Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Lap died
    Quote Originally Posted by refueler View Post
    I have another problem the laptop that I purchased to replace the other laptop and installed the hex net program onto has a problem. The problem is with the mouse pad and the geek squad is telling me to trade it in for a new machine. Is there a procedure to solve this problem or can I just download the program again.
    Yes, your license to use VCDS is embedded in your HEX-NET. This means you can download, install, and use VCDS on any computer that you wish.
  2. #12
    Nov 2014
    Cornish (USA)
    The next question is should I delete the vcds program from the laptop before I turn it in to get a new computer? I probably should have planned ahead and asked this question in the first post.
  3. #13
    No need to delete VCDS. It doesn't do anything useful without an interface. But you may want to have a look in your Logs and Scans folders and grab whatever you've got there for posterity.
  4. #14
    Nov 2014
    Cornish (USA)
    thank you for your help
  5. #15
    I think it's time to Bite the Bullet and buy a new machine.
  6. #16
    May 2014
    SouthEast England
    I'm doing the same thing - moving to a new laptop.
    Is there any reason why I shouldn't just copy and paste the whole of the Ross-Tech directory (from the root of the Windows C: drive) straight into the new machine - or will that screw up the config if a virgin copy of VCDS has just been installed on the new machine?
  7. #17
    Quote Originally Posted by mojo View Post
    Well, Uninstall won't work because you won't have any registry entries telling it what to uninistall. No big deal really.
    You also won't have desktop or Start Menu short-cuts. Oh, and if you're using a "legacy" interface, you'd have to install the drivers for it manually. You can certainly do that, but I think it would be better to properly install VCDS on the new machine, then copy & paste the some of the sub-folders; Logs and Scans being the most important, but Debug and Scaling couldn't hurt either.
  8. #18
    May 2014
    SouthEast England
    Will do - thanks.
    BTW... I know the software development world hopes that Linux will just go away and die, but is there a good guide somewhere about getting VCDS running under Linux (Mint, latest version)? I've tried the link in the FAQ (IIRC) from a couple of years ago about getting it working under Wine, but it didn't work for me! Really would like to crack that one as VCDS is literally the only thing that I have to build my laptop top run Windows for (as well as dual-boot to Linux) and it's just a pain...
  9. #19
    Will do - thanks.
    Not that I am aware of.
    I think the biggest hangup was the drivers for the FTDI chip in the "legacy" USB interfaces.
    Someone who likes to play with Linux might want to try again with the a HEX-V2 or HEX-NET, on USB both enumerate as HID devices, and the HEX-NET can communicate via TCP/IP / WiFi.
