Results 1 to 10 of 11
Thread: VCDS Mobile with Sharan 7N
    Aug 2017
    Hello I am new and tried the VCDS Mobile on my Sharan 7N.
    I have the Problem that when I try to display the advanced measuring blocks, diffrent blocks are displayed as I ticked.
    Exsample when I choose engine RPM, selector lever position is displayed.
    Regards,
    Stefan
    #hndoc:?docid=00003218&xt=hnh:7375572EC997A3735D1535AD14556087ED26150874C992B4A6ED83D9FFD7BC87
    VCDS Mobile 0.4401.0.4
    VIN: WVWZZZ7NZFV000463
    Scan: 01 03 08 09 10 15 16 17 18 19 22 25 42 44 46 4C 52 53 56 61
    	 62 69 6C 6D 72 BE BF
    BE-Sliding Door Left -- Status: OK 0000
    BF-Sliding Door Right -- Status: OK 0000
    Address 01: Engine  (CFFB J623)	Labels: 03-01.clb
    	Part No SW: 03L 906 018 HK	HW: 03L 907 309 Q
    	Component: R4 2.0l TDI   H28 9978
    	Revision: 44H28---
    	Coding: 0019001A043601080000
    	Shop #: WSC 00240 216 00000
    	ASAM Dataset: EV_ECM20TDI01103L906018HK 003013
    	ROD: EV_ECM20TDI01103L906018HK.rod
    	VCID: 7AB761EB46C9D1EFB3C740AA04-802F
    No fault codes found.
    Address 03: ABS Brakes	Labels: 7N0-614-109.clb
    	Part No SW: 7N0 614 109 S	HW: 7N0614109S
    	Component: J104   C3 450M VDE2  0040
    	Revision: --H07---	Serial Number: 00000008126427
    	Coding: 0018973
    	Shop #: WSC 00020 790 00000
    	VCID: 3D3DAAF71767BED7D665A3CE2D-8068
    Address 08: Auto HVAC  (J255)	Labels: 5K0-907-044.clb
    	Part No SW: 7N0 907 044 R	HW: 7N0 907 044 R
    	Component: Clima-Sharan  H02 0404
    	Revision: 00001K02
    	Coding: 021000C449
    	Shop #: WSC 00020 999 00000
    	ROD: EV_ClimatronicSharan.rod
    	VCID: 3FC1D0FF1D6B34C7C479B9E607-806A
    Address 09: Cent. Elect.  (J519)	Labels: 1K0-937-08x-09.clb
    	Part No SW: 5K0 937 084 K	HW: 5K0 937 084 K
    	Component: BCM PQ35 B    122 0173
    	Revision: BA122001
    	Coding: 40590A3F8125F3C0508800C05400006443D11308426D2D226480872000C1
    	VCID: 3A37A1EB064909EFF34780AAC4-806F
    	Subsystem 1 - 	Part No SW: 7N1-955-119-A	Labels: 1Kx-955-119.clb
    	Component: WWS    140401033 0044
    	Coding: 004DBD
    	Subsystem 2 - 	Part No SW: 5Q0-955-547	Labels: 5Q0-955-547.clb
    	Component: RLFS         024 0042
    	Coding: 0228BB
    	Subsystem 3 - 	Part No SW: 7N0-951-171-A
    	Component: DWA-Sensor 00002 0206
    	Subsystem 4 - 	Part No SW: 1K0-951-605-C
    	Component: LIN BACKUP HOH05 1501
    03789 - Terminal 75 Limp Mode Active
    Address 10: Park/Steer Assist  (J446)	Labels: 1Q0-919-475.clb
    	Part No SW: 7N0 919 475 A	HW: 7N0 919 475
    	Component: PARKHILFE 8K  H06 0012
    	Revision: --------
    	Coding: 318001
    	ASAM Dataset: EV_EPHVA18VW4280000 001005
    	ROD: EV_EPHVA18VW4280000.rod
    	VCID: 3935BEE7034F1AF7FA3D77BED9-806C
    Address 15: Airbags  (J234)	Labels: 5K0-959-655.clb
    	Part No SW: 7N0 959 655 C	HW: 7N0 959 655 C
    	Component: VW10Airbag00N H12 0014
    	Coding: 00304E
    	ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
    	ROD: EV_AirbaVW10TS6VW428.rod
    	Subsystem 1 - 	Part No SW: ----
    	Component: S.Sens.Fahr.V--- ---
    	Serial Number: 3493ETS607DFCCC199DR
