Serial number: 00007183028101
       Coding: 766FF2
       ROD: EV_IVBDriveSideFrnt.rod
       VCID: 2F677F4476A5E53E23-807A
       Serial number: 00007183096802
       Coding: 366FF2
       Part No SW: 4H0 907 541 B    HW: 4H0 907 541
       Coding: 7E01020101
       ASAM Dataset: EV_AdaptCruisContr2AU64X 002018
       ROD: EV_AdaptCruisContr2AU64X_002.rod
       VCID: 28559458534BB206E2-807C
       Part No SW: 4G0 907 107 D    HW: 4H0 907 107
       Component: BV-SG         H30 0038
       Serial number: 005000052208127
       Coding: 02A19A000111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       VCID: 275797645E55BD7EEB-8072
    0091 - Function Limitation due to Missing Video Data
              C1108 00 [009] -  -
                        Reset counter: 215
                        Mileage: 61242 km
                        Date: 2017.08.26
                        Time: 16:32:29
                        Outside air temperature: 26.0 °C
                        Voltage terminal 15: 13.2 V
                        Control Module temperature: 34.0 °C
    Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
       Coding: 0066F609031F0376070308014240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
    Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 326176306597C8D64C-8066
    Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
       Part No SW: 4H0 907 145     HW: 4H0 907 145
       Component: AEM - LEAR    H05 0006
       Revision: 00001001    Serial number: 97804000683004
       ASAM Dataset: EV_AEMLearAU64X 002014
       ROD: EV_AEMLearAU64X.rod
       VCID: 66C9DA6099DF647610-8032
    End-------------------------(Elapsed Time: 07:09)--------------------------
    Aug 2016
    The Hague, NL
    Nah your [ code] at the end should be [/code]
    Aug 2017
    Thanks for the tip. I don't git what this does but I'll do as you have shown and it will post as intended?
    Tim
    Aug 2016
    The Hague, NL
    It's how BB code works. Opening a tag goes like [name_of_tag] and to close it at the end, one uses [/name_of_tag] (note the / ). The text to be manipulated is between the two tags
    I.e.
    Uwe is crazy
    Or the bold tag that's a b between square brackets
    Jack is awesome
  5. Likes Uwe, Eric, Jack@European_Parts liked this post
    Aug 2017
    If I had known I needed to be an IT Professional to work on cars I bet I would not be working on cars but rather I'd be an IT Professional.
    Now, does anyone know how to fix the 34 Level Control codes that I have?
    Tim
    United States
    The module appears to be coded properly but the No End-of-Line Programming DTC isn't very optimistic.
    Quote Originally Posted by Audiwerk View Post
              U1013 00 [009] - -
                        Reset counter: 214
                        Mileage: 61242 km
                        Date: 2017.08.26
                        Time: 16:32:34
              B2013 00 [009] -  -
                        Reset counter: 214
                        Mileage: 61242 km
                        Date: 2017.08.26
                        Time: 16:32:34
    What repairs (or replaced/damaged parts) caused the 34-Level control system problems. That history may help.
  8. Likes DrPeter, Uwe, Jack@European_Parts liked this post
    Aug 2017
    I replaced the 4.0t engine @ 38K miles. He never changed the oil or added just drove it spun the bearings trashed the motor.
    When it arrived it was sitting practically on the ground. When motor work was complete I started the car and expected the level control to wake up. The drivers door module is also pissed and I thought the 2 may be related so I went to basic and told it to raise itself which it did. I have been stupid in the past and I may have been this time too. I do not recall but when figuring out how to get it to raise I may have (probably) hit the top line "get rid of all adaptations". Everything about the system is very cooperative when telling it to get to work using the commands in basic settings. Seems that basic settings would not be a good place to do what I was doing. It is Basic Settings. I am sure I've caused my own troubles.
  10. #8
    Aug 2017
    ........ and Thank You for fixing my original post.
    Tim
  11. #9
    Jack is awesome
    No no no I'm just the resident ASSHOLE.........
    Yeah OP many make this their own problem.........
    Hey Uwe.......
    I have read this all to often and advise that a warning be flagged in VCDS & to stop someone to pause and think before making this operation a success of lost values.
    NostraJackAss Has an Idea! /\
  12. Likes Dana, DrPeter liked this post
  13. #10
    United States
    I hear you Jack. That exact BS is labeled: [*IDE01475] Resetting of all adaptations The exact results vary depending on the controller .. but I afraid to "test" that on my (out of warranty) Tiggy 55-Xenon module. As of the most recent release we can add notes to the label files that appear in UDS protocol modules when the user is in the Adp or BS functions. Might not be a bad idea to put a note/warning in some of those.
    Tim,
    I'm not sure if the parameters are truly lost, and if so that's going to need ODIS online or more powerful offline tools, but I think we should look at an Adaptation Function control module map. Please do the following KOEO:
    [Applications]
    [Controller Channels Map]
    Address: 34
    Function: Adaptation
    Output: CSV File
    [Start]
    That will result in a map located in the logs folder. Open it with Notepad (plain text) so you can copy an paste it in reply. You can use the same [CODE] ... [/CODE] tags to wrap it. It should look like this example from my 02 trans: http://forums.ross-tech.com/showthre...ll=1#post82820
  14. Likes DrPeter, Jack@European_Parts, Uwe liked this post
