Page 33 of 37 FirstFirst ... 233132333435 ... LastLast
Results 321 to 330 of 365
Thread: Current Versions
  1. #321
    Quote Originally Posted by romad View Post
    But I'm told that my Hex-Net is up to date. Where do I find the CFB & BL info?
    VCIConfig will show them to you, but we don't have a Mac build of that ready, so you'll need something running Windows to use it.
    Of course, I could also check the server...
    [time passes]
    You have CFB: 0.10, BL: 0.27, and DS: 0000050
    VCIConfig would probably update your BL to 0.28, but this makes no perceptible functional difference.
  2. #322
    Verified VCDS User romad's Avatar
    Oroville, California People's Republic
    Thanks, Uwe.
    So the first digit of the Dataset is ignored and only the last 7 digits are important?
    I was hoping I could use Codeweavers Crossover application to run the Windows applications but it looks like the last time any was tried was in 2012 and it failed to run on Crossover 12.
  3. #323
    Thanks, Uwe.
    It's not ignored. It contains flags that specify what (if any) old data must be scrubbed and replaced. But the actual version info is indeed in the digits on the right.
  4. Likes jyoung8607 liked this post
  5. #324
    Bump for new beta versions CB V0.4417 and DS 60000055
    Beta Versions:
    These updates are optional. If you are unsure, you do not need to do anything, you can stay on the release channel. If you accept some risks and wish to test the latest stuff, you can switch your interface to the beta update channel via the advanced tab in VCIConfig.
    CB V0.4417
    * Support for new UDS loc descriptions
    * Support for new dataset
    * Fix to make DTC clear counting consistent
    * Adds support for ROD clear option
    DS 60000055
    * New rod and label data
    * Support for ROD clear option
  6. Likes Uwe, WebCF liked this post
  7. #325
    May 2014
    CB: 0.4422
    * Adds new UDS addresses
    0.4417 -> 0.4422? Whats with 18-21?
  8. #326
    Quote Originally Posted by WebCF View Post
    The only way to get a new version into an interface for internal testing is to give it a new version number. Not every version that we test is going to be be made available to the public.
  9. Likes PetrolDave liked this post
  10. #327
    Dec 2016
    Amsterdam
    What is ‘ROD clear option’?
    Current:
  11. #328
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Quote Originally Posted by MasterTommy View Post
    It's a mini factory reset for VCDS Mobile, just for the ASAM/ROD data cache. It zaps anything you've downloaded over-the-air within Mobile, or with the VCIConfig utility. It's really only needed if you're troubleshooting something to do with ASAM/ROD data within VCDS Mobile running on HEX-NET. It has nothing to do with VCDS on Windows, and it doesn't apply to HEX-V2 at all.
    Silence gives consent.
  12. Likes Santos, Eric, Uwe, Derek liked this post
  13. #329
    I just did a check for any updates and was told my Hex-Net was up-to-date. However, the CodeBlock version on it is V0.4411, while version V0.4417 is listed as the current one in Post 1 of this thread. Why am I being told my device is up-to-date?
    APP Id (1) CodeBlock V0.4411 API V4
    FW version: 0.254.
    Dataset: 00000050
    K1: OK
    K2: OK
    CAN: Testing
    VCDS-Cloud: OK
    Config: OK
  14. #330
    Release channel vs. Beta...
    Use VCIConifg to set yourself to Beta if you wish.
