Page 34 of 37 FirstFirst ... 243233343536 ... LastLast
Results 331 to 340 of 365
Thread: Current Versions
  1. #331
    Verified VCDS User romad's Avatar
    Oroville, California People's Republic
    Release channel vs. Beta...
    Use VCIConifg to set yourself to Beta if you wish.
    Ah, OK that explains it. I'll just stay with the release version. Thanks, Uwe. Oh, my computer is an iMac so I just use Firefox to connect.
  2. #332
    Bump for beta version CB V0.4427
    * Fix for Kline comms with long header
  3. Likes Uwe, Eric, Boki Ar, vagtuning liked this post
  4. #333
    Bump for CB V0.4430
    * More fixes for Kline long header packets
    * Fix for comms drop with certain modules that wait a long time to respond
  5. Likes Boki Ar, Uwe liked this post
  6. #334
    Aug 2015
    Bump for CB V0.4430
    during update of cb V0.4430 from cb V0.4427 the process locked up and now the hexnet is no longer functioning. Just has one red light blinking when I plug in usb cable to test or config. Anyway to recover it?
  7. #335
    Jun 2014
    Swansea, UK
    Quote Originally Posted by tmoe View Post
    Does the Windows VCDS Interface Config Utility (VCIConfig) still retrieve the serial number ok?
    If so, try this
  8. Likes Eric, Uwe liked this post
  9. #336
    Aug 2015
    Quote Originally Posted by Mike@Gendan View Post
    If so, try this
    funny that thread was exactly what was going on with my hex-net. I did the reboot everything and it started but would fail with an error code -8 or com error or something like that. I normally don't have upnp enabled on my core router to the internet but I enabled it and then comm to ross-tech update servers started to work again. I forgot this has happened to me in the past and I forgot to enable before I start the CB update.
    Many thanks for the info.
  10. Likes Eric, Mike@Gendan, Uwe liked this post
  11. #337
    I just did an update and I'm told I am up to date with the following:
    CB: 0.4411
    FW: 0.254
    CFB: 0.10
    BL: 0.28
    DS: 00000050
    Does that look good for the channel I'm on? In Post #1 it lists BL: as 0.27
  12. #338
    Yes you are on release, so that is correct.
  13. #339
    Of course he could set himself to Beta if he wanted to.
  14. #340
    No, I'm fine with the release channel. My only concern was with the BL version discrepancy between what I was told I had and what was shown here
