7P TOUAREG PARKING BRAKE WILL NOT BASIC SET,HELPPPPPPP
Danners74
C?ID=273244
Hello all. Ive got this right pain of a job. 2012 Touareg with EPB issue. Shoes, discs and pads were changed.......NOT by myself. Initally had a a fair few faults in the memory with park brake motors and temp fault with the motors (due to maladjusted shoes)
I looked at the measure values for AIR GAP and found they deviated massively outside the setpoints 1.9-2.4 mm they were 1.485mm LH and 1.459mm RH.
The air gaps originally from factory stored are 2.296mm and 2.161mm.
I have since adjusted the air gaps according to the factory manual and RossTech guide. The Faults come up on dash saying no EPB,Hill assist and auto hold does not work either. Ive tried road testing and ive had charger connected.
WHEN carrying out the air gap calibratin it always says not running? Is this right and am i doint the correct procedure?????????? PLEASE can somebody help?
My first scan prior to adjustments.
Tuesday,29,August,2017,10:43:55:44004
VCDS Version: 17.8.0.1 (x64)
Dealer/Shop Name: Victoria Volkswagen.
Workshop Code: 210 01843 000002
VIN: WVGZZZ7PZCD066081   License Plate:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 56 5F 62 72
VIN: WVGZZZ7PZCD066081   Mileage: 54149km-33646miles
Address 01: Engine (J623-CRCA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401 F    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0002
   Revision: 53H37---
   Coding: 292A4012232601020000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0117P0907401F 001003
   ROD: EV_ECM30TDI0117P0907311C.rod
   VCID: 326CA783658485D64C-8066
4483 - Function Restriction due to Faults in Other Modules
          U1113 00 [032] - -
14690 - Loading Mode active
          P169A 00 [032] - -
5243 - Fuel Pressure Sensor (G247)
          P0191 00 [096] - Implausible Signal
   Part No SW: 0C8 927 750 AG    HW: 0C8 927 750 AG
   Component: AL1000 AISIN  001 2083
   Coding: 001568
   Shop #: WSC 54705 001 1048576
   ROD: EV_TCMAL991031_002.rod
   VCID: 71EE688FA002FECE75-8024
Address 03: ABS Brakes (J104)       Labels:| 7P0-907-379.clb
   Part No SW: 7P0 907 379 J    HW: 7P0 907 379 A
   Component: MK25A         H36 0433
   Revision: --------    Serial number: 413120010EC815
   Coding: 5B6B13C3092A2559DAF4C89B90D3A450F700
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: 4480F15BCF303B66EE-8010
   Part No SW: 4H0 907 064 BL    HW: 4H0 907 064 BL
   Coding: 01B60000000000000000
   VCID: 74E0619BD710CBE69E-8020
   Subsystem 1 - Part No SW: 7P6 959 754 AJ    HW: 7P6 959 754 AJ
   Component: FBSTOUAREGIDG  H05 0051
   Serial number: 0812000068656016
   Serial number: 2312000078412005
   Part No SW: 7P6 907 040 BK    HW: 7P6 907 040 BK
   Component: Klima 2 Zonen H20 1305
   Coding: B6A6000890
   VCID: 7EF443B3E15C91B6F8-802A
15360256 - Component Protection
          U1101 00 [008] - Active
                    Fault Frequency: 7
                    Reset counter: 169
                    Mileage: 49980 km
                    Date: 2017.03.11
                    Time: 14:50:52
                    Voltage terminal 30-Data: 11.7 V
                    Component protection-Data: 31
0243 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 158
                    Mileage: 44039 km
                    Date: 2016.10.04
                    Time: 19:43:49
                    Voltage terminal 30-Data: 14.6 V
                    Outside air temperature-Data: 14.50 °C
                    Engine speed-Data: 1383 /min
   Part No SW: 4H0 907 063 BL    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0111
   Revision: 15012002    Serial number: 00000001322578
   Coding: 6900001181345D010005000300005F5F431D470807000241000000000000
   VCID: 73E26287D21ECCDE87-8026
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    120412  31  0020
   Serial number: 90243401120424194658
   Coding: 004DBD
   Component: RLFS  H09 0011
   Serial number: 10378476
