Results 1 to 1 of 1
Thread: Touareg (T1) Wiper Issue 00003 - Control Module - 014 Defective
    Aug 2017
    Hello. Having a bit of an issue with my touareg (2005) wipers. They work almost all the time however from time to time they almost look stuck (when I try to wipe the window they attempt to move up 3 or 4 times however only half an inch of movement each time if that. Only way to resolve the issue is to turn off the ignition and turn it back on again... problem solved. Not very good when living in Scotland and the rain can just come on all of a sudden with no warning! Attached is a VCDS scan which shows some other faults but youl see address 68 showing the wiper error. I know touareg move their wipers when the bonnet is opened however I've checked the measuring block for the bonnet release when this is happening and it shows shut (inactive).
    Any help would be greatly appreciated as I don't really want to go throwing money at a new wiper motor if its not that although I know the J400 control module is part of the motor and may require to be replaced. I've attached a link to a video of the problem when trying to wipe the window (this happens with any active wiper stalk position). Apologies if links aren't allowed and I will remove (my first post)
    https://www.youtube.com/watch?v=Dk8AiEuOlO4
    Saturday,26,August,2017,15:24:48:21670
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
    VCDS Version: 17.1.3.0  HEX-V2 CB: 0.4336.4
    Data version: 20170220 DS267.3
    Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
    Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
              37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
       Mileage: 174560km-108466miles
    Address 01: Engine        Labels: 059-907-401-ASB.clb
       Part No SW: 7L0 907 401     HW: 8E0 907 401 AB
       Component: 3.0L V6TDI  G001AG  0110
       Revision: --H02---    Serial number: VWZ3Z0E1335720
       Coding: 0011779
       Shop #: WSC 00799 210 87178
       VCID: 688AB240BE669127859-5184
       Part No: 09D 927 750 D
       Component: AL 750 6A           0655
       Coding: 0004200
       Shop #: WSC 31414 000 00000
       VCID: 2F38195C5B08061F843-5160
    Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
       Part No: 7L0 907 379 G
       Component: ESP ALLRAD MK25     0203
       Coding: 0014338
       VCID: 3D2433148164E48F06F-5184
       Part No SW: 3D0 909 135 N    HW: 5WK 470 21
       Component:    Kessy            6610
       Revision: 66105312    Serial number: VWZ3Z0E1335720
       Coding: 0000232
       VCID: 303A1A20463619E79D9-5184
    Address 08: Auto HVAC        Labels: 7L6-907-040.clb
       Part No: 7L6 907 040 L
       Component: CLIMAtronic R/L     4017
       Coding: 0000030
       VCID: 392C2704954CD8AF2A7-5184
                014 - Defective
    Address 09: Cent. Elect.        Labels: 7Lx-937-049-V1.clb
       Part No: 7L6 937 049 M
       Component:                     3001
       Coding: 0098340
       VCID: 46D65CF8D4B2A757575-5184
       Part No: 3D0 909 601 F
       Component: 0B Airbag 8.4E+ H11 1151
       Coding: 0012354
       VCID: 2616FC7874F24757775-5184
       Part No: 7L6 953 549 D
       Component: Lenksäulenmodul     3301
       Coding: 0000031
       VCID: 40DA4AE0F69689676D9-5184
    Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
       Part No: 7L6 920 970 Q
       Component: KOMBIINSTRUMENT RB8 2035
       Coding: 0007411
       VCID: 45D45BF4E9B4AC4F5EF-5184
    Address 18: Aux. Heat        Labels: 7L6-819-008.lbl
       Part No: 7L6 815 071 C
       Component: Standheizung E1MAC
       Coding: 0000000
       VCID: 323E1028483A2BF7EBD-5184
       Part No: 6N0 909 901
       Coding: 0000006
       VCID: 70BADA2086B659E7DD9-5184
       Part No: 0AD 927 755 BE
       Component: TRANSFERCASE        0122
       VCID: 7F58091CCBE8369F543-5160
       Part No: 7L0 959 933 E
       Component: 2L HSG              0201
       Coding: 0000069
       VCID: 3E2634188C62FF971F5-4B1E
       Subsystem 1 - Part No: 7L0 959 701 K
       Component: Tuersteuergeraet FS 0201
       Subsystem 2 - Part No: 7L0 959 702 K
       Component: Tuersteuergeraet BF 0201
       Subsystem 3 - Part No: 7L0 959 703 C
       Subsystem 4 - Part No: 7L0 959 704 C
       Subsystem 5 - Part No: 7L0 907 719
       Component:    Neigungssensor   0020
       Subsystem 6 - Part No: 7L6 951 171
       Component: B  Innenraumsensor  0020
    Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
       Part No: 7L6 035 195 A
       Component: Radio DE2           0012
       Coding: 0001405
       VCID: 313C1F244D3C10EF927-5184
    Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
       Part No: 7L0 955 119 L
       Component: Front Wiper         4027
       Coding: 0000850
       Shop #: WSC 31414 000 376832
       Component: RLS nicht vorhanden
       Coding: 00000000
                014 - Defective
       Part No: 7L0 919 283 F
       Component: 0D Einparkhilfe     1107
    End----------(Elapsed Time: 12:35, VBatt start/end: 12.0V/11.9V)-----------
