Page 5 of 37 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 365
Thread: Current Versions
  1. #41
    Is this for the headlight leveling controllers in Mobile mode?
    Yes it is.
  2. Likes jyoung8607 liked this post
  3. #42
    CB V0.4109 is out, with support for CAN TP1.6 1281, needed for a few (special snowflakes) specific modules
    Also has some reliability and performance tweaks for VCDS comms, mainly for beta 14.7
    Also out is FW V0.187, which has several behind the scenes tweaks and fixes
    --Shaun
  4. #43
    VCDS Beta 14.7.0
    • Requires CB v4109 and FW 0.187 so update your HEX-NET first!
    • Drastically optimized timeouts and error processing, should make WiFi more reliable and faster
    • HEX-NET will be faster on UDS modules, especially those with slaves
    • Fixed potential buffer overflow if WiFi is unreliable during HEX-NET comms init with controller
    • Merged USB and WiFi send routines
    • Moved all out of sequence packet buffering to one place
    • Fixed some out of sequence packets not being pulled in the right order
    • More OBD2 fixes (Mode 9 type 11)
    • Fixed some fails to re-initialize variables used with modules not responding normally to ID commands (for all interfaces)
    • Fixed Polo 6R UDS platform determination
    • Added work-around for buggy firmware in TRW 0x44 preventing MWB 80 from displaying
    • Fixed forced & incorrect coding suggestion for certain new airbag modules
    • Fixed Phaeton airbag freeze frame claiming to have mileage but not having it.
  5. #44
    VCDS Beta 14.7.1
    • Requires CB v4109 and FW 0.187 -- which you already have if you're currently using 14.7.0.
    • Offers to open VCDS-Mobile for firmware update if connected in infrastructure mode
    • Fix for Basic Settings in UDS modules & HEX-NET
  6. #45
    Cb Version 0.4110 is out, which has support for measuring value/BS group zero
  7. #46
    Awesome! The guys with old distributor-pump TDIs will be thrilled!
    CB V0.4111 is released, with a fix for manually entering group zero and a fix for a possible memory leak when force closing a session during kline comms
    --Shaun
  9. #48
    VCDS Beta 14.7.2
    • Requires CB v0.4111, so update your HEX-NET first.
    • Fix for CAN telegram timing and recovery if controller sends keep-alive between two telegrams
    • Fix for slow inter-telegram timing on CAN/TP20 for non HEX-NET interfaces
    • Workaround for Touareg 46 K-line flood when requesting DTCs
    • Fix slowness when Adapation channel N/A on KWP2000/CAN TP20
    • Fix slowness when terminating basic settings on KWP2000/CAN TP20
    • Fix potential missing slave ID on some 46 controllers (e.g. Touareg)
    • A number new/updated label files; Data Version 20140714
    NC USA
    This seems to create an infinite loop, at least for me.
    After the install it asks to download ~16MB, runs the whole install, then does it again once VCDS launches, over and over.
    Only way I've found to get out is to untick the Run Now after install completes, or click cancel when it asked to update the Data Version.
    Same scenario on 2 machines.
  11. #50
    It's possible I fat-fingered something on the update server...
    [Time passes]
    It ain't obvious. Nope. That isn't the problem. I do see what the problem is though. Somebody goofed and it wasn't me, but I should caught it. I put a work-around on the server for now.
    Sorry about that!
    I'll go re-do the distro now and fix it right.
