Electrical faults - B8 Audi S5
tomieg
New Member
HC839090 (2nd hand?)
Hey guys!
I'm trying to track down an electrical fault in my S5. I think one of the modules or relays could be bad? I've already checked the fuses and they are all good. I've purchased the vehicle guide from AllDataDIY but can't seem to find the location of the associated "J" modules.
19 Faults Found:
Address 01: Engine (J623-CAUB)
Address 03: ABS Brakes (J104)
Address 05: Acc/Start Auth. (J393)
Address 06: Seat Mem. Pass (J521)
Address 08: Auto HVAC (J255)
Address 09: Cent. Elect. (J519)
Address 10: Park/Steer Assist (J446)
Address 15: Airbags (J234)
Address 16: Steering wheel (J527)
Address 19: CAN Gateway (J533)
Address 36: Seat Mem. Drvr (J136)
Address 42: Door Elect, Driver (J386)
Address 46: Central Conv. (J393)
Address 47: Sound System (J525)
Address 52: Door Elect, Pass. (J387)
Address 53: Parking Brake (J540)
Address 55: Headlight Range 7 Faults Found:
Address 65: Tire Pressure (J502)
Address 6C: Back-up Cam. 3 Faults Found:
VAG COM scan results
Chassis Type: 8T-AU48 (8T0)
Scan: 01 03 05 06 07 08 09 0E 0F 10 15 16 17 19 1E 36 37 42 46 47
          52 53 55 56 65 6C 77
Address 01: Engine (J623-CAUB)       Labels:. 079-907-560-CAU.clb
   Part No SW: 8T0 907 560 G    HW: 8T0 907 560
   Component: 4.2l V8/4V    H10 0009
   Revision: 76H10---
   Coding: 01140009180F0120
   Shop #: WSC 23972 002 1048576
   VCID: 3E737049A92E0BB6B8-806A
19 Faults Found:
049446 - No Communications with Steering Angle Sender (G85)
               U0126 - 008 -  - Intermittent
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:15:27
                    RPM: 1539 /min
                    Load: 22.0 %
                    Temperature: 99.0°C
                    Temperature: 67.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 12.192 V
005640 - Steering Angle Signal
               P1608 - 008 - Malfunction indication from Steering Angle Sensor - Intermittent
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:15:27
                    RPM: 1539 /min
                    Load: 22.0 %
                    Temperature: 99.0°C
                    Temperature: 67.0°C
                    Voltage: 12.192 V
005703 - Check Coding of ECUs on Powertrain Data Bus
               P1647 - 008 -  - Intermittent
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:15:27
                    RPM: 1539 /min
                    Load: 25.9 %
                    Temperature: 99.0°C
                    Temperature: 67.0°C
                    Voltage: 12.319 V
049682 - Steering Column Control Module
               U0212 - 008 - No Communications - Intermittent
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:15:27
                    RPM: 1238 /min
                    Load: 24.7 %
                    Temperature: 99.0°C
                    Temperature: 66.0°C
                    Voltage: 12.319 V
005715 - Please check DTC Memory of ABS Controller
               P1653 - 001 -  - Intermittent
                    Fault Status: 00100001
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:15:28
                    RPM: 1201 /min
                    Load: 23.9 %
                    Temperature: 99.0°C
                    Temperature: 66.0°C
                    Voltage: 12.319 V
               P1653 - 008 -  - Intermittent
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:15:28
                    RPM: 1201 /min
                    Load: 23.9 %
                    Temperature: 99.0°C
                    Temperature: 66.0°C
                    Voltage: 12.319 V
049441 - No Communication with ABS Brake Control Module
               U0121 - 008 -  - Intermittent
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:17:51
                    RPM: 612 /min
                    Load: 42.3 %
                    Temperature: 93.0°C
                    Temperature: 69.0°C
                    Voltage: 13.589 V
049478 - No Communication with Diagnostic Gateway
               U0146 - 008 -  - Intermittent
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:17:51
                    RPM: 612 /min
                    Load: 42.3 %
                    Temperature: 93.0°C
                    Temperature: 69.0°C
                    Voltage: 13.589 V
049448 - No Communications with Parking Brake Control Module
