VW Touareg 7P - 01-Engine -- Status: Cannot be reached 0100
sasha
Australia
C?ID=287611
Hi
It seems my engine ecu has had better days.
Could someone please advise how do I go about replacing it? Say I can find a second hand one form a wrecker, what do I do next? Plug it in and then what? How do I code it properly? What adaptation will be required?
Big thanks in advance!
Thursday,10,August,2017,16:45:45:15919
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
VCDS Version 17.8.0.1 (x64)
Mileage: 134224km-83402mi   Repair Order:
Chassis Type: 7P6
Scan: 01 02 03 05 08 09 10 15 16 17 19 2E 42 46 52 53 56 62 72 77
          A7
   Mileage: 134224km-83402miles
A7-Infotain. Interface -- Status: Malfunction 0010
Address 01: Engine
   Part No SW: 0C8 927 750 AM    HW: 0C8 927 750 AM
   Component: AL1000 AISIN  001 1932
   Coding: 001568
   Shop #: WSC 05787 002 1048576
   ROD: EV_TCMAL991031_002.rod
   VCID: 77FC6EAACEF36BFEBB-8023
12809 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [039] - -
                    Reset counter: 0
                    Engine speed: 30.0 /min
                    Transmission input speed: 330 /min
                    Transmission output speed: 180 /min
                    Engine torque: -60 Nm
                    Transmission fluid temperature: 30 ∞C
                    Accelerator position: 0.0 %
                    Clutch status: closed
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
                    EOP failure status: Normalcy
                    EOP target revolution: 0 /min
                    EOP actual revolution: 65279 /min
                    Engine Speed signal Current: 65279 /min
                    EOP failure status with EOP without HV: Motor normal stop
                    EOP target current: 65278 mA
Address 03: ABS Brakes (J104)       Labels:| 7P0-907-379.clb
   Part No SW: 7P0 907 379 K    HW: 7P0 907 379 A
   Component: MK25A         H36 0418
   Revision: --------    Serial number: 419810010EC010
   Coding: 5B6B13C349252554DAF5C89992DBA4507700
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 007001
   ROD: EV_ESPMK25A00700.rod
   VCID: 4580D462C49FC96EF9-8011
336388 - Databus
          U1121 00 [137] - Missing Message
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:02
                    Standard Freeze  Frame Dynamic: 00 3D 03 57 28 00 00 00 05 00 03 20 02
   Part No SW: 4H0 907 064 BE    HW: 4H0 907 064 BE
   Component: BCM2 2.0      H31 0330
   Coding: 01B60000000000000000
   VCID: 6DD04CC2B4AFD12E51-8039
   Subsystem 1 - Part No SW: 7P6 959 754 L    HW: 7P6 959 754 L
   Component: FBSTOUAREGIDG  H05 0051
   Serial number: 0811000080748004
   Serial number: 2311000131620011
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:03
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Fault Frequency: 180
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 10:39:59
   Part No SW: 7P6 907 040 BA    HW: 7P6 907 040 BA
   Component: Klima 2 Zonen H20 1203
   Coding: 3626200890
   VCID: 74E659A6DF8500E69E-8021
0331 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:03
                    Voltage terminal 30-Data: 12.2 V
                    Outside air temperature-Data: 10.00 ∞C
15360256 - Component Protection
          U1101 00 [008] - Active
                    Reset counter: 77
                    Mileage: 130801 km
                    Date: 2017.03.18
                    Time: 04:42:29
                    Voltage terminal 30-Data: 8.3 V
                    Component protection-Data: 31
0247 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 134
                    Mileage: 131797 km
                    Date: 2017.04.04
                    Time: 11:17:57
                    Outside air temperature-Data: 21.50 ∞C
                    Engine speed-Data: 0 /min
0386 - Functional Limitation due to Energy Management
          B10CD 00 [008] -  -
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 09:00:04
                    Voltage terminal 30-Data: 11.3 V
                    Outside air temperature-Data: 6.00 ∞C
                    Interior temperature-Data: 4.90 ∞C
                    Energy management deactivation stage-Data: 1
   Part No SW: 4H0 907 063 BD    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0100
   Revision: 15012002    Serial number: 00000001162480
   Coding: 6900001181345D010005000300005F5F431D460807000241000000000000
   VCID: 6BD442DA8ABBDF1E4F-803F
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 955 120
   Component: WWS    100619  31  0020
   Serial number: 90243401100622035942
   Coding: 013F93
   Component: RLFS  H09 0011
   Serial number: 10204511
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 B    HW: 7P6 941 431 B
   Component: E1 - LDS  H04 0031
   Serial number: 00000000003006110131
6 Faults Found:
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:13:00
                    Reset counter: 128
                    Mileage: 134226 km
                    Date: 2017.05.11
                    Time: 11:59:00
