Hi
It seems my engine ecu has had better days.
Could someone please advise how do I go about replacing it? Say I can find a second hand one form a wrecker, what do I do next? Plug it in and then what? How do I code it properly? What adaptation will be required?
Big thanks in advance!
Thursday,10,August,2017,16:45:45:15919
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
VCDS Version 17.8.0.1 (x64)
Mileage: 134224km-83402mi Repair Order:
Chassis Type: 7P6
Scan: 01 02 03 05 08 09 10 15 16 17 19 2E 42 46 52 53 56 62 72 77
A7
Mileage: 134224km-83402miles
01-Engine -- Status: Cannot be reached 0100
2E-Media Player 3 -- Status: Malfunction 0010
A7-Infotain. Interface -- Status: Malfunction 0010
Address 01: Engine
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 AM HW: 0C8 927 750 AM
Component: AL1000 AISIN 001 1932
Coding: 001568
Shop #: WSC 05787 002 1048576
ASAM Dataset: EV_TCMAL991031 002112
ROD: EV_TCMAL991031_002.rod
VCID: 77FC6EAACEF36BFEBB-8023
12809 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [039] - -
Reset counter: 0
Engine speed: 30.0 /min
Transmission input speed: 330 /min
Transmission output speed: 180 /min
Engine torque: -60 Nm
Transmission fluid temperature: 30 ∞C
Accelerator position: 0.0 %
Clutch status: closed
Clutch status: Open
Clutch status: Open
Clutch status: Open
Clutch status: Open
Clutch status: Open
Clutch status: Open
EOP failure status: Normalcy
EOP target revolution: 0 /min
EOP actual revolution: 65279 /min
Engine Speed signal Current: 65279 /min
EOP failure status with EOP without HV: Motor normal stop
EOP target current: 65278 mA
Address 03: ABS Brakes (J104) Labels:| 7P0-907-379.clb
Part No SW: 7P0 907 379 K HW: 7P0 907 379 A
Component: MK25A H36 0418
Revision: -------- Serial number: 419810010EC010
Coding: 5B6B13C349252554DAF5C89992DBA4507700
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_MK25AXT 007001
ROD: EV_ESPMK25A00700.rod
VCID: 4580D462C49FC96EF9-8011
336388 - Databus
U1121 00 [137] - Missing Message
Reset counter: 128
Mileage: 134224 km
Date: 2017.05.10
Time: 18:14:02
Standard Freeze Frame Dynamic: 00 3D 03 57 28 00 00 00 05 00 03 20 02
Part No SW: 4H0 907 064 BE HW: 4H0 907 064 BE
Component: BCM2 2.0 H31 0330
Coding: 01B60000000000000000
VCID: 6DD04CC2B4AFD12E51-8039
Subsystem 1 - Part No SW: 7P6 959 754 L HW: 7P6 959 754 L
Component: FBSTOUAREGIDG H05 0051
Serial number: 0811000080748004
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2311000131620011
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 128
Mileage: 134224 km
Date: 2017.05.10
Time: 18:14:03
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
Fault Frequency: 180
Reset counter: 168
Mileage: 134224 km
Date: 2017.05.12
Time: 10:39:59
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 BA HW: 7P6 907 040 BA
Component: Klima 2 Zonen H20 1203
Coding: 3626200890
VCID: 74E659A6DF8500E69E-8021
0331 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 128
Mileage: 134224 km
Date: 2017.05.10
Time: 18:14:03
Voltage terminal 30-Data: 12.2 V
Outside air temperature-Data: 10.00 ∞C
U1101 00 [008] - Active
Reset counter: 77
Mileage: 130801 km
Date: 2017.03.18
Time: 04:42:29
Voltage terminal 30-Data: 8.3 V
Component protection-Data: 31
0247 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Fault Frequency: 6
Reset counter: 134
Mileage: 131797 km
Date: 2017.04.04
Time: 11:17:57