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 B    HW: 7P6 941 431 B
   Component: E1 - LDS  H04 0031
   Serial number: 00000000001105120175
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 B    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0021
   Revision: --------    Serial number: 28261212802769
   Coding: 108501
   ASAM Dataset: EV_VW526ParkiAssis2 001011
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 428CF743D5243556DC-8016
   Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
   Component: VW10Airbag00K H05 0025
   Revision: --------    Serial number: 003L000361WN
   Coding: 00000000000000000000000000000000304B
   VCID: 418EF84FD0222E4EC5-8014
   Serial number: 3575LRB405L1C4LI59CJ
   Serial number: 3585LRB405L1C4LI81BE
   Serial number: 3515RRB405R181TUE0A-
   Serial number: 3525RRB405T181TUL092
   Serial number: 3555NRB400U4UE2078SY
   Serial number: 3565NRB400U4UE2091KM
   Part No SW: 4H0 953 568 H    HW: 7P6 953 507 M
   Revision: --------    Serial number: 90815LEC0000P
   Coding: 000C35
   VCID: 387895AB8BF86F8672-806C
   Serial number: 0179488
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb
   Part No SW: 7P6 920 982 E    HW: 7P6 920 982 E
   Component: Kombi         H14 0253
   Revision: 12240067    Serial number: 658080512592013
   Coding: 3327310022002600010004
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526_VW52.rod
   VCID: 4088FD4BDB282746CA-8014
   Part No SW: 7P6 907 530 C    HW: 7P6 907 530 A
   Component: GW-CAN-L-MOST H08 5202
   Revision: --------    Serial number: 00000000519920
   Coding: 000D077500
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: 387895AB83F86F8672-806C
   Serial number: 00000000005650319237
   Voltage stabilizer:
   Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
   Component: TSG FA        H07 0166
   Revision: --------    Serial number: 0000126926492
   Coding: 011D0620D001451005080002
   VCID: 4480F15BC7303B66EE-8010
   Revision: 00002001    Serial number: 0176341670
   Coding: 011B162228B9008083200624000000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 171
   Component: DWA-Sensor  002 0204
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0166
   Revision: --------    Serial number: 0000127201511
   Coding: 011D0620D001451005080000
   VCID: 3B728AA7BACE449E9F-806E
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1242400267
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 36649B9389EC99F660-8062
   Slave 3:
0001 - Control Module Overtemperature Condition
          P0634 00 [008] - -
                    Reset counter: 137
                    Mileage: 54017 km
                    Date: 2017.08.21
                    Time: 17:51:26
                    Voltage: 12.8 V
0040 - Motor for Electronic Parking Brake
          C10E3 29 [008] - Signal Implausible
                    Reset counter: 0
                    Mileage: 53994 km
                    Date: 2017.08.20
                    Time: 19:32:23
                    Voltage: 12.2 V
0004 - Parking Brake Motor; Left
          C10BC 07 [008] - Mechanical Failure
                    Reset counter: 137
                    Mileage: 53999 km
                    Date: 2017.08.20
                    Time: 19:59:59
                    Voltage: 14.4 V
0052 - Parking Brake Motor; Right
          C10BD 07 [008] - Mechanical Failure
                    Reset counter: 137
                    Mileage: 53999 km
                    Date: 2017.08.20
                    Time: 19:59:59
                    Voltage: 13.0 V
0051 - No Calibration
          B2010 F0 [008] - Deviation From Expected Range
                    Reset counter: 109
                    Mileage: 52334 km
                    Date: 2017.05.24
                    Time: 15:56:03
                    Voltage: 12.2 V
   Part No SW: 4G0 035 061 E    HW: 4G0 035 061
   Component: Radio U DAB   H60 0099
   Revision: AB001007    Serial number: 109E$0C7564086