               U0128 - 008 -  - Intermittent
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:17:51
                    RPM: 612 /min
                    Load: 42.3 %
                    Temperature: 93.0°C
                    Temperature: 69.0°C
                    Voltage: 13.589 V
049473 - Body Control Module (Central Electric 2)
               U0141 - 008 - No Communications - Intermittent
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:17:51
                    RPM: 601 /min
                    Load: 41.2 %
                    Temperature: 93.0°C
                    Temperature: 69.0°C
                    Voltage: 13.589 V
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:17:51
                    RPM: 601 /min
                    Load: 41.2 %
                    Temperature: 93.0°C
                    Temperature: 69.0°C
                    Voltage: 13.589 V
049472 - Body Control Module (Central Electric)
               U0140 - 008 - No Communications - Intermittent
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:17:51
                    RPM: 601 /min
                    Load: 41.2 %
                    Temperature: 93.0°C
                    Temperature: 69.0°C
                    Voltage: 13.589 V
049508 - No Communications with HVAC Control Module (J301)
               U0164 - 008 -  - Intermittent
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:17:51
                    RPM: 601 /min
                    Load: 41.2 %
                    Temperature: 93.0°C
                    Temperature: 69.0°C
                    Voltage: 13.589 V
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:17:51
                    RPM: 601 /min
                    Load: 41.2 %
                    Temperature: 93.0°C
                    Temperature: 69.0°C
                    Voltage: 13.589 V
049493 - No Communication with Instrument Cluster
               U0155 - 008 -  - Intermittent
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:17:51
                    RPM: 601 /min
                    Load: 40.4 %
                    Temperature: 93.0°C
                    Temperature: 69.0°C
                    Voltage: 13.462 V
049561 - Door Control Module - Driver's Door
               U0199 - 008 - No Communications - Intermittent
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:17:51
                    RPM: 606 /min
                    Load: 37.6 %
                    Temperature: 93.0°C
                    Temperature: 69.0°C
                    Voltage: 13.335 V
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:17:51
                    RPM: 606 /min
                    Load: 38.4 %
                    Temperature: 93.0°C
                    Temperature: 69.0°C
                    Voltage: 13.335 V
001057 - Warm Up Catalyst; Bank 1
               P0421 - 002 - Efficiency Below Threshold - Intermittent
                    Mileage: 141045 km
                    Date: 2007.10.26
                    Time: 00:05:42
                    RPM: 2670 /min
                    Load: 34.5 %
                    Speed: 90.0 km/h
                    Temperature: 88.0°C
                    Temperature: 36.0°C
                    Voltage: 13.970 V
001073 - Warm Up Catalyst; Bank 2
               P0431 - 002 - Efficiency Below Threshold
                    Fault Status: 01100010
                    Mileage: 141045 km
                    Date: 2007.10.26
                    Time: 00:05:42
                    RPM: 2659 /min
                    Load: 33.3 %
                    Speed: 90.0 km/h
                    Temperature: 88.0°C
                    Temperature: 36.0°C
                    Voltage: 13.843 V
Readiness: 0000 1101
   Part No SW: 8K0 907 379 J    HW: 8K0 907 379 J
   Component: ESP8 quattro  H03 0190
   Coding: 110500
   Shop #: WSC 06325 000 00000
   VCID: 408F0EB1D3DA7D46CA-8014
10 Faults Found:
                    Fault Status: 00101101
                    Fault Frequency: 37
                    Reset counter: 193
                    Mileage: 140681 km
                    Date: 2017.08.11
                    Time: 17:23:01
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0015
                    Hex Value: 0x0284
                    Hex Value: 0x00FF
01200 - ABS Valves Supply Voltage
            000 -  -  - Intermittent
