- Joined
- May 1, 2016
- Messages
- 32
- Reaction score
- 14
- Location
- South Africa
- VCDS Serial number
- C?ID=117317
I managed to successfully code ALA on my 2018 Audi SQ5. I purchased a used steering stalk (with the button at the tip of the indicator stalk to turn ALA on/off) on e-Bay. Everything is working fine as far as ALA is concerned, but when I turn the vehicle on, I get a "Heated Steering Wheel Malfunction" warning. It appears that the donor vehicle had a heated steering wheel.
My understanding is that I should change the coding of Module 16, but the "Coding" button of Module 16 is greyed out.
I hoped that if I fit my vehicle's original slip ring to the stalk assembly, it may resolve the problem, but it makes no difference - still getting the Heated Steering Wheel Malfunction warning when turning on the vehicle.
Is the steering control unit (16) part of the stalk assembly? And if so, is there a way to code it or is my only solution to look for a stalk assembly of a vehicle without a heated steering wheel?
This is the result in respect of Module 16 of the scan I had done when I got the vehicle:
And here is a complete current scan of the vehicle:
I hope there is another solution apart from buying another steering stalk assembly.
Address 16: Steering wheel (J527) Labels: None
Part No SW: 80A 907 129 AD HW: 80A 907 129 AD
Component: Lenks.Modul H02 0003
ROD: EV_SMLSKLOAU736_007_AU49.rod
VCID: 6A98079E8D6A521634-803E
Sunday,20,August,2017,17:44:45:05563
VCDS Version: 17.8.0.1 (x64) HEX-NET CB: 0.4401.4
Dealer/Shop Name: Audi
Workshop Code: 7xx 02xxx 000200
VIN: WAUZZZFY8H20xxxxx License Plate:
Chassis Type: FY-AU49 (4M2)
Scan: 01 02 03 08 09 13 15 16 17 19 29 36 39 3C 42 44 46 47 52 5F
69 6C 6D 74 81 82 8B A5 A9 BB BC CF D6 D7
VIN: WAUZZZFY8H2040032 Mileage: 472km-293miles
Address 01: Engine (J623-CWGD) Labels: None
Part No SW: 80A 907 559 B HW: 06M 907 309 D
Component: 3.0l V6 TFSI H21 0003
Revision: B2H21000
Coding: 2A2A0032257E050B34380000000000000000000000000000
ASAM Dataset: EV_ECM30TFS01180A907559B 001003
ROD: EV_ECM30TFS01180A907559B.rod
VCID: 2E10CB8E7102FE3628-807A
Readiness: 1110 0001
Address 02: Auto Trans (J217) Labels:* None
Part No SW: 80A 927 158 HW: 0D5 927 156 H
Component: 0D5 30TSIRdW H05 1002
Revision: --H05---
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002010
ROD: EV_TCMALX52011_AU49.rod
VCID: 699A7892886C590E3D-803C
Part No SW: 80A 907 379 F HW: 80A 907 379 A
Component: ESP9 Premium H09 0657
Coding: 1CAA14BE30A60A96D19E5894187F52A2E6A5CA38280C508B1A184A4567A553
ASAM Dataset: EV_ESP9BOSCHAU426K 011013
ROD: EV_ESP9BOSCHAU426K.rod
VCID: 3228DFFE653ADAD64C-8066
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 80A 820 043 H HW: 80A 820 043 H
Component: Klima Zone 3 H32 0090
Coding: 6608000C5544450D02000100080000000000000000000000000000000000
ROD: EV_AirCondiBHTCAU491.rod
VCID: 22082FBE35DA4A56BC-8076
Subsystem 1 - Part No SW: 4M1 820 021 A HW: 4M1 820 021 A
Component: J216 FLuftV H08 0003
Serial number: 00000000000001315601
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0006
Serial number: D018859880PAG0MUFU02
Subsystem 3 - Part No SW: 80A 919 158 HW: 80A 919 158
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Coding: 07501943C13900CD050F51199F3F08F9130B31080000000000000000600016810A4502AB22B70A
Shop #: WSC 12345 123 61029
ROD: EV_BCM1BOSCHAU736_018.rod
VCID: 02484F3E951AAA569C-8056
