Results 1 to 10 of 11
Thread: 7P TOUAREG PARKING BRAKE WILL NOT BASIC SET,HELPPPPPPP
    Verified VCDS User Danners74's Avatar
    Jun 2016
    Unhappy 7P TOUAREG PARKING BRAKE WILL NOT BASIC SET,HELPPPPPPP
    Hello all. Ive got this right pain of a job. 2012 Touareg with EPB issue. Shoes, discs and pads were changed.......NOT by myself. Initally had a a fair few faults in the memory with park brake motors and temp fault with the motors (due to maladjusted shoes)
    I looked at the measure values for AIR GAP and found they deviated massively outside the setpoints 1.9-2.4 mm they were 1.485mm LH and 1.459mm RH.
    The air gaps originally from factory stored are 2.296mm and 2.161mm.
    I have since adjusted the air gaps according to the factory manual and RossTech guide. The Faults come up on dash saying no EPB,Hill assist and auto hold does not work either. Ive tried road testing and ive had charger connected.
    WHEN carrying out the air gap calibratin it always says not running? Is this right and am i doint the correct procedure?????????? PLEASE can somebody help?
    My first scan prior to adjustments.
    Tuesday,29,August,2017,10:43:55:44004
    VCDS Version: 17.8.0.1 (x64)
    Dealer/Shop Name: Victoria Volkswagen.
    Workshop Code: 210 01843 000002
    VIN: WVGZZZ7PZCD066081   License Plate:
    Chassis Type: 7P-VW52 (7P6)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 56 5F 62 72
    VIN: WVGZZZ7PZCD066081   Mileage: 54149km-33646miles
    Address 01: Engine (J623-CRCA)       Labels:. 059-907-401-V2.clb
       Part No SW: 7P0 907 401 F    HW: 4G0 907 401
       Component: 3.0TDI EDC17  H37 0002
       Revision: 53H37---
       Coding: 292A4012232601020000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM30TDI0117P0907401F 001003
       ROD: EV_ECM30TDI0117P0907311C.rod
       VCID: 326CA783658485D64C-8066
    4483 - Function Restriction due to Faults in Other Modules
              U1113 00 [032] - -
    14690 - Loading Mode active
              P169A 00 [032] - -
    5243 - Fuel Pressure Sensor (G247)
              P0191 00 [096] - Implausible Signal
       Part No SW: 0C8 927 750 AG    HW: 0C8 927 750 AG
       Component: AL1000 AISIN  001 2083
       Coding: 001568
       Shop #: WSC 54705 001 1048576
       ASAM Dataset: EV_TCMAL991031 002112
       ROD: EV_TCMAL991031_002.rod
       VCID: 71EE688FA002FECE75-8024
    Address 03: ABS Brakes (J104)       Labels:| 7P0-907-379.clb
       Part No SW: 7P0 907 379 J    HW: 7P0 907 379 A
       Component: MK25A         H36 0433
       Revision: --------    Serial number: 413120010EC815
       Coding: 5B6B13C3092A2559DAF4C89B90D3A450F700
       ROD: EV_ESPMK25A00800.rod
       VCID: 4480F15BCF303B66EE-8010
       Part No SW: 4H0 907 064 BL    HW: 4H0 907 064 BL
       Component: BCM2 2.0      H31 0333
       Coding: 01B60000000000000000
       VCID: 74E0619BD710CBE69E-8020
       Subsystem 1 - Part No SW: 7P6 959 754 AJ    HW: 7P6 959 754 AJ
       Component: FBSTOUAREGIDG  H05 0051
       Serial number: 0812000068656016
       Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
       Serial number: 2312000078412005
       Part No SW: 7P6 907 040 BK    HW: 7P6 907 040 BK
       Component: Klima 2 Zonen H20 1305
       Coding: B6A6000890
       VCID: 7EF443B3E15C91B6F8-802A
              U1101 00 [008] - Active
                        Fault Frequency: 7
                        Reset counter: 169
                        Mileage: 49980 km
                        Date: 2017.03.11
                        Time: 14:50:52
                        Voltage terminal 30-Data: 11.7 V
                        Component protection-Data: 31
    0243 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Reset counter: 158
                        Mileage: 44039 km
                        Date: 2016.10.04
                        Time: 19:43:49
                        Voltage terminal 30-Data: 14.6 V
                        Outside air temperature-Data: 14.50 °C
                        Engine speed-Data: 1383 /min
       Part No SW: 4H0 907 063 BL    HW: 4H0 907 063 D
       Component: BCM1 2.0      H12 0111
       Revision: 15012002    Serial number: 00000001322578
       Coding: 6900001181345D010005000300005F5F431D470807000241000000000000
       VCID: 73E26287D21ECCDE87-8026
       Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
       Component: WWS    120412  31  0020
       Serial number: 90243401120424194658
       Coding: 004DBD
       Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
       Component: RLFS  H09 0011
