2002 Audi TTQ Central Locking Code
hintv
C?ID=313905
Sorry if this is long but, wanted to make sure I covered everything.
My Ragtop leaked and shortly after my windows, top, gas release, trunk, dome light, door locks, and brake light would stay on. VCDS could not communicate with module 35. Pulled out the module, checked the board and everything was corroded. (Must have been leaking for awhile.)
Replaced the Central Locking Module, part bought from Audi by VINN number. It matches the original also.
On VCDS autoscan the module(35) communicated and defaulted to code 15900.
Gas release, trunk, dome light, brake light, alarm, door locks work. The windows do not work from inside the car from either the driver side and passenger side. It does however works with with the key in the door lock, windows down when clicking door unlock X2 and windows up when locking the doors. Windows also moves slightly when opening and closing the door.
The ragtop does not move at all, one thing to note is that I'm not getting any indicator or my dash that the top is unlatched. Granted it could be a separate issue but it worked before everything else failed.
So, having used the VCDS for only a few days, could this be coding? I added all codes together and they all add up to way over 15900. Is there a way to see was 15900 activates?
The car is road ready but, would be nice to get the windows and top working.
Any help on direction to my fix would be great. Thanks in advance.
scott@mms
C?ID=57446
I've been through this, but I didn't 'win' because the owner of the car wanted to try a used controller, which (we found out later) was also water damaged. In a post in another arena in which the 15900 code worked out to be correct, I will copy and paste some responses that technician received. Please take these at face value and make your own decision.
"If it is a TT Coupe or Roadster with a manually operated top the coding is 15884. If it is a hydraulically operated roadster then the coding is 15900"
"If your TT has a manual top the basic coding is 158844 or 15916 for autolock at 20 KM/h. If your TT has a hydraulic top it is 15900 or 15932 for autolock."
hintv
C?ID=313905
Tried both 15900 and 15932 still no luck with windows or top. I'd be happy with just operating the windows from the inside. Thanks for the quick response.
hintv
C?ID=313905
So sad :cry: no auto-scan...........
Sorry, battery died.
Wednesday,16,August,2017,18:39:23:34678
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4401.4
VIN: TRUUT28N121036223   License Plate: GUAVAJ
Mileage: 114984   Repair Order:
Chassis Type: 8N (8N - Audi TT (1999 > 2007))
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Address 01: Engine        Labels: 06A-906-032-AMU.lbl
   Part No: 8N0 906 018 AN
   Component: 1.8L R4/5VT     G   0004
   Coding: 06710
   Shop #: WSC 01236
   VCID: 7DA4F17EE4E9198F30C-513C
   TRUUT28N121036223     AUZ5Z0B4285101
            P1602 - 35-00 - Voltage too Low
17695 - Boost Pressure Control Valve (N249)
            P1287 - 35-10 - Open Circuit - Intermittent
Readiness: 0010 0101
Address 03: ABS Brakes        Labels: 8N0-907-379-MK60-A.lbl
   Part No: 8N0 907 379 H
   Component: ESP ALLRAD MK60     0101
   Coding: 0022544
   Shop #: WSC 01236 785 00200
   VCID: 41DC4D8EDD91BD6F144-5160
Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
   Part No: 8N0 820 043 A
   Component: TT-KLIMAVOLLAUTOMAT D03
   Coding: 00140
   Shop #: WSC 01236
   VCID: 280AF02A5BEB6C2733A-2580
Address 15: Airbags        Labels: 8N0-959-655.lbl
   Part No: 8N0 959 655 A
   Component: Airbag Front+Seite 5000
   Coding: 01103
   Shop #: WSC 01236
   VCID: 3E263672A96FC297696-513C
00532 - Supply Voltage B+
Address 17: Instruments        Labels: 8Nx-920-xxx-17.lbl
   Part No: 8N1 920 980 A
   Component: KOMBI+WEGFAHRS. M73 D04
   Coding: 07244
   Shop #: WSC 23190
   VCID: 3432145A972318C78F2-4B00
Address 22: AWD        Labels: 02D-900-554.lbl
   Part No: 02D 900 554 C
   Component: HALDEX LSC  ECC     0010
   VCID: 201AE80A33DB94677BA-4B00
            07-00 - Signal too Low
Address 35: Centr. Locks        Labels:. 8Nx-962-267.lbl
   Part No: 8N7 962 267 A
   Component: Central Lock/Alarm  D06
   Coding: 15900
   VCID: 3E263672A96FC297696-4EC8
Address 56: Radio        Labels: 8E0-035-1xx-56.lbl
   Part No: 4B0 035 186 H
   Component: concert II  NP2    0009
   Coding: 04202
   Shop #: WSC 22122
   VCID: 2514F91E2CF9714F08C-4E40
End----(Elapsed Time: 02:56, VBatt start/end: 11.6V/11.6V. VIgn 11.5V)-----
Sounds like a bad wire in doors or fuse.....maybe bad switch panel in door being corroded.