                    Reset counter: 193
                    Mileage: 141039 km
                    Date: 2017.08.19
                    Time: 16:15:46
                    Hex Value: 0x0000
                    Hex Value: 0x0280
                    Hex Value: 0x0039
                    Hex Value: 0x8193
                    Hex Value: 0x00FF
                    Fault Frequency: 10
                    Reset counter: 193
                    Hex Value: 0x0000
                    Hex Value: 0x0780
                    Hex Value: 0x000E
                    Hex Value: 0xB994
                    Hex Value: 0x00FF
                    Fault Frequency: 10
                    Reset counter: 193
                    Hex Value: 0x0000
                    Hex Value: 0x2780
                    Hex Value: 0x0018
                    Hex Value: 0x6693
                    Hex Value: 0x00FF
                    Fault Frequency: 9
                    Reset counter: 193
                    Hex Value: 0x0000
                    Hex Value: 0x2280
                    Hex Value: 0x0022
                    Hex Value: 0x2395
                    Hex Value: 0x00FF
                    Fault Status: 00100101
                    Fault Frequency: 9
                    Reset counter: 193
                    Hex Value: 0x0000
                    Hex Value: 0x2280
                    Hex Value: 0x0022
                    Hex Value: 0x2A95
                    Hex Value: 0x00FF
                    Fault Frequency: 9
                    Reset counter: 193
                    Hex Value: 0x0000
                    Hex Value: 0x2280
                    Hex Value: 0x0018
                    Hex Value: 0x3795
                    Hex Value: 0x00FF
                    Fault Frequency: 9
                    Reset counter: 193
                    Hex Value: 0x0000
                    Hex Value: 0x2280
                    Hex Value: 0x0018
                    Hex Value: 0x1B95
                    Hex Value: 0x00FF
01794 - Control Module - Incorrect Chassis (VIN) Number
                    Fault Frequency: 9
                    Reset counter: 193
                    Hex Value: 0x0000
                    Hex Value: 0x2280
                    Hex Value: 0x0038
                    Hex Value: 0x1392
                    Hex Value: 0x00FF
                    Fault Frequency: 9
                    Reset counter: 193
                    Hex Value: 0x0000
                    Hex Value: 0x2280
                    Hex Value: 0x0022
                    Hex Value: 0x2395
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 289 G    HW: 8K0 907 289 G
   Component: BCM2.01       H38 0253
   Coding: 0F0000
   VCID: 3D717745A42810AEA1-8068
   Subsystem 1 - Part No SW: 8K0 905 852 A    HW: 8K0 905 852 A
   Component: ELVAUDIB8  H34 0039
   Serial number: 0207000000498014
02638 - Enabling Steering Column Lock
                    Fault Status: 00101001
                    Reset counter: 193
                    Mileage: 140852 km
                    Date: 2017.08.18
                    Time: 15:18:18
                    Fault Status: 01101101
                    Reset counter: 153
                    Mileage: 141039 km
                    Date: 2017.08.19
                    Time: 13:24:03
00166 - Access/Start Authorization Switch (E415)
                    Reset counter: 153
                    Mileage: 141038 km
                    Date: 2007.10.26
                    Time: 00:02:14
   Part No SW: 8T0 959 760     HW: 8T0 959 760
   Component: MEM-BFS       H08 0027
   Revision: AA000000    Serial number: 00001001021539
   Coding: 00017025002C44440000
   VCID: 55A1CFE53C58E8EE89-8000
                    Reset counter: 193
                    Mileage: 141039 km
                    Date: 2017.08.19
                    Time: 16:22:00
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 729 D    HW: 4E0 035 729 A
   Component: Interfacebox    H43 3010
   Revision: 00000000    Serial number: 340GO077503565
   Coding: 0025003
   Shop #: WSC 25167 444 52659
   VCID: 3A7B7C597506279684-806E
   Subsystem 1 - Part No: 8T0 919 609 D
   Component: E0380 BedienteilH07 0100
   Subsystem 2 - Serial number: 00000000010084
   Subsystem 3 - Serial number: 0129.06.070000000100010056ÿ
   Subsystem 4 - Serial number: 010056ÿ
