Results 1 to 10 of 13
Thread: 2007 Passat 1.9 TDI won't go up a hill wiithout Limp Mode
    Stoke on Trent, England
    2007 Passat 1.9 TDI won't go up a hill only wiithout Limp Mode
    Hi Guys/gals.
    I have a friend who lives local with this problem with her 2007 Passat 1.9 TDI-PD BXE.
    It only goes up a hill the Malfunction Indicator Lamp (MIL)(K83) comes on. If the car stops and the turn the ignition off. Start up everything is ok.
    On level ground or down bank the car performs normally is only when it goes up an hill/bank/incline.
    She has had it in garages for this problem. A new MAF sensor fitted, the turbo removed and cleaned.
    I said pop down for a scan and check.
    its the 000564 - Boost Pressure Regulation P0234 rather than the other 2 faults
    Saturday,29,July,2017,14:12:01:21184
    VCDS Version: 17.1.3.0
    VIN: WVWZZZ3CZ7E******   License Plate: 2007 PASSAT 1.9 TDI BXE
    Mileage: 218320km-135657mi   Repair Order:
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56
    VIN: WVWZZZ3CZ7E152807   Mileage: 218320km-135657miles
    Address 01: Engine        Labels: 03G-906-016-BKC.clb
       Part No SW: 03G 906 021 LR    HW: 03G 906 021 AN
       Component: R4 1,9L EDC  000SG  9248
       Revision: --H06---    Serial number: VWZCZ000000000
       Coding: 0000071
       Shop #: WSC 00011 888 181093
       VCID: 7AFE7F54358D9991A7-802E
                   P0234 - 000 - Limit Exceeded (Overboost Condition) - Intermittent
                        Fault Status: 00110000
                        Mileage: 218312 km
                        Time: 12:44:49
                        RPM: 2814 /min
                        Speed: 69.0 km/h
                        Load: 72.2 %
                        Voltage: 14.52 V
                        Bin. Bits: 11000000
                        Absolute Pres.: 1907.4 mbar
                        Absolute Pres.: 2315.4 mbar
    Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
       Part No SW: 3C0 614 109     HW: 3C0 614 109
       Component: ESP 440 C4     H018 0001
       Revision:  H018       Serial number: 0668304814
       Coding: 0013569
       Shop #: WSC 05311 000 00000
       VCID: 5BB01AD09A774099DC-800E
       Part No: 1K0 820 047 GK
       Component: Climatic PQ35   120 0606
       VCID: 73E0527012E7E8D9E4-8026
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
       Part No SW: 3C0 937 049 AD    HW: 3C0 937 049 AD
       Component: Bordnetz-SG     H52 2002
       Revision: 00H52000    Serial number: 00000006460210
       Coding: 00880F0700041A00470A00000F000000000859435C0001
       VCID: 6BD04A104AD730192C-803E
       Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer 121206 022  0601
       Coding: 00046997
       Shop #: WSC 05311
       Part No SW: 3C0 909 605 M    HW: 3C0 909 605 M
       Component: 0C AIRBAG VW8   031 2522
       Revision: 11031000    Serial number: 003B1PRGKS35
       Coding: 0012355
       VCID: 306A9D7CA37193C159-8064
       Subsystem 1 - Serial number: 6332MSME1434656B
       Subsystem 2 - Serial number: 6342MSME15011F3F
       Subsystem 3 - Serial number: 6351HTS6GIE86N56
       Subsystem 4 - Serial number: 6361HTS62AD01N67
       Part No SW: 3C0 953 549 J    HW: 3C0 953 549 J
       Component: Lenksäulenmodul 006 0010
       Revision: 00006000    Serial number: 3C9953507AA
       Coding: 0000004
       VCID: 336092705267A8D924-8066
    00888 - Wiper Switch for Intermittent Operation (E22)
       Part No SW: 3C0 920 960 K    HW: 3C0 920 960 K
       Component: KOMBIINSTRUMENT VD1 1614
       Revision: V0007000    Serial number: 00000000000000
       Coding: 0007405
       Shop #: WSC 12345 067 57207
       VCID: 2B508A108A57F0196C-807E
    Address 19: CAN Gateway        Labels: 3C0-907-530-V1.clb
       Revision: 00007000    Serial number: 0700C06C0601DC
       Coding: 3D3D0C04C22003
       VCID: 214C6838F89B2A49C6-8074
       Part No SW: 3C0 959 433 AB    HW: 3C0 959 433 AB
       Component:    IMMO         043 0383
       Shop #: WSC 00706 210 72041
       VCID: 6ADE4F14452D291157-803E
       Subsystem 1 - Part No: 3C0 905 861 H
       Component:    ELV          028 0380
       3C0905861H     ELV          028 0380
    02823 - Requirements for Locking the Steering Column Lock not met
                000 -  -  - Intermittent
                        Reset counter: 243
                        Mileage: 218266 km
                        Time: 14:51:57
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.clb
       Component: J386  TUER-SG FT    1132
       Revision: 32008001    Serial number: 00000020869210
       Coding: 0000565
       VCID: 3B70BA507A376099FC-806E
       Part No: 1K2 909 144 L
       Component: EPS_ZFLS Kl.134 H07 1806
       VCID: 3564AC685C13B6E90A-8060
       Component:    KSG PQ46 ELV 043 0472
       Coding: 0191020851030E763004941570085BCE103CA0
       Component: LIN BACKUP HORN H07 8003
       Subsystem 2 - Part No: 3C0 951 171 A
       Component: Neigungssensor  002 0508
       Subsystem 3 - Part No: 3C0 951 171 A
       Component: Innenraumueberw.002 0508
    01134 - Alarm Horn (H12)
                        Fault Frequency: 111
                        Reset counter: 247
                        Mileage: 217916 km
                        Time: 17:29:45
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.clb
       Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
       Component: J387  TUER-SG BT    1132
       Revision: 32008001    Serial number: 00000083269216
       Coding: 0000564
       VCID: 3C72B94C7F3967A1F5-8068
       Part No SW: 3C0 907 801 G    HW: 3C0 907 801 G
       Component: EPB  VD8HC005   013 0005
       Revision:   013
       Coding: 0000011
       Shop #: WSC 00700 210 88118
       VCID: 26467B2491B5CD71B3-8072
       Part No: 1K0 035 186 T
       Component: Radio GR0       020 0023
       Revision: 0002006S    Serial number: VWZ2Z2F1711821
       Coding: 0020200
       Shop #: WSC 05314 000 00000
       VCID: 3778A660461F44F918-8062
    End-------------------------(Elapsed Time: 01:29)--------------------------
    I know Limp Mode can be bad vacuum pipes/connections, I had a look around and they look good.