What does blocks say for a switch identifier of the top when open or closed?
What is the condition of F205. F254 and F267 ?
There isn't just one switch..........
It may have to be manually reset and opened fully to see the apposed switch condition to allow for the switches to operate again.
Part No: 8N7 962 267 A <<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Okay good correct controller
Coding: 15900
Activated carbon canister
1E4
Activated charcoal canister acc. to ORVR
and siphoning device for filling up
Additional child seat anchors
3B0
Without additional child seat anchor
Additional tires (winter tires)
2WA
Without additional tires
Air bag
4UG
Driver's and front passenger air bag
with kneebar and front passenger air bag
deactivation
Anti-theft protection system
9V3
Anti-theft protection system (EATAS) for
Antifreeze
1C2
Antifreeze up to -35 degree celsius
tolerance up to -40 degree C
Auxiliary heating
9M0
Without auxiliary/parking heater
Backrest release
3H5
Backrest release for front seats with
additional backrest release on the inner
side
Base engine
T6B
4-cylinder gasoline engine 1.8 L
unit 06A.G
Batteries
J1L
Battery 280 A (60 Ah)
Body measures
5C2
Body measures for increased safety
requirements
Body style
K8J
Roadster
Brake pad wear indicator
9U1
Brake type, front
1LT
Disc brakes, front
Brake type, rear
1KF
Disc brakes, rear
Braking systems
1AT
Elektronisches Stabilitätsprogramm (ESP)
Bumper systems
2K5
Reinforced bumpers
Carrier frequency for radio remote control
5D2
Carrier frequency 315 MHz
CD changer/CD player
7A2
CD changer
Cd enhancing underbody panel
2D1
Complete cd enhancing underbody panel
CD ROM/DVD/SD card
7QA
Without CD/DVD for navigation
Center armrest
6E0
Without center armrest front
Component part sets with country-specific design requirements
B0A
Component parts set without
Cruise control
8T2
Cruise control system (CCS)
electronic
Cup holder
4M9
Cup holder
Customized installation
FC0
Without customized installation
Delivery equipment
2A4
Delivery equipment for shipment (transit
coating) with thick seat cover
Door and lid locking system
4K2
Radio remote controlled central locking
"SZV"
Doors
0A1
2 doors
Drive layout
1X1
Four wheel drive
Emission standard
0GL
Emission standard TLEV
Engine cooling system
8Z6
Hot country
Engine specifications
MS4
4-cyl. turbo gasoline eng. 1.8 L/165 kW
base engine is T6B
Equipment levels
A8U
Executive US equipment
Exterior mirror setting
6XD
Exterior mirrors: electrically
adjustable/heated
Exterior noise suppression measures
2B9
Additional exterior noise suppression
First aid kit / warning triangle
1T3
First aid kit with warning triangle
Fresh air intake for passenger compartment (with particulate filter)
2V5
Fresh air intake system with activated
charcoal canister
Front license plate bracket
6W3
License plate bracket front (small, NAR)
Front seats
Q1D
Sports front seats
Front stabilizer
0AS
Front stabilizer
Front underbody guard
1SA
Without additional front underbody guard
Fuel filler cap/door, locking option
2W2
Fuel filler cap, attached (NAR)
Fuel quantity for initial filling
1Z6
Increase in initial standard fuel
filling
Fuel systems
0F2
Fuel system for carburetor gasoline
engine
Fuel tank treatment
2LB
Kraftstoffbehälter mit besonderer
Werkstoffbehandlung (Fluorierung)
Gearshift boot/cover
6R3
Rubber gearshift boot
Gearshift knob/handle
6Q7
Leather gearshift knob with aluminum
appearance
General operating permit, alterations
C00
Operating permit, initial registration
Generators
8GL
Alternator 120 A
Hand brake lever handle
6PA
Plastic hand brake lever handle
Handling standard production and pre-production series
FA0
Control of standard production
Hardtop
5F2
Hardtop preparation
Headlight
8JD
Headlight with gas discharge lamp for
driving on the right (US design)
Headlight activation
8K0
Without special headlight
activation
Headlight washer system
8X1
Headlight-range adjustment
8Q2
Automatic headlight-range adjustment
static
Heat accumulator system/additional heater
7E0
W/o heat accumulator/auxiliary heating
Heated washer nozzles
9T1
Heated washer nozzles, front
Heating and air conditioning system
9AK
Climatronic with impact pressure
control free of cfc
Horns
8Y1
Two-tone horn
Identification plates
1EP
Special identification plate (USA)
Ignition/starter switch locking system
0RA
Without ignition/starter switch locking
system
Insert for the filling up of unleaded fuel/fuel type
2G9