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 B    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0021
   Revision: --------    Serial number: 28291109466618
   Coding: 108501
   ASAM Dataset: EV_VW526ParkiAssis2 001011
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 428ACF7ED5B1FE56DC-8017
1111316 - Speaker for Front Parking Aid
          B10F5 14 [009] - Open or Short to Ground
                    Reset counter: 29
                    Mileage: 127869 km
                    Date: 2017.01.13
                    Time: 06:18:01
   Part No SW: 7P0 959 655 B    HW: 7P0 959 655 B
   Component: VW10Airbag00T H05 0023
   Revision: --------    Serial number: 003JX003HKEN
   Coding: 000000000000000000000000000000003054
   VCID: 408EC576DBBDEC46CA-8015
   Serial number: 3575LRB405T0ISD6996Y
   Serial number: 3585LRB405T0ISD6GGQQ
   Serial number: 3515RRB405N0LMIQNH4R
   Serial number: 3525RRB405R0LMIQGHL%
   Serial number: 3555NRB40530FAMEM98J
   Serial number: 3565NRB40530FAME31I3
12 Faults Found:
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
9440273 - Driver side knee airbag igniter
          B100C 11 [136] - Short to Ground
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:27
9440283 - Driver side knee airbag igniter
          B100C 1B [137] - Resistance Too High
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
9442587 - Igniter for battery interrupt
          B1015 1B [137] - Resistance Too High
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:01
9439771 - Front Passenger's Side Airbag Igniter
          B100A 1B [137] - Resistance Too High
                    Mileage: 134224 km
                    Date: 2017.05.13
                    Time: 00:11:32
9437713 - Igniter for Passenger's Airbag
          B1002 11 [137] - Short to Ground
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
          B1007 1B [137] - Resistance Too High
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
9439515 - Seat Belt Tensioner Igniter; rear; driver's side
          B1009 1B [137] - Resistance Too High
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
9439259 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
          B1008 1B [137] - Resistance Too High
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
9447424 - Front crash data stored
          B1028 00 [137] -  -
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:13:58
9466352 - Crash Data from Belt Tensioner Stored
          B1071 F0 [137] - Unknown Error Elaboration
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:13:58
   Part No SW: 4H0 953 568 F    HW: 7P6 953 507 L
   Revision: --------    Serial number: 90815KGR0008W
   Coding: 000015
   VCID: 3662A3AE817952F660-8063
   Serial number: 0095038
00889 - Horn (H)
            007 - Short to Ground
                    Fault Status: 01100111
                    Fault Frequency: 19
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:59
                    Reset counter: 40
00532 - Supply Voltage B+
                    Reset counter: 40
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb
   Part No SW: 7P6 920 880 P    HW: 7P6 920 880 P
   Component: Kombi         H14 0248
   Revision: 12240064    Serial number: 658290113592021
   Coding: 3327310022000008000002
   Shop #: WSC 22040 959 00000
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526_VW52.rod
   VCID: 489EDD56F38DD40602-801D
13635840 - Supply voltage
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 15:42:37
16776971 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:02
   Part No SW: 7P6 907 530 B    HW: 7P6 907 530 B
   Component: Gateway-CAN-L H08 5202
   Revision: --------    Serial number: 00000000210829
   Coding: 000D077500
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: 377CAEAA8E73ABFE7B-8063
   Serial number: 00000000005650926403
   Voltage stabilizer:
6 Faults Found:
6657 - Generator
          U1052 00 [009] - No Communication
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:02
                    Voltage terminal 30: 12.1 V
                    Voltage terminal 15: 12.2 V
                    Control Module temperature: 16 ∞C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
5712 - Radio
          U1066 00 [008] - No Communication
                    Reset counter: 168
                    Mileage: 116443 km
                    Date: 2016.09.02
                    Time: 13:36:00
                    Voltage terminal 30: 13.1 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 12 ∞C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [009] - -
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:01
                    Voltage terminal 30: 12.2 V
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
0017 - Supply voltage
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 16:22:11
                    Voltage terminal 30: 8.3 V
                    Control Module temperature: 17 ∞C
                    System status: K-/Dash-CAN_MOST_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
12290 - Quiescent Current
          U1406 00 [008] - Too High