    	Subsystem 2 - 	Part No SW: ----
    	Component: S.Sens.Beif.V--- ---
    	Serial Number: 3503ETS60B2EBCD19DDF
    	Subsystem 3 - 	Part No SW: ----
    	Component: S.Sens.Fahr.H--- ---
    	Serial Number: 3513ETS608DF5B519DDA
    	Subsystem 4 - 	Part No SW: ----
    	Component: S.Sens.Beif.H--- ---
    	Serial Number: 3523ETS607A5CD119DD2
    Address 16: Steering wheel  (J527)	Labels: 5K-16.lbl
    	Part No SW: 5K0 953 501 CT	HW: 5K0 953 569 AL
    	Revision: FF010042
    	Coding: 5180240000
    	VCID: 7EBF6DFB5AE1FDCF8FEF6CFA58-802B
    Address 17: Instruments  (J285)	Labels: 5K0-920-xxx-17.clb
    	Part No SW: 7N0 920 870 L	HW: 7N0 920 870 L
    	Component: KOMBI         H03 0905
    	Coding: 140F01
    	ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
    	VCID: 3B39A4EF097328E7E8518DD633-806E
    Address 18: Aux. Heat	Labels: 1K0-815-071.clb
    	Part No SW: 7N0 963 271 G
    	Component: Zuheizer        051  3041
    	Revision: 00051000	Serial Number: 09028242000000
    	Coding: 0000041
    	VCID: 3833BBE338459BFF05336AB2EA-806D
    Address 19: CAN Gateway  (J533)	Labels: 7N-19.clb
    	Part No SW: 7N0 907 530 AQ	HW: 7N0 907 530 AL
    	Component: J533  Gateway H58 1653
    	Revision:   H58
    	Coding: 468002
    	VCID: 7F4190FF5DEBECC784F979E647-802A
    Address 22: AWD  (J492)	Labels: 0CQ-907-554.clb
    	Part No SW: 0AY 907 554 F	HW: 0AY 907 554 F
    	Component: Haldex4Motion H52 7521
    	Coding: 0401
    	ROD: EV_AllWheelContrHA1VW37X_VW36.rod
    	VCID: 4EDFFD3BAAC1AD4F3F0F5CBAC8-801B
    Address 25: Immobilizer  (J334)	Labels: 5K0-920-xxx-25.clb
    	Part No SW: 5K0 953 234	HW: 5K0 953 234
    	Component: IMMO          H03 0905
    	ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
    	VCID: EA97D1ABB669E16FC32710EAD4-80BF
    Address 42: Door Elect, Driver  (J386)	Labels: 7N0-959-793.clb
    	Part No SW: 7N0 959 793 F	HW: 7N0 959 793 F
    	Component: TSG FA        H03 0553
    	Revision:
    	Coding: 01102E208000411011
    	VCID: 45CDC2177FB776178EB5FB2EB5-8010
    Address 44: Steering Assist	Labels: 5N1-909-144.clb
    	Part No SW: 5N1 909 144 R	HW: 5N1909148J
    	Component: J500__APA-BS KL.325  1401
    	Revision: 1BH04739	Serial Number: 00141220089601
    	Coding: 0000258
    	VCID: 41C5D6076B9FDA37B28DCF1E61-8014
    Address 46: Failed to respond
    Address 52: Door Elect, Pass.  (J387)	Labels: 7N0-959-792.clb
    	Part No SW: 7N0 959 792 F	HW: 7N0 959 792 F
    	Component: TSG BF        H03 0553
    	Revision:
    	Coding: 01102C208000411011
    	VCID: 44CBDF13748D4F1F99ABEE2246-8011
    Address 53: Parking Brake	Labels: 3AA-907-801.clb
    	Part No SW: 3AA 907 801 J	HW: 3AA907801J
    	Component: J540 EPB4  VW-63206  0012
    	Revision:   H19   	Serial Number: 00000000003355
    	Coding: 0024167
    Address 56: Radio  (J0503)	Labels: 5M0-035-1xx-56.clb
    	Part No SW: 3C8 035 190 C	HW: 3C8 035 190 C
    	Component: Radio RCD510  052 0213
    	Revision: 00000001
    	Coding: 0500040004000D
    	VCID: 23097C8F91C36827C06185B6FB-8076
    Address 61: Battery Regul.  (J840)	Labels: 1K0-907-534.clb
    	Part No SW: 7N0 907 534	HW: 7N0 907 530 AL
    	Component: Batt.regelung H58 1653