Filler neck module 2 with insert
Installation differentiation for vehicle components
0EN
transmission MQ 350
vehicle components
Instrument inserts
U1B
Instrument insert with mph speedometer,
clock, tachometer and trip odometer
Label for central electric
0W2
English-speaking countries
Left exterior mirror
5SG
Left exterior mirror: flat
Left vanity mirror
4SB
Vanity mirror left
Lock operation for tailgate/trunk lid
4E4
Rear door/tailgate release lever inside
Lockable wheel bolts
1PA
Standard wheel bolts
Lumbar support
7P0
Without lumbar support
in seat backrests
Manufacturing sequence differentiation
0FA
Standard manufacturing sequence
Mud flap
6N0
Without mud flaps
Multi-function display/trip computer
9Q2
Multi-function display/on-board computer
with check control
Navigation device
7Q0
Without navigation device
Outdoor temperature gage
9Y1
Owner's manuals
0VM
Information kit in American English
Paint preservative/transit coating
5K3
Liquid film sealant
Park distance control
7X0
Without park distance control
Platform group class
7PF
Platform group class 6
Platform module floor pan, rear
4P0
Rear floor panel module, type 1
Preparation for two-way radio installation
9D0
Without preparation for two-way radio
installation
Proportioning valve
1H0
Without proportioning valve
Quattro GmbH
FQ0
Standard production wheels
Radios
8UQ
Radio "concert" for USA
Rear axle
0N5
Standard rear axle
Rear fog light
8TA
Without rear fog light
Rear spoiler
5J1
Rear spoiler
Rear stabilizer
0BH
Rear stabilizer
Rear trim panel
6V2
Rear trim panel
Rear window wiper and washer system
8M0
W/o rear window wiper and washer system
Remote-controlled garage door opener
VC1
Right exterior mirror
5RW
Right exterior mirror: convex (US)
large viewing field
Right vanity mirror
4TB
Vanity mirror right
Roof insert/convertible top
3FN
Canvas convertible top, operated
electrically
Rough-road/sports version
2UA
Standard design
Safety certificate
0LM
Special plates/stickers/
safety certificates for California
Seat adjustment
3L3
Manual height adjustment for front seats
Seat belt check
9P1
Seat belt reminder, electric
contact in buckle
Seat covering
N3Q
Fine napa leather seat covering
Seat heater
4A3
Seat heater for front seats
separately controlled
Self-collection / special control
A00
No self-collection
Service interval prolongation
QG1
Shock absorption, chassis, front
G17
Front shock absorption
Shock absorption, chassis, rear
1JT
Rear sports shock absorption
Side air bag
4X1
Side air bag front
Smoking/non-smoking package
9JD
Smoking package, ashtray front
Spare wheel/breakdown set
1G9
Space-saving spare wheel for temporary
use, radial tire
(5-hole)
Speaker installation
8RY
Speakers with BOSE sound
Special editions
E0A
No special edition
Special labels/plates
0SS
Labels/plates in English and French
Steering
1N4
Power steering
Steering column systems
2C5
Axial and vertical adjustable steering
column
Steering system arrangement
L0L
Left-hand drive vehicle
Steering wheels
2ZN
Leather trimmed sports steering wheel
with aluminum appearance
Tachograph/logbook
9NX
Without electronic logbook
Telephone/telematics
9W0
W/o car phone preparation/installation
Throttle actuation
0L2
Electric throttle actuation
Tire suppliers
V0G
MICHELIN tires
Tires
H6G
Tires 225/45 ZR17 91Y
Trailer hitch
1D0
Without trailer hitch
Transit coating
NT0
Transit coating (type 1)
Transmission specifications
G0L
6-speed manual transmission for
four-wheel drive vehicle
Transmission types/gearshift mechanisms
0G4
Cable gearshift
Type approval countries/countries with special requirements
B34
Legal requirements USA
Type sign
2Z1
Type sign at rear
and "Quattro" nameplates respectively
Vehicle class differentiation units/platform components
0CV
Vehicle class differentiation 8N0
Vehicle specifications
F0A
No special purpose vehicle, standard
equipment
Versions
FM0
Basic equipment variant
Washer fluid level indicator
8W1
Weight category front axle
L38
Suspension range 38
installation control only, no
requirement forecast
Weight category rear axle
0YR
Weight range 16
Wheels
C4N
Alloy wheels 7.5J x 17
Wind blocker
7S1
Wind blocker
Window regulator
4R1
Power windows
Windshield glass type
4GP
Windshield in heat-insulating glass with
sunshield and viewing window for vehicle
identification number
Windshield wiper intermittent control
8N4
with potentiometer (four speeds)
PAS
audio package for USA
PPX
Premium package for USA
Vehicle Identification No.