Outside air temperature-Data: 21.50 ∞C
Engine speed-Data: 0 /min
0386 - Functional Limitation due to Energy Management
B10CD 00 [008] - -
Reset counter: 168
Mileage: 134224 km
Date: 2017.05.12
Time: 09:00:04
Voltage terminal 30-Data: 11.3 V
Outside air temperature-Data: 6.00 ∞C
Interior temperature-Data: 4.90 ∞C
Energy management deactivation stage-Data: 1
Part No SW: 4H0 907 063 BD HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0100
Revision: 15012002 Serial number: 00000001162480
Coding: 6900001181345D010005000300005F5F431D460807000241000000000000
VCID: 6BD442DA8ABBDF1E4F-803F
Subsystem 1 - Part No SW: 7P0 955 120 HW: 955 120
Component: WWS 100619 31 0020
Serial number: 90243401100622035942
Coding: 013F93
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: RLFS H09 0011
Serial number: 10204511
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 B HW: 7P6 941 431 B
Component: E1 - LDS H04 0031
Serial number: 00000000003006110131
Fault Status: 01101100
Reset counter: 128
Mileage: 134224 km
Date: 2017.05.10
Time: 18:14:00
Reset counter: 128
Mileage: 134224 km
Date: 2017.05.10
Time: 18:14:00
Reset counter: 128
Mileage: 134224 km
Date: 2017.05.10
Time: 18:14:00
Reset counter: 128
Mileage: 134224 km
Date: 2017.05.10
Time: 18:13:00
Reset counter: 128
Mileage: 134226 km
Date: 2017.05.11
Time: 11:59:00
Reset counter: 128
Mileage: 134224 km
Date: 2017.05.10
Time: 18:14:00
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 B HW: 7N0 919 475
Component: PARKHILFE 8K H05 0021
Revision: -------- Serial number: 28291109466618
Coding: 108501
ASAM Dataset: EV_VW526ParkiAssis2 001011
ROD: EV_VW526ParkiAssis2.rod
VCID: 428ACF7ED5B1FE56DC-8017
1111316 - Speaker for Front Parking Aid
B10F5 14 [009] - Open or Short to Ground
Reset counter: 29
Mileage: 127869 km
Date: 2017.01.13
Time: 06:18:01
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 B HW: 7P0 959 655 B
Component: VW10Airbag00T H05 0023
Revision: -------- Serial number: 003JX003HKEN
Coding: 000000000000000000000000000000003054
ROD: EV_AirbaVW10BPAVW526_001.rod
VCID: 408EC576DBBDEC46CA-8015
Serial number: 3575LRB405T0ISD6996Y
Serial number: 3585LRB405T0ISD6GGQQ
Serial number: 3515RRB405N0LMIQNH4R
Serial number: 3525RRB405R0LMIQGHL%
Serial number: 3555NRB40530FAMEM98J
Serial number: 3565NRB40530FAME31I3
12 Faults Found:
9437211 - Igniter for Driver's Airbag
B1000 1B [137] - Resistance Too High
Mileage: 134224 km
Date: 2017.05.10
Time: 18:14:00
9440273 - Driver side knee airbag igniter
B100C 11 [136] - Short to Ground
Mileage: 134224 km
Date: 2017.05.10
Time: 18:14:27
9440283 - Driver side knee airbag igniter
B100C 1B [137] - Resistance Too High
Mileage: 134224 km
Date: 2017.05.10
Time: 18:14:00
9442587 - Igniter for battery interrupt
B1015 1B [137] - Resistance Too High
Mileage: 134224 km
Date: 2017.05.10
Time: 18:14:01
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [137] - Resistance Too High
Mileage: 134224 km
Date: 2017.05.13
Time: 00:11:32
9437713 - Igniter for Passenger's Airbag
B1002 11 [137] - Short to Ground
Mileage: 134224 km
Date: 2017.05.10
Time: 18:14:00
9438747 - Igniter for Seat Belt Tensioner; Driver's Side
B1006 1B [137] - Resistance Too High
Mileage: 134224 km
Date: 2017.05.10
Time: 18:14:00
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
B1007 1B [137] - Resistance Too High
Mileage: 134224 km
Date: 2017.05.10
Time: 18:14:00
