Hi I have a problem with an A3 that belongs to a motor trade customer, The previous history is unknown and it was bought at auction with this
fault.
The car starts and runs every time although it cranks a little longer than i think is normal. It has a rev limit when stationary and produces no fault codes
untill driven. At which point it drops in to limited performance mode and logs faults for fuel pressure.
The fuel pressure is to low, when over 2500rpm under load the actual and desired pressures are way off.
I have so far tried the following.
Replaced fuel filter, Checked for any sign of air in fuel. Confirmed that there is plenty of good fuel in the tank.
Checked that both low pressure pumps are running, Then tested the low fuel pessure and found it to be 4 bar at all times, when driving and
under load low pressure is still 4 bar. My info says 3.8 so i'm fairly confident the low pressure system is ok.
I'v also done an injector back leakage test in the workshop and also driving when the fault happens using a pressure transducer and scope.
The injector back leakege does not suddenly increase when fault happens.
I have looked at duty cycle and current with a scope of both the inlet metering valve and the desiel regulating valve. but i dont have good data to compair with.
The fuel system is I believe EDC17 with a cp4.1 single piston pump. I have read that they are becoming common failures and that swarf can sometimes be found in the pump under the inlet metring valve. which i'v removed but found it to be clean.
There are a very large amount of data blocks in vcds and i wonder if any one has any advice on which ones if any may help.
I have alldata euro access to the workshop manuel which i'm not so sure is as good as erwin.
Any advice as to where to go next would be much appreciated
The trade customer is however as tight as a drum and is all ready talking about punting it back through the auction if i think its the pump.
Cheers Alan
fault.
Cheers Alan
Tuesday,15,August,2017,06:31:32:05279
VCDS Version: 17.1.3.0
VIN: WAUZZZ8P0AB020805 License Plate:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 61 62 72
VIN: WAUZZZ8P0AB020805 Mileage: 156060km-96971miles
Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 AB HW: 03L 906 018 AG
Component: R4 2,0L EDC X20 6744
Revision: 41X20--- Serial number: AUX7Z0J1FN30PB
Coding: 00190012040501080000
ASAM Dataset: EV_ECM20TDI01103L906018AB 003006
ROD: EV_ECM20TDI01103L906018AB.rod
VCID: 6ADF9A4C8D6B761157-803E
5211 - Fuel Rail/System Pressure
P0087 00 [101] - Too Low
Mileage: 156066 km
Date: 2017.08.17
Time: 01:39:30
Engine speed: 2783.00 /min
Normed load value: 99.6 %
Vehicle speed: 74 km/h
Coolant temperature: 78 °C
Intake air temperature: 35 °C
Voltage terminal 30: 14.360 V
Unlearning counter according OBD: 77
Fuel temperature: 35.3 °C
Mean injection quantity: 66.86 mg/stroke
Rail pressure regulation: status-Bit 0: 00000101
Fuel high pressure: actual value: 583400 hPa
High fuel pressure: specified value: 1.4e+006 hPa
Pressure control valve adaptation factor: 1.0463
Fuel level: 18.00 l
5227 - Fuel Rail/System Pressure
P0087 00 [172] - Too Low
Mileage: 156068 km
Date: 2017.08.17
Time: 01:40:47
Engine speed: 1473.00 /min
Normed load value: 55.3 %
Vehicle speed: 39 km/h
Coolant temperature: 79 °C
Intake air temperature: 27 °C
Voltage terminal 30: 14.380 V
Fuel temperature: 36.8 °C
Mean injection quantity: 26.83 mg/stroke
Rail pressure regulation: status-Bit 0: 00000100
Fuel high pressure: actual value: 683600 hPa
High fuel pressure: specified value: 937300 hPa
Pressure control valve adaptation factor: 1.0106
Fuel level: 18.00 l
5175 - Fuel Pressure Regulation
P1065 00 [101] - Regulation Discrepancy
Mileage: 156068 km
