Results 1 to 2 of 2
Thread: Race seaats - Audi TTS 2016
    Jun 2015
    None of the forum Recipes online have given me a solution: insert 4.7ohm resistors to the yellow plug under the carpet where the seats plug in but still get error lights and messages. Seat belt clips are attached to race seats for street use, but they are also not plugged into anything, Im sure they were connected to the pressure sensor on the seats.
    The coding area on the 8S MK3 Audi apprears to be vastly different from what has been posted about where to look to code-out or otherwise interact with airbags. I also suspect that I can't disable an airbag if the airbag is not connected to the car as some options that sound like a seat airbag can't be configured.
    Any help?
    Thursday,27,July,2017,17:15:26:63869
    VCDS Version: 17.1.3.0 (x64)  HEX-NET CB: 0.4341.4
    2016 Audi TTS 8S MK3
    Chassis Type: FV (8S0)
    Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 3C 42 44 47 52 55 5F
              6C A9
    VIN: TRUC1AFV3G1023480
    Address 01: Engine (J623-CYFB)       Labels: None
       Part No SW: 8S0 906 259 C    HW: 06K 907 425 E
       Component: 2.0l R4 TFSI  H13 0001
       Revision: --H13---
       Coding: 0A1D00322426000E3004
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM20TFS0208S0906259C 001003
       ROD: EV_ECM20TFS0208S0906259C.rod
       VCID: 3D32EE95AC88D3A9C2-8068
    21388 - Valve for Exhaust Flap 1 (N321)
              P3019 00 [104] - Open Circuit
                        Mileage: 18252 km
                        Date: 2017.07.06
                        Time: 15:12:21
                        Engine speed: 824.75 /min
                        Normed load value: 3.5 %
                        Coolant temperature: 89 °C
                        Intake air temperature: 71 °C
                        Voltage terminal 30: 11.816 V
                        Unlearning counter according OBD: 24
                        Engine: operating status: IS
                        STATE_LS_SAE[1]: OL_CDN
                        T_AST_SAE: 2 s
                        MAP_MES_SAE: 29 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                        FAC_TPS_1_SAE: 12.109375 %
                        FUP_H_SAE: 5820.0 kPa
    21399 - Valve for Exhaust Flap 2 (N322)
              P3023 00 [104] - Open Circuit
                        Mileage: 18252 km
                        Date: 2017.07.06
                        Time: 15:12:21
                        T_AST_SAE: 2 s
                        MAP_MES_SAE: 29 kPa
    21419 - Internal Control Module Error
              P2610 00 [032] - Engine Shut-down Timer
                        Mileage: 19134 km
                        Date: 2017.07.18
                        Time: 04:25:18
                        Engine speed: 1123.75 /min
                        Normed load value: 6.3 %
                        Coolant temperature: 48 °C
                        Intake air temperature: 45 °C
                        Voltage terminal 30: 11.582 V
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 43 kPa
                        FAC_TPS_1_SAE: 14.062500 %
                        FUP_H_SAE: 6370.0 kPa
    17178 - Databus
              U1123 00 [040] - Received Error Message
                        Mileage: 19134 km
                        Date: 2017.07.18
                        Time: 04:25:18
                        Engine speed: 1339.00 /min
                        Normed load value: 7.8 %
                        Coolant temperature: 22 °C
                        Intake air temperature: 25 °C
                        Voltage terminal 30: 11.621 V
                        Drivetrain coordinator: ACC fault status-ACC: Not active: although TSK passive
                        Drivetrain coordinator: ACC fault status-Start and stop request: Set at stopping speed
                        Drivetrain coordinator: ACC fault status-Bit 2: Not transmitted simultaneously
                        Drivetrain coordinator: ACC fault status-Bit 3: Does not reactivate after DTC-induced shutdown
                        Drivetrain coordinator: ACC fault status-Bit 4: Not active when limiter active
                        Drivetrain coordinator: ACC fault status-Bit 5: Transmits no undefined signals
                        Drivetrain coordinator: ACC fault status-Bit 6: Not active when main switch off
                        Drivetrain coordinator: ACC fault status-Bit 7: Not active when driver braking
                        Drivetrain coordinator: ACC fault status-Bit 8: Not active during the EPB emer. braking