                    Reset counter: 136
                    Mileage: 128861 km
                    Date: 2017.02.04
                    Time: 16:58:02
                    Voltage terminal 30: 12.5 V
                    Control Module temperature: 47 ∞C
                    System status: LIN_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
                    Fault Frequency: 15
                    Reset counter: 168
                    Mileage: 129945 km
                    Date: 2017.03.03
                    Time: 01:54:45
                    Voltage terminal 30: 12.4 V
                    Control Module temperature: 23 ∞C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
Address 2E: Media Player 3 (J650)       Labels: None
   Part No SW: 7P6 035 342 C    HW: 7P6 035 342 C
   Revision: A1001003    Serial number: 7669620744
   VCID: 316890B2681775CE35-8065
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 14:49:05
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 16:21:08
   Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
   Component: TSG FA        H07 0166
   Revision: --------    Serial number: 0000117815978
   Coding: 011D0620D001451005080000
   VCID: 4486C966C7A5F066EE-8011
   Revision: 00002001    Serial number: 0155131862
   Coding: 0100162028B9009480200624000000000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P0 959 591     HW: 7P0 959 591
   Component: J245 PS30.050  H07 0006
   Serial number:     WOO12778313
   Coding: 191100
   Subsystem 2 - Part No SW: 7P0 959 591 A    HW: 4H0 959 591
   Component: J394 PS30.050  H07 0006
   Serial number:     WOO12726653
   Coding: 191100
00985 - Right Tail Light (M2)
                    Fault Status: 00101100
                    Reset counter: 136
                    Mileage: 132062 km
                    Date: 2017.04.05
                    Time: 09:48:07
00984 - Left Tail Light (M4)
                    Fault Frequency: 12
                    Reset counter: 168
                    Mileage: 133210 km
                    Date: 2017.04.24
                    Time: 07:26:26
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:03
00230 - Transmission Park Selector Switch (F305)
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:15:07
                    Reset counter: 40
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 16:25:56
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0162
   Revision: --------    Serial number: 0000117798379
   VCID: 3B74B29ABA5B8F9E9F-806F
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: A117060011F
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 3662A3AE897952F660-8063
   Slave 3:
12652544 - Supply voltage
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 17:05:12
                    Voltage: 7.4 V
0018 - Switch for Electric Parking Brake
          C100C 01 [009] - Electrical Failure
                    Voltage: 12.4 V
12656642 - Databus
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:02
                    Voltage: 12.2 V
12656770 - Databus
                    Reset counter: 128
                    Mileage: 134226 km
                    Date: 2017.05.11
                    Time: 11:59:11
                    Voltage: 11.4 V
Address 56: Radio
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0162
   Revision: --------    Serial number: 0000118463983
   Coding: 011C06200001251005080000
   VCID: 3A7AB79EB561B69684-806F
   Component: TSG HR        H09 0162
   Revision: --------    Serial number: 0000118426845
   Part No SW: 3C8 035 730 B    HW: 3C8 035 730 B
   Component: Telefon       011 0723
   Revision: --------    Serial number: 35909603189691
   Coding: 020000000100010000000000
   ASAM Dataset: EV_UHVPremi A02003
   ROD: EV_UHVPremi_A02.rod
   VCID: 224A6FFE35F1DE56BC-8077
          U1400 00 [008] - -
                    Fault Frequency: 31
                    Reset counter: 40
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 13:39:44
                    Reset counter: 40
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 16:05:23
Address A7: Infotain. Interface (J885)       Labels:* None
   Part No SW: 7P6 907 540 A    HW: 1K0 907 951
   Component: IF CAN Infot. H27 0012
   Serial number: 100711F6000022
   Coding: 04052602000000001003
   ASAM Dataset: EV_InfotInterConti 001002
   ROD: EV_InfotInterConti.rod
0017 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 16:01:10
4098 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:03
End-------------------------(Elapsed Time: 04:38)--------------------------
What does the inside of the ECU look like? If it's only the pins and mating connector that have this corrosion, I think it could be cleaned up.
In order to get a new ECU working, you'll need a GeKo session. IIRC, there are no provisions for independent garages to have access to that facility in Australia, meaning a dealer would have to do it. Alternatively, you might be able to send both ECUs to someone for an identity transfer. In any case, VCDS can't do it.
I would try cleaning it up first as Uwe stated above.
