when ac is on, there is no cold air and the radiator fans don't turn on.
changed the G65 pressure sensor, had no effect. pressure sensor show 7 bar pressure
checked refrigeration gas with gauges and low side 80psi - high side 60psi , but even though these aint the ideal pressures they would correct themselves if the ac kicked in.
did hvac test and there is current going to compressor.
did an output test and when it tests the RCV the radiator fans kick in, so they must be ok?
and looked on ross-tech wiki for the following fault and couldn't find anything -
005697 - Please check DTC Memory of A/C Controller P1641 - 000 - - Intermittent
any help on what to try next would be great :-)
Sunday,23,July,2017,12:56:08:21944
VCDS Version: 17.1.3.0 HEX-V2 CB: 0.4401.4
VIN: WVWZZZ1KZ7B035671 License Plate: VA06OZP
Mileage: 190270km-118228mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: WVWZZZ1KZ7B035671 Mileage: 190270km-118228miles
Address 01: Engine Labels: 03G-906-016-BKD.clb
Part No SW: 03G 906 021 KK HW: 03G 906 021 KK
Component: R4 2,0L EDC 000SG 9821
Revision: --H02--- Serial number: VWZ7Z0F7057135
Coding: 0000072
Shop #: WSC 00521 210 75581
VCID: 72BED2E208AA7A172BD-8026
Mileage: 189761 km
Time: 14:01:33
RPM: 798 /min
Voltage: 13.76 V
Bin. Bits: 00000100
Temperature: 69.3°C
(no units): 0.0
012546 - Motor for Intake Manifold Flap (V157)
P3102 - 000 - No Signal - Intermittent
Voltage: 12.92 V
Bin. Bits: 00000100
Torque: 0.0 Nm
Torque: 351.4 Nm
005746 - Coolant Fan Control 1
P1672 - 000 - Open or Short to Ground - Intermittent
Mileage: 189773 km
Time: 17:18:42
RPM: 798 /min
Voltage: 14.14 V
Bin. Bits: 00000100
Temperature: 82.8°C
Duty Cycle: 9.7 %
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Revision: 00H11001
Coding: 0023170
Shop #: WSC 00046 412 16384
VCID: 73B0D7E677B0731F20B-8026
Part No: 1K0 820 047 FH
Component: Climatic PQ35 120 0606
VCID: 6FB8DB961B9857FFC43-803A
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000004308857
Coding: E5890F2700041500001400001400000000087F075C
Shop #: WSC 00046 000 81920
VCID: 2B000F86EF006BDFA8B-807E
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 070706 020 0501
Coding: 00038805
Shop #: WSC 00046
Subsystem 2 - Part No: 1K0 955 559 AE Labels: 1K0-955-559-AF.CLB
Component: RLS 110706 014 1201
Coding: 00208933
Shop #: WSC 00046
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 38 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD0LR8X9
Coding: 0013112
VCID: 3D2431DE0174F56F06F-8068
Subsystem 1 - Serial number: 6332MSME112D0F216
Subsystem 2 - Serial number: 6342MSME0F0D0245B
Subsystem 3 - Serial number: 6352QSME12502251
Subsystem 4 - Serial number: 6362QSME10241E358
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 035 0070
Coding: 0000012
Shop #: WSC 00046 412 819200
VCID: 74B2D4FA72BE7427391-8020
Part No SW: 1K0 920 963 B HW: 1K0 920 963 B
Component: KOMBIINSTRUMENT VDD 1610
Revision: V0003000 Serial number: VWZ7Z0F7057135
Coding: 0003403
Shop #: WSC 00011 888 96745
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001067088A6B
Coding: 3D3F0B4007000003
Shop #: WSC 00046 412 1966080
VCID: 2C020C9AEA0E6CE7A11-8078
Reset counter: 25
Mileage: 190243 km
Time: 14:22:04
01304 - Radio
Fault Frequency: 7
Reset counter: 68
Mileage: 190243 km
Time: 14:39:58
Component: IMMO VDD 1610
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 005 0964
Coding: 0000692
VCID: 382A20CA2E56D047D59-806C
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.069 H07 1806
VCID: 353429FE39442D2FCEF-8060
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 199002005103087F2D04840570085FC690FCA0
Shop #: WSC 00046 412 212992
VCID: 035087262710439F30B-8056
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Component: NGS No Answer
Subsystem 3 - Component: IRUE No Answer
Reset counter: 25
Mileage: 190243 km
Time: 14:38:51
00323 - Vehicle Inclination Sensor (G384)
Reset counter: 25
Mileage: 190243 km
Time: 14:38:51
01134 - Alarm Horn (H12)
Reset counter: 25
Mileage: 190243 km
Time: 14:38:51
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000692
VCID: 392C25CE155CC94F2A7-806C
Address 56: Radio
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 005 0912
Coding: 0000144
Shop #: WSC 00046 412 1012544
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D04019ED11465EFB6F-8078
014 - Defective
End----------(Elapsed Time: 01:09, VBatt start/end: 12.3V/12.3V)-----------
