Can't cycle SAI pump on/off
gagnonj14
C?ID=314635
Hello!
I'm new to VCDS and i'm having difficulty cycling my SAI pump on and off for troubleshooting. I have a 2012 audi s4 and I'm using the latest version of VCDS. When I look up the output tests section of the engine module, I simply cant find the one for the pump, and the option for sequential tests is grayed out...
I went to check the basic setup to find a general test that tells me that it failed.. I would simply like to be able to activate it while the engine is not running.
Thanks!
Jean-Michel
gagnonj14
C?ID=314635
Wednesday,23,August,2017,20:16:54:50142
VIN: WAUFGCFL0CA113919   License Plate: N69 EAY
Mileage: 198380km-123267mi   Repair Order:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2E 36 3C 42 46 47 52 53
          55 56 62 72 77
VIN: WAUFGCFL0CA113919   Mileage: 198380km-123267miles
Address 01: Engine (J623-CCBA)       Labels:| 06E-907-551-CAK.clb
   Part No SW: 8K0 907 551 D    HW: 8K0 907 551 A
   Component: 3.0T SIMOS84  H08 0003
   Revision: --H08---
   Coding: 0104000A240F0128
   Shop #: WSC 06324 000 00000
   ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
   ROD: EV_ECM30TFS0218K0907551D.rod
   VCID: 323E125304A35C779DE-8066
8931 - Secondary Air Injection System: Bank 1
          P0491 00 [237] - Insufficient Flow
                    Fault Frequency: 12
                    Mileage: 194950 km
                    Date: 2017.07.14
                    Time: 21:26:29
                    Engine speed: 1324.00 /min
                    Normed load value: 18.8 %
                    Coolant temperature: 30 °C
                    Intake air temperature: 31 °C
                    Voltage terminal 30: 13.202 V
                    Engine speed: actual: 1216 /min
                    MAF_ENVD: 452.10587 mg/stroke
                    Coolant temperature (unfiltered): 30.0 °C
                    Engine: operating status: PL
                    Battery voltage: 13.101563 V
                    STATE_LS_ENVD[1]: 4
8932 - Secondary Air Injection System: Bank 2
          P0492 00 [232] - Insufficient Flow
                    Fault Frequency: 11
                    Mileage: 194950 km
                    Date: 2017.07.14
                    Time: 21:26:29
                    Engine speed: actual: 1184 /min
                    MAF_ENVD: 212.43529 mg/stroke
                    Coolant temperature (unfiltered): 23.3 °C
                    Engine: operating status: IS
                    Battery voltage: 13.203125 V
                    STATE_LS_ENVD[2]: 2
   Part No SW: 8K2 927 156 S    HW: 0B5 927 156 F
   Component: 0B5 30TFSINAR H10 0001
   Revision: --H10---    Serial number: 0000000742
   Coding: 000001
   Shop #: WSC 06325 000 00000
   ROD: EV_TCMDL501.rod
   VCID: 46D65E83982BD0D7216-8012
9473 - Sensor for Gear Actuator 2
          P17E1 00 [096] - Mechanical Malfunction
   Part No SW: 8K0 907 379 BJ    HW: 8K0 907 379 BJ
   Component: ESP8 quattro  H04 0060
   Coding: 29050A
   VCID: 025E8293F4032CF74DE-8056
   Part No SW: 8K0 907 064 CG    HW: 8K0 907 064 CG
   Component: BCM2 2.0      H05 0435
   Coding: 0D0100
   VCID: 77A8E347AFC1795F6A0-8022
   Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
   Component: J764 ELV MLB  H38 0042
   Serial number: 2311000298851012
   Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
   Component: KLIMA 3 ZONEN H08 0180
   Revision: C1000000    Serial number: 01140120120923
   Coding: 66002000
   VCID: 005A889BFA0F3EE75BA-8054
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H30 0392
   Revision: 10030001    Serial number: 00000001191114
   Coding: 26001096463CAF212700080300003D0D0F1CD34802010161000000
   VCID: 3C223C6BD6679A07472-8068
   Component: WWS 130112  H07 0070
   Serial number: SWF12010135711
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 11840174
   Coding: 025028
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002312110395
   Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
   Component: HOMELINK  H01 0010
   Part No SW: 8K0 919 475 T    HW: 8P0 919 475 M
   Component: PARKHILFE 4K  H01 0081
   Revision: 11001001    Serial number: 36861201000032
   Coding: 00010D
   VCID: 4ACE6AB38CB334B7C5E-801E
   Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
   Serial number: 003GLD90734X
   Coding: 30453735423030303030554A304C384B3053
   VCID: 45D4598FA52DDBCF28C-8010
   Serial number: 6334MSME693028304
   Serial number: 6344MSME69336C67Q
   Serial number: 6352QSME70693B48P
   Serial number: 6362QSME6F691262P
   Serial number: 63732SME3E653A603
   Serial number: 63832SME3E65145E9
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90372KLG00059
   Coding: 000036
   VCID: 3E263663C07B8817696-806A
   Component: E221 - MFL  H02 0010
   Part No SW: 8K0 920 931     HW: 8K0 920 931