   Coding: 010105020100000003
   VCID: 1F4A5E370E1638BE93-804A
   Part No SW: 7P6 035 670 C    HW: 7P6 035 670
   Component: H-BNT-EU      H46 0458
   Revision: --------    Serial number: 478D90C7578708
   Coding: 010101050040C1ED01000B0E00000003F0040101
   VCID: 35669C9F9CEA92EE69-8060
   Subsystem 1 - Part No: 8R0 060 884 AH
   Component: EUR 2012  1308
   Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: DU8 SV Touch  H26 0045
   Serial number: VWZ8Z9M7801B3Q
   Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: CD-Database  1886
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0167
   Revision: --------    Serial number: 0000127361479
   Coding: 011C04200001251005080000
   VCID: 3A7C8FA3B5F47D9684-806E
   Component: TSG HR        H09 0167
   Revision: --------    Serial number: 0000127363180
End-------------------------(Elapsed Time: 03:59)--------------------------
Tuesday,29,August,2017,16:23:30:44004
                Address 53: Parking Brake  (7P0 907 801 F)
16:23:28
  IDE04435-MAS01849   Air gap-Left 2.296 mm
  IDE04435-MAS01850   Air gap-Right 2.161 mm
  IDE05272-MAS01849   Air gap before calibration-Left 2.161 mm
  IDE05272-MAS01850   Air gap before calibration-Right 2.222 mm
Tuesday,29,August,2017,17:27:10:44004
                Address 53: Parking Brake       Labels: 7P0-907-801.clb
Control Module Part Number: 7P0 907 801 F    HW: 7P0 907 801 F
  Component and/or Version: EPB           H51 1201
           Software Coding: 01040100
            Work Shop Code: WSC 01843 210 00002
              ASAM Dataset: EV_ParkbA7 000006 (VW52)
                       ROD: EV_ParkbA7.rod
0024 - No Basic Setting
          B2010 00 [009] -  -
                    Reset counter: 148
                    Mileage: 54152 km
                    Date: 2017.08.29
                    Time: 17:26:41
                    Voltage: 12.4 V
Tuesday,29,August,2017,17:34:49:44004
17:34:48
  IDE05272-MAS01849   Air gap before calibration-Left 2.323 mm
  IDE05272-MAS01850   Air gap before calibration-Right 2.305 mm
Tuesday,29,August,2017,17:52:58:44004
   Revision: 53H37---
   Coding: 001568
   Coding: B6A6000890
   Coding: 004DBD
   Coding: 025223
   Coding: 108501
   Coding: 000C35
   Coding: 000D077500
   Voltage stabilizer:
   Coding: 01040100
   Shop #: WSC 01843 210 00002
   ROD: EV_ParkbA7.rod
          B2010 00 [009] -  -
                    Reset counter: 148
                    Mileage: 54149 km
                    Date: 2017.08.29
                    Time: 16:45:25
                    Voltage: 13.6 V
0025 - No Calibration
          B2010 F0 [009] - Deviation From Expected Range
                    Reset counter: 148
                    Mileage: 54149 km
                    Date: 2017.08.29
                    Time: 16:47:22
                    Voltage: 14.2 V
End-------------------------(Elapsed Time: 03:56)--------------------------
Tuesday,29,August,2017,19:51:40:44004
                       ROD: EV_ParkbA7.rod
          B2010 00 [009] -  -
                    Reset counter: 148
                    Mileage: 54155 km
                    Date: 2017.08.29
                    Time: 19:50:03
                    Voltage: 13.8 V
                    Reset counter: 148
                    Mileage: 54155 km
                    Date: 2017.08.29
                    Time: 19:50:04
                    Voltage: 13.8 V
Tuesday,29,August,2017,19:56:57:44004
                       ROD: EV_ParkbA7.rod
          B2010 00 [009] -  -
                    Mileage: 54155 km
                    Date: 2017.08.29
                    Time: 19:54:41
                    Voltage: 13.8 V
                    Reset counter: 148
                    Mileage: 54155 km
                    Date: 2017.08.29
                    Time: 19:55:46
                    Voltage: 13.8 V
Ive tried every which way to do basic setting AIR GAP CALIBRATION and im a tad frustrated as ive not long walked in the door........PLEASE HELP.