Subsystem 1 - Part No SW: 80C 955 119 HW: 80C 955 119
Component: 426 RL 170303 040 0570
Serial number: 00000001702272101671
Coding: 5FC7F7
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 20344511X81A955555A0
Coding: 02006E
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 AB HW: 4M0 941 531 AB
Component: E1 - LDS H06 0008
Serial number: 13 05 2017 71330162
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE112041723610609
Coding: 210000
Interior Light Module:
Subsystem 5 - Part No SW: 80A 947 135 D HW: 80A 947 135
Component: Dachmodul Q5 H31 0310
Serial number: Q00001610
Coding: 010104
Subsystem 6 - Part No SW: 8W0 925 301 BG HW: 8W0 925 301 BG
Component: SL-B9/Q5NF H17 0010
Serial number: 2617000090817001
Subsystem 7 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V512 LLR1SLvL H03 0012
Serial number: L14DH08201691
Subsystem 8 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V514 LLR1SKvL H03 0012
Serial number: L14DH08201266
Subsystem 9 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V516 LLR1SLvR H03 0012
Serial number: L14DH08201711
Subsystem 10 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V518 LLR1SKvR H03 0012
Serial number: L14DH08201274
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 80A 907 561 HW: 8W0 907 561
Component: LRR4 H10 0220
Coding: 3464E75B58FFEC06747860A4
ASAM Dataset: EV_ACCBOSCHAU49X 002018
ROD: EV_ACCBOSCHAU49X_002.rod
VCID: 658274A264747D6E19-8030
2121 - Databus
U1122 00 [009] - Implausible Message
Reset counter: 18
Mileage: 472 km
Date: 2017.08.20
Time: 17:14:52
Control Module temperature: 44 °C
Voltage terminal 15: 11.9 V
Address 15: Airbags (J234) Labels:* None
Part No SW: 80A 959 655 N HW: 80A 959 655 N
Component: AirbagVW30 031 0513
Serial number: 003WBM018U1M
Coding: AACCF00000800000980000FFF08C40000065
ASAM Dataset: EV_AirbaVW31SMEAU65x 001006
ROD: EV_AirbaVW31SMEAU65x_AU49.rod
VCID: 3E30FBCEA1620EB6B8-806A
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 HW: 4M0 980 945
Component: BeltPretRevFL 205 2033
Serial number: 80A857705A0054R00483
Coding: 88001B
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2033
Serial number: 80A857706A0054R01857
Coding: 88001B
Subsystem 3 - Part No SW: ----------- HW: 480 001 003 17
Serial number: 35700000000AA254F12L
Subsystem 4 - Part No SW: ----------- HW: 480 001 103 17
Serial number: 35800000000D2350F12E
Subsystem 5 - Part No SW: ----------- HW: 480 032 303 17
Component: SideSensor_Dr 002 0149
Serial number: 351000C20ECBDD8089B-
Subsystem 6 - Part No SW: ----------- HW: 480 032 303 17
Component: SideSensor_Pr 002 0149
Serial number: 352000C20EC21171481W
Subsystem 7 - Part No SW: ----------- HW: 480 033 003 17
Component: FrontSensor_D 002 0149
Serial number: 355000C20469AA810997
Front Sensor Passenger:
Subsystem 8 - Part No SW: ----------- HW: 480 033 003 17
Component: FrontSensor_P 002 0149
Serial number: 356000C20461A880EACF
Central Sensor XY:
Subsystem 9 - Part No SW: ----------- HW: 480 022 302 17
Component: CentrSensorXY 000 0108
Serial number: I0O0001C12465B5432FR
Part No SW: 80A 907 129 AN HW: 80A 907 129 AN
VCID: 74A419E6DFAE94E69E-8020
Address 17: Instruments (J285) Labels:* 8W5-920-xxx-17.clb
Part No SW: 8W5 920 790 C HW: 8W5 920 790 C
Component: FBenRDW H17 0313
Coding: 248D96C47C98000801A3E9481000200000000000
ASAM Dataset: EV_DashBoardAU736 001022
ROD: EV_DashBoardAU736.rod
VCID: 42C88F3ED59A6A56DC-8016
Part No SW: 4M2 907 468 D HW: 4M2 907 468 A
