Page 55 of 68 FirstFirst ... 545535455565765 ... LastLast
Results 541 to 550 of 678
Thread: EV Thread
  1. #541
    Administrator Andy's Avatar
    Sector 7G
    I'm skeptical of the solar panels delivering that much power. I get about 4 miles per hour from 1kW on a stenchin cord. 7.5 miles/hr would be almost double that assuming similar efficiency. Rooftop solar arrays are much bigger than 5 square meters, IIRC.
  2. Likes D-Dub liked this post
  3. #542
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    You're right to be skeptical, but as an example, even cut in half, that covers my wife's commute with a side trip to the grocery store with room to spare.
    Plus, with the panels and charge control right on board, you get to skip a lot of wiring, plus an AC to DC conversion, possibly two if they can charge individual blocks of batteries well matched to the panel output without having to step up to the full pack voltage.
    Silence gives consent.
  4. Likes D-Dub liked this post
  5. #543
    Question is whether it really makes sense to embed the panels in the car?
    For $120k I could buy an e-tron quattro or a pretty nice Tesla and put a much bigger array of panels on the roof of my garage.
    Am I the only one here who would be reluctant to park a car that expensive out in the elements all the time?
  6. Likes PetrolDave, D-Dub liked this post
  7. #544
    Cincinnati, OH
    As a matter of efficiency no, it probably makes little sense unless they made a lot of strides truly integrating solar as structural bodywork rather than just a layer on top. As a matter of convenience, possibly yes. That's what I think is interesting about their car.
    Along those lines, I'm surprised we haven't seen more innovation in auto-docking of some sort. I understand electrifying roads is horrifically expensive, but I would've thought there'd be a residential (or Supercharger) docking solution by now. I know Elon had that "don't drop the soap" robot a while back, but I never saw anything else come out.
  8. #545
    Funny you should mention that. VAG already has dozens of fault codes defined for an inductive charging plate solution. From what I've been able to gather, the car will be able to position itself over the plate, which then rises out of the floor to within some minimal distance of a pickup coil in the car. I'm not sure what car this will actually be implemented in or when, but it's clearly something they're working on.
    Caveat: It wouldn't be the first time they've defined fault codes for something that never got sold. They also have fault codes for 16-cylinder diesel engines.
  9. Likes jyoung8607, NZDubNurd, PetrolDave, Eric liked this post
  10. #546
    Yeah, that is a great question.
    Ideally this kind of stuff would start on BUS's and semi's (trailers), and RV's (my dream a volt style RV primarily powered by electricity generated by solar, with some kind of 'range extender', be it gas/diesel/hydrogen or kerosene or even used fryer oil).
  11. #547
    Sector 7G
    More on the Buzz Lightyear car:
  12. Likes D-Dub liked this post
  13. #548
    OMG. I'm currently working on those for French...
  14. #549
  15. #550
    Cincinnati, OH
    /r/BrandNewSentence
