Ross tech wiki upgrades
ee3Si
Bulgaria
C?ID=179209
We received feedback regarding 1K0-953-549-CD. A customer successfully installed it a 2009 Golf with a LIN 1.3 steering wheel from a 2006 Passat (1P0-959-542) so I'll edit that Wiki page.
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 056 0111
Coding: 0000334
VCID: 76E3311901625D8E77-8022
Component: E0221 002 0010​
Actually I retrofitted the cruise control first by using 1K0 953 549 CD (SWCM) and 1K0 953 513 G(or F or A) 9B9 Turn signal switch/Cruise Control Operation Lever (Stalk) - it was just P&P including some VAG-COM coding, no need for rewiring and any other hardware modifications. Later I added the MFSW (LIN1.3) as I had a Passat B6 to take from and test it before hand. Since it worked fine I found and bought a MFSW on ebay and replaced the original SW keeping my Air-Bag as it was the most expensive item should I had to replace the SW with MFSW LIN2.0. By the way I cannot confirm if right hand buttons work as I have a LowLine MFD, but left hand buttons work perfectly well.
   #22
Dana
Western PA, USA
Excellent, thanks for the details. Even though it won't be an issue unless you upgrade to HighLine MFD you may want to check MVBs in that #16 module for the right buttons.
D
Deleted member 1234
Guest
whatever 638 is
You can code it but it won't work
this one no good
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: J0527 638 0070
Coding: 0000012
Shop #: WSC 00153 210 84930
VCID: 74E3DA046E3D
this one is ok
Component: Lenksäulenmodul 035 0070
Coding: 0000042
Shop #: WSC 00152 210 91233
VCID: 74E3DA046E20
So the module above is a good one??
Part No SW: 1K0 953 549 CK HW: 1K0 953 549 CK
Component: J0527 055 0111
Coding: 0000634
Shop #: WSC 00231 447 72242
VCID: 7DDF35AB249FCCD008-8028
Subsystem 1 - Part No: 3T0 959 537 A Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H07 0011
Coding: 00000131
golfi_vend
Tartu, Estonia
C?ID=195131
There is SWCM 5K0953549E, this is midline and supports MFA and cruise.
   #25
golfi_vend
Tartu, Estonia
C?ID=195131
I suggest maybe add a guide in wiki regarding the ESP Test function. I had great success with it in roundabout. Any other way i wasn't able to clear the code. I tried in parking lot, but no success.
   #26
golfi_vend
Tartu, Estonia
C?ID=195131
Module 5K0-953-569-R need info update.
Will support AT-trans, will support cruise, will support MFD, will not support MFSW.
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.lbl
   Part No SW: 3C5 953 501 BC    HW: 5K0 953 569 R
   Revision: FF010040    Serial number: 20110415100458
   Coding: 1980210000
   Shop #: WSC 00028 028 00021
   VCID: 67DD49D99E6B567A09-8032
          Time: 00:00:00
golfi_vend
Tartu, Estonia
C?ID=195131
Regarding the 1K0 953 549 BC i had forgotten about version number and tried to retrofit CCS to caddy which had the "incorrect" BC.
I was able to activate the cruise when hitting and releasing the cancel function on the cruise stalk, but that is no correct way.
Saturday,16,September,2017,18:23:38:01666
VCDS Version: 17.8.0.1 (x64)
VIN: WV2ZZZ2KZ8X   License Plate: CRUISE RETROFIT
Mileage: 301890km-187585mi   Repair Order:
Chassis Type: 2K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 46 52 56 77
VIN: WV2ZZZ2KZ8X   Mileage: 301890km-187585miles
Address 01: Engine        Labels: 03G-906-021-BLS.clb
   Part No SW: 03G 906 021 PF    HW: 03G 906 021 AB
   Component: R4 1,9L EDC G000SG  1331
   Revision: --H07---    Serial number: VWX7Z0G63NH0H0
   Coding: 0000071
   Shop #: WSC 49433 126 82327
   VCID: 72EB288D6DA9A3D68C-8026
   Revision: 00H11001
   Coding: 0021206
   Shop #: WSC 35110 377 00190
   VCID: 73E52D8912B3AADE87-8026
   Part No SW: 1K0 820 047 HB    HW: 1K0 820 047 HB
   Component: Climatic PQ35   141 1010
   Revision: 00141028    Serial number: 00000000000000
   VCID: 6BD535E94A83721E4F-803E
   Revision: 00H54000    Serial number: 01000007399703
   Coding: 01884F030004100047000000000000000009FF075C000100000000000000
   Shop #: WSC 35110 377 08192
   VCID: 71E9278168AF98CE75-8024
   Subsystem 1 - Part No: 2K1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 130707 021  0501
   Coding: 00038805
   Shop #: WSC 35110
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 AJ    HW: 6Q0 909 605 AJ
   Component: 1C AIRBAG VW52  024 2400
   Revision: 05024000    Serial number: 0037UD079TT+
   Coding: 0012611
   VCID: 7F0DF1B92EFBFEBEF3-802A
   Coding: 0000042
   VCID: 74E72E9517BDADE69E-8020
   Part No SW: 1T0 920 864 A    HW: 1T0 920 864 A
   Component: KOMBIINSTRUMENT VDD 1212
   Revision: V0002000    Serial number: VWX7Z0G63NH0H0
   Coding: 0016101
   Shop #: WSC 00011 888 96745
   VCID: 3365ED895233EADE47-8066
   Component: J533  Gateway   H07 0052
   Revision:   H07 01    Serial number: 180707F1000506
   Coding: A9801F064006027400
   VCID: 306FE285A325D1C63A-8064
   Component: IMMO            VDD 1212
Address 37: Navigation        Labels: 1K0-035-191.lbl
   Part No SW: 1K0 035 191 D    HW: 1K0 035 191 D
   Component: J401                0303
   Revision: 00018000    Serial number: VWZ1Z2G7293719
   Coding: 0023400
   VCID: 23451DC9E2D37A5EB7-8076
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         006 1205
   Coding: 0000048
   VCID: 387FDAA54B55098672-806C
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 CP
   Coding: 808B04087F2D8405484A036010C0
   Shop #: WSC 49433 126 04005
   VCID: 000F7245530581468A-8054
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000048
   VCID: 3979DFA1705F108E8D-806C
Address 56: Radio        Labels: 1K0-035-191.lbl
   Component: R                   0303
   Coding: 0023400
Address 77: Telephone        Labels: 3C0-035-729.lbl
   Part No SW: 3C0 035 729 G    HW: 3C0 035 729 G
   Component: Telefon             7609
   Revision: 00012000    Serial number: 0000000945214
   Coding: 0016041
   VCID: 275D09D996EB967EEB-8072
End-------------------------(Elapsed Time: 01:33)--------------------------
   #28
m87a
Bosnia and Herzegovina
C?ID=156900
also
Module 5K0-953-569-AS need info update
supports steering angle sensor and also supports automatic transmition (dsg)
golfi_vend
Tartu, Estonia
C?ID=195131
Anyone has PCB images of "BC" module with CCS active?
This is the "BAD" version.
