2005 Vw touran, ABS cannot be reached + many more. Can someone help?
Kimste
Norway
C?ID=264855
Hi!
I was changing my oil here the other day, and some time ago my radio went dead, i was about to finish up, when i thought i just should check my fuses to see if i had missed one blown one for the radio.
But, there was one thing i did wrong, my ignition was on!:mad::cry:
I was checking the fuses, and i checked them all, both in the enginebay and under the dash.
When i got in to the car after, almost every warning light lighted up my car on the inside.
I connected the car, and here is what i found out.
Saturday,26,August,2017,13:00:06:18381
VCDS Version: 17.8.0.1 (x64)
VIN: WVGZZZ1TZ6W001897   License Plate:
Mileage: 265610km-165042mi   Repair Order:
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 69 72
VIN: WVGZZZ1TZ6W001897   Mileage: 265610km-165042miles
03-ABS Brakes -- Status: Cannot be reached 1100
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 016 CD    HW: 028 101 194 5
   Component: R4 1,9L EDC G000SG  6246
   Revision: 12345678    Serial number: VWZ7Z0E2162445
   Coding: 0000072
   Shop #: WSC 01324 785 00200
   VCID: 67DDDCB5562A197E2B-8032
18057 - Powertrain Data Bus
            P1649 - 000 - Missing Message from ABS Controller
                    Torque: 46.0 Nm
                    Speed: 4.0 km/h
                    Load: 0.0 %
                    Voltage: 12.01 V
                    Bin. Bits: 00001000
                    Torque: 0.0 Nm
                    Bin. Bits: 00000000
Readiness: 0 0 1 1 1
Address 03: ABS Brakes
   Part No: 1K0 907 044 BA
   Component: ClimatronicPQ35 066 0606
01316 - ABS Control Module
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Revision: 00H37000    Serial number: 00000001916004
   Coding: 098B8F210004100000120C000000000000087F075C
   VCID: 2B5560858A42FD1E0F-807E
   Subsystem 1 - Component: Fehler Lin-Slave 01
02071 - Local Databus
                    Reset counter: 95
                    Mileage: 265611 km
                    Voltage: 12.30 V
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 95
                    Mileage: 265611 km
                    Voltage: 12.30 V
   Part No SW: 1T0 909 605 C    HW: 1T0 909 605 C
   Component: 02 AIRBAG VW62 0506 1500
   Revision: 09025000    Serial number: 0038BD0DBRZZ
   Coding: 0012338
   VCID: 356146FD5C06BBEE69-8060
   Part No SW: 1K0 953 549 F    HW: 1K0 953 549 F
   Component: Lenks‰ulenmodul 021 0050
   Coding: 0000042
   Part No: 1T0 920 872 A
   Component: KOMBIINSTRUMENT VDD 1112
   Coding: 0007101
   Shop #: WSC 44402 001 1048576
   VCID: 326B7DE1AD68ACD64C-8066
Address 18: Aux. Heat        Labels: 1K0-815-071.clb
   Part No: 1K0 815 071 H
   Component: Zuheizer        031 1312
   Revision:        A    Serial number: 09010046
   Coding: 0000011
   VCID: 2A5B658185B8E416F4-807E
   Revision:   H10       Serial number: 28001055180419
   Coding: 3D3F5340078002
                    Reset counter: 95
                    Mileage: 265611 km
                    Time: 11:19:36
01304 - Radio
                    Reset counter: 95
                    Mileage: 265611 km
                    Time: 11:19:40
   Component: IMMO            VDD 1112
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1T0 959 701
   Component: Tuersteuergeraet 09 0157
   Coding: 0000116
   VCID: 74E7BBF917FCE2E69E-8020
   Part No: 1K1 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
00625 - Vehicle Speed Signal
                    Mileage: 5600 km
                    Temperature: 16.0∞C
                    Voltage: 12.20 V
                    Voltage: 11.90 V
            000 -  -
   Part No SW: 1K0 959 433 AR    HW: 1K0 959 433 AR
   Component: 01 KSG PQ35 G2  010 0101
   Revision: 00010000    Serial number: 00000000000000
   Coding: 009002085103087F2D06840560084F01E0A500
   VCID: 000FE7295344CE468A-8054
01312 - Powertrain Data Bus
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 95
                    Mileage: 265611 km
                    Time: 11:46:17
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1T0 959 702
   Coding: 0000116
   VCID: 75E186FD1C86FBEEA9-8020
Address 56: Radio
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 B
   Component: Tuersteuergeraet 06 0214
   Coding: 0000048
   VCID: 2F6D7495BE5A813E23-807A
Address 69: Trailer
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 B
   Coding: 0000048
   VCID: 306F77E9A3649EC63A-8064
End-------------------------(Elapsed Time: 01:48)--------------------------
Address 01: DTCs cleared
This was the first one. And when i tried a second time, i got this.
Saturday,26,August,2017,12:24:21:18381
VIN: WVGZZZ1TZ6W001897   License Plate: AR96294
Mileage: 265610km-165042mi   Repair Order: anette
03-ABS Brakes -- Status: Sporadic communication error 1000
   Coding: 0000072
                    RPM: 798 /min
                    Torque: 34.0 Nm
                    Speed: 4.0 km/h
                    Load: 0.0 %
                    Voltage: 14.14 V
                    Bin. Bits: 00001000
                    Torque: 156.0 Nm
                    Bin. Bits: 00000000
Readiness: 1 1 0 0 0
   Subsystem 1 - Part No: 1T0 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW358  012  0401
   Coding: 00065493
   Shop #: WSC 01324
   Coding: 0012338
   Coding: 0000042
   Coding: 0007101
   Coding: 0000011
                    Reset counter: 135
                    Mileage: 265611 km
                    Time: 00:15:58
01304 - Radio
                    Fault Frequency: 17
                    Reset counter: 95
                    Mileage: 265611 km
                    Time: 00:16:03
   Coding: 0000116
                    Mileage: 5600 km
                    Temperature: 24.0∞C
                    Voltage: 14.20 V
                    Voltage: 14.00 V
            000 -  -
                    Reset counter: 95
                    Mileage: 265611 km
                    Time: 11:06:44
   Coding: 0000116
Address 56: Radio
   Coding: 0000048
Address 69: Trailer
   Coding: 0000048
End-------------------------(Elapsed Time: 01:45)--------------------------
As you can se on the 03 ABS, one the first log it can not be reached, on the second one, it is sporadic comm.
Does anyone have a hint or clur where i should begin?
It looks like everything ends up with the ABS unit?!
HELP ME PLEASE!!:thanks::thanks::thanks::thanks:
Any chance you put one of the fuses back in the wrong location, like someone did in this car?
Kimste
Norway
C?ID=264855
I'm pretty sure that i have put all the fuses back in the right location. My manual dies not have the right fuse placement information though.
Do you know of any good overwiev of the different fuse locations? It's definently worth the try.
The factory WD is the best fuse table and can be found at Erwin online.
https://erwin.volkswagen.de/erwin/showHome.do