                        Drivetrain coordinator: brake fault status-ESP: no error
                        Drivetrain coordinator: brake fault status-Deceleration controller: Available
                        Drivetrain coordinator: brake fault status-TSK/ESP handshake: no error
                        Drivetrain coordinator: brake fault status-Bit 1: no error
                        Drivetrain coordinator: brake fault status-Bit 3: Not malfunction due to inaccurate engine torque
                        Drivetrain coordinator: brake fault status-Bit 4: No indication of TSK message consistency error
                        Drivetrain coordinator: brake fault status-Bit 6: Automatic engagement OK
                        Drivetrain coordinator: brake fault status: 5
                        Drivetrain coordinator: brake function status-Parking Brake: not active
                        Drivetrain coordinator: brake function status-ACC: Not braking
                        Drivetrain coordinator: brake function status-ESP: Not invoking TSK braking
                        Drivetrain coordinator: brake function status-Driver: Not braking
                        Drivetrain coordinator: brake function status-Hill descent control: passive
                        Drivetrain coordinator: brake function status-ASR: no intervention
                        Drivetrain coordinator: brake function status-MSR: no intervention
                        Drivetrain coordinator: brake function status-ADS: no intervention
                        Drivetrain coordinator: brake function status-ABS: no intervention
                        Drivetrain coordinator: brake function status-EDL: no intervention
                        Drivetrain coordinator: brake function status-ASP: no intervention
                        Drivetrain coordinator: brake function status-AWV2: No warning pressure
                        Drivetrain coordinator: brake function status-Bit 4: no intervention
                        Drivetrain coordinator: brake function status-Bit 11: not passively cycled
                        Drivetrain coordinator: brake function status-Bit 12: not passively cycled
                        Drivetrain coordinator: brake function status-Bit 13: Standstill not detected
    Readiness: 0000 0001
       Part No SW: 0D9 300 013 D    HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H53 4905
       Revision: 06253104    Serial number: TFK01512051727
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021.rod
       VCID: 187C1F01E36AD68131-804C
       Part No SW: 8S0 907 379 D    HW: 8S0 907 379 D
       Component: ESC           H42 0522
       Revision: 00000000    Serial number: 63425000000324
       Coding: 24AA608D0A9B15AC0095086C8291910623240650A80010418960C4
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 060016
       ROD: EV_Brake1UDSContiMK100IPB_060.rod
       VCID: 42C89D69D576AC51BF-8016
    0297 - Steering Angle Sensor
              B1168 F2 [008] - Not Initialized
                        Reset counter: 242
                        Mileage: 19134 km
                        Date: 2017.07.18
                        Time: 04:25:17
    8216 - Databus
                        Reset counter: 241
                        Mileage: 19134 km
                        Date: 2017.07.20
                        Time: 00:00:25
                        Reset counter: 241
                        Mileage: 18252 km
                        Date: 2017.07.06
                        Time: 15:03:26
    32869 - Databus
              U1123 00 [137] - Received Error Message
                        Reset counter: 201
                        Mileage: 19134 km
                        Date: 2017.07.18
                        Time: 17:14:49
       Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
       Component: VWKESSYMQB    036 0710
       Revision: 00036000    Serial number: 0389859552
       Coding: 030C0C1720
       ASAM Dataset: EV_KessyHellaMQBAB 004032
       VCID: 3A38E589BDA6E491E7-806E
    Address 08: Auto HVAC (E87)       Labels: None
       Part No SW: 8S0 820 043     HW: 8S0 820 043
       Component: AC Automat    H05 0030
       Revision: 20009000    Serial number: 16060000009000
       Coding: 400040100001041100
       ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
       ROD: EV_AirCondiVAPrehAU33x.rod
       VCID: 6C9413D187728A2125-8038
       Serial number: 8AE80A08000000000001
       Operating and display unit 1 for air conditioning:
       Subsystem 2 - Part No SW: 8S0 820 373 A    HW: 8S0 820 373 A