9439515 - Seat Belt Tensioner Igniter; rear; driver's side
B1009 1B [137] - Resistance Too High
Mileage: 134224 km
Date: 2017.05.10
Time: 18:14:00
9439259 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
B1008 1B [137] - Resistance Too High
Mileage: 134224 km
Date: 2017.05.10
Time: 18:14:00
9447424 - Front crash data stored
B1028 00 [137] - -
Mileage: 134224 km
Date: 2017.05.10
Time: 18:13:58
9466352 - Crash Data from Belt Tensioner Stored
B1071 F0 [137] - Unknown Error Elaboration
Mileage: 134224 km
Date: 2017.05.10
Time: 18:13:58
Part No SW: 4H0 953 568 F HW: 7P6 953 507 L
Revision: -------- Serial number: 90815KGR0008W
Coding: 000015
VCID: 3662A3AE817952F660-8063
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0095038
00889 - Horn (H)
007 - Short to Ground
Fault Status: 01100111
Fault Frequency: 19
Reset counter: 128
Mileage: 134224 km
Date: 2017.05.10
Time: 18:14:59
Reset counter: 40
00532 - Supply Voltage B+
Reset counter: 40
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb
Part No SW: 7P6 920 880 P HW: 7P6 920 880 P
Component: Kombi H14 0248
Revision: 12240064 Serial number: 658290113592021
Coding: 3327310022000008000002
Shop #: WSC 22040 959 00000
ASAM Dataset: EV_KombiUDSRBVW526 001013
ROD: EV_KombiUDSRBVW526_VW52.rod
VCID: 489EDD56F38DD40602-801D
13635840 - Supply voltage
Reset counter: 168
Mileage: 134224 km
Date: 2017.05.12
Time: 15:42:37
16776971 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 128
Mileage: 134224 km
Date: 2017.05.10
Time: 18:14:02
Part No SW: 7P6 907 530 B HW: 7P6 907 530 B
Component: Gateway-CAN-L H08 5202
Revision: -------- Serial number: 00000000210829
Coding: 000D077500
ASAM Dataset: EV_GatewVW526UDS 001006
ROD: EV_GatewUDS_VW52.rod
VCID: 377CAEAA8E73ABFE7B-8063
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650926403
Voltage stabilizer:
6657 - Generator
U1052 00 [009] - No Communication
Reset counter: 128
Mileage: 134224 km
Date: 2017.05.10
Time: 18:14:02
Voltage terminal 30: 12.1 V
Voltage terminal 15: 12.2 V
Control Module temperature: 16 ∞C
System status: Terminal 15 on
Engine running: On
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
5712 - Radio
U1066 00 [008] - No Communication
Reset counter: 168
Mileage: 116443 km
Date: 2016.09.02
Time: 13:36:00
Voltage terminal 30: 13.1 V
Voltage terminal 15: 0.0 V
Control Module temperature: 12 ∞C
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status: OFF
Datenfeld: 0
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [009] - -
Reset counter: 128
Mileage: 134224 km
Date: 2017.05.10
Time: 18:14:01
Voltage terminal 30: 12.2 V
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
0017 - Supply voltage
Reset counter: 168
Mileage: 134224 km
Date: 2017.05.12
Time: 16:22:11
Voltage terminal 30: 8.3 V
Control Module temperature: 17 ∞C
System status: K-/Dash-CAN_MOST_active
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 0
12290 - Quiescent Current
U1406 00 [008] - Too High
Reset counter: 136
Mileage: 128861 km
Date: 2017.02.04
Time: 16:58:02
Voltage terminal 30: 12.5 V
Control Module temperature: 47 ∞C
System status: LIN_active
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 0
U140B 00 [008] - -
Fault Frequency: 15
Reset counter: 168
Mileage: 129945 km
Date: 2017.03.03
Time: 01:54:45
Voltage terminal 30: 12.4 V
Control Module temperature: 23 ∞C
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 1
