Results 1 to 10 of 15
Thread: MK7 golf, disable Hill Hold
    Aug 2017
    Virginia, USA
    I'd like to disable the hill hold function on my 2015 Golf SportWagen with 6 speed manual.
    There are instructions for the MK6 but they don't quite work for the MK7, no choices when you get to the long coding helper for ABS Byte 16, if that's even the right location for the MK7.
    http://www.golfmk6.com/forums/showpo...&postcount=196
    Thursday,24,August,2017,13:20:20:48918
    VCDS Version: 17.8.0.1  HEX-NET CB: 0.4401.4
    VIN: 3VWFA7AU7FM508616   License Plate:
    Mileage: 8503km-5283mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 52 5F 75
    VIN: 3VWFA7AU7FM508616   Mileage: 8503km-5283miles
    Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 C    HW: 04L 907 309
       Component: R4 2.0l TDI   H23 9282
       Revision: 85H23---
       Coding: 01190012032410081000
       Shop #: WSC 09461 444 00000
       ASAM Dataset: EV_ECM20TDI01104L906021C 004014
       ROD: EV_ECM20TDI01104L906021C_004.rod
       VCID: 25023685245E106ED9-8070
    Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-ESP-V1.clb
       Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
       Component: ESC           H32 0385
       Revision: 00000000    Serial number: 50625000001998
       Coding: 04FA6AA124200974007D020181C92520562490004081A4B200630050C002
       Shop #: WSC 01383 790 50316
       VCID: 47DE9C0DFE12E27E0B-8012
       Revision: 00021000    Serial number: 0361024578
       Coding: 030C0C
       ROD: EV_KessyHellaMQBAB_002_VW37.rod
       VCID: 3A38F5F9BDE08F9684-806E
       Part No SW: 5GM 907 426     HW: 5GM 907 426
       Component: AC Manuell    H02 1001
       Revision: 00001K01
       Coding: 02020104202100000000000010000000
       VCID: 05425605849E306EB9-8050
    Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-BV1.clb
       Part No SW: 5Q0 937 087 Q    HW: 5Q0 937 087 Q
       Component: BCM PQ37BOSCH 028 0145
       Revision: --------    Serial number: 86580702152123
       Coding: 000108424041804169E44000000403001800000000000000000000000000
       Shop #: WSC 00066 790 00076
       ROD: EV_BCMBOSCH_014.rod
       VCID: 49DA9A35E806140E1D-801C
       Component: WWS    141205  043 0581
       Serial number:         150402032925
                        Reset counter: 251
                        Mileage: 280 km
                        Date: 2013.01.14
                        Time: 16:46:10
       Serial number: 003GCR01DELL
       Occupant Detection:
       Component: BF-Gewichtss.  H10 0021
       Serial number: IBH0000J150002IIIP0N
       Coding: 303138
       Subsystem 2 - Part No SW: -----------    HW: 480 003 001 15
       Serial number: 3570000000047959321C
       Subsystem 3 - Part No SW: -----------    HW: 480 000 302 15
       Serial number: 358000000001CC410317
       Subsystem 4 - Part No SW: -----------    HW: 480 400 302 15
       Serial number: 3510002B71901D9341C$
       Subsystem 5 - Part No SW: -----------    HW: 480 400 302 15
       Serial number: 3520002B71901D90F2D7
       Subsystem 6 - Part No SW: -----------    HW: 480 400 302 15
       Serial number: 3550002AB196FF51F0DU
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 302 15
       Serial number: 3560002B71901D93E2AA
       Revision: FF032032    Serial number: 20150210500268
       Coding: 0400
       Shop #: WSC 66564 385 16448
       ROD: EV_SMLSVALEOMQB_VW37.rod
       VCID: 04444B018FA40966AE-8050
       Part No SW: 5G1 920 841     HW: 5G1 920 841
       Component: KOMBI         243 4270
       Coding: 0BA412122180CF0502086A001000000000000000
       Shop #: WSC 00066 790 00064
       VCID: 6582768564DED06E19-8030
       Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
       Component: GW MQB Mid    211 2203
       Revision: --------    Serial number: 06031510001169
       Coding: 0901000800087300EF000008080F00000001050000000000000000000000
       Shop #: WSC 00066 790 07025
       ROD: EV_GatewConti_011.rod
       VCID: 71AA12D5A0160CCE75-8024
       Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H16 0101
       Serial number: 29150000484830125112
       Coding: 30FFFF
       Power Converter DC AC:
       Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
       Component: WECHSELRICHTE  H53 0041
       Serial number: 0033852
       Revision: 00000000    Serial number: 15000042994001
       Coding: 5500000000000000
       ROD: EV_ELVMarquMQB_004_VW37.rod