       Component: E774 BuA_1  H07 0020
       Serial number: 00000000000000023249
       Operating and display unit 2 for air conditioning:
       Subsystem 3 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
       Component: E775 BuA_2  H07 0020
       Operating and display unit 3 for air conditioning:
       Subsystem 4 - Part No SW: 8S0 820 359     HW: 8S0 820 359
       Component: E776 BuA_3  H07 0020
       Operating and display unit 4 for air conditioning:
       Subsystem 5 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
       Component: E777 BuA_4  H07 0020
       Operating and display unit 5 for air conditioning:
       Subsystem 6 - Part No SW: 8S0 820 373 B    HW: 8S0 820 373 B
       Component: E778 BuA_5  H07 0020
       Part No SW: 5Q0 937 085 BH    HW: 5Q0 937 085 AF
       Component: BCM MQBAB HNA H24 0175
       Serial number: 01061600900137
       Coding: 040D5C46C80106FD41444004531007A80080000000000000000000000000
       ROD: EV_BCMBOSCH_016_AU37.rod
       VCID: 004C57619BFA7E41E9-8054
       Subsystem 1 - Part No SW: 8S1 955 119 B    HW: 8K1 955 119 B  Labels: 5QX-955-119-V1.CLB
       Component: 43x LL 151127  038 0371
       Serial number: 00000001511260301922
       Coding: 1BC7F7
       Serial number: 61139713
       Coding: 00005D
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
       Serial number: 22 09 2015  00000318
       Subsystem 4 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
       Component: USHL5  H04 0040
       Serial number: 0000009600335Z0DSO02
       Coding: 150000
       Subsystem 5 - Part No SW: 8S0 959 719     HW: 8S0 959 719
       Component: GTO BF  H05 0010
       Serial number: 20151215154112 00455
       Subsystem 6 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
       Serial number: 00000000000064541528
              B1806 F0 [009] - Safety Shut-Off due to Occupant Detection
                        Reset counter: 201
                        Mileage: 19134 km
                        Date: 2017.07.20
                        Time: 00:00:28
    558100 - Databus
                        Reset counter: 201
                        Mileage: 19134 km
                        Date: 2017.07.20
                        Time: 00:00:28
    572164 - Control Module for Multi-Contour Seat; Driver Side
              U1083 00 [009] - No Communications
                        Reset counter: 201
                        Mileage: 1048574 km
    576260 - Control Module for Multi-Contour Seat; Passenger Side
              U1085 00 [009] - No Communications
                        Reset counter: 201
                        Mileage: 19134 km
                        Date: 2017.07.20
                        Time: 00:00:01
    Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
       Revision: --------    Serial number: 39391534909766
       Coding: 0070150011
       VCID: 43C6986DCA6CA559B4-8016
    13637426 - Databus
                        Reset counter: 241
                        Mileage: 19134 km
                        Date: 2017.07.18
                        Time: 17:14:48
       Part No SW: 8V0 907 376 E    HW: 8V0 907 376 E
       Component: DAEMPFUNGS-SG H09 0072
       Serial number:       111215031
       ASAM Dataset: EV_AudiMagneRide 002003
       ROD: EV_AudiMagneRide_002_AU37.rod
    10522629 - Databus
                        Reset counter: 241
                        Mileage: 19134 km
                        Date: 2017.07.18
                        Time: 17:14:48
                        COM: 09 F8 09 D9 00 00 05 4A 00 00
                        Voltage terminal 30: 11.9 V
                        Terminal 15 status via CAN: Terminal 15 on
                        Steering angle: Not available
                        Steering rate: 0 rad/s
                        AMR state: 0
                        Damping adjustment indicator lamp: OFF
                        ESP automatic engagement: not activated
                        Fall-back level: 00 00 10 20
    10522630 - Databus
                        Reset counter: 241
                        Mileage: 19134 km
                        Date: 2017.07.18
                        Time: 17:14:48
                        COM: 09 F8 09 D9 00 00 05 4B 00 00
                        AMR state: 0
    10526728 - Databus
                        Reset counter: 242
                        Mileage: 19134 km
                        Date: 2017.07.18
                        Time: 17:14:52
                        COM: 09 E8 09 E8 00 00 16 2A 00 00