You will need to send the ECU out for a data transfer or buy a new ECU and have an SVM session done at the dealer.
If you want we can help with a data transfer, to a used unit you supply of identical part # or reman unit for sale.
sasha
Australia
C?ID=287611
@uwe the terminals were cleaned however still no go. I haven't touched inside of the ECU. To make it more interesting one of the pins have broken off too... (I guess because of corrosion)
@jack i'll email you, thanks for the offer!
Sasha, I'm curious: How did you get this kind of corrosion on the ECU pins? Was this vehicle exposed to salt water at some point?
Hey Uwe
All 0x01 Master locations for the TOW-RIG since first production........leak water directly on the ECU vent port and down to the plug which eventually allows water through heat transition to take on water around the crummy orange seal too.
That corrosion is not from salt water & pretty standard at this location.
This is why I recommend adding a snorkel tube to the vent port and bagging the ECU with a proper rain shield.
To prove the theory I present that usually I sell mostly 0x01 Master units and that if you do a search or observation of the condition of the cases on 0x01 versus 0x11 you will see a difference in external corrosion.
Sasha,
I replied to your email with request for VIN # please & to JPPSG this for part #?
sasha
Australia
C?ID=287611
@jack thank you very much for the info however I did managed to find a local shop that would do the clone for me so was on the hunt for a second hand ECU.
Sadly I did indeed find the ECU in Germany and bought it. While the ECU was in transit I obviously kept thinking about why the original would just be dead (as you probably were wondering also @uwe) and then I remembered about this DTC
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:01
Fair enough I find this fella under the left front seat which has been 'deployed' and nothing coming through it as reported by my multimeter.
So yesterday I temporary connected the two terminals directly (where the interrupter was connected), connect the original ECU, ignition on and scan - ECU is working!
Address 01: Engine (J623-CJMA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 311 C    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0002
   Revision: 53H37---
   Coding: 292A4012232601020000
   Shop #: WSC 22040 959 99908
   ASAM Dataset: EV_ECM30TDI0117P0907311C 001002
   ROD: EV_ECM30TDI0117P0907311C.rod
   VCID: 2F6C96CA7623633E23-807B
5568 - Sensor for Ambient Air Temperature (G17)
          P0073 00 [039] - Signal too High
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Time: 00:01:37
                    Coolant temperature: 22 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 12.120 V
                    Mean injection quantity: 0.00 mg/stroke
                    Control Module temperature: 24.0 °C
                    EGR_governor_deviation: 375.7 mg/stroke
                    Inj Ctl q Curr: 0.00 mg/stroke
                    Standardised airflow ratio: 3.9999
                    Air_Flow_Rate_from_Mass_Air_Flow_Sensor_kg_h: 0.0 kg/h
                    Actual charge pressure: 1005 hPa
5290 - Throttle Actuator Control Circuit
          P2100 00 [039] - Open Circuit
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Time: 00:01:47
                    Voltage terminal 30: 11.980 V
                    Air mass: actual value (mg/stroke): 0.0 mg/stroke
                    Throttle valve adapter: specified value: 100.00 %
                    Throttle valve adapter: actual value: 105.00 %
                    Throttle valve adapter: offset closed: 0.04 %
                    Throttle valve adapter: status-Bit 0: 0
                    Throttle valve adapter: status-Bit 16: 11
                    Throttle valve adapter: status-Bit 24: 55
                    Throttle valve adapter: status-Bit 8: 2
                    Throttle valve adapter: uncond voltage actual value: 4384.0 mV
5595 - Crash Shut-Down Activated
          P1609 00 [039] - -
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Time: 00:01:36
4629 - ECM Power Relay Load Circuit
          P068A 00 [032] - Opens Too Early
Now the only issue I have is that there is a broken pin on the original ECU. I've searched the web and ELSA WIN trying to find what that pin is 'responsible' for however haven't been successful yet. Pin 67.
If anyone knows where this information can be found please let me know. (or if easier tell me what that pin is used by/for).
Thanks in advance!
sasha
Australia
C?ID=287611
Ohh sorry @jack when ECU was out of action the VIN didn't come up.