TRUUT28N121036223
Model
Audi TT Road. 1,8 qu.
ATT
Date of production
04.07.2002
Year
2002
Sales type
8N9569
Engine Code
AMU
Transmission Code
FMN
Axle drive
6S
Equipment
JN
Roof color
PA
Exterior color / Paint Code
A2 / Y9B
hintv
C?ID=313905
Still trying to figure out how to use the blocks for troubleshooting. It almost made sense before the battery died.
I've been searching on how to do this. Not sure just yet. Kinda makes sense that it might be a fuse. From what I gather it's somewhere under the dash.
Question: If the driver side window controls don't work, will that affect the passenger side? I was going to try to find a schematic on the system. Does the passenger switch feed off the driver side switches?
Guess I need to find out if I have the tools to bring the top up and down to try the reset.
Yes.........
hintv
C?ID=313905
Yes.........
I played around with blocks this evening and so far it seems I have a bad latch switch. It shows unlocked even with the top latched. I am able to manually toggle the switch to show locked. So on block 09 it shows canvas cover not recognized. Is it a true problem or just software?
Still haven't figured out the window so I plan to open up the door panel tomorrow. Is there a group in block that I can toggle the window switched to see if it's actuating?
Also, I have yet to find a procedure to cycle the top.
Address 35: Centr. Locks (8N7 962 267 A)
18:56:07 Group 010: Convertible Top II
Data for Front Lock Switch (F172)
Group 010 Latch Open Switch
Not Cover Detector Switch (F171)
Available Front Lock Switch (F202)
19:12:12 Group 009: Convertible Top I
Not Oper. Operation Switch (E137)
Not Recogn. Canvas Cover recognized
Not Recogn. Hard Top recognized
19:12:12 Group 010: Convertible Top II
Unlocked Front Lock Switch (F172)
engaged Latch Open Switch
Not Oper. Cover Detector Switch (F171)
Front Front Lock Switch (F202)
Don't forget to check the center console top switches too...........8N7919719D
hintv
C?ID=313905
Decided to back track and check fuses again, just in case one blew during the repair. Found #6 open. Changed it out and everything is working well, maybe too well. Even got all the key fobs working.
Anyway, I knew that the top was leaking at the seal and needed to use the car as a second since last Christmas. I decided to seal it as a temp fix. Well lowered the top but forgot to break the seal. Shattered the back window. Guess I need to fix that next.
Thanks for all the help and info.
Thank you for the feedback OP.
This is why the JPPSG and "process" are so seriously important.
Keithuk
Stoke on Trent, England
C?ID=122432
Engine Code: AMU That's not listed in ETKA engine codes going back to the first PDF.
Keithuk
C?ID=122432
I checked ElsaWin for that Type Code: 8N9569 and engine code AMU and it shows. Under power unit it shows other engine codes that are used.
If you Google Audi AMU engine code. Sites show its used in America.
APX or AMU
Whats the difference between engines? AMU? BEA? etc.
Manufacturer: Audi, Date(s) Used: 09/2002-06/2006, Model: Audi TT/TTS Coupe/Roadster, Engine Code: AMU, 165Kw, 225PS, 1.8 Ltr, 4 Cyls, Remarks: USA ("USA"): Turbo, Motronic
FMN is shown:
Manufacturer: Audi, Date(s) Used: 07/2001-04/2003, Model: Audi TT/TTS Coupe/Roadster, Transmission Code: FMN, Transmission Type: 6S
