So after a couple drinks I figured I would play around with Byte 18 in 09. I thought I was being smart by copying the long code before messing with it so I could get it back to norm. Well as I have learned it's masked so that didn't help. Seems 0B and 0F work ok But the center cluster of LED's are the brake lights now.
Does anyone know the code for a 2103 VW CC?
Here's car info...
13 CC US spec
Led tails
Xenons with Adaptive headlights
Here's car info...
13 CC US spec
Led tails
Thursday,17,August,2017,12:51:22:52868
VCDS Version: 17.8.0.1 (x64)
VIN: WVWRN7AN6DE506985 License Plate: HEYROBI
Mileage: 160850km-99947mi Repair Order:
Chassis Type: AN-VW46 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 4F 52 53 55 56 5D 62
65 72
VIN: WVWRN7AN6DE506985 Mileage: 160850km-99947miles
09-Cent. Elect. -- Status: Malfunction 1010
5D-Operations -- Status: Cannot be reached 1100
65-Tire Pressure -- Status: Malfunction 1010
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 06J 906 027 FE HW: 06J 907 309 B
Component: MED17.5.2 TFSI 2 3952
Revision: PAH04--- Serial number: VWZCZ000000000
Coding: 0404010A1C070160
Shop #: WSC 05245 444 105081
VCID: 73E5BE19127BACDE87-8026
008801 - Boost Pressure Control Valve (N249)
P2261 - 000 - Mechanical Malfunction - Intermittent
Mileage: 160251 km
Date: 2017.08.11
Time: 17:41:28
RPM: 1439 /min
Load: 10.2 %
Speed: 59.0 km/h
Temperature: 99.0∞C
Temperature: 39.0∞C
Absolute Pres.: 980.0 mbar
Voltage: 13.589 V
Part No SW: 02E 300 058 N HW: 02E 927 770 AL
Component: GSG DSG AG6 512 3509
Revision: 05551213 Serial number: 00001203271443
Coding: 0000024
Shop #: WSC 05311 000 00000
VCID: 25419041EC2F826ED9-8070
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AF HW: 3AA 614 109 AF
Component: J104 C2 450M V446 0023
Revision: --H07--- Serial number: 00000005583097
Coding: 0004495
VCID: 71E9B41168679ECE75-8024
Reset counter: 22
Mileage: 155724 km
Date: 2017.06.20
Time: 12:11:30
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 12.00 V
Bin. Bits: 00011111
Count: 281
Hex Value: 0x0000
Part No SW: 3AA 907 044 J HW: 3AA 907 044 J
Component: Climatronic H03 0101
Revision: 00001K01
Coding: 0010001008
Shop #: WSC 00015 115 00000
VCID: 377D4A098E8300FE7B-8062
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 J HW: 3AA 937 087 J
Component: BCM PQ47 H++ 421 0465
Revision: BD421001
Coding: 000800006000000000880281B40008C02755000041208D20E486402400C0
Shop #: WSC 05311 123 12345
VCID: 418924D1D8474E4EC5-8014
Subsystem 1 - Part No SW: 3C8 955 119 F HW: 3C8 955 119 F Labels: 1KX-955-119.CLB
Component: WWS464 200312 010 0604
Serial number: 200312
Coding: 00BF95
Subsystem 2 - Part No SW: 7N0 955 559 HW: 7N0 955 559 Labels: 7N0-955-559.CLB
Component: RLFS 021 0024
Serial number: Y12M03D29h13m26s42S1
Coding: 0F008C
18 Faults Found:
00059 - Terminal 30 for Interior Lighting
Fault Status: 00101011
Reset counter: 107
Mileage: 160626 km
Date: 2017.08.15
Time: 21:44:51
Term 15 Off
Voltage: 12.20 V
00153 - Windshield Wiper Motor; Driver Side (V216)
Reset counter: 107
Mileage: 160626 km
Date: 2017.08.15
Time: 21:44:55
Term 15 Off
Voltage: 12.20 V
00834 - Signal for Activation of Heated Rear Window
Fault Status: 00101001
Reset counter: 107