Date: 2017.08.17
Time: 01:41:02
Engine speed: 1683.00 /min
Normed load value: 98.8 %
Vehicle speed: 44 km/h
Coolant temperature: 80 °C
Intake air temperature: 26 °C
Voltage terminal 30: 14.680 V
Engine status: COENG_RUNNING
Fuel temperature: 37.0 °C
Mean injection quantity: 24.18 mg/stroke
Pressure control valve adaptation factor: 0.7000
Fuel pressure regulator valve: specified value rail pressure: 1.5122e+006 hPa
High fuel pressure: specified value: 1.0579e+006 hPa
Fuel high pressure: actual value: 878900 hPa
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 13424012092400FAC81302E4901E0092380800
Shop #: WSC 00046 412 00000
VCID: 7AFFAA0CF5CBC691A7-802E
Part No SW: 8P0 820 047 D HW: 8P0 820 047 D
Component: J255 Klima Man H08 0060
Revision: 00H08004 Serial number: 00000000000000
VCID: 316D4D20A83DC5C956-8064
Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
Part No SW: 8P0 907 063 A HW: 8P0 907 063 A
Component: BCM PQ35 M 105 0575
Revision: 00105 AK
Coding: 0E000A2FB005F0C0207041E00000015C431A29AA004DC122E4008F800041
VCID: 326F422C6D3BFED12F-8066
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00DD13
Subsystem 2 - Part No: 8P0 951 177
Component: Innenraumuebe H04 0020
Subsystem 3 - Part No: 1K8 951 605
Component: LIN BACKUP HO H09 9002
Subsystem 4 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
01134 - Alarm Horn (H12)
014 - Defective
Fault Status: 01101110
Reset counter: 150
Mileage: 156062 km
Date: 2017.08.16
Time: 23:38:30
Voltage: 14.65 V
Term 50 On
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
Component: Airbag AU1042 H06 0160
Revision: -------- Serial number: 003FB004YWV1
Coding: 30314238303830303037554A305238503053
ROD: EV_Airba10AURB4.rod
VCID: 4FA92BD816C9B33920-801A
Serial number: 3572DRB40000A58CF24%
Serial number: 3582DRB40000A4D5010K
Serial number: 35128RB4000054342261
Serial number: 35228RB4000054A53014
Serial number: 35547RB40000552F285M
Serial number: 35647RB40000552F21DO
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0002012
VCID: 46870EFC31B3727193-8012
Component: E0221 H02 0100
Part No SW: 8P0 920 982 J HW: 8P0 920 982 J
Component: KOMBIINSTR. VDO H03 0990
Revision: D0H03005 Serial number: 2241J005018539
Coding: 0004428
Shop #: WSC 00028 001 00001
VCID: 408B18E413975C41A9-8014
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AF HW: 1K0 907 951
Component: J533 Gateway H17 0233
Revision: H17 Serial number: 1521J101150291
Coding: E9807F06000202042103
VCID: 6BD19F484A916F192C-803E
Revision: D0H03005 Serial number: AUX7Z0J1FN30PB
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 N HW: 8P0 959 801 N
Component: Tuer-SG H04 0100
Coding: 0131764
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 232 3001
Revision: 00H17000
Shop #: WSC 00046 000 90108
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.clb
Part No SW: 8P0 959 802 N HW: 8P0 959 802 N
Coding: 0131764
VCID: 479903F836B96B7968-8012
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 152 E HW: 8P0 035 152 E
Component: R Chorus2+ H03 0280
Revision: 00H03000 Serial number: AUZ1Z2K6131210
Coding: 0200021
VCID: 2D555150B405A12972-8078
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 1K0 907 534 HW: 1K0 907 951
Component: Batt.regelung H17 0233
Revision: -------- Serial number: 1521J101150291
Coding: 0303085A
VCID: 68DBE0449B67440141-803C
Subsystem 1 - Part No SW: 1K0 915 181 C HW: 1K0 915 181 A
Component: J367-BDM H07 0125
Serial number: 00000000002790901689
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0131216
Shop #: WSC 00046 412 1012544
VCID: 428F12EC1D9B4E51BF-8016
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0131216
VCID: 438117E802814759B4-8016
End-------------------------(Elapsed Time: 02:26)--------------------------