New scan done yesterday:
Wednesday,13,September,2017,18:03:50:15919
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VirtualBox)
VIN: WVGZZZ7PZCD011169   License Plate: TOUAREG
Chassis Type: 7P-VW52 (7P6)
          A7
VIN: WVGZZZ7PZCD011169   Mileage: 134224km-83402miles
   Revision: 53H37---
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Time: 00:01:37
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Time: 00:01:47
          P1609 00 [039] - -
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Time: 00:01:36
   Coding: 001568
          U0100 00 [039] - -
                    Reset counter: 0
                    Transmission fluid temperature: 30 °C
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
336388 - Databus
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:02
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:03
                    Fault Frequency: 185
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 10:39:59
02823 - Requirements for Locking the Steering Column Lock not met
            000 -  -  - Intermittent
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.13
                    Time: 00:41:53
   Coding: 3626200890
6 Faults Found:
0239 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Time: 00:00:02
                    Voltage terminal 30-Data: 12.9 V
                    Outside air temperature-Data: 77.00 °C
          U1111 00 [008] - -
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:03
                    Outside air temperature-Data: 10.00 °C
                    Reset counter: 77
                    Mileage: 130801 km
                    Date: 2017.03.18
                    Time: 04:42:29
0243 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.22
                    Time: 20:05:04
                    Voltage terminal 30-Data: 12.1 V
                    Outside air temperature-Data: 77.50 °C
          U1113 00 [008] - -
                    Reset counter: 134
                    Mileage: 131797 km
                    Date: 2017.04.04
                    Time: 11:17:57
                    Outside air temperature-Data: 21.50 °C
          B10CD 00 [008] -  -
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 09:00:04
                    Outside air temperature-Data: 6.00 °C
                    Interior temperature-Data: 4.90 °C
   Coding: 013F93
   Coding: 025223
9 Faults Found:
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:13:00
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Time: 00:00:00
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Time: 06:27:00
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.22
                    Time: 20:05:00
                    Reset counter: 128
                    Mileage: 134226 km
                    Date: 2017.05.11
                    Time: 11:59:00
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
   Coding: 108501
1113107 - Front Parking Aid Sensor(s)
          B10FC 13 [009] - Open Circuit
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.22
                    Time: 20:05:02
                    Reset counter: 29
                    Mileage: 127869 km
                    Date: 2017.01.13
                    Time: 06:18:01
12 Faults Found:
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:27
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:01
                    Mileage: 134224 km
                    Date: 2017.05.13
                    Time: 00:11:32
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:00
          B1028 00 [137] -  -
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:13:58
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:13:58
   Coding: 000015
00889 - Horn (H)
                    Fault Status: 00100111
                    Fault Frequency: 21
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:59
                    Reset counter: 40
                    Reset counter: 40
                    Reset counter: 40
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Time: 00:00:02
                    Reset counter: 168
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 15:42:37
          U1111 00 [008] - -
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:02
16776976 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.22
                    Time: 20:05:04
   Coding: 000D077500
   Voltage stabilizer:
6 Faults Found:
6657 - Generator
          U1052 00 [008] - No Communication
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:02
                    Control Module temperature: 16 °C
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
5712 - Radio
                    Reset counter: 168
                    Mileage: 116443 km
                    Date: 2016.09.02
                    Time: 13:36:00
                    Control Module temperature: 12 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
          U0100 00 [008] - -
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:01
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 16:22:11