Mileage: 160626 km
Date: 2017.08.15
Time: 21:44:52
Term 15 Off
Voltage: 12.20 V
00984 - Left Tail Light (M4)
Fault Status: 00101010
Reset counter: 100
Mileage: 160391 km
Date: 2017.08.12
Time: 21:57:46
Voltage: 12.05 V
00985 - Right Tail Light (M2)
Reset counter: 96
Mileage: 160204 km
Date: 2017.08.11
Time: 13:55:26
Voltage: 11.80 V
Reset counter: 100
Mileage: 160391 km
Date: 2017.08.12
Time: 21:56:53
Voltage: 12.15 V
01259 - Fuel Pump Relay (J17)
Reset counter: 107
Mileage: 160626 km
Date: 2017.08.15
Time: 21:44:57
Term 15 Off
Voltage: 12.20 V
01516 - Terminal 30; Left
Reset counter: 107
Mileage: 160626 km
Date: 2017.08.15
Time: 21:18:19
Term 15 Off
Voltage: 12.25 V
Reset counter: 95
Mileage: 160178 km
Date: 2017.08.10
Time: 18:18:47
Voltage: 12.15 V
Reset counter: 107
Mileage: 160626 km
Date: 2017.08.15
Time: 21:44:54
Term 15 Off
Voltage: 12.20 V
Reset counter: 107
Mileage: 160626 km
Date: 2017.08.15
Time: 21:44:54
Term 15 Off
Voltage: 12.20 V
01800 - Light Switch (E1)
Reset counter: 107
Mileage: 160626 km
Date: 2017.08.15
Time: 21:18:19
Term 15 Off
Voltage: 12.25 V
02092 - Enabling Heated Seat
Reset counter: 107
Mileage: 160626 km
Date: 2017.08.15
Time: 21:44:52
Term 15 Off
Voltage: 12.20 V
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
Reset counter: 107
Mileage: 160626 km
Date: 2017.08.15
Time: 21:44:52
Term 15 Off
Voltage: 12.20 V
02391 - Terminal 30 Reference
Reset counter: 107
Mileage: 160626 km
Date: 2017.08.15
Time: 21:18:19
Term 15 Off
Voltage: 12.25 V
03266 - Control Circuit for Signal Horn
Reset counter: 107
Mileage: 160626 km
Date: 2017.08.15
Time: 21:44:51
Term 15 Off
Voltage: 12.20 V
02738 - Bulb for Tail/Brake Light; Left
Reset counter: 100
Mileage: 160391 km
Date: 2017.08.12
Time: 21:56:52
Voltage: 12.15 V
02739 - Bulb for Tail/Brake Light; Right
Reset counter: 96
Mileage: 160204 km
Date: 2017.08.11
Time: 13:55:27
Voltage: 11.80 V
Part No SW: 5N0 959 655 T HW: 5N0 959 655 T
Component: J234__717 VW10 HI 2118
Revision: 24017000 Serial number: 003LDP6A8ANX
Coding: 0012599
VCID: 4E930FEDD919A13648-801A
Subsystem 1 - Part No: 3C8 959 339 A
Subsystem 2 - Serial number: 00000000008CCT
Subsystem 3 - Serial number: 0013.03.120000300000650195ˇÜ63
Subsystem 4 - Serial number: 650195ˇÜ6332MTS644460762 ˇÜ63
Subsystem 5 - Serial number: 60762 ˇÜ6342MTS627450752 ˇÜ63
Subsystem 6 - Serial number: 50752 ˇÜ6351HTS6MOECMAKJ ˇÜ63
Subsystem 7 - Serial number: CMAKJ ˇÜ6361HTS639GCMAKR ˇÜ63
Subsystem 8 - Serial number: CMAKR ˇÜ63727TS6R9DSNAKR ˇÜ63
Subsystem 9 - Serial number: SNAKR ˇÜ63827TS6D6DSNAKJ ˇ
Subsystem 10 - Serial number: SNAKJ ˇ
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C5 953 501 BG HW: 5K0 953 569 T
Revision: FF010041 Serial number: 20120403201076
Coding: 099A270000
Shop #: WSC 00015 115 12345
VCID: 6BD5A679824B741E4F-803E
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 830000
Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb
Part No SW: 3C8 920 970 T HW: 3C8 920 970 T
Component: KOMBI H04 0609
Coding: 230D01
Shop #: WSC 05314 115 12345
VCID: 3D715821ACBF2AAEA1-8068
12658432 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 185
Reset counter: 109
Mileage: 155724 km
Date: 2017.06.20
Time: 12:11:29
