Page 32 of 37 FirstFirst ... 223031323334 ... LastLast
Results 311 to 320 of 365
Thread: Current Versions
  1. #311
    Jun 2015
    Thank you Benevolent Dictator
  2. #312
    Bump for CB V0.4409
    * Fix for data loading/rod redirect issues
    * Fix for UDS mv drops with grouped requests + turbo mode
    * Fix for Immo3 extra info parsing
  3. Likes Uwe liked this post
  4. #313
    Verified VCDS User hans j's Avatar
    Mar 2014
    Utah
    Mine keeps telling my I'm not up to date, but the updating software says I am up to date. I've been having to use older versions to make it work.
    VCDS 17.12 says I'm at:
    CB 0.4409.4
    FW 0.254
    WiFi 310C
    and says firmware update required.
    Firmware software says:
    CB 0.4409
    FW 0.254
    CFB 0.10
    BL 0.28
    DS 00000050
  5. #314
    You'll need to flip your interface onto the Beta update channel using VCIConfig, as described on the Beta Page in the Release Notes section:
    If you are using a HEX-NET or HEX-V2 interface, you must set the update channel for your interface to "Beta" and update it before you can use this version of VCDS.
  6. Likes hans j, Shaun, Boki Ar liked this post
  7. #315
    You need to switch your interface to the beta channel to get the latest testing firmware that goes with the beta version of VCDS.
    In VCIConfig, go to [Advanced] -> Update channel [Beta] -> [Change Channel]
    Then check for updates again.
    EDIT: As Uwe showed above, with the picture.
  8. Likes Uwe, Boki Ar liked this post
  9. #316
    Mar 2014
    Utah
    That worked! Thanks again.
  10. Likes Shaun, Uwe, Boki Ar liked this post
  11. #317
    Bump for CB V0.4411
    * Support for configurable CharInt from VCDS
    * Test fix for comms with certain CAN modules
  12. Likes Uwe, Eric, PetrolDave liked this post
  13. #318
    Channel set
    Bump for CB V0.4411
    I have your Beta version of VCDS on my desktop and also the release, should I set the channel for the HexNet to beta in the beta version only, or do I also set the beta channel in the release version?
  14. #319
    Quote Originally Posted by Gary View Post
    It doesn't matter which one you use. That setting tells the server which channel you're on; it's not a local setting.
    BTW, since we now have a Release 18.1.0, Beta 17.12 is deprecated.
  15. Likes Eric liked this post
  16. #320
    Verified VCDS User romad's Avatar
    Oroville, California People's Republic
    I just updated my Hex-Net but all I see on the "About" is this:
    CodeBlock V0.4411
    FW version: 0.254
    Dataset: 00000050
    No CFB or BL
    No 10000050 dataset
    But I'm told that my Hex-Net is up to date. Where do I find the CFB & BL info?
    I'm viewing this via my Firefox 52ESR web browser on my iMac