    	Coding: 330F7859
    	VCID: F1A5C6C79BBF0AB7826D5F5E71-80A4
    	Subsystem 1 - 	Part No SW: 1K0-915-181-H
    	Component: J367-BDM     H07 0180
    Address 62: Door, Rear Left  (J388)	Labels: 7N0-959-794.clb
    	Part No SW: 7N0 959 794 J	HW: 7N0 959 794 H
    	Component: TSG HL        H01 0556
    	Revision:
    	Coding: 01006C200000411001
    	VCID: 4AD7F12B56A9996F63E7306AF4-801F
    Address 69: Trailer  (J345)	Labels: 7N0-907-383.clb
    	Part No SW: 7N0 907 383	HW: 7N0 907 383
    	Component: Anhaenger     H09 0120
    	Revision: 3I001003
    	Coding: 410C040001000000
    	VCID: F3A9CCCFE1A338A7708175766B-80A6
    Address 6C: Back-up Cam.	Labels: 5N0-907-441.clb
    	Part No SW: 7N0 907 441	HW: 7N0907441
    	Component: J772__Rearview       0020
    	Revision: 00H13000	Serial Number: 525 PA8J441339
    	Coding: 0030011
    	VCID: EE9FDDBB8A81954F9F4F3C3A28-80BB
    Address 6D: Trunk Elect.  (----)	Labels: 7N0-959-107.clb
    	Part No SW: 7N0 959 107 E	HW: 7N0 959 107 A
    	Component: HDSG-Modul    H11 0243
    	Revision: 41011001
    	Coding: 0733334003
    	ASAM Dataset: EV_HDSGVW428 201138
    	ROD: EV_HDSGVW428_VW36.rod
    Address 72: Door, Rear Right  (J389)	Labels: 7N0-959-794.clb
    	Component: TSG HR        H01 0556
    	Revision:
    Address BE: Sliding Door Left  (J558)	Labels: 7N0-959-244.clb
    	Part No SW: 7N0 959 244 B	HW: 7N0 959 244 B
    	Component: Schiebetuer_l 005 2414
    	Shop #: WSC 00000 000
    	ASAM Dataset: EV_AST A03704
    	ROD: EV_AST.rod
    	VCID: 3833BBE3384503FF05336AB2EA-806D
    Address BF: Sliding Door Right  (J731)	Labels: 7N0-959-244.clb
    	Component: Schiebetuer_r 005 2414
    	ROD: EV_AST.rod
    Quote Originally Posted by sbrimmers View Post
    Could you post some screen-shots of this behavior please?
    Aug 2017
    Here are the Screenshots.
    I cross checked the same result with I Phone.
    Regards, Stefan
  4. Likes Uwe liked this post
    Try in vcds-mobile [Options] -> [Clear Dataset Cache] and then check what it shows in measuring values.
    Aug 2017
    Hi Shaun,
    I tried it but same result, it loaded the ASAM new but still selected and displayed values do not match.
    I checked the ABS Group there the measuring values works fine.
    I did some screenshots maybe it helps.
    Regards,
    Stefan
    Aug 2017
    Nobody an Idea? I especially procured the Hex Net Version to Log Data with my mobile.
    Regards,
    Stefan
    What happens if you try going through the "live data hud" function in mobile?
  9. #8
    Aug 2017
    The same Problem wir HUD
  10. #9
    Nov 2014
    World
    Problem confirmed on a 2015 Alhambra, on several control modules, VCDS mobile on my HEX-NET with CB 4408 will just show random measuring values instead of the ones selected, also some ASAM data can not be loaded even though I am on 4G, and the Ross-Tech Cloud times out immediately, of course I can send specific infos if requested.
  11. Likes Uwe liked this post
  12. #10
    Aug 2017
    Hello Detlef,
    I tried today with CB 4407.
    I had to clear the Cache to be able to load the ASAM.
    But the same Problem as before.
    Stefan