   Component: KOMBIINSTR.   H12 0261
   Revision: 00000000    Serial number: ND2229A1D
   Coding: 8B0709008A000008020000
   VCID: 6B80CF37E389CDBF9E8-803E
   Part No SW: 8T0 907 468 AG    HW: 8T0 907 468 J
   Component: GW-BEM 6CAN   H06 0120
   Revision: HB901054    Serial number: 5400H11A1382D0
   Coding: 00C303
   VCID: 06569E83D82B10D7616-8052
   Component: J367-BDMHella  H03 8040
   Serial number: 8851666301
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 A    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H13 0025
   Serial number: 001201120001004
   ASAM Dataset: EV_AllWheelDiffeQSPCAN 003016
   VCID: 2E060623109B7897F96-807A
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0290
   Revision: 00000000
   Coding: 020302
   VCID: 392C257FD955AF2F5C4-806C
   Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
   Component: MEM-FS        H06 0076
   Revision: AA000000    Serial number: 00000020977929
   Coding: 00581B00000000000000
   VCID: 3B203F77D3699D3F4E8-806E
   Part No SW: 8K0 907 566 H    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH02 0030
   Revision: 00H02000    Serial number: 6PZ 009 014-82
   VCID: 3C223C6BDA679A07472-8068
   Subsystem 1 - Part No: 8K0 907 568 H
   Component: J0770_SWA_Slave_H01 0030
   Subsystem 2 - Serial number: 6PZ 009 014-92
   Subsystem 3 - Serial number: 5F09.01.1200H010003C324995ÿ
   Subsystem 4 - Serial number: 324995ÿ
   Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
   Component: TSG FA        H08 1501
   Coding: 011C13204E00410001
   VCID: 53F077D75BF9757FB68-8006
   Revision: 00002001    Serial number: 0167599298
   Coding: 0106023A00FA440580B0013200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000475724
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 AH    HW: 8T0 035 223
   Component: DSP STD       H07 0230
   Revision: S2200000
   Coding: 0203010102
   VCID: 74B2D44BBEB712474F2-8020
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
                    Fault Status: 00101011
                    Fault Frequency: 29
                    Reset counter: 51
                    Mileage: 194922 km
                    Date: 2017.07.14
                    Time: 11:37:23
                    Voltage: 11.80 V
                    Temperature: 36.0°C
                    Bin. Bits: 00000000
   Part No SW: 8T0 959 792 M    HW: 8T0 959 792 D
   Component: TSG BF        H08 1501
   VCID: 52FE72D364E37C77BDE-8006
   Revision: 00000003    Serial number: 20000000174016
   VCID: 3432144BFE3752478F2-8060
Address 55: Headlight Range        Labels: 8T0-907-357.clb
   Part No SW: 8H0 907 357 C    HW: 8H0 907 357 C
   Component: AFS 1           H01 0040
   Revision: 00H01001    Serial number:
   Coding: 0000019
   VCID: 323E125308235C779DE-8066
   Subsystem 1 - Part No: 8K0 941 329
   Component: AFS-Modul links H01 S001
   Subsystem 2 - Part No: 8K0 941 329
   Component: AFS-Modul rechtsH01 S001
02988 - Left-Hand/Right-Hand Traffic Switchover Active
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Reset counter: 40
                    Mileage: 198383 km
                    Date: 2017.08.23
                    Time: 20:12:34
   Part No SW: 8T1 035 195 AD    HW: 8T1 035 195 AD
   Component: Symph3 Sirius H02 0351
   Revision: 00000004    Serial number: AUZ5Z4I1094622
   Coding: 240200020101870003DB270804
   Shop #: WSC 34394 001 1048576
   VCID: 79ACE57F99D56F2F1C4-802C
   Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
   Component: Display
            000 -  -  - Intermittent
                    Fault Frequency: 48
                    Reset counter: 50
                    Mileage: 194922 km
                    Date: 2017.07.14
                    Time: 11:37:25
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
   Part No SW: 8T0 959 795 N    HW: 8T0 959 795 B
   Component: TSG HL        H06 1501
   Coding: 010C13204000210001
   VCID: 56F68EC3480B6057516-8002
   Component: TSG HR        H06 1501
   Part No SW: 8T0 862 336 F    HW: 8T0 862 336 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005253839
   Coding: 0010370
   VCID: 3E263663CC7B8817696-806A
End----(Elapsed Time: 01:56, VBatt start/end: 11.8V/11.9V. VIgn 11.9V)-----
There is a Basic Setting:
IDE00747 -- Checking secondary air system.
But there does not appear to be an Output Test for the SAI pump.
gagnonj14
C?ID=314635
Ok... in that case I will test it myself with a 12v source while checking the vacuum lines for leaks..
Thanks!
gagnonj14
C?ID=314635
I have another question regarding the exact same problem( I haven't fixed it yet ). Is there a way to disable this function completely. (Secondary air injection) or to modify the pressure expected by the ECU in order to get rid of that annoying MIL...
No, you can't disable emissions systems with VCDS.
