Page 12 of 37 FirstFirst ... 2101112131422 ... LastLast
Results 111 to 120 of 365
Thread: Current Versions
  1. #111
    NC USA
    Quote Originally Posted by solomon View Post
    Hmmm, no rodlist.txt - just rodlist and rodlist-2 (no file extensions).
    Same thing on mine that's stuck in the loop...
    Interesting thing is it auto-mounted as drive E: when I plugged it into Windoze.
  2. #112
    CO, USA
    Quote Originally Posted by jakematic View Post
    Hmmm, Windoze box withOUT the VCDS drivers? I never tried that...
    Richard
  3. #113
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    It's not that. The Java config utility sends HEX-NET a special command to offer up a USB mass storage device during the upgrade, and turns it off when it's finished. It's similar to say, an Android phone where you have to explicitly tell it to offer up its onboard storage as a USB device to the host, otherwise it doesn't.
    Jason
  4. Likes jakematic liked this post
  5. #114
    NC USA
    With. Did the same on a Mac...
    I think it was stuck in an unusual state since power cycling it stopped the behaviour.
  6. #115
    CO, USA
    OIC, whenever I hook to the computer I'm only USB-powered so I naturally power-cycle between USB plug-in events. My bad. I understood the utility function switching, just hadn't ever tried to see what the default driver would be - or don't remember what happened when I tried that ages ago
    Richard
  7. #116
    NC USA
    Apologies - I should have clarified what I did.
    The HN is usually connected via USB to a Mac, but seeing your exchange with Shaun I attached to the to W8.1 VM on the same machine.
    Idea was that the Windoze version might complete the update....
    Edit: And who wouldn't want to poke around behind the curtain if you get a chance
  8. #117
    Hmmm, no rodlist.txt - just rodlist and rodlist-2 (no file extensions). Email sent anyway.
    Richard
    Yes sorry, this is the file I meant.
    --Shaun
  9. #118
    NC USA
    Did VCDS 14.10.0 just get refreshed ?
    My machine asked to update it and I could swear I already did.
    Also see some HN FW updates....
  10. #119
    If so, somebody did it behind my back, and unless I'm unconscious or dead, that would be a -CLM- around here.
    Is it possible you had an old version installed somewhere else and that's what triggered it? Did it ask you to update when you started VCDS or when you booted up the machine?
    I suspect at least one of your HNs is on the Alpha channel. That means it may get stuff before it's announced here.
    NC USA
    It is possible there is an old version as this was the machine I was confused about earlier in this thread.
    The update notification popped up out of the blue this afternoon.
    More than likely just an anomaly on my goofball VM.
    Speaking of which I have got to clean it up because I used the wrong version of the config utility today. Again.
    It was both of them.
    This never happened.... everyone move along.... nothing to see here
    ps- I still owe you an updated Auto-Scan which I'll do as soon as work stops trying to comminution me...
  12. Likes Uwe, PCI Max liked this post