Component: Gateway H16 0107
Revision: 4W010003 Serial number: 03G4W004817419
Coding: 03010001000086405407000008590032FC120000180000000100000000000000
ASAM Dataset: EV_GatewCONTIAU736 002040
ROD: EV_GatewCONTIAU736_002.rod
VCID: 393AE8D2B84C298E8D-806C
Subsystem 1 - Part No SW: 80A 951 523 D HW: 80A 951 523 D
Component: J453 MFL H06 0002
Serial number: 20170427160422 00495
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 0001325100
Address 29: Left Light (J1018) Labels: None
Part No SW: 80A 907 397 D HW: 80A 907 397 D
Component: LCM_MLBevo H06 0017
ASAM Dataset: EV_LCMLeftCONTIAU426 001009
ROD: EV_LCMLeftCONTIAU426_AU49.rod
VCID: 302CD5F66B36E8C63A-8064
Address 36: Seat Mem. Drvr (J136) Labels:* None
Part No SW: 4M1 959 760 HW: 4M1 959 760
Component: MEM-FS 008 0031
Serial number: 512A1471180351
Coding: 00781B000000B0010000010101010000000000000000000000000000000000
ROD: EV_SCMDriveSideCONTIAU736_AU37.rod
VCID: 76A023EEC9D286F6A0-8022
Address 39: Right Light (J1023) Labels: None
ASAM Dataset: EV_LCMRightCONTIAU426 001009
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4M0 907 566 D HW: 4M0 907 566
Component: MRR1Rear H18 0410
Revision: --------
Coding: 5EC002
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
ROD: EV_RearRadarS1BoschAU736.rod
VCID: 3620E3EE8952C6F660-8062
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M1 959 793 B HW: 4M1 959 793 B
Component: TSG FS006 0737
Serial number: CLSM1QDM002ZP
Coding: 005D9A015E010480000110B2
ROD: EV_DCU2DriveSideMAXHKLO_AU49.rod
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 4M0 909 144 H HW: 4M0 909 144 B
Component: EPS_MLBEVO1BS H20 0005
Serial number: 0000727647
Coding: B0112101000100
ASAM Dataset: EV_EPSVWBSAU736 009023
ROD: EV_EPSVWBSAU736_009.rod
VCID: 3424D9E69F2ED4E65E-8060
5570561 - Databus
Reset counter: 18
Mileage: 472 km
Date: 2017.08.20
Time: 17:14:52
Dynamic environmental data: 12 12
FreezeFrame_mw_1212-Vehicle speed: 0 km/h
FreezeFrame_mw_1212-Error Mask driver assistance functions: 00 00
FreezeFrame_mw_1212-Eventmask_IMS: 80 00
FreezeFrame_mw_1212-IMS Status AWA: 03
FreezeFrame_mw_1212-IMS Status DSR: 03
FreezeFrame_mw_1212-IMS Status HCA: 03
FreezeFrame_mw_1212-IMS Status STA: 04
FreezeFrame_mw_1212-Internal torque: 0.00
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 CP HW: 8W0 907 064 P
Component: BCM2 MLBevo 018 0344
Coding: 013500004F110040630980000E00D80033004010004002502F0000000504803F001F0003020000
ASAM Dataset: EV_BCM2HellaAU736 012013
ROD: EV_BCM2HellaAU736_012.rod
VCID: 0C546106A75EEC26E6-8058
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY170382A53
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000068794813
Subsystem 3 - Part No SW: 3G0 962 243 B HW: 3G0 962 243 B
Component: GEB.F.Heckoef H17 0904
Serial number: 58050466
Address 47: Sound System (J525) Labels:* None
Part No SW: 80A 035 223 A HW: 80A 035 223
Component: MIB2_amp_P_Q5 H03 0420
Revision: 00000001 Serial number: AUZ8ZAGTK00ESQ3
Coding: 0194010800AFAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
ROD: EV_AMPMst16C2Gen2ALPI_AU49.rod
VCID: 197A0852188C098E6D-804C
Part No SW: 4M1 959 792 B HW: 4M1 959 792 B
Component: TSG BFS006 0737
Serial number: CLSM1QDI009K0
Coding: 005D9A015E010480000110B0
ROD: EV_DCU2PasseSideMAXHKLO_AU49.rod
VCID: 3D32FCC2AC6415AEA1-8068
Part No SW: 8W5 035 039 HW: 8W5 035 039
Component: MU-P-LN-RW 033 0917
Serial number: A801E0H9270264