                    Control Module temperature: 17 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
                    Reset counter: 136
                    Mileage: 128861 km
                    Date: 2017.02.04
                    Time: 16:58:02
                    Control Module temperature: 47 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
                    Fault Frequency: 16
                    Reset counter: 168
                    Mileage: 129945 km
                    Date: 2017.03.03
                    Time: 01:54:45
                    Control Module temperature: 23 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 14:49:05
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 16:21:08
   Coding: 191100
   Coding: 191100
6 Faults Found:
                    Reset counter: 136
                    Mileage: 132062 km
                    Date: 2017.04.05
                    Time: 09:48:07
                    Fault Frequency: 12
                    Reset counter: 168
                    Mileage: 133210 km
                    Date: 2017.04.24
                    Time: 07:26:26
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:03
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:15:07
                    Reset counter: 40
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 16:25:56
                    Fault Frequency: 67
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.22
                    Time: 17:39:08
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Time: 06:26:16
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   Slave 3:
6 Faults Found:
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 17:05:12
                    Voltage: 7.4 V
0016 - Indicator Lamp in Controls
          C1014 14 [008] - Open or Short to Ground
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.13
                    Time: 00:17:11
                    Voltage: 11.8 V
12656642 - Databus
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:02
                    Voltage: 12.2 V
12656770 - Databus
                    Reset counter: 168
                    Mileage: 134226 km
                    Date: 2017.05.11
                    Time: 11:59:11
                    Voltage: 11.4 V
                    Voltage: 12.4 V
12656790 - Databus
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.22
                    Time: 20:05:08
                    Voltage: 12.0 V
Address 56: Radio
          U1400 00 [008] - -
                    Fault Frequency: 32
                    Reset counter: 40
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 13:39:44
                    Reset counter: 40
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 16:05:23
          U1400 00 [008] - -
                    Reset counter: 168
                    Mileage: 134224 km
                    Date: 2017.05.12
                    Time: 16:01:10
          U1111 00 [009] - -
                    Reset counter: 128
                    Mileage: 134224 km
                    Date: 2017.05.10
                    Time: 18:14:03
End-------------------------(Elapsed Time: 04:29)--------------------------
"Multimedia", video/DVD/notebook connection 9WL Multimedia socket for external audio source
Activated carbon canister 1E0 Without activated charcoal canister
Additional body covers, side 6EA Without additional side body covers (stone guard)
Additional tires (winter tires) 2WA Without additional tires
Additional warning lights 9TB Additional warning lights (door area)
Air bag 4UH Air bag for driver and front passenger with knee air bag
Air cleaner (engine) 1L1 Air cleaner for dusty regions
Alternative drive module 0K0 Without alternative drive module
Antennas 8ZH Antenna for AM/FM reception, "diversity"
Anti-theft protection system 7AA Electronic vehicle immobilization device
Auxiliary heating 9M0 Without auxiliary/parking heater
Base engine TF1 6-cylinder diesel engine 3.0 l unit 059.H
Batteries J0B 520 A (92 Ah) battery
Battery/alternator capacity NY0 Standard battery/alternator capacity
Body measures 5C0 Without special body measures
Body style K8G Hatchback
Bolt-on kit 6GA Without add-on kit
Brake type, front 1LC Disc brakes, front
Brake type, rear 2EG Disc brakes, rear
Braking systems 1AT Electronic stabilization program (ESP)
Breakaway interior mirror 4L6 Breakaway interior rear view mirror, automatically dimming
Bumper 2JC Comfort bumpers
Call feature NZ0 Without emergency call control unit
Carrier frequency for radio remote control 5D1 Carrier frequency 433.92 MHz-434.42 Mhz
CD changer/CD player 7A0 Without CD changer/CD player
Center armrest 6E3 Front center armrest
Center armrest rear 6D1 Center armrest rear
Center console 3D1 Center console
Child lock 4H5 Electrically operated child lock
Chrome work package QJ1 Chrome work package
Climatic zones 0Y2 Tropical zones
Compass/traffic sign display QR0 Without compass/traffic sign display/ traffic signs recognition
Component part sets with country-specific design requirements B0R Component parts set, complying with vehicle type for Australia, various parts