   Part No SW: 8T1 820 043 R    HW: 8T1 820 043 R
   Component: KLIMA 3 ZONEN H05 0110
   Revision: C1000000    Serial number: 0113.08.070113
   Coding: 48022000
                    Reset counter: 193
                    Reset counter: 193
01844 - Control Module for Fresh Air Blower (J126)
                    Reset counter: 153
                    Temperature: 31.0°C
                    Speed: 5.1 km/h
                    Load: 100.0 %
                    Reset counter: 193
   Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
   Component: BCM1 1.0      H20 0253
   Revision: 05020001    Serial number: 00000000029571
   Coding: 26001091061CAF211700000300003D3D4F9C138800010161000000
   Shop #: WSC 25167 444 52656
   VCID: 306F5E71637AEDC63A-8064
   Subsystem 1 - Part No SW: 8T1 955 119 B    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 170707  H13 0040
   Serial number: SWFBIE 0000141
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8T0 955 559     HW: 4E0 955 559 B
   Component: RLS  H12 0001
   Serial number: 10012379
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 J    HW: 8K0 941 531 J
   Component: E1 - LDS  H07 0070
   Serial number: 00000000001407070154
   Subsystem 4 - Part No SW: 8K0 907 410 A    HW: 8K0 907 410 A
   Component: UGDO HL US  H04 0060
9 Faults Found:
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                    Fault Status: 00101100
                    Reset counter: 193
                    Mileage: 141039 km
                    Date: 2017.08.19
                    Time: 13:36:00
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                    Reset counter: 153
                    Mileage: 140792 km
                    Date: 2017.08.13
                    Time: 21:21:00
                    Reset counter: 193
                    Mileage: 141039 km
                    Date: 2017.08.19
                    Time: 16:00:00
                    Reset counter: 193
                    Mileage: 141039 km
                    Date: 2017.08.19
                    Time: 16:02:00
                    Reset counter: 193
                    Mileage: 141038 km
                    Date: 2017.08.19
                    Time: 09:13:00
                    Reset counter: 145
                    Mileage: 140537 km
                    Date: 2017.08.04
                    Time: 22:10:00
                    Reset counter: 193
                    Mileage: 140537 km
                    Date: 2017.08.04
                    Time: 22:10:00
01516 - Terminal 30; Left
                    Fault Status: 00101011
                    Reset counter: 193
                    Mileage: 141039 km
                    Date: 2017.08.19
                    Time: 16:16:00
00927 - Terminal 30 (Right)
                    Reset counter: 193
                    Mileage: 140851 km
                    Date: 2017.08.18
                    Time: 15:15:00
   Part No SW: 8T1 035 110 A    HW: 8T1 035 110 A
   Component: MP3-Changer     H41 0350
   Revision: 00041003    Serial number: AUZ5ZBG4018899
   VCID: 285FB6119BAAA506E2-807C
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 K    HW: 4E0 035 593 F
   Component: SDAR SIRIUS     H07 0140
   Revision: 00000000    Serial number: AUZ4Z7G0123908
   Coding: 0000100
   VCID: 2F6D5D0DBE44F23E23-807A
                    Reset counter: 117
                    Mileage: 139452 km
                    Date: 2017.06.22
                    Time: 10:27:16
   Part No SW: 8K0 919 475     HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0003
   Revision: 11001001    Serial number: 46130719903238
   Coding: 200002
   VCID: 76E3A869C19E83F6A0-8022
                    Reset counter: 193
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:17:51
                    Temperature: 43.0°C
                    Reset counter: 193
                    Time Indication: 15
                    Temperature: 0.0°C
   Part No SW: 8K0 959 655 C    HW: 8K0 959 655 C
   Component: AirbagVW-AU10 H23 0409
   Serial number: 0039GD10075B
   Coding: 303333333730303030304A55304C38543053
   Shop #: WSC 06435 000 00000
   ASAM Dataset: EV_AirbaECUVWAUDI010 A02001
   VCID: 3D717745AC2810AEA1-8068
   Subsystem 1 - Part No SW: 8K0 959 339     HW: 8K0 959 339
   Component: BF-Gewichtss.  H01 0040
   Serial number: 5810000R070000053V
   Serial number: 6334LSME175C4E70M