Address 2E: Media Player 3 (J650) Labels: None
Part No SW: 7P6 035 342 C HW: 7P6 035 342 C
Revision: A1001003 Serial number: 7669620744
VCID: 316890B2681775CE35-8065
Reset counter: 168
Mileage: 134224 km
Date: 2017.05.12
Time: 14:49:05
Reset counter: 168
Mileage: 134224 km
Date: 2017.05.12
Time: 16:21:08
Part No SW: 4H0 959 793 N HW: 4H0 959 793 F
Component: TSG FA H07 0166
Revision: -------- Serial number: 0000117815978
Coding: 011D0620D001451005080000
VCID: 4486C966C7A5F066EE-8011
Revision: 00002001 Serial number: 0155131862
Coding: 0100162028B9009480200624000000000000000000000000000000000000
Subsystem 1 - Part No SW: 7P0 959 591 HW: 7P0 959 591
Component: J245 PS30.050 H07 0006
Serial number: WOO12778313
Coding: 191100
Subsystem 2 - Part No SW: 7P0 959 591 A HW: 4H0 959 591
Component: J394 PS30.050 H07 0006
Serial number: WOO12726653
Coding: 191100
00985 - Right Tail Light (M2)
Fault Status: 00101100
Reset counter: 136
Mileage: 132062 km
Date: 2017.04.05
Time: 09:48:07
00984 - Left Tail Light (M4)
Fault Frequency: 12
Reset counter: 168
Mileage: 133210 km
Date: 2017.04.24
Time: 07:26:26
Reset counter: 128
Mileage: 134224 km
Date: 2017.05.10
Time: 18:14:03
00230 - Transmission Park Selector Switch (F305)
008 - Implausible Signal
Fault Status: 01101000
Reset counter: 128
Mileage: 134224 km
Date: 2017.05.10
Time: 18:15:07
Reset counter: 40
Mileage: 134224 km
Date: 2017.05.12
Time: 16:25:56
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0162
Revision: -------- Serial number: 0000117798379
VCID: 3B74B29ABA5B8F9E9F-806F
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: A117060011F
Coding: 01040100
ROD: EV_ParkbA7.rod
VCID: 3662A3AE897952F660-8063
Slave 3:
12652544 - Supply voltage
Reset counter: 168
Mileage: 134224 km
Date: 2017.05.12
Time: 17:05:12
Voltage: 7.4 V
0018 - Switch for Electric Parking Brake
C100C 01 [009] - Electrical Failure
Voltage: 12.4 V
12656642 - Databus
Reset counter: 128
Mileage: 134224 km
Date: 2017.05.10
Time: 18:14:02
Voltage: 12.2 V
12656770 - Databus
Reset counter: 128
Mileage: 134226 km
Date: 2017.05.11
Time: 11:59:11
Voltage: 11.4 V
Address 56: Radio
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0162
Revision: -------- Serial number: 0000118463983
Coding: 011C06200001251005080000
VCID: 3A7AB79EB561B69684-806F
Component: TSG HR H09 0162
Revision: -------- Serial number: 0000118426845
Address 77: Telephone (J412) Labels:| 3C8-035-730-A.clb
Part No SW: 3C8 035 730 B HW: 3C8 035 730 B
Component: Telefon 011 0723
Revision: -------- Serial number: 35909603189691
Coding: 020000000100010000000000
ASAM Dataset: EV_UHVPremi A02003
ROD: EV_UHVPremi_A02.rod
VCID: 224A6FFE35F1DE56BC-8077
U1400 00 [008] - -
Fault Frequency: 31
Reset counter: 40
Mileage: 134224 km
Date: 2017.05.12
Time: 13:39:44
Reset counter: 40
Mileage: 134224 km
Date: 2017.05.12
Time: 16:05:23
Address A7: Infotain. Interface (J885) Labels:* None
Part No SW: 7P6 907 540 A HW: 1K0 907 951
Component: IF CAN Infot. H27 0012
Serial number: 100711F6000022
Coding: 04052602000000001003
ASAM Dataset: EV_InfotInterConti 001002
ROD: EV_InfotInterConti.rod
0017 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 168
Mileage: 134224 km
Date: 2017.05.12
Time: 16:01:10
4098 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 128
Mileage: 134224 km
Date: 2017.05.10
Time: 18:14:03
End-------------------------(Elapsed Time: 04:38)--------------------------
