Results 1 to 10 of 13
Thread: help needed, air con was intermittent and then suddenly stopped working
    Verified VCDS User dayrider's Avatar
    Jul 2017
    Question help needed, air con was intermittent and then suddenly stopped working
    when ac is on, there is no cold air and the radiator fans don't turn on.
    changed the G65 pressure sensor, had no effect. pressure sensor show 7 bar pressure
    checked refrigeration gas with gauges and low side 80psi - high side 60psi , but even though these aint the ideal pressures they would correct themselves if the ac kicked in.
    did hvac test and there is current going to compressor.
    did an output test and when it tests the RCV the radiator fans kick in, so they must be ok?
    and looked on ross-tech wiki for the following fault and couldn't find anything -
    005697 - Please check DTC Memory of A/C Controller P1641 - 000 - - Intermittent
    any help on what to try next would be great :-)
    Sunday,23,July,2017,12:56:08:21944
    VCDS Version: 17.1.3.0  HEX-V2 CB: 0.4401.4
    VIN: WVWZZZ1KZ7B035671   License Plate: VA06OZP
    Mileage: 190270km-118228mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
    VIN: WVWZZZ1KZ7B035671   Mileage: 190270km-118228miles
    Address 01: Engine        Labels: 03G-906-016-BKD.clb
       Part No SW: 03G 906 021 KK    HW: 03G 906 021 KK
       Component: R4 2,0L EDC  000SG  9821
       Revision: --H02---    Serial number: VWZ7Z0F7057135
       Coding: 0000072
       Shop #: WSC 00521 210 75581
       VCID: 72BED2E208AA7A172BD-8026
                        Mileage: 189761 km
                        Time: 14:01:33
                        RPM: 798 /min
                        Load: 0.0 %
                        Voltage: 13.76 V
                        Bin. Bits: 00000100
                        Temperature: 69.3°C
                        (no units): 0.0
    012546 - Motor for Intake Manifold Flap (V157)
                   P3102 - 000 - No Signal - Intermittent
                        Load: 0.0 %
                        Voltage: 12.92 V
                        Bin. Bits: 00000100
                        Torque: 0.0 Nm
                        Torque: 351.4 Nm
    005746 - Coolant Fan Control 1
                   P1672 - 000 - Open or Short to Ground - Intermittent
                        Mileage: 189773 km
                        Time: 17:18:42
                        RPM: 798 /min
                        Load: 0.0 %
                        Voltage: 14.14 V
                        Bin. Bits: 00000100
                        Temperature: 82.8°C
                        Duty Cycle: 9.7 %
       Revision: 00H11001
       Coding: 0023170
       Shop #: WSC 00046 412 16384
       VCID: 73B0D7E677B0731F20B-8026
       Part No: 1K0 820 047 FH
       VCID: 6FB8DB961B9857FFC43-803A
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
       Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
       Revision: 00H37000    Serial number: 00000004308857
       Coding: E5890F2700041500001400001400000000087F075C
       Shop #: WSC 00046 000 81920
       VCID: 2B000F86EF006BDFA8B-807E
       Component: Wischer 070706 020  0501
       Coding: 00038805
       Shop #: WSC 00046
       Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
       Component: RLS     110706 014  1201
       Coding: 00208933
       Shop #: WSC 00046
       Component: 38 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD0LR8X9
       Coding: 0013112
       VCID: 3D2431DE0174F56F06F-8068
       Subsystem 1 - Serial number: 6332MSME112D0F216
       Subsystem 2 - Serial number: 6342MSME0F0D0245B
       Subsystem 3 - Serial number: 6352QSME12502251
       Subsystem 4 - Serial number: 6362QSME10241E358
       Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
       Component: Lenksäulenmodul 035 0070
       Coding: 0000012
       Shop #: WSC 00046 412 819200
       VCID: 74B2D4FA72BE7427391-8020
       Part No SW: 1K0 920 963 B    HW: 1K0 920 963 B
       Revision: V0003000    Serial number: VWZ7Z0F7057135
       Coding: 0003403
       Shop #: WSC 00011 888 96745
    Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
       Revision:   H12       Serial number: 31001067088A6B