Coding: 012456090000000013110002000A00332F001AE601700100FE
VCID: 78BC2DD6C3C6F086B2-802C
Subsystem 1 - Part No SW: V03 959 801 PT HW: -----------
Component: ROW 2017/2018 --- 0065
Subsystem 2 - Part No SW: 80A 919 605 HW: 80A 919 605
Component: AU426_DU_HIGH H42 0008
Serial number: AUZ8Z9HBL01312
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 80A 919 615 HW: 80A 919 615
Component: ControlUnit_P H15 0209
Serial number: 16031700000000000468
Component: Gracenote2 --- 4011
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 4M0 907 383 D HW: 4M0 907 383 B
Component: Anhaenger H20 0216
Revision: 9A001003 Serial number: 0434157910
Coding: 0110000202000000
VCID: 3326DAFA9A20D3DE47-8066
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4M0 907 428 E HW: 4M0 907 428
Component: Areaview 2 H13 0315
Serial number: C854607JG013312
Coding: 02240601BF0FA10008404080
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
Address 6D: Trunk Elect. (J605) Labels:* None
Part No SW: 8W8 959 107 B HW: 8W8 959 107
Component: HDSG-Modul H13 0161
Revision: -------- Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Coding: 07B0
VCID: 48DC9D16F3A6400602-801C
Address 74: Chassis Control (J775) Labels:* None
Part No SW: 80A 907 777 M HW: 80A 907 777 C
Component: Fahrwerk-SG H35 1214
Serial number: 0804170307
Coding: 90503032F8
ASAM Dataset: EV_ChassContrContiAU426 001003
ROD: EV_ChassContrContiAU426_VW53.rod
VCID: 3B36F2DAB2701B9E9F-806E
Air Suspension Compressor:
Subsystem 1 - Part No SW: 4M0 907 778 HW: 4M0 907 778
Component: V66LFKompOLV H06 0013
Serial number: 00000000004130105279
Coding: 303030
Address 81: Gear Shift (J587) Labels: None
Part No SW: 80C 713 041 K HW: 80C 713 041 K
Component: GSM-LL H09 0073
Revision: 0L0D5012 Serial number: 20170403000544
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 260033AE59F2B676D0-8072
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 80A 919 617 A HW: 80A 919 617 A
Component: HeadUpDisplay H11 1640
Coding: 4E01C0
ASAM Dataset: EV_HudNSEIKAU736 001017
ROD: EV_HudNSEIKAU736_AU49.rod
VCID: 2B16C29A42108B1E0F-807E
Address 8B: Adaptive Cruise 2 (J850) Labels: None
Part No SW: 80A 907 541 HW: 8W0 907 541
ASAM Dataset: EV_ACC2BOSCHAU49X 002018
ROD: EV_ACC2BOSCHAU736_002_AU73.rod
VCID: 63866ABA6A40035EF7-8036
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 80A 907 217 HW: 80A 907 217
Component: BVS H14 0042
Coding: 0405020600000404024023A7CD00000090000020C280
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 80A 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 170228203692
ROD: EV_SoundActuaGen2AU64X_VW26.rod
VCID: 689C7D969366600622-803C
Part No SW: 4M1 959 795 B HW: 4M1 959 795 B
Component: TSG HFS006 0737
Serial number: CLSM1QD500A2Z
Coding: 000D980000010480000010A0
VCID: 40CC8536DB967846CA-8014
Component: TSG HBFS006 0737
Serial number: CLSM1QD500A2L
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 4M0 907 590 D HW: 4M0 907 590
Revision: --------
Coding: 5EC002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
ROD: EV_RearRadarS2BoschAU736.rod
Address D6: Light Ctrl Left 2 (A31) Labels: None
Part No SW: 7PP 941 592 CB HW: 7PP 941 592 C
Component: LED1L H10 2003
ROD: EV_LEDModLeftMELCOAU736_AU49.rod
VCID: 1A78175E1D8A029664-804E
Address D7: Light Ctrl Right 2 (A27) Labels: None
Component: LED1R H10 2003
End----(Elapsed Time: 02:19, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