       Serial number: 10378476
       Coding: 025223
       Subsystem 3 - Part No SW: 7P6 941 431 B    HW: 7P6 941 431 B
       Component: E1 - LDS  H04 0031
       Serial number: 00000000001105120175
    Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
       Part No SW: 7P6 919 475 B    HW: 7N0 919 475
       Component: PARKHILFE 8K  H05 0021
       Revision: --------    Serial number: 28261212802769
       Coding: 108501
       ASAM Dataset: EV_VW526ParkiAssis2 001011
       ROD: EV_VW526ParkiAssis2.rod
       VCID: 428CF743D5243556DC-8016
       Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
       Component: VW10Airbag00K H05 0025
       Revision: --------    Serial number: 003L000361WN
       Coding: 00000000000000000000000000000000304B
       ROD: EV_AirbaVW10BPAVW526_001.rod
       VCID: 418EF84FD0222E4EC5-8014
       Serial number: 3575LRB405L1C4LI59CJ
       Serial number: 3585LRB405L1C4LI81BE
       Serial number: 3515RRB405R181TUE0A-
       Serial number: 3525RRB405T181TUL092
       Serial number: 3555NRB400U4UE2078SY
       Serial number: 3565NRB400U4UE2091KM
       Part No SW: 4H0 953 568 H    HW: 7P6 953 507 M
       Revision: --------    Serial number: 90815LEC0000P
       Coding: 000C35
       VCID: 387895AB8BF86F8672-806C
       Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
       Component: E221__MFL-TAS  H03 0027
       Serial number: 0179488
    Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb
       Part No SW: 7P6 920 982 E    HW: 7P6 920 982 E
       Component: Kombi         H14 0253
       Revision: 12240067    Serial number: 658080512592013
       Coding: 3327310022002600010004
       ASAM Dataset: EV_KombiUDSRBVW526 001013
       ROD: EV_KombiUDSRBVW526_VW52.rod
       VCID: 4088FD4BDB282746CA-8014
       Part No SW: 7P6 907 530 C    HW: 7P6 907 530 A
       Component: GW-CAN-L-MOST H08 5202
       Revision: --------    Serial number: 00000000519920
       Coding: 000D077500
       ASAM Dataset: EV_GatewVW526UDS 001006
       ROD: EV_GatewUDS_VW52.rod
       VCID: 387895AB83F86F8672-806C
       Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
       Component: Batt_Sensor  H07 0140
       Serial number: 00000000005650319237
       Voltage stabilizer:
       Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
       Component: TSG FA        H07 0166
       Revision: --------    Serial number: 0000126926492
       Coding: 011D0620D001451005080002
       VCID: 4480F15BC7303B66EE-8010
       Revision: 00002001    Serial number: 0176341670
       Coding: 011B162228B9008083200624000000000000000000000000000000000000
       Subsystem 1 - Part No: 7P6 951 171
       Component: DWA-Sensor  002 0204
       Component: TSG BF        H07 0166
       Revision: --------    Serial number: 0000127201511
       Coding: 011D0620D001451005080000
       VCID: 3B728AA7BACE449E9F-806E
       Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
       Component: EPB           H51 1201
       Revision: 00000000    Serial number: C1242400267
       Coding: 01040100
       ROD: EV_ParkbA7.rod
       VCID: 36649B9389EC99F660-8062
       Slave 3:
    0001 - Control Module Overtemperature Condition
              P0634 00 [008] - -
                        Reset counter: 137
                        Mileage: 54017 km
                        Date: 2017.08.21
                        Time: 17:51:26
                        Voltage: 12.8 V
    0040 - Motor for Electronic Parking Brake
              C10E3 29 [008] - Signal Implausible
                        Reset counter: 0
                        Mileage: 53994 km
                        Date: 2017.08.20
                        Time: 19:32:23
                        Voltage: 12.2 V
    0004 - Parking Brake Motor; Left
              C10BC 07 [008] - Mechanical Failure
                        Reset counter: 137
                        Mileage: 53999 km
                        Date: 2017.08.20
                        Time: 19:59:59
                        Voltage: 14.4 V
    0052 - Parking Brake Motor; Right
              C10BD 07 [008] - Mechanical Failure
                        Reset counter: 137
                        Mileage: 53999 km
                        Date: 2017.08.20
                        Time: 19:59:59
                        Voltage: 13.0 V
    0051 - No Calibration
              B2010 F0 [008] - Deviation From Expected Range
                        Reset counter: 109
                        Mileage: 52334 km
                        Date: 2017.05.24
                        Time: 15:56:03
