Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Golf MK6 Bluetooth retrofit problem
    Jul 2017
    Quote Originally Posted by m87a View Post
    when you connect to bluetooth go to settings and allow rsap and audio, it could be disabled which will cause this issue
    I have already enabled everything I could find.
  2. #12
    Tartu, Estonia
    I would suggest coding 020100000100000000000101 which worked very well in my Passat with retrofitted BT. You need to disable antenna diagnostic though and check the LC-helper for anything obvious mismatch.
    But please describe what doesn't work or how You are trying to connect. If you need live help i might be able to help you via Skype or whereever
    The world is my oyster...
  3. #13
    Jul 2017
    My main problem right now is that rsap or a2dp doesn't work. I can't change track from radio nor can I create wifi.
    I will give your coding suggestion a try when I get a chance.
  4. #14
    United States
    Please try the coding suggestion from golfi_vend first. This is what I came up with after reading the email:
    020000010100010000000100
  5. Likes Uwe, Persojet liked this post
  6. #15
    Jul 2017
    Hi, Tried them both out. Neither did any good :/
  7. #16
    Jan 2015
    Bosnia and Herzegovina
    if all of this didn't help, my opinion is that your rcd is causing issues? can you try to swap your bluetooth to other vehicle to test it?
  8. #17
    Jul 2017
    I tried coding Telephone CAN on for radio but it rejects my coding attemps.
    Unfortunately I can't get another car to try on.
  9. #18
    Jul 2017
    Quote Originally Posted by Persojet View Post
    Seems to be impossible. I'm probably going to return the product to seller. Any suggestions to what module get next to give a try? My main needs would be A2DP and making phonecalls.