These are the errors im getting and my second scan
Tuesday,29,August,2017,19:58:11:44004
VIN: WVGZZZ7PZCD066081   Mileage: 54155km-33650miles
   Revision: 53H37---
   Coding: 001568
   Coding: B6A6000890
   Coding: 004DBD
   Coding: 025223
   Coding: 108501
   Coding: 000C35
   Coding: 000D077500
   Voltage stabilizer:
   Coding: 01040100
   ROD: EV_ParkbA7.rod
                    Reset counter: 148
                    Mileage: 54155 km
                    Date: 2017.08.29
                    Time: 17:46:21
                    Voltage: 14.2 V
          B2010 00 [009] -  -
                    Reset counter: 148
                    Mileage: 54155 km
                    Date: 2017.08.29
                    Time: 17:46:21
                    Voltage: 14.2 V
End-------------------------(Elapsed Time: 03:57)--------------------------
KIND regards DANNERS :banghead:
PS ive included there some of the current measure values of pre air gap calibration/basic settings in the second scan............. it just does not want to know
Danners74
C?ID=273244
UWE? do you have any ideas?
Dana
Western PA, USA
Hi Danners,
Firstly thanks for all of the data and history! It looks like you already found this page .. but I think the Output Tests > grind-in test drive is worth a shot since all of the parts were replaced:
http://wiki.ross-tech.com/wiki/index.php/VW_Touareg_(7P)_Parking_Brake
You'll find a video of Uwe and Eric messing with his 2015 T'reg (that was not broken) within that linked page. After the grind-in I would hope all DTCs clear but if not, please try the Basic Settings [*IDE04509*] Air gap calibration again to see if you get a Finished Correctly result.
Best,
Dana
Danners74
C?ID=273244
Morning yes loads of data sorry I saved a fair few........tiredness took over last night. Thanks though Dana I will give it a go later today. Much appreciated.
I was wondering though........surely if you were to just tweek the shoes for an adjustment, say on a service you should be able to basic set the AIRGAP?
I guess the person before me didn't know what they were doing and Im having to pick up where he left off?
Regards Danners...........:eek:
Danners74
C?ID=273244
Good afternoon. Just like to say many thanks to you DANA! I watched the video on how to carry out the grind in procedure. Carried it out as I looked at the MVB's for grind in distance-they hadn't been carried out. All basic settings are now complete and Im one happy tec!!!
May I just add something......some refinement perhaps on the video as to allow a rest period for the EPB motors to cool? I was doing approximately 6 KMH in D1. Other than that thanks again.:thumbs::thumbs:
Regards and have a nice day!:)
Dana
Western PA, USA
Thanks Danners! Glad to hear that worked out.
Big_lou44
Canada
C?ID=317870
Hi, I know this isn’t fresh but I’m having a similar issue. I need to adjust my air gaps as well and am having a hell of a time finding this screw/nut to turn to adjust. I’ve pulled the tire off and the plug that should reveal the adjustment but haven’t seen anything. Any help would be greatly appreciated as I have run through the videos and can do the break in to clear the codes. It is going to go in to VW if I can’t figure this air gap adjustment on my own. Just hoping you guys could help.
Big_lou44
Canada
C?ID=317870
Lol I guess I should mention the vehicle. 2011 VW Touareg Comfortline
Big_lou44
Canada
C?ID=317870
Wow I have the same issue as the last guy in that thread. Guess this is gonna have to go in. Too bad I was hoping I could do this with the VAGCOM. I adjusted the brakes to 2.1 and 2.1. Logged on and checked the gaps, starting 1.8 and 0.76, gaps before calibration changed to 2.1, 2.3 after opening and closing. But can’t get away from aborted for safety reasons. So weird. They are working but I can’t calibrate. If anyone has any pointers I’m all ears.
Big_lou44
Canada
C?ID=317870
Same faults as your YouTube video Uwe. Not calibrated and no basic settings. I’m stumped.