Country codes FE0 Without country code (no DVD player in vehicle)
Cruise control 8T1 Cruise control system (CCS)
Cup holder 4M3 Cup holder
Customized installation FC0 Without customized installation
Decorative films / emblems 6F0 Without decorative films / emblems
Delivery equipment 2A0 Without delivery equipment
Differential lock 1Y0 Without differential lock
Door and lid locking system 4K3 Radio remote controlled central locking operated from inside and safe securing
Door and side trim panels 4AP Door and side trim panel
Driving on the left/on the right AV0 Driving on the left
Electric interface for external use UF6 Electric interface for external use (MDI)
Emission standard 7MQ Emissions standard, EU5 mod
Engine cooling system 8Z6 Hot country
Engine specifications D1Q 6-cyl. turbo dies. eng. 3.0 l/150 kW (24V), base engine is T41/TF1/TH1
Entry grab handle (A/B-pillar) 6X0 Without entry grab handle
Equipment levels A8B Basic equipment
Exhaust tailpipe 0P3 Sports tailpipe of polished stainless steel
Exterior mirror setting 6XW Exterior mirrors: automatically dimming, electrically foldable/adjustable, separately heated
Fire extinguisher 6A0 Without fire extinguisher
First aid kit / warning triangle 1T0 Without first aid kit and warning triangle
Floor mats 0TD Front and rear floor mats
Front fog light/additional headlight 8WH Front fog lamp and cornering lamp
Front license plate bracket 6W1 License plate bracket front (large)
Front seats Q1A Standard front seats
Fuel quantity for initial filling 1Z0 Initial standard fuel filling
Fuel systems 0F5 Fuel system for diesel engine
Fuel tank capacity 0M0 Fuel tank
Fuse box (for industrial engine only) KE2 Additional fuse
Gearshift knob/handle 6Q2 Leather gearshift knob/handle
General operating permit, alterations C04 Operating permit, alteration
Generators 9G1 Alternator 220 A
Headlight 8ID Halogen twin headlights
Headlight activation 8K3 Separate daytime running lights with low beam assistant and "Coming Home" feature
Headlight washer system 8X0 Without headlight washer system
Headlight-range adjustment 8Q1 Headlight-range adjustment
Headrests 5ZF Front headrests
Heat accumulator system/additional heater 7E0 W/o heat accumulator/auxiliary heating
Heated washer nozzles 9T1 Heated washer nozzles, front
Heating and air conditioning system 9AD Climatronic, free of cfc
Identification plates 1EJ Special identification plate
Insert for the filling up of unleaded fuel/fuel type 2G0 Without insert for the filling up of fuel
Inserts 5MA Decorative inserts
Instrument inserts U5A Instrument insert, km/h speedometer
Interior lighting 9MA Interior lighting for basic equipment
Interior noise suppression measures 3W7 Acoustics package "Extra"
Left exterior mirror 5SJ Left exterior mirror: convex
License plate lighting KL0 Standard license plate lighting
Light assistance system 8G0 Without light assistant
Lock operation for tailgate/trunk lid 4E2 Tailgate/trunk lid release from inside (electrically)
Luggage compartment cover 3U4 Luggage compartment cover
Luggage compartment floor covering 6SJ Trunk floor covering, reversible mat (rubber/fabric)
Lumbar support 7P0 Without lumbar support in seat backrests
Mass damper for steering wheels 1Q3 Mass damper for steering wheel, XXHz
Molding roof liner 6NJ Standard molded headlining
Multi-function display/trip computer 9Q2 Multi-function display/on-board computer with check control
Nameplate set 0PP Nameplate set "BlueMotion"
Navigation device 7Q0 Without navigation device
Operating voltage 9Z0 Operating voltage 12V
Outer rear seat belts 3ZU 3-point seat belts, outer rear with ECE label
Owner's manuals 0VF Information kit in English
Paint coating FB0 Standard paint coating
Paint preservative/transit coating 5K5 Transit coating film with additional transport protection measures
Park distance control 7X2 Park distance control, front and rear
Parking brake UH2 Parking brake
Partition 3CX Net partition
Pedal cluster VF0 Standard pedal cluster
Pedestrian protection VL1 Extended pedestrian protection measures
Power latching for tailgate GY0 Without power latching for tailgate
Radiator grille 6KA Radiator grille
Radios 8AI Radio "RCD510 MP3"
Rear cargo area 3GD Plane rear cargo area
Rear fog light 8TD Rear fog light for driving on the left
Rear license plate bracket 6P1 License plate bracket rear (ECE)
Rear seat catch UK1 Standard rear seat release
Rear seats 3NW Rear seat bench/backrest, split folding with center armrest
Refrigerator 1W2 Glove compartment cooling system
Remote-controlled garage door opener VC0 W/o remote-controlled garage door opener
Restraint systems, front 3QT 3-point seat belts with tensioner and height adjustment, front
Right exterior mirror 5RV Right exterior mirror: aspherical
Roll-up sun screen for rear and side windows 3Y0 Without roll-up sun screen
Roof insert/convertible top 3FU Big roof system
Roof rails/roof load rack 3S1 Bright roof rails
Scuff plates 7M0 Plastic scuff plates in door apertures
Seat adjustment 3L3 Manual height adjustment for front seats