                        Voltage terminal 30: 13.8 V
                        AMR state: 6
                        Damping adjustment indicator lamp: On
                        Time since terminal 15 off: Not available
                        Outside air temperature via CAN: 26.0 °C
                        ESP automatic engagement: activated
       Part No SW: 5Q0 959 655 R    HW: 5Q0 959 655 R
       Serial number: 003M9R002EVM
       Coding: BFCCF0C000800000A000001FC24800000065
       VCID: 4FEEA45D1624513920-801A
       Occupant Detection:
       Subsystem 1 - Part No SW: -----------    HW: -----------
       Component: BF-Gewichtss.  --- ----
       Serial number: ---00000000000-----U
       Subsystem 2 - Part No SW: -----------    HW: 480 000 401 16
       Serial number: 35700000000D8744471K
       Subsystem 3 - Part No SW: -----------    HW: 480 000 401 16
       Serial number: 3580000000085744471D
       Subsystem 4 - Part No SW: -----------    HW: 480 012 311 15
       Component: SideSensor_Dr  004 0108
       Serial number: 351001A056661EF47C5F
       Subsystem 5 - Part No SW: -----------    HW: 480 401 609 15
       Serial number: 3550002C51D1B5D4A19E
       Front Sensor Passenger:
       Subsystem 6 - Part No SW: -----------    HW: 480 401 609 15
       Serial number: 3560002C51D1B5D35289
    7 Faults Found:
    9440027 - Driver's side; side-airbag igniter
              B100B 1B [137] - Resistance Too High
                        Mileage: 19134 km
                        Date: 2017.07.18
                        Time: 04:25:17
    9439771 - Front Passenger's Side Airbag Igniter
              B100A 1B [137] - Resistance Too High
                        Mileage: 19134 km
                        Date: 2017.07.20
                        Time: 00:00:24
    9444373 - Safety belt switch - driver side
              B101C 15 [137] - Open or Short to Plus
                        Mileage: 19134 km
                        Date: 2017.07.18
                        Time: 17:14:48
    9444629 - Safety belt switch - passenger side
              B101D 15 [137] - Open or Short to Plus
                        Mileage: 19134 km
                        Date: 2017.07.20
                        Time: 00:00:25
    9444885 - Driver's seat position sensor
              B101E 15 [137] - Open or Short to Plus
                        Mileage: 19134 km
                        Date: 2017.07.18
                        Time: 17:14:48
    9445141 - Passenger's seat position sensor
              B101F 15 [137] - Open or Short to Plus
                        Mileage: 19134 km
                        Date: 2017.07.20
                        Time: 00:00:25
    9445937 - Seat occupied recognition control module
              B1022 31 [137] - No Signal
                        Reset counter: 201
                        Mileage: 19134 km
                        Date: 2017.07.20
                        Time: 00:00:28
       Part No SW: 8S0 907 129 AJ    HW: 8S0 907 129 AJ
       Component: Lenks. Modul  H07 0140
       Revision: --------    Serial number: 91335PAB00866
       Coding: 2058
       ASAM Dataset: EV_SMLSKLOMQB 019002
       ROD: EV_SMLSKLOMQB_AU37.rod
       VCID: 02485D6995F66C51FF-8056
    Address 17: Instruments (J285)       Labels: Redir Fail!
       Part No SW: 8S0 920 890 A    HW: 8S0 920 890 A
       Component: FBenUSA       H35 0264
       Coding: 086F08413989D7050221E8C09800800000000000
       ASAM Dataset: EV_DashBoardBOSCHAU33X 001020
       ROD: EV_DashBoardBOSCHAU33X.rod
       VCID: 383CFF8183AAF68111-806C
    16776966 - Databus
                        Reset counter: 241
                        Mileage: 19134 km
                        Date: 2017.07.20
                        Time: 00:00:25
       Part No SW: 8S0 907 468 C    HW: 8S0 907 468
       Component: GW MQB TT3    012 0244
       Revision: --------    Serial number: 09121510802289
       Coding: 0301000424025A004B000228B80000000000000000000000000000000001
       ASAM Dataset: EV_GatewContiAU33X 011003
       ROD: EV_GatewContiAU33X.rod
       VCID: 40CC9761DB7ABE41A9-8014
       Subsystem 2 - Part No SW: 8S0 951 523 C    HW: 8S0 951 523 C
       Component: J453 MFL  H07 0002
       Serial number: 20151214121441 01091
       Subsystem 3 - Part No SW: 8S0 915 181 A    HW: 8S0 915 181 A
       Serial number: 3764008303
    131698 - No Communcation  with Control Module for Electronic Suspension Damping
              U0139 00 [008] - -
                        Reset counter: 241
                        Mileage: 19134 km
                        Date: 2017.07.20