   Serial number: 6344LSME1570616DC
   Serial number: 6352QSME3207431DA
   Serial number: 6362QSME365113399
   Serial number: 63732SME34021205G
   Serial number: 63832SME354C0B2F9
9444097 - Front Passenger's Front Airbag Crash Sensor
          B101B 01 [136] - Electrical Failure
                    Mileage: 141006 km
                    Date: 2017.08.19
                    Time: 07:54:03
9444137 - Front Passenger's Front Airbag Crash Sensor
          B101B 29 [136] - Signal Implausible
                    Fault Frequency: 18
                    Mileage: 140671 km
                    Date: 2017.08.06
                    Time: 17:13:27
12583424 - Powertrain Databus
          U0002 00 [008] - No Communications
                    Reset counter: 193
9482752 - Seat Occupied Recognition
          B10B2 00 [008] - Function Restriction due to Missing Message(s)
                    Reset counter: 193
   Component: Lenks.Modul   H10 0012
   Revision: --------    Serial number: 90315GH90001C
   Coding: 000016
                    Reset counter: 40
                    Mileage: 141039 km
                    Date: 2017.08.19
                    Time: 13:23:59
                    Reset counter: 193
                    Reset counter: 193
                    Fault Frequency: 10
                    Reset counter: 193
                    (no units): 44.0
                    Text: 2C92FFFFFFFF00C0FF
                    Lambda Factor: 4.24
                    Raw, Index/Key Err.: 255 255 000
                    Text: 3E840000FFFFFFFFFF
                    T.B. Angle: 0.0°
                    Raw, Index/Key Err.: 255 255 255
   Part No SW: 8T0 920 980 P    HW: 8T0 920 980 P
   Component: KOMBIINSTR.   H28 0216
   Revision: 00000000    Serial number: 7LB270918
   Coding: 830F01000B00D705020000
   VCID: 489F1691FBEA450602-801C
   Part No SW: 8T0 907 468 F    HW: 8T0 907 468 F
   Component: GW-BEM 4CAN-M H07 0084
   Revision: EB002032    Serial number: 3200E07725808D
   Coding: 000003
   VCID: 448702A1C7C26166EE-8010
   Subsystem 1 - Part No SW: 8K0 915 181     HW: 8K0 915 181
   Component: J367-BDM  H06 0150
   Serial number: 17002BC5230707
02256 - Quiescent Current
                    Reset counter: 193
                    Mileage: 141039 km
                    Date: 2017.08.19
                    Time: 11:36:00
                    Reset counter: 193
                    Mileage: 141039 km
                    Date: 2017.08.19
                    Time: 16:15:23
Address 1E: Media Player 2 (R192)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 B    HW: 4E0 035 785 B
   Component: SG ext.Player H09 0700
   Revision: 00000000
   VCID: 275DB52D56B4AA7EEB-8072
   Component: MEM-FS        H08 0027
   Revision: AA000000    Serial number: 00001001019397
   Coding: 00197B25002C44440000
                    Reset counter: 193
                    Mileage: 141039 km
                    Date: 2017.08.19
                    Time: 16:22:00
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 M
   Component: MNS US          H50 1100
   Revision: 00000000    Serial number: 341Z0077502619
   VCID: 387F66514B0A358672-806C
   Part No SW: 8K0 959 793     HW: 8K0 959 793
   Component: TSG FA        H09 0149
   Revision:             Serial number: 0Gxa
   Coding: 011C13225E002201
   VCID: 7DF1B745E4A8D0AEE1-8028
                    Reset counter: 193
   Revision: 00002001    Serial number: 0105559302
   Coding: 0106069A007A44C500B000
   Subsystem 1 - Part No SW: 8K0 959 719     HW: 8K0 959 719
   Component: GTO BF  H06 0040
   Serial number: 00000000000000004061
                    Reset counter: 193
                    Mileage: 141039 km
                    Date: 2017.08.19
                    Time: 13:24:03
01512 - Control Module for Sliding Roof
                    Reset counter: 153
                    Mileage: 141039 km
                    Date: 2017.08.19
                    Time: 13:36:44
                    Reset counter: 193
                    Mileage: 141039 km
                    Date: 2017.08.19
                    Time: 16:15:23
                    Reset counter: 193
                    Mileage: 141039 km
                    Date: 2017.08.19
                    Time: 16:22:34
                    Reset counter: 193
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:15:32