Seat belt check 9P3 Seat belt reminder, electric contact in buckle
Seat covering N4M Partially leather seat covering
Seat heater 4A3 Seat heater for front seats separately controlled
Seat ventilation/massage seat 4D0 Without seat ventilation/massage seat
Service interval prolongation QG1 Service interval prolongation
Shock absorption/suspension, chassis 1BA Standard suspension/shock absorption
Side air bag 4X4 Side air bag, front and rear with curtain air bag
Side and rear windows 4KC Side and rear windows in heat-insulating glass
Side assist/lane departure warning 7Y0 Without lane change assistant
Smoking/non-smoking package 9JA Non-smoking package
Socket 7B3 12-volt socket(s)
Spare wheel/breakdown set 1G1 Space-saving spare wheel
Speaker installation 8RM 8 speakers (passive)
Special editions E0A No special edition
Special labels/plates 0SC Labels/plates in English
Special registration measures 3M0 Without special measures
Start/stop system/regenerative braking 7L8 Start/stop system with regenerative braking
Steering 1N3 Speed-related variable steering assist (Servotronic)
Steering column systems 2C5 Axial and vertical adjustable steering column
Steering system arrangement L0R Right-hand drive vehicle
Steering wheels 1MH Leather steering wheel
Sticker (customized or special edition) 0KA Without stickers and badges
Subsequent guarantee EA0 Without subsequent warranty
Sun visors 5XH Sun visors with illuminated vanity mirror on driver's and front seat passenger's side
Tachograph/logbook 9NX Without electronic logbook
Taillight assemblies 8SA Taillight assemblies, standard design
Telephone/telematics 9W4 Car phone preparation
Tie down straps/net/pocket 6M3 Trunk net
Tire pressure warning light 7K0 Without tire pressure warning light
Tire suppliers V0A Tires w/o specification of tire brand
Tires H8Y Tires 255/60 R17 106V
Tool kit and jack 1S1 Tool kit and jack
Trailer hitch 1M5 Trailer hitch preparation
Transit coating NT0 Transit coating (type 1)
Transmission specifications G1G 8-speed automatic transmission for four-wheel drive vehicle
Tray areas package QE4 Tray areas package 2
Trunk sill protection 2P2 Trunk sill protection in stainless steel
TV reception/digital radio reception QV0 W/o TV reception/digital radio reception
Type approval countries/countries with special requirements B30 Type approval Australia
Vehicle class differentiation units/platform components 7KJ Vehicle class differentiation 7P0
Vehicle tracking system 7G0 Without preparation for VTS (vehicle tracking system)
Versions FM0 Basic equipment variant
Weight category front axle 0JB Weight category front axle weight range 2
Weight category rear axle 0YA Weight range 1 installation control only, no requirement forecast
Wheel covers 1NS Covers for wheel hubs/wheel bolts
Wheels CH7 Alloy wheels 7.5J x 17
Windshield glass type 4GF Windshield in heat-insulating glass
PAA Side air bags for outer rear seats
PCA Design package "Chrome & Style"
PGN Net partition, reversible luggage compartment mat and luggage net
PJ0 "Atacama" painted in sterling silver - 4 alloy wheels 7.5J x 17 - tires 255/60 R17
PTC "Lights & Vision" package
WLA "Cricket" leather trim
Vehicle Identification No. WVGZZZ7PZCD011169
Model Touareg Blue Motion TOUA
Date of production 07.08.2011
Year 2012
Sales type 7P52GJ
Engine Code CJMA
Transmission Code MYX
Axle drive 8A
Equipment JJ
Roof color 2T
Exterior color / Paint Code 2T / C9X
Part No SW: 7P0 907 311 C HW: 4G0 907 401 <<<<<<<<<<<<<<<<<<<<<<<<<< Confirmed identity config!
Working!
sasha
Australia
C?ID=287611
Thanks @jack
Do you know about pin 67 on the ECU, what is it used for?
The One
Australia
C?ID=277442
Thanks @jack
T105/67 is negative for the J338 throttle valve module.
sasha
Australia
C?ID=287611
:facepalm: looks like i missed your post @jack - thank you for that :thumbs:
that would explain this DTC then
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Time: 00:01:47
The One
Australia
C?ID=277442
                    Mileage: 134224 km
                    Date: 2013.01.02
                    Time: 00:01:47
Yes it does Sasha. I don't think you'll be able to re-pin this TBH, and as you probably are aware, secondhand ECU's are hard to come by in Aus for the 7P Touareg haha
sasha
Australia
C?ID=287611
Second hand ECU is not a problem as I already got it. I'll see if the pin can be soldered on, if not, cloning will be done.
:popcorn:
The One
Australia
C?ID=277442
:popcorn:
Clearly I didn't read that ahaa. I would probably just clone it TBH, less stuffing around with pin soldering etc..
sasha
Australia
C?ID=287611
edc17cp44 is actually quite popular, all these have them - A5, A6, A7, A8, Q5, Q7, Cayenne, Macan
The One
Australia
C?ID=277442
Didn't even think ahaha - I got schooled today :facepalm:
sasha
Australia
C?ID=287611
Thought I'd finish up this thread on a good note. I ended up soldering the broken pin onto the original ECU and all is working fine, no issues in the last 6 months.
As I got it - kangaroo fur was in the front bumper..
All complete