    Limp mode: What is it, what are the causes, and how to fix it for the Audi and VW TDI diesel turbo
    http://wiki.ross-tech.com/wiki/index...8/P0234/000564
    Check Charge Pressure Control System
    Perform Output Test (to check the Turbo Charger)
    Perform Basic Setting (to check the Charge Pressure Control)
    How do you Perform Basic Setting (to check the Charge Pressure Control)?
    I checked the MAF sensor in MVB 011 and it appears to be working ok.
    I saved the MAF sensor CSV file but you can't add any files to this forum.
    Any suggestion of things to check? Any help would be appreciated.
    New User Keith
    Jul 2014
    Yorkshire
    basic settings 011
    Thanks for the response.
    I've changed the title slightly to hill only. Driving the car on level ground or down bank no problem its only when you go up a bank. She turns the car off, starts it back up and the MIL clears and it ok until she find another bank.
    I thought is there something in the fuel tank floating about and it blocks the pickup pipe when you go up a bank.
    I said I checked MVB 011 and showed the VC-Scope and saved the CSV file. When I clicked on Log I couldn't save the MAF values shown to a text file it just flicked over to the VC-Scope.
    I'm sure I've mentioned this before. Have you have done an AutoScan and saved the file there is a popup that always shows you can click to open the log folder which I know where it is. When you close the popup is ALWAYS asks are you sure you want to close this. Its as though if you close it you loose the saved file. I've always found that very annoying.
    Any one else found that?
    New User Keith
    Keith........
    Here's the scope.....The boost is in a positive deviation under load request and exceeding the boost target by 150-200MBAR then causing limp mode enacted since out of the diagnostic stacks adaptive target range/threshold.
    The WG or VNT is stuck on within the turbo more than likely from carbon but the WG could also be set wrong or in mechanical failure.
    It is also possible in some cases the intake or EGR could be so restricted that it pings the MAP sensor into thinking a positive deviation is present.
    Please investigate it.......
  5. Likes Uwe, ivagp liked this post
    I posted this problem on my other forum. A reply came back saying it can be a bad camshaft.
    http://www.myturbodiesel.com/threads...mp-mode.31155/
    A bad camshaft will effect performance all through the rev range not just Limp Mode on banks.
    New User Keith
    Sure a PD could have a faulty cam or lifters also causing this especially if FOD programmed.......... so that would be correct but usually you would get some popping from incomplete combustion and misfires......
    JPPSG
    Yes I know about the bad camshafts, this engine is quiet. What the AutoScan doesn't show is its done 140,000 miles. As I've said:
    A bad camshaft will effect performance all through the rev range not just Limp Mode on banks. They rattle when the valve lifter bucket breaks up.
    New User Keith
  9. #8
    I spoke to the owner tonight did she get my email with the log file. She said yes but the car is now fixed.
    How is it fixed I asked. She took it to a taxi company and told them of her problem. They said that's normal for a TDI.
    They went out for a test drive and it went into Limp Mode on a level road. That's just a woman's diagnostic procedure hill only. They came back and plugged in their diagnostic scanner and it showed at problem with the Exhaust Gas Recirculation (EGR) Valve. They removed it and it was blocked with crap. They cleaned it and put it back and on the test drive it didn't go into Limp Mode.
    I asked did she notice the scanner they used make/model/colour no she didn't. Being a taxi company with different makes and models it would have been a good generic one.
    There are 132 codes for Exhaust Gas Recirculation (EGR) why didn't VCDS pick up on this in the scan?
    New User Keith
  10. #9
    Quote Originally Posted by Keithuk View Post
    This question is poorly phased. It should be, "Why didn't this car's ECU set an EGR code?"
  11. Likes NEtech liked this post
  12. #10
    Ok why didn't VCDS read the ECU set and EGR code?
    New User Keith
