Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: 2002 Audi TTQ Central Locking Code
    Don't forget to check the center console top switches too...........8N7919719D
  2. #12
    Aug 2017
    Decided to back track and check fuses again, just in case one blew during the repair. Found #6 open. Changed it out and everything is working well, maybe too well. Even got all the key fobs working.
    Anyway, I knew that the top was leaking at the seal and needed to use the car as a second since last Christmas. I decided to seal it as a temp fix. Well lowered the top but forgot to break the seal. Shattered the back window. Guess I need to fix that next.
    Thanks for all the help and info.
  4. #13
    Thank you for the feedback OP.
    This is why the JPPSG and "process" are so seriously important.
  5. #14
    Stoke on Trent, England
    Engine Code: AMU That's not listed in ETKA engine codes going back to the first PDF.
    New User Keith
  6. #15
    Quote Originally Posted by Keithuk View Post
    I checked ElsaWin for that Type Code: 8N9569 and engine code AMU and it shows. Under power unit it shows other engine codes that are used.
    If you Google Audi AMU engine code. Sites show its used in America.
    APX or AMU
    Whats the difference between engines? AMU? BEA? etc.
    Manufacturer: Audi, Date(s) Used: 09/2002-06/2006, Model: Audi TT/TTS Coupe/Roadster, Engine Code: AMU, 165Kw, 225PS, 1.8 Ltr, 4 Cyls, Remarks: USA ("USA"): Turbo, Motronic
    FMN is shown:
    Manufacturer: Audi, Date(s) Used: 07/2001-04/2003, Model: Audi TT/TTS Coupe/Roadster, Transmission Code: FMN, Transmission Type: 6S
    New User Keith