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 107
Mileage: 160626 km
Date: 2017.08.15
Time: 21:38:50
Part No SW: 7N0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H41 1623
Revision: H41 Serial number: 270312F2003204
Coding: 461006
Shop #: WSC 05314 123 12345
VCID: 3E735F2DA9B931B6B8-806A
9 Faults Found:
Fault Status: 00110100
Reset counter: 107
Mileage: 160626 km
Date: 2017.08.15
Time: 21:38:50
Fault Frequency: 184
Reset counter: 109
Mileage: 155724 km
Date: 2017.06.20
Time: 12:11:34
00380 - Special Vehicle Control Module (J608)
Fault Status: 01110100
Reset counter: 52
Mileage: 160118 km
Date: 2017.08.09
Time: 18:23:04
00469 - Infotainment Databus in Single Wire Operation
Reset counter: 70
Mileage: 155724 km
Date: 2017.06.20
Time: 12:11:32
Reset counter: 207
Mileage: 155724 km
Date: 2017.06.20
Time: 12:11:34
01304 - Radio
Reset counter: 70
Mileage: 155724 km
Date: 2017.06.20
Time: 12:11:34
Reset counter: 207
Mileage: 155724 km
Date: 2017.06.20
Time: 12:11:34
02649 - Digital Radio Tuner
Reset counter: 207
Mileage: 155724 km
Date: 2017.06.20
Time: 12:11:34
02749 - Control Module / Control Head for Telephone (J738)
Reset counter: 52
Mileage: 160118 km
Date: 2017.08.09
Time: 18:23:05
Part No SW: 3AA 959 433 A HW: 3AA 959 433 A
Component: IMMO 042 0400
Revision: 00042000 Serial number: VWZCZ000000000
VCID: 377D4A09468300FE7B-8062
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 3C8 959 701 HW: 3C0 959 793 C
Component: TUER-SG FT 002 0551
Revision: 12110009 Serial number: 0004679971
Coding: 0004FF
Shop #: WSC 05311 115 12345
VCID: 6DD1A861BC5F7A2E51-8038
Slave Driver:
Subsystem 1 - Part No SW: 3C8 959 703 D HW: 3C8 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0501
Serial number: 00000002826164
Coding: 010498
68100 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 107
Mileage: 160626 km
Date: 2017.08.15
Time: 21:38:51
68105 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 52
Mileage: 160118 km
Date: 2017.08.09
Time: 18:23:03
Part No SW: 5N1 909 144 M HW: 5N1 909 148 G
Component: J500__APA-BS KL.303 1002
Revision: 1AH03734 Serial number: 00120830103701
Coding: 0000258
VCID: 3C7755257FA523A696-8068
Component: KSG PQ47 ELV 042 0634
Coding: 1A910F800186407F7F021C1FF08A0F0E105B41
Shop #: WSC 05311 123 08193
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H41 1623
Coding: 00030308
VCID: 6FEDB269BE53883E63-803A
Subsystem 1 - Part No SW: 3C8 919 204 A HW: 3C8 919 204 A
Component: Analoguhr 005 0003
Fault Frequency: 119
Reset counter: 70
Mileage: 155724 km
Date: 2017.06.20
Time: 12:11:30
Part No SW: 3C8 959 702 HW: 3C0 959 792 C
Component: TUER-SG BT 002 0551
Revision: 14110009 Serial number: 0004709960
Coding: 0004FE
VCID: 6ED3AF6DB159813668-803A
Slave Passenger:
Subsystem 1 - Part No SW: 3C8 959 704 D HW: 3C8 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0501
Serial number: 00000002824780
Coding: 010498
U1111 00 [008] - -
Reset counter: 107
Mileage: 160626 km
Date: 2017.08.15
Time: 21:38:51
U1111 00 [009] - -
Reset counter: 52
Mileage: 160118 km
Date: 2017.08.09
Time: 18:23:03
131584 - Motor for Rear Window Regulator
B11EE 54 [008] - Missing Calibration / Basic Setting
Fault Frequency: 7
Reset counter: 109