   Part No SW: 8T0 035 223 M    HW: 8T0 035 223 C
   Component: DSP Prem      H12 0280
   Revision: 00H12003    Serial number: 34813000405402
   Coding: 020101
   Shop #: WSC 12336 024 394758
   VCID: 387F66518B0A358672-806C
03278 - Functionality Limited due to Missing Messages
                    Reset counter: 175
                    Voltage: 11.50 V
                    Temperature: 30.0°C
                    Temperature: 36.0°C
                    Bin. Bits: 01000000
                    Bin. Bits: 00010000
                    Bin. Bits: 00000000
   Part No SW: 8K0 959 792     HW: 8K0 959 792
   Component: TSG BF        H09 0149
   Revision:             Serial number: 0sTa
   VCID: 7CF7BA41FFB2D9A6D6-8028
                    Reset counter: 193
   Part No SW: 8K0 907 801 C    HW: 8K0 907 801 C
   Component: EPB Audi B8   H03 0040
   Revision: 00000003    Serial number: 00000000013502
   VCID: 2F6D5D0D7E44F23E23-807A
6 Faults Found:
                    Reset counter: 193
                    Voltage: 11.90 V
                    Count: 84
                    Hex Value: 0x0270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Reset counter: 193
                    Voltage: 11.90 V
                    Count: 67
                    Hex Value: 0x0270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Status: 11101101
                    Reset counter: 153
                    Mileage: 140681 km
                    Date: 2017.08.06
                    Time: 17:55:05
                    Voltage: 12.00 V
                    Count: 80
                    Hex Value: 0x0273
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Reset counter: 193
                    Voltage: 11.90 V
                    Count: 81
                    Hex Value: 0x4070
                    Hex Value: 0x0082
                    Hex Value: 0x0101
                    Reset counter: 193
                    Voltage: 11.90 V
                    Count: 64
                    Hex Value: 0x0270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Reset counter: 193
                    Voltage: 11.90 V
                    Count: 68
                    Hex Value: 0x0270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
Address 55: Headlight Range        Labels: 8T0-907-357.clb
   Part No SW: 8T0 907 357 A    HW: 4F0 907 357 F
   Coding: 0000017
   Shop #: WSC 25167 444 53701
   VCID: 3C777A417F3219A696-8068
7 Faults Found:
02071 - Local Databus
                    Fault Status: 00101110
                    Fault Frequency: 14
                    Reset counter: 193
                    Mileage: 141034 km
                    Date: 2017.08.19
                    Time: 08:17:35
01771 - Control Module for Headlight Range (J431)
                    Reset counter: 193
                    Mileage: 141034 km
                    Date: 2017.08.19
                    Time: 08:17:53
                    Reset counter: 193
                    Mileage: 141034 km
                    Date: 2017.08.19
                    Time: 08:19:42
02233 - Left Headlight Power Output Stage (J667)
                    Reset counter: 193
                    Mileage: 141039 km
                    Date: 2017.08.19
                    Time: 15:48:13
                    Reset counter: 193
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:17:51
                    Reset counter: 193
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:15:38
                    Reset counter: 193
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:17:51
   Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
   Revision: 00000000    Serial number: 336GW077513756
   VCID: 2E534009B94EFB3628-807A
Address 65: Tire Pressure (J502)       Labels:. 8K0-907-273.clb
   Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
   Component: J502-RDK      H03 0240
   Revision: 00001001    Serial number: 12822707050161
   Coding: 0CD154
                    Reset counter: 193
                    Mileage: 141071 km
                    Date: 2007.10.26
                    Time: 01:07:57
                    Bin. Bits: 00001000 00100101
                    Voltage: 12.50 V
                    Text:  26,0°C;n.erkannt;     n.erkannt
                    Fault Frequency: 52
                    Reset counter: 193
                        Not Recogn.