                        Time: 00:00:27
                        Supply voltage: Terminal 30: 11.8 V
                        Terminal 15: On
    Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
       Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7754
       Serial number: HA1-00026.11.15
       Coding: 0101
       ROD: EV_AllWheelContrHA1VW37X_SK12.rod
       VCID: 45C28675C4589B699A-8010
    Address 3C: Lane Change (J769)       Labels: 5Q0-907-566.clb
       Part No SW: 8S0 907 566     HW: 4H0 907 566 F
       Component: SWA Master    H08 0050
       Serial number: 0388715503
       Coding: 030311
       ROD: EV_LaneChangAssis_VW51.rod
       VCID: 7CB42391F7121AA1B5-8028
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 8S0 907 568     HW: 4H0 907 568 F
       Component: SWA Slave  H08 0050
       Serial number: 0388697105
       Coding: 030311
       Serial number: 281015BJO20231
       Coding: 001F53225C00040100000402
       Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
       Component: EPS_MQB_ZFLS  505 5063
       Coding: 8102
       ROD: EV_SteerAssisMQB_VW31.rod
       VCID: 393AFA85B8A0EF89EE-806C
       Part No SW: 8S0 035 465 C    HW: 8S0 035 465
       Component: MIB2_amp_P_TT H06 0240
       Revision: 00000001    Serial number: AUZ8ZAFH700F8EW
       Coding: 0133040000AA2A2AAA0000010000
       ASAM Dataset: EV_AMPMst16C1Gen2ALPI 001012
       ROD: EV_AMPMst16C1Gen2ALPI_AU37.rod
       VCID: 3522F6B594B80BE90A-8060
       Serial number: 291015BJS16569
       Coding: 001F53225E00040100000402
    Address 55: Headlight Range (J745)       Labels: None
       Part No SW: 4H4 907 357 G    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0115
       Coding: 0362001123200400
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005012
       VCID: 3620F1B989BE00F103-8062
       Coding: E01800
       Coding: E01800
       Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H02 S002
       Coding: E01800
       Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H02 S002
       Coding: E01800
    13705473 - Databus
                        Reset counter: 241
                        Mileage: 19134 km
                        Date: 2017.07.20
                        Time: 00:00:27
    Address 5F: Information Electr. (J794)       Labels: Redir Fail!
       Part No SW: 8S0 035 025 A    HW: 8S0 035 025
       Component: MU-H-LNS-US   043 0376
       Serial number: A263L0FB001269
       Coding: 013354020000000011220002041A00102F0000E1007000047E
       VCID: 2B16D0CD42FC4D196C-807E
       Subsystem 1 - Part No SW: V03 959 801 GE    HW: -----------
       Component: NAR 2016  --- 0048
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8S0 919 614 L    HW: 8S0 919 614 L
       Component: ControlUnit_H  H22 0136
       Serial number: APVAK109111500010173
       Component: Gracenote2  --- 3007
              U11B8 00 [008] - No Communications
                        Reset counter: 236
                        Mileage: 18901 km
                        Date: 2017.07.13
                        Time: 14:40:30
                        Voltage terminal 30: 13.2 V
                        Interface for external media: status-Status: Open circuit
    6666 - Optical data bus
              U1049 00 [008] - Open circuit
                        Reset counter: 241
                        Mileage: 19134 km
                        Date: 2017.07.20
                        Time: 00:00:37
                        Voltage terminal 30: 13.1 V
                        Temperature of MOST transceiver-Maximum value: -50 °C
                        Temperature of MOST transceiver-Minimum value: -8 °C
                        Temperature of MOST transceiver-Current: 22 °C
    Address 6C: Back-up Cam. (J772)       Labels: 5Q0-980-556.clb
       Part No SW: 5Q0 980 556 A    HW: 5Q0 980 556
       Component: RVC Compact   H08 0172
       Coding: 0233540102002001000040
       ROD: EV_CamSysRVRVCPANAMQBAB_VW37.rod
       Part No SW: 8S0 907 159 A    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0005
       Serial number: 151028202896
       ROD: EV_SoundActuaGen2AU64X_VW26.rod
       VCID: 3B36E08DB29CDD99FC-806E
    End----------(Elapsed Time: 01:41, VBatt start/end: 12.1V/12.1V)-----------
    Sunday,30,July,2017,18:08:40:63869
    VIN: TRUC1AFV3G1023480   License Plate: BBB
              6C A9
       Revision: --H13---
    32869 - Databus
                        Reset counter: 202
                        Mileage: 19169 km
                        Date: 2017.07.27
                        Time: 17:16:40