       VCID: 3424DBC19F8479E65E-8060
       Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
       Serial number: 170315060505IX
       Coding: 003013200000040000000000
       VCID: 3E30F9E9A1C8A3B6B8-806A
       Serial number: 00000000000000941806
       Coding: 011000
       Component: EPS_MQB_ZFLS  126 1061
       Coding: 0102
       ROD: EV_SteerAssisMQB.rod
       VCID: 43C6881DCA2ACE5ED7-8016
       Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
       Serial number: 03031506050B2T
       VCID: 3D32FEE5ACCEB8AEA1-8068
       Serial number: 00000000000000920730
       Coding: 091000
       Part No SW: 5G0 035 844     HW: 5G0 035 844
       Component: MU-S-S-US     014 0645
       Serial number: V7B00303150400
       Coding: 02730200FF00000021220001001800001F0100140100010002
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 64846B816FE4A9660E-8030
       Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
       Component: ABT_Std_Plus  H60 0030
       Serial number: VWZ8Z9PS5017KR
              B11CF 53 [009] - Deactivated
                        Reset counter: 28
                        Mileage: 349 km
                        Date: 2017.04.21
                        Time: 15:50:15
                        Voltage terminal 30: 12.6 V
       Component: OCULowMQBUS   007 0564
       Coding: 02730202C2821A017F1E06000000
       Shop #: WSC 00066 790 00322
       ROD: EV_OCULowMQB_VW37.rod
    End----------(Elapsed Time: 01:20, VBatt start/end: 12.4V/12.4V)-----------
    Any help or suggestions would be much appreciated,
    Grigg
    Curious: Why do you want to disable it?
    The ABS in this car is completely different than in the MK6. I do not see a straightforward way of disabling it entirely, but there seem to be some Adaptation channels that might allow alterning its behavior:
    MAS02138 - Hill-start assistant (Early/Late/Normal)
    MAS08145 - Hill-start assistant: increase threshold (%)
    Aug 2017
    Virginia, USA
    Personal preference, I am very comfortable driving a manual and how the hill holder operates sometimes fights me, it can require more clutch slipping and throttle than necessary.
    It often fights me when leaving a parking spot, which I have gotten around by not using the foot brake then release the hand brake and drive away, feels like I'm playing games with the car..
    Sometimes it's just fine, but I still don't need it.
    I have been using the "Early" setting and it is slightly less obtrusive, but it still functions.
    The "increase threshold" adaptation I don't understand. Mine is set at 3% so I tried 0% thinking "nothing" compared to "something" would be noticeable, but I couldn't tell a difference, and it did still function.
    Without understanding what that % means or does I wasn't comfortable playing with it much more.
    Thanks,
    Grigg
  4. Likes Blade3562 liked this post
    OK, if anyone knows how to disable Hill-Hold in this ABS, please chime in.
    ^^^^^ Uwe: the generally accepted method for enabling/disabling Hill Hold on 3Q0 907 379 units is to set/unset Byte 25, Bit 0 and Bit 1.
    In Crigg's auto scan, the code string for the module @ address Hex03 is
    So the mod is to change this to :
    04FA6AA124200974007D020181C92520562490004081A4B200600050C002
  7. Likes Uwe, Dana, hadez16, jyoung8607, Blade3562 liked this post
    Aug 2017
    Virginia, USA
    Thanks Don,
    I'll try that first thing tomorrow.
    Grigg
  9. Likes Dana liked this post
  10. #7
    Stoke on Trent, England
    Not on Mk7 Golf.
    How to enable or disable hill hold on your Volkswagen Golf mk6
    New User Keith
  11. #8
    Exactly how is this relevant in the context of this thread, which is clearly about an Mk.7? Moreover, the OP already already has the instructions for an Mk.6 and found they are not applicable to his car.
  12. #9
    Aug 2017
    Virginia, USA
    In Grigg's auto scan, the code string for the module @ address Hex03 is
    Thanks Much Don,
    This worked perfectly! I'm very pleased to have the hill holder disabled on my MK7.
    Thanks again,
    Grigg
  13. Likes Uwe, DV52, hadez16, jyoung8607, Dana liked this post
  14. #10
    Jun 2017
    Thanks for this Thread.
    Is this the same way for enabling the Hill Hold function? Or is there special hardware required or something?
    If yes, whats the result when the Hill Hold switch is not present?
    Does this also work on 8V0 907 379?