                    Voltage: 12.00 V
                    Text:   -50°C;n.erkannt;     n.erkannt
                    Reset counter: 193
                        Not Recogn.
                    Bin. Bits: 00001000 00100100
                    Voltage: 11.90 V
   Part No SW: 8T0 907 441     HW: 4L0 907 441 A
   Revision: --H12---    Serial number: 525PA8-J77500F
   Coding: 1000008
   VCID: 75E1AF651C9888EEA9-8020
                    Reset counter: 193
                    Mileage: 141039 km
                    Date: 2017.08.19
                    Time: 16:22:07
                        Term 15 Off
                        Reverse OFF
                    Count: 3
                    Fault Frequency: 15
                    Reset counter: 193
                        Term 15 Off
                        Reverse OFF
                    Count: 3
                    Reset counter: 193
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:15:28
                        Reverse OFF
                    Count: 3
   Part No SW: 4F0 910 336 E    HW: 4E0 862 335
   Component: Handyvorb2      H00 0950
   Coding: 0010900
   VCID: 2541BF25ECB8B86ED9-8070
End-------------------------(Elapsed Time: 03:37)--------------------------
Thanks,
-Tom
Did anything happen (or was any work done to the car) on 2017.08.19?
Almost all your fault codes are flagged "Intermittent". That means the fault condition that set the code did not exist (or could not be detected) at the time the scan was performed. A whole lot of them have the above date stamp though..
I'm not seeing an obvious common thread, but I'm not a B8 expert, and it does seem likely there is one.
tomieg
New Member
Hey Uwe!
Yes, unfortunately my car suffered some damage to the right headlight wiring harness which since has been repaired and I'm now chasing down these error codes.
Thanks,
-Tom
If repairs have been made since 2017.08.19 (which was only two days ago!) I would clear all the fault codes and see what (if anything) comes back.
tomieg
New Member
Hmm, yeah that's a good point! I will give that a try and keep you guys posted! Thanks Uwe!
tomieg
New Member
Ok guys. Good news is after clearing the initial DTC's and re scanning more than half of the errors are gone! Please see the existing errors below. There still seems to be some sort of communications error going on...i'm going to double check all the positioning for the fuses.
   Revision: 76H10---
19 Faults Found:
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:15:27
                    RPM: 1539 /min
                    Load: 22.0 %
                    Temperature: 99.0°C
                    Temperature: 67.0°C
                    Voltage: 12.192 V
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:15:27
                    RPM: 1539 /min
                    Load: 22.0 %
                    Temperature: 99.0°C
                    Temperature: 67.0°C
                    Voltage: 12.192 V
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:15:27
                    RPM: 1539 /min
                    Load: 25.9 %
                    Temperature: 99.0°C
                    Temperature: 67.0°C
                    Voltage: 12.319 V
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:15:27
                    RPM: 1238 /min
                    Load: 24.7 %
                    Temperature: 99.0°C
                    Temperature: 66.0°C
                    Voltage: 12.319 V
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:15:28
                    RPM: 1201 /min
                    Load: 23.9 %
                    Temperature: 99.0°C
                    Temperature: 66.0°C
                    Voltage: 12.319 V
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:15:28
                    RPM: 1201 /min
                    Load: 23.9 %
                    Temperature: 99.0°C
                    Temperature: 66.0°C
                    Voltage: 12.319 V
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:17:51
                    RPM: 612 /min
                    Load: 42.3 %
                    Temperature: 93.0°C
                    Temperature: 69.0°C
                    Voltage: 13.589 V
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:17:51
                    RPM: 612 /min
                    Load: 42.3 %
                    Temperature: 93.0°C
                    Temperature: 69.0°C
                    Voltage: 13.589 V
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:17:51
                    RPM: 612 /min
                    Load: 42.3 %
                    Temperature: 93.0°C
                    Temperature: 69.0°C