       Coding: 030C0C1720
       Coding: 1BC7F7
       Coding: 00005D
       Light switch:
       Coding: 150000
                        Reset counter: 202
                        Mileage: 19169 km
                        Date: 2017.07.27
                        Time: 17:16:41
    558100 - Databus
                        Reset counter: 202
                        Mileage: 19169 km
                        Date: 2017.07.27
                        Time: 17:16:41
                        Reset counter: 202
                        Mileage: 19169 km
                        Date: 2017.07.27
                        Time: 17:16:37
                        Reset counter: 202
                        Mileage: 19169 km
                        Date: 2017.07.27
                        Time: 17:16:38
       Coding: 0070150011
    3162116 - Valve for Damping Adjustment Rear Right
              C1043 13 [008] - Open Circuit
                        Reset counter: 245
                        Mileage: 19390 km
                        Date: 2017.07.28
                        Time: 10:52:13
                        COM: B9 31 00 00 00 00 00 00 00 00
                        Voltage terminal 30: 12.8 V
                        Vehicle_level_sender_PWM-Left front: 40.8 %
                        Vehicle_level_sender_PWM-Right front: 28.4 %
                        Vehicle_level_sender_PWM-Left rear: 26.0 %
                        Vehicle_level_sender_PWM-Right rear: Not available
                        AMR state: 0
                        Dampening adjustment: current Highside-Left front: 2230 mA
                        Dampening adjustment: current Highside-Right front: 1685 mA
                        Dampening adjustment: current Highside-Left rear: 1910 mA
                        Dampening adjustment: current Highside-Right rear: -11 mA
                        Dampening adjustment valve: current Lowside-Left front: 2240 mA
                        Dampening adjustment valve: current Lowside-Right front: 1689 mA
                        Dampening adjustment valve: current Lowside-Left rear: 1916 mA
                        Dampening adjustment valve: current Lowside-Right rear: -8 mA
                        Fall-back level: 00 00 06 42
       Occupant Detection:
    7 Faults Found:
              B100B 1B [136] - Resistance Too High
                        Mileage: 19169 km
                        Date: 2017.07.27
                        Time: 17:16:37
              B100A 1B [136] - Resistance Too High
                        Mileage: 19169 km
                        Date: 2017.07.27
                        Time: 17:16:37
                        Mileage: 19169 km
                        Date: 2017.07.27
                        Time: 17:16:39
                        Mileage: 19169 km
                        Date: 2017.07.27
                        Time: 17:16:38
                        Mileage: 19169 km
                        Date: 2017.07.27
                        Time: 17:16:39
                        Mileage: 19169 km
                        Date: 2017.07.27
                        Time: 17:16:39
                        Reset counter: 202
                        Mileage: 19169 km
                        Date: 2017.07.27
                        Time: 17:16:41
       Coding: 2058
       Coding: 0101
       Coding: 030311
       Coding: 030311
       Coding: 8102
       Coding: E01800
       Coding: E01800
       Coding: E01800
       Coding: E01800
    End----------(Elapsed Time: 01:37, VBatt start/end: 12.2V/12.2V)-----------
    Jun 2015
    the above is what greeted me after reconnecting battery. This is what is left after clearing DTC codes:
    Thursday,27,July,2017,17:23:28:63869
    VIN: TRUC1AFV3G1023480 License Plate: BBBARISEATSBAG
    Address 15: Airbags Labels: 5Q0-959-655.CLB
    Control Module Part Number: 5Q0 959 655 R HW: 5Q0 959 655 R
    Component and/or Version: AirbagVW20 010 0830
    Software Coding: BFCCF0C000800000A000001FC24800000065
    Work Shop Code: WSC 06385 790 00016
    ASAM Dataset: EV_AirbaVW20SMEVW37X 002144 (AU37)
    7 Faults Found:
    Mileage: 19169 km
    Date: 2017.07.27
    Time: 17:16:37
    Mileage: 19169 km
    Date: 2017.07.27
    Time: 17:16:37
    Mileage: 19169 km
    Date: 2017.07.27
    Time: 17:16:39
    Mileage: 19169 km
    Date: 2017.07.27
    Time: 17:16:38
    Mileage: 19169 km
    Date: 2017.07.27
    Time: 17:16:39
    Mileage: 19169 km
    Date: 2017.07.27
    Time: 17:16:39
    Reset counter: 202
    Mileage: 19169 km
    Date: 2017.07.27
    Time: 17:16:41
