- Apr 18, 2014
- 679
- 216
- Stoke on Trent, England
- C?ID=122432
2007 Passat 1.9 TDI won't go up a hill only wiithout Limp Mode
Hi Guys/gals.
I have a friend who lives local with this problem with her 2007 Passat 1.9 TDI-PD BXE.
It only goes up a hill the Malfunction Indicator Lamp (MIL)(K83) comes on. If the car stops and the turn the ignition off. Start up everything is ok.
On level ground or down bank the car performs normally is only when it goes up an hill/bank/incline.
She has had it in garages for this problem. A new MAF sensor fitted, the turbo removed and cleaned.
I said pop down for a scan and check.
its the 000564 - Boost Pressure Regulation P0234 rather than the other 2 faults
I know Limp Mode can be bad vacuum pipes/connections, I had a look around and they look good.
Limp mode: What is it, what are the causes, and how to fix it for the Audi and VW TDI diesel turbo
http://wiki.ross-tech.com/wiki/index.php/16618/P0234/000564
Check Charge Pressure Control System
Perform Output Test (to check the Turbo Charger)
Perform Basic Setting (to check the Charge Pressure Control)
How do you Perform Basic Setting (to check the Charge Pressure Control)?
I checked the MAF sensor in MVB 011 and it appears to be working ok.
I saved the MAF sensor CSV file but you can't add any files to this forum.
Any suggestion of things to check? Any help would be appreciated.
Hi Guys/gals.
Saturday,29,July,2017,14:12:01:21184
VCDS Version: 17.1.3.0
VIN: WVWZZZ3CZ7E****** License Plate: 2007 PASSAT 1.9 TDI BXE
Mileage: 218320km-135657mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56
VIN: WVWZZZ3CZ7E152807 Mileage: 218320km-135657miles
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 021 LR HW: 03G 906 021 AN
Component: R4 1,9L EDC 000SG 9248
Revision: --H06--- Serial number: VWZCZ000000000
Coding: 0000071
Shop #: WSC 00011 888 181093
VCID: 7AFE7F54358D9991A7-802E
P0234 - 000 - Limit Exceeded (Overboost Condition) - Intermittent
Fault Status: 00110000
Mileage: 218312 km
Time: 12:44:49
RPM: 2814 /min
Speed: 69.0 km/h
Load: 72.2 %
Voltage: 14.52 V
Bin. Bits: 11000000
Absolute Pres.: 1907.4 mbar
Absolute Pres.: 2315.4 mbar
Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
Part No SW: 3C0 614 109 HW: 3C0 614 109
Component: ESP 440 C4 H018 0001
Revision: H018 Serial number: 0668304814
Coding: 0013569
Shop #: WSC 05311 000 00000
VCID: 5BB01AD09A774099DC-800E
Part No: 1K0 820 047 GK
Component: Climatic PQ35 120 0606
VCID: 73E0527012E7E8D9E4-8026
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 AD HW: 3C0 937 049 AD
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000006460210
Coding: 00880F0700041A00470A00000F000000000859435C0001
VCID: 6BD04A104AD730192C-803E
Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 121206 022 0601
Coding: 00046997
Shop #: WSC 05311
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 M HW: 3C0 909 605 M
Component: 0C AIRBAG VW8 031 2522
Revision: 11031000 Serial number: 003B1PRGKS35
Coding: 0012355
VCID: 306A9D7CA37193C159-8064
Subsystem 1 - Serial number: 6332MSME1434656B
Subsystem 2 - Serial number: 6342MSME15011F3F
Subsystem 3 - Serial number: 6351HTS6GIE86N56
Subsystem 4 - Serial number: 6361HTS62AD01N67
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 J HW: 3C0 953 549 J
Component: Lenksäulenmodul 006 0010
Revision: 00006000 Serial number: 3C9953507AA
Coding: 0000004
VCID: 336092705267A8D924-8066
00888 - Wiper Switch for Intermittent Operation (E22)
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 960 K HW: 3C0 920 960 K
Component: KOMBIINSTRUMENT VD1 1614
Revision: V0007000 Serial number: 00000000000000
Coding: 0007405
Shop #: WSC 12345 067 57207
VCID: 2B508A108A57F0196C-807E
Address 19: CAN Gateway Labels: 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C06C0601DC
Coding: 3D3D0C04C22003
VCID: 214C6838F89B2A49C6-8074
Part No SW: 3C0 959 433 AB HW: 3C0 959 433 AB
Component: IMMO 043 0383
Revision: 00043000 Serial number: VWZCZ000000000
Shop #: WSC 00706 210 72041
VCID: 6ADE4F14452D291157-803E
Subsystem 1 - Part No: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
02823 - Requirements for Locking the Steering Column Lock not met
Reset counter: 243
Mileage: 218266 km
Time: 14:51:57
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1132
Revision: 32008001 Serial number: 00000020869210
Coding: 0000565
VCID: 3B70BA507A376099FC-806E
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.134 H07 1806
Shop #: WSC 02069 000 90108
VCID: 3564AC685C13B6E90A-8060
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 043 0472
Coding: 0191020851030E763004941570085BCE103CA0
Component: LIN BACKUP HORN H07 8003
Subsystem 2 - Part No: 3C0 951 171 A
Component: Neigungssensor 002 0508
Subsystem 3 - Part No: 3C0 951 171 A
Component: Innenraumueberw.002 0508
01134 - Alarm Horn (H12)
Fault Frequency: 111
Reset counter: 247
Mileage: 217916 km
Time: 17:29:45
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1132
Revision: 32008001 Serial number: 00000083269216
Coding: 0000564
VCID: 3C72B94C7F3967A1F5-8068
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 G HW: 3C0 907 801 G
Component: EPB VD8HC005 013 0005
Revision: 013
Coding: 0000011
Shop #: WSC 00700 210 88118
VCID: 26467B2491B5CD71B3-8072
Part No: 1K0 035 186 T
Component: Radio GR0 020 0023
Revision: 0002006S Serial number: VWZ2Z2F1711821
Coding: 0020200
Shop #: WSC 05314 000 00000
VCID: 3778A660461F44F918-8062
End-------------------------(Elapsed Time: 01:29)--------------------------