                    Voltage: 13.589 V
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:17:51
                    RPM: 601 /min
                    Load: 41.2 %
                    Temperature: 93.0°C
                    Temperature: 69.0°C
                    Voltage: 13.589 V
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:17:51
                    RPM: 601 /min
                    Load: 41.2 %
                    Temperature: 93.0°C
                    Temperature: 69.0°C
                    Voltage: 13.589 V
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:17:51
                    RPM: 601 /min
                    Load: 41.2 %
                    Temperature: 93.0°C
                    Temperature: 69.0°C
                    Voltage: 13.589 V
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:17:51
                    RPM: 601 /min
                    Load: 41.2 %
                    Temperature: 93.0°C
                    Temperature: 69.0°C
                    Voltage: 13.589 V
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:17:51
                    RPM: 601 /min
                    Load: 41.2 %
                    Temperature: 93.0°C
                    Temperature: 69.0°C
                    Voltage: 13.589 V
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:17:51
                    RPM: 601 /min
                    Load: 40.4 %
                    Temperature: 93.0°C
                    Temperature: 69.0°C
                    Voltage: 13.462 V
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:17:51
                    RPM: 606 /min
                    Load: 37.6 %
                    Temperature: 93.0°C
                    Temperature: 69.0°C
                    Voltage: 13.335 V
                    Mileage: 141042 km
                    Date: 2017.08.19
                    Time: 18:17:51
                    RPM: 606 /min
                    Load: 38.4 %
                    Temperature: 93.0°C
                    Temperature: 69.0°C
                    Voltage: 13.335 V
                    Mileage: 141045 km
                    Date: 2007.10.26
                    Time: 00:05:42
                    RPM: 2670 /min
                    Load: 34.5 %
                    Speed: 90.0 km/h
                    Temperature: 88.0°C
                    Temperature: 36.0°C
                    Voltage: 13.970 V
                    Mileage: 141045 km
                    Date: 2007.10.26
                    Time: 00:05:42
                    RPM: 2659 /min
                    Load: 33.3 %
                    Speed: 90.0 km/h
                    Temperature: 88.0°C
                    Temperature: 36.0°C
                    Voltage: 13.843 V
   Coding: 48022000
                    Reset counter: 153
                    Mileage: 141071 km
                    Date: 2007.10.28
                    Time: 00:08:54
                    Temperature: 24.0°C
                    Load: 100.0 %
   Coding: 00FD11
   Coding: 02532C
                    Reset counter: 153
                    Mileage: 141071 km
                    Date: 2007.10.28
                    Time: 00:08:00
03207 - Charisma Switch Module
                    Reset counter: 153
                    Mileage: 141071 km
                    Date: 2007.10.28
                    Time: 00:08:00
                    Reset counter: 153
                    Mileage: 141071 km
                    Date: 2007.10.28
                    Time: 00:08:56
                    Reset counter: 193
                    Mileage: 141071 km
                    Date: 2007.10.28
                    Time: 00:08:52
                    Voltage: 11.90 V
                    Count: 80
                    Hex Value: 0x0273
                    Hex Value: 0x0001
                    Hex Value: 0x1010
tomieg
New Member
So it looks like i'm missing some fuses or they're in the wrong spot...
tomieg
New Member
So i was playing around with the fuse box yesterday and noticed that I was missing fuses and or they were in the incorrect location...
Can anyone clarify which direction the fuse order should be read? The vehicle diagram depicts bottom to top while the panel in the car indicated a top down approach. Very confusing...
NZDubNurd
New Zealand
C?ID=230482
One thing to look for: Places that should probably have a fuse, will have terminals inserted in both sides - lots will only have a terminal in one side, or none - they won't do anything with a fuse in them :-)
tomieg
New Member
Hey guys,
Just to bring some closure this thread all was sorted once the fuses were moved back to their original locations :)
Thanks,
-Tom