                        Voltage: 12.2 V
       Part No SW: 4G0 035 061 E    HW: 4G0 035 061
       Component: Radio U DAB   H60 0099
       Revision: AB001007    Serial number: 109E$0C7564086
       Coding: 010105020100000003
       VCID: 1F4A5E370E1638BE93-804A
       Part No SW: 7P6 035 670 C    HW: 7P6 035 670
       Component: H-BNT-EU      H46 0458
       Revision: --------    Serial number: 478D90C7578708
       Coding: 010101050040C1ED01000B0E00000003F0040101
       VCID: 35669C9F9CEA92EE69-8060
       Subsystem 1 - Part No: 8R0 060 884 AH
       Component: EUR 2012  1308
       Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
       Component: DU8 SV Touch  H26 0045
       Serial number: VWZ8Z9M7801B3Q
       Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
       Component: CD-Database  1886
       Component: TSG HL        H09 0167
       Revision: --------    Serial number: 0000127361479
       Coding: 011C04200001251005080000
       VCID: 3A7C8FA3B5F47D9684-806E
       Component: TSG HR        H09 0167
       Revision: --------    Serial number: 0000127363180
    End-------------------------(Elapsed Time: 03:59)--------------------------
    Tuesday,29,August,2017,16:23:30:44004
                    Address 53: Parking Brake  (7P0 907 801 F)
    16:23:28
      IDE04435-MAS01849   Air gap-Left 2.296 mm
      IDE04435-MAS01850   Air gap-Right 2.161 mm
      IDE05272-MAS01849   Air gap before calibration-Left 2.161 mm
      IDE05272-MAS01850   Air gap before calibration-Right 2.222 mm
    Tuesday,29,August,2017,17:27:10:44004
                    Address 53: Parking Brake       Labels: 7P0-907-801.clb
    Control Module Part Number: 7P0 907 801 F    HW: 7P0 907 801 F
      Component and/or Version: EPB           H51 1201
               Software Coding: 01040100
                Work Shop Code: WSC 01843 210 00002
                  ASAM Dataset: EV_ParkbA7 000006 (VW52)
                           ROD: EV_ParkbA7.rod
    0024 - No Basic Setting
              B2010 00 [009] -  -
                        Reset counter: 148
                        Mileage: 54152 km
                        Date: 2017.08.29
                        Time: 17:26:41
                        Voltage: 12.4 V
    Tuesday,29,August,2017,17:34:49:44004
    17:34:48
      IDE05272-MAS01849   Air gap before calibration-Left 2.323 mm
      IDE05272-MAS01850   Air gap before calibration-Right 2.305 mm
    Tuesday,29,August,2017,17:52:58:44004
       Revision: 53H37---
       Coding: 001568
       Coding: B6A6000890
       Coding: 004DBD
       Coding: 025223
       Coding: 108501
       Coding: 000C35
       Coding: 000D077500
       Voltage stabilizer:
       Coding: 01040100
       Shop #: WSC 01843 210 00002
       ROD: EV_ParkbA7.rod
              B2010 00 [009] -  -
                        Reset counter: 148
                        Mileage: 54149 km
                        Date: 2017.08.29
                        Time: 16:45:25
                        Voltage: 13.6 V
    0025 - No Calibration
              B2010 F0 [009] - Deviation From Expected Range
                        Reset counter: 148
                        Mileage: 54149 km
                        Date: 2017.08.29
                        Time: 16:47:22
                        Voltage: 14.2 V
    End-------------------------(Elapsed Time: 03:56)--------------------------
    Tuesday,29,August,2017,19:51:40:44004
                           ROD: EV_ParkbA7.rod
              B2010 00 [009] -  -
                        Reset counter: 148
                        Mileage: 54155 km
                        Date: 2017.08.29
                        Time: 19:50:03
                        Voltage: 13.8 V
                        Reset counter: 148
                        Mileage: 54155 km
                        Date: 2017.08.29
                        Time: 19:50:04
                        Voltage: 13.8 V
    Tuesday,29,August,2017,19:56:57:44004
                           ROD: EV_ParkbA7.rod
              B2010 00 [009] -  -
                        Mileage: 54155 km
                        Date: 2017.08.29
                        Time: 19:54:41
                        Voltage: 13.8 V
                        Reset counter: 148
                        Mileage: 54155 km
                        Date: 2017.08.29
                        Time: 19:55:46
                        Voltage: 13.8 V
    Ive tried every which way to do basic setting AIR GAP CALIBRATION and im a tad frustrated as ive not long walked in the door........PLEASE HELP.
