Page 2 of 37 FirstFirst 123412 ... LastLast
Results 11 to 20 of 365
Thread: Current Versions
    VCDS Beta 14.4.1:
    -Requires CB v4019 which has many K-line/KWP2000 fixes and some on CAN (so please update that first!)
    -Fixes switched MWBs on dual ECUs over K
    -Working turbo mode on dual ECUs over K
    -Fixed GVL on Up! Gateway
  2. Likes jyoung8607 liked this post
  3. #12
    CB V0.41 is out
    inb4 two in the same day, yay
  4. Likes Eric liked this post
  5. #13
    VCDS Beta 14.4.2:
    - Requires HN CB v0.4100 that fixes not closing sessions after some number of modules have been scanned.
    - Faster turbo mode on dual-ECU over K
    - Fixed missing CAN status with non-HEXNET when CAN not ready in Options->Test
    - Improved HEXNET detection logic
  6. Likes jyoung8607 liked this post
  7. #14
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Love it!!!
    My HEX-NET should be delivered today. If the contents of my Phaeton's engine compartment haven't yet been been evenly distributed across the floor at my dealership, I'll go over and give it a try this afternoon. They were waiting on parts from the Fatherland to begin, which are supposed to show up any time now.
    Jason
  8. #15
    V0.4102 is now out, fixes several issues with certain modules, more details above
  9. Likes jakematic, jyoung8607 liked this post
  10. #16
    VCDS Beta 14.5.0:
    * Additional K-Line fixes
    * Improved buffering of HEX-NET packets in VCDS
    * Fixes slowness on UDS modules introduced a couple weeks ago
    * Updated UDS addresses and fixes for telegram length while decoding
    * Fix for failing output tests under UDS and possibly errors with same size telegram
    * Turbo mode now works on address 11 for K-Line
  11. Likes jakematic, jyoung8607 liked this post
  12. #17
    CB V0.4104 and FW 0.184 are out. Improved comms and added support for certain controllers. See details above.
  13. Likes jyoung8607, jakematic liked this post
  14. #18
    VCDS Beta 14.5.1
    * Fixes HID USB packets received out of order on some slow PCs
    * Lets user know when HEXNET is busy talking to cloud server
    * Improved reliability on low baudrate controllers
    * Made measuring blocks reliable on CAN dual-ECU with HEXNET
    * Increased buffer size for concatenated GVL packets in Wifi
    * Time elapsed now displayed at the end of the autoscan (last line)
    * Requires CodeBlock 4103 or higher -- so please update your HEX-NET first.
    NOTE: Check for Updates twice -- the CodeBlock and FW (firmware) are separate updates.
    * Also includes new USB drivers for classic USB interfaces (HEX+CAN, KII, Micro-CAN).
  15. Likes jyoung8607, Eric, jakematic liked this post
  16. #19
    CB V0.4105 has been released, which should fix the issues some people have seen with the last update and certain gateways. More details above.
  17. Likes jyoung8607, jakematic liked this post
  18. #20
    VCDS Beta 14.5.2
    * Requires codeblock 4104 -- or newer.
    * Tighter 1281 interbyte timing by default on HUC; HCC was fine and is unchanged.
    * Fixed unable to clear UDS fault codes on ECM/TCM
    * Fixed ghost long adp channels
    * Fixed crash with autoscan/debug 1024/hexnet
    * Display debug level if any at end of autoscan
    * Enforce HN FW version (184 required) in [Options] -> [Test]
  19. Likes jakematic liked this post