       Coding: 3D3F0B4007000003
       Shop #: WSC 00046 412 1966080
       VCID: 2C020C9AEA0E6CE7A11-8078
                        Reset counter: 25
                        Mileage: 190243 km
                        Time: 14:22:04
    01304 - Radio
                        Fault Frequency: 7
                        Reset counter: 68
                        Mileage: 190243 km
                        Time: 14:39:58
       Component: IMMO            VDD 1610
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.clb
       Component: Tuer-SG         005 0964
       Coding: 0000692
       VCID: 382A20CA2E56D047D59-806C
       Part No: 1K2 909 144 L
       Component: EPS_ZFLS Kl.069 H07 1806
       Shop #: WSC 02069 000 90108
       VCID: 353429FE39442D2FCEF-8060
    Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
       Component:    KSG PQ35 G2  020 0202
       Coding: 199002005103087F2D04840570085FC690FCA0
       Shop #: WSC 00046 412 212992
       VCID: 035087262710439F30B-8056
       Subsystem 1 - Component:   Sounder No Answer
       Subsystem 2 - Component:       NGS No Answer
       Subsystem 3 - Component:      IRUE No Answer
                        Reset counter: 25
                        Mileage: 190243 km
                        Time: 14:38:51
                        Reset counter: 25
                        Mileage: 190243 km
                        Time: 14:38:51
    01134 - Alarm Horn (H12)
                        Reset counter: 25
                        Mileage: 190243 km
                        Time: 14:38:51
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.clb
       Coding: 0000692
       VCID: 392C25CE155CC94F2A7-806C
    Address 56: Radio
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.clb
       Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
       Component: Tuer-SG         005 0912
       Coding: 0000144
       Shop #: WSC 00046 412 1012544
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.clb
       Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
       Coding: 0000144
       VCID: 2D04019ED11465EFB6F-8078
                014 - Defective
    End----------(Elapsed Time: 01:09, VBatt start/end: 12.3V/12.3V)-----------
    That just means that the ECU is aware of a fault in the HVAC module. However, it's flagged "Intermittent", meaning the fault condition that set this code did not exist (or could not be detected) at the time the scan was performed. I'd speculate that the fault(s) in the HVAC module have been cleared, but not the the ECU...
    Jul 2017
    thanks for your response Uwe
    how would i clear it in the ecu so it don't show up again?
    also would that be the same for all the other intermittent faults like -
    Jul 2017
    If compressor is taking current but not operating it suggest it is faulty or stuck. remove drive belt and see if you can physical turn the compressor inner and outer by hand
  5. Likes Uwe, Jack@European_Parts liked this post
    Quote Originally Posted by dayrider View Post
    [Select]
    [01-Engine]
    [Fault Codes]
    [Clear Codes]
    Note that you cannot prevent a fault code from being set again if the fault condition re-occurs.
    Jul 2017
    does this look like everything is working?
    First pic off.
    Jul 2017
    According to your second picture the compressor should be pulling 0.8amp but the actual reading is blank. give the compressor clutch a good live and earth, see if it then pulls the clutch in and works . Obviously stay well clear of any moving parts.
  9. #8
    The compressors are known for shear pin breakage in addition if you find that the clutch engages after jump out advised by paull.
  10. #9
    Jul 2017
    Quote Originally Posted by paull View Post
    Mine doesn't have a clutch, it's always engaged on the mk5s.
  11. #10
    Verified VCDS User Danners74's Avatar
    Jun 2016
    Guys there are no clutches to speak of on these any more. That's what the N280 is for on the compressor. That's PWM'd and have swash plates inside on some. Do check the spindle as stated as they do fall apart internally and the two separate on the front of the pulley. Done loads in dealer and out of.
  12. Likes Uwe, RyMar liked this post