Mileage: 155998 km
Date: 2017.06.23
Time: 18:25:54
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000000604161
Coding: 0022156
VCID: 3663470D4189F9F660-8062
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 071200010B000400
Shop #: WSC 05311 115 00000
Subsystem 1 - Part No SW: 1T0 941 329 HW: 1T0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0007
Coding: 350000
Subsystem 2 - Part No SW: 1T0 941 329 HW: 1T0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0007
Coding: 350000
Address 56: Radio
Address 5D: Operations
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 D HW: 3AA 907 273 D
Component: RDKBERU30 H09 0010
Serial number: 10000000109807
ASAM Dataset: EV_RDKBERU30 003012
ROD: EV_RDKBERU30_003.rod
VCID: 35614001948FF2EE69-8060
12656640 - Databus
U1200 00 [008] - Defective
Reset counter: 109
Mileage: 160626 km
Date: 2017.08.15
Time: 20:53:35
8401152 - Radio Frequency Interference
C105C 00 [008] - -
Reset counter: 105
Mileage: 160582 km
Date: 2017.08.15
Time: 10:04:07
Vehicle speed: 56 km/h
Outside air temperature: 27 ∞C
Reception level antenna 1: 410 mV
Offset level antenna 1: 180 mV
End-------------------------(Elapsed Time: 03:18)--------------------------
65 72
56-Radio -- Status: Malfunction 1110
Mileage: 160251 km
Date: 2017.08.11
Time: 17:41:28
RPM: 1439 /min
Load: 10.2 %
Speed: 59.0 km/h
Temperature: 99.0∞C
Temperature: 39.0∞C
Voltage: 13.589 V
Coding: 0000024
Coding: 0004495
Reset counter: 70
Mileage: 160852 km
Date: 2017.08.17
Time: 08:51:55
Hex Value: 0x0000
Voltage: 12.00 V
Bin. Bits: 00011111
Count: 281
Hex Value: 0x0000
Revision: 00001K01
Coding: 0010001008
Revision: BD421001
Coding: 00BF95
Coding: 0F008C
Coding: 0012599
Coding: 099A270000
Coding: 830000
Coding: 230D01
Coding: 461006
Reset counter: 70
Mileage: 160852 km
Date: 2017.08.17
Time: 08:51:57
01304 - Radio
Reset counter: 70
Mileage: 160852 km
Date: 2017.08.17
Time: 08:52:00
Reset counter: 70
Mileage: 160852 km
Date: 2017.08.17
Time: 08:51:57
Coding: 0004FF
Slave Driver:
Coding: 010498
Coding: 0000258
Coding: 00030308
Reset counter: 70
Mileage: 160852 km
Date: 2017.08.17
Time: 08:51:55
Coding: 0004FE
Slave Passenger:
Coding: 010498
Coding: 0022156
Coding: 350000
Coding: 350000
Address 56: Radio
End-------------------------(Elapsed Time: 03:08)--------------------------
Thursday,17,August,2017,13:17:01:52868
65 72
Readiness: 1110 0101
Coding: 0000024
Coding: 0004495
Reset counter: 70
Mileage: 160852 km
Date: 2017.08.17
Time: 08:58:46
Hex Value: 0x0000
Voltage: 12.00 V
Bin. Bits: 00011111
Count: 281
Hex Value: 0x0000
Revision: 00001K01
Coding: 0010001008
Revision: BD421001
Coding: 00BF95
Coding: 0F008C
Coding: 0012599
Coding: 099A270000
Coding: 830000
Coding: 230D01
Coding: 461006
Reset counter: 70
Mileage: 160852 km
Date: 2017.08.17
Time: 08:51:57
01304 - Radio
Reset counter: 70
Mileage: 160852 km
Date: 2017.08.17
Time: 08:52:00
Reset counter: 70
Mileage: 160852 km
Date: 2017.08.17
Time: 08:51:57
Coding: 0004FF
Slave Driver:
Coding: 010498
Coding: 0000258
Coding: 00000208
Reset counter: 70
Mileage: 160852 km
Date: 2017.08.17
Time: 09:07:00
Coding: 0004FE
Slave Passenger:
Coding: 010498
Coding: 0022156
Coding: 350000
Coding: 350000
Address 56: Radio
