Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: 2005 Audi S4 4.2 6MT Convertible
    Fresher scan with more DTCs
    Tuesday,12,September,2017,17:22:46:18206
    VCDS Version: 17.8.0.2  HEX-V2 CB: 0.4401.4
    Data version: 20170721 DS277.0
    VIN: WUARL48H35K900373   License Plate:
    Chassis Type: 8H (AS - AndyS4)
    Scan: 01 03 08 09 0F 15 16 17 26 36 46 55 56 63 73
    VIN: WUARL48H35K900373   Mileage: 144930km-90055miles
    Address 01: Engine        Labels: 079-910-560-BBK.lbl
       Part No SW: 8H0 910 560 F    HW: 8E0 907 560
       Component: 4.2L V8/5V      G   0010
       Revision: 00000000    Serial number: AUZ6Z0D0226145
       Coding: 0007714
       Shop #: WSC 00672 785 00200
       VCID: 2B000DC1DF1141BFDEB-513C
    17947 - Clutch Pedal Switch (F36)
                P1539 - 004 - Implausible Signal
    Readiness: 0000 0100
       Part No: 8E0 614 517 Q
       Component: ABS/ESP allrad      4533
       Coding: 04595
       Shop #: WSC 00672
       VCID: 36362CB511530C57B15-51A8
       Part No: 8E0 820 043 AC
       Component:   A4 Klimaautomat   1424
       Coding: 00100
       Shop #: WSC 00672
       VCID: 629EA0E5ED5BC0F72DD-513C
       Part No: 8E0 907 279 F
       Component: int. Lastmodul  USA 0517
       Coding: 01013
       Shop #: WSC 00672
       VCID: 35342BB90C55074FB8F-4AE0
    02104 - Light Detection Sensor (G399)
                29-10 - Short to Ground - Intermittent
    Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
       Part No: 8E0 035 593 A
       Component: SDAR XM            0010
       VCID: 2708F1F1C6C965DF3A3-5042
    02633 - Antenna for Satellite Tuner
                35-00 -  -
    Address 15: Airbags        Labels: 8H0-959-655-84.lbl
       Part No: 8H0 959 655 D
       Component: Airbag 8.4EC        0015
       Coding: 0010105
       VCID: 3B203D812F71D13F4EB-5160
       Part No: 8E0 953 549 N
       Component: Lenksáulenmodul     0611
       Coding: 01041
       Shop #: WSC 00672
       VCID: 3E2634953963C417695-4B00
       Part No: 8H0 920 980 M
       Component: KOMBI+WEGFAHRS. RB4 D22
       Coding: 01231
       Shop #: WSC 00001
       VCID: 392C2789204DE32F5C7-5160
       WUARL48H35K900373     AUZ6Z0D0226145
    Address 26: Auto Roof        Labels: 8H0-959-255.lbl
       Part No: 8H0 959 255
       Component:  VSG  B6 CABRIO     6386
       VCID: 73B0D5A147A1597F56B-5160
       Part No: 8H0 959 760
       Component: Sitzmemory EE H06   0010
       Coding: 00002
       Shop #: WSC 00065
       VCID: 74B2D6BD479F5E474F1-4B1E
       Part No: 8H0 959 433 E
       Component: Komfortgerát T7B    3320
       Coding: 11884
       Shop #: WSC 05140
       VCID: 36362CB511530C57B15-4B00
       Subsystem 1 - Part No: 8H1959801B
       Component: Tőrsteuer.FS BRM 1103
       Subsystem 2 - Part No: 8H1959802B
       Component: Tőrsteuer.BF BRM 3020
       Subsystem 3 - Part No: 8H0959801A
       Component: Tőrsteuer.HL BRM 0002
       Subsystem 4 - Part No: 8H0959802A
       Component: Tőrsteuer.HR BRM 0002
       Part No: 4Z7 907 357
       Coding: 00070
       Shop #: WSC 00672
       VCID: 0452867D173F6EC77F1-4B1E
       Part No: 8E0 035 195 H
       Component: symphony II PM6    0410
       Coding: 00301
       Shop #: WSC 05120
       VCID: 2C020EDDDF2F4687D71-5042
    Address 63: Entry Assist,D        Labels: None
       Part No: 8H0 959 760 A
       Component: EasyEntry F M H13   0010
       Coding: 00006
       Shop #: WSC 00065
       VCID: 35342BB90C65074FB8F-4B1E
    Address 73: Entry Assist, P        Labels: None
       Component: EasyEntry BF  H13   0010
       Coding: 00005
       Shop #: WSC 00065
    01733 - Switch for Head-Rest Adj. Pass. Seat (E170); Down
                28-10 - Short to Plus - Intermittent
    End----------(Elapsed Time: 02:06, VBatt start/end: 13.9V/13.9V)-----------
  2. Likes Uwe, Andy liked this post
  3. #12
    OBD2 map
    ;33-OBD2
    ;Tuesday,12,September,2017,16:57:42:18206
    ;VCDS Version: Release 17.9.0  Data version: 20170721 DS277.0
    ;VCID: 55F48B39AC05274F58F-513C
    04,Calculated load value,0.0 %
    05,Engine coolant temperature,77 °C
    06,Short Term Trim - Bank 1,0.0 %
    07,Long Term Trim - Bank 1,4.7 %
    08,Short Term Trim - Bank 2,0.0 %
    09,Long Term Trim - Bank 2,0.8 %
    0C,Engine RPM,0 /min
    0D,Vehicle speed,0 km/h
    0E,Ignition timing advance for cyl #1,0.0 Degrees
    0F,Intake air temperature,69 °C
    10,Mass Air Flow,0.00 g/s
    11,Throttle position sensor,15.7 %
    12,Secondary Air Status,Atmosphere/off
    13,Location of O2 sensors,B1S1 B1S2 ,B2S1 B2S2
    15,Bank 1 Sensor 2 Status,0.450 V
    19,Bank 2 Sensor 2 Status,0.450 V
    1C,OBD Requirements Met,OBD + OBD II
    34,Bank 1 Sensor 1 Status,1.003 Lambda,0.000 mA
    38,Bank 2 Sensor 1 Status,1.003 Lambda,-0.008 mA
  4. Likes Uwe, NEtech, Andy liked this post