    These are the errors im getting and my second scan
    Tuesday,29,August,2017,19:58:11:44004
    VIN: WVGZZZ7PZCD066081   Mileage: 54155km-33650miles
       Revision: 53H37---
       Coding: 001568
       Coding: B6A6000890
       Coding: 004DBD
       Coding: 025223
       Coding: 108501
       Coding: 000C35
       Coding: 000D077500
       Voltage stabilizer:
       Coding: 01040100
       ROD: EV_ParkbA7.rod
                        Reset counter: 148
                        Mileage: 54155 km
                        Date: 2017.08.29
                        Time: 17:46:21
                        Voltage: 14.2 V
              B2010 00 [009] -  -
                        Reset counter: 148
                        Mileage: 54155 km
                        Date: 2017.08.29
                        Time: 17:46:21
                        Voltage: 14.2 V
    End-------------------------(Elapsed Time: 03:57)--------------------------
    KIND regards DANNERS
    PS ive included there some of the current measure values of pre air gap calibration/basic settings in the second scan............. it just does not want to know
  2. Likes Dana liked this post
  3. #2
    Jun 2016
    UWE? do you have any ideas?
    United States
    Hi Danners,
    Firstly thanks for all of the data and history! It looks like you already found this page .. but I think the Output Tests > grind-in test drive is worth a shot since all of the parts were replaced:
    http://wiki.ross-tech.com/wiki/index..._Parking_Brake
    You'll find a video of Uwe and Eric messing with his 2015 T'reg (that was not broken) within that linked page. After the grind-in I would hope all DTCs clear but if not, please try the Basic Settings [*IDE04509*] Air gap calibration again to see if you get a Finished Correctly result.
    Best,
    Dana
  5. Likes Uwe liked this post
    Jun 2016
    Morning yes loads of data sorry I saved a fair few........tiredness took over last night. Thanks though Dana I will give it a go later today. Much appreciated.
    I was wondering though........surely if you were to just tweek the shoes for an adjustment, say on a service you should be able to basic set the AIRGAP?
    I guess the person before me didn't know what they were doing and Im having to pick up where he left off?
    Regards Danners...........
    Jun 2016
    Good afternoon. Just like to say many thanks to you DANA! I watched the video on how to carry out the grind in procedure. Carried it out as I looked at the MVB's for grind in distance-they hadn't been carried out. All basic settings are now complete and Im one happy tec!!!
    May I just add something......some refinement perhaps on the video as to allow a rest period for the EPB motors to cool? I was doing approximately 6 KMH in D1. Other than that thanks again.
    Regards and have a nice day!
  8. Likes Dana, Uwe, jyoung8607 liked this post
  9. #6
    United States
    Thanks Danners! Glad to hear that worked out.
  10. Likes Uwe liked this post
  11. #7
    Sep 2017
    Canada
    Hi, I know this isn’t fresh but I’m having a similar issue. I need to adjust my air gaps as well and am having a hell of a time finding this screw/nut to turn to adjust. I’ve pulled the tire off and the plug that should reveal the adjustment but haven’t seen anything. Any help would be greatly appreciated as I have run through the videos and can do the break in to clear the codes. It is going to go in to VW if I can’t figure this air gap adjustment on my own. Just hoping you guys could help.
  12. #8
    Sep 2017
    Canada
    Lol I guess I should mention the vehicle. 2011 VW Touareg Comfortline
  13. #9
    There are pictures a ways down in this thread:
    http://forums.ross-tech.com/showthread.php?3267
  14. #10
    Sep 2017
    Canada
    Wow I have the same issue as the last guy in that thread. Guess this is gonna have to go in. Too bad I was hoping I could do this with the VAGCOM. I adjusted the brakes to 2.1 and 2.1. Logged on and checked the gaps, starting 1.8 and 0.76, gaps before calibration changed to 2.1, 2.3 after opening and closing. But can’t get away from aborted for safety reasons. So weird. They are working but I can’t calibrate. If anyone has any pointers I’m all ears.
