Results 1 to 10 of 10
Thread: Passat 2007 abs code
    Egypt
    I had changed the module of parking brake , and the code of abs had been changed , so i want the code , i have tried abs code of 0046469 and it is not worked , could you tell me the abs code
    Wednesday,26,July,2017,07:05:09:43156
    VCDS Version: 16.8.4.2
    Dealer/Shop Name: Harisa car service
    VIN: WVWZZZ3CZ7P094709   License Plate:
    Mileage: 63760km-39618mi   Repair Order:
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
    VIN: WVWZZZ3CZ7P094709   Mileage: 63760km-39618miles
    53-Parking Brake -- Status: Malfunction 1010
    Address 01: Engine        Labels: 06A-906-033-BGU.lbl
       Part No: 06A 906 033 EC
       Component: SIMOS72 1.6l 2VG    9601
       Revision: --H03---    Serial number: VWZCZ000000000
       Coding: 0000071
       Shop #: WSC 00028 028 00001
       VCID: 64C34B42A7F32B624D-8030
    28793 - No Communication with ABS Brake Control Module
                U0121 - 009 -  - Intermittent
                        RPM: 992 /min
                        Mass Air / Rev.: 163.5 mg/str
                        Bin. Bits: 00000100
                        Hex Value: 0x0000
                        Mass Air / Rev.: 0.0 mg/str
                        Bin. Bits: 00000001
                        Hex Value: 0x0000
    28800 - No Communications with Parking Brake Control Module
                U0128 - 009 -  - Intermittent
                        RPM: 992 /min
                        Bin. Bits: 00000100
                        Hex Value: 0x0000
                        Bin. Bits: 00000001
                        Hex Value: 0x0000
    18061 - Please check DTC Memory of ABS Controller
                P1653 - 008 -
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
    Readiness: 0010 0001
    Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
       Part No SW: 3C0 614 109     HW: 3C0 614 109
       Component: ESP 440 C4     H018 0001
       Revision:  H018       Serial number: 0668155317
       Coding: 0001922
       VCID: 5BB170BE9A8D149AFC-800E
    7 Faults Found:
                000 -  -
                        Mileage: 63766 km
                        Time: 20:29:18
                000 -  -
                        Mileage: 63766 km
                        Time: 20:29:18
                        Mileage: 63766 km
                        Time: 20:29:18
                        Mileage: 63766 km
                        Time: 20:29:18
                        Mileage: 63766 km
                        Time: 20:29:18
                        Mileage: 63766 km
                        Time: 20:29:18
                        Mileage: 63766 km
                        Time: 20:29:18
    Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
       Part No SW: 3C0 907 044 AF    HW: 3C0 907 044 AF
       Component: ClimatronicPQ46 050 0505
       Revision: 00050005    Serial number: 00000000000000
       VCID: 65C55646ACC9526A5A-8030
    01316 - ABS Control Module
                        Reset counter: 101
                        Mileage: 63766 km
                        Time: 16:29:59
       Part No SW: 3C0 937 049 H    HW: 3C0 937 049 H
       Component: Bordnetz-SG     H37 1301
       Revision: 00H37000    Serial number: 00000004499281
       Coding: 00840F0700041A00000A00000F000000000959435C0000
       VCID: 2E57E96AB9BFD1326B-807A
       Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
       Component: Wischer 140906 003  0205
       Coding: 00046997
       Shop #: WSC 00028
       Part No SW: 3C0 909 605 M    HW: 3C0 909 605 M
       Component: 0B AIRBAG VW8   031 2522
       Revision: 11031000    Serial number: 003B1PNMX4D6
       Coding: 0012354
       VCID: 306BF712A38BC7C279-8064
       Subsystem 1 - Serial number: 6332MSME14453608
       Subsystem 2 - Serial number: 6342MSME14474F54
       Subsystem 3 - Serial number: 6351HTS66HB07R07
       Subsystem 4 - Serial number: 6361HTS66HBKU2C6
       Part No SW: 3C0 953 549 J    HW: 3C0 953 549 J
       Component: Lenksäulenmodul 006 0010
       Revision: 00006000    Serial number: 3C5953507AB
       Coding: 0000011
       VCID: 3361F81E529DFCDA04-8066
       Part No SW: 3C0 920 852 G    HW: 3C0 920 852 G
       Component: KOMBIINSTRUMENT VD1 1614
       Revision: V0007000    Serial number: 00000000000000
       Coding: 0006105
       Shop #: WSC 36000 360 21868
       VCID: 27591C4E9645807AA8-8072
                        Reset counter: 89
                        Fault Frequency: 53
                        Reset counter: 101
                        Mileage: 63443 km
                        Time: 01:50:22
                        Fault Frequency: 53
                        Reset counter: 101
                        Mileage: 63443 km
                        Time: 01:50:22
    Address 19: CAN Gateway        Labels: 3C0-907-530-V1.clb
       Revision: 00007000    Serial number: 0700C06A310316
       Coding: 3DFD0C04C21002
       VCID: 214D0256F8617E4AE6-8074
                        Fault Frequency: 73
                        Reset counter: 101
                        Mileage: 63443 km
                        Time: 02:36:02
                        Fault Frequency: 73
                        Reset counter: 101
                        Mileage: 63443 km
                        Time: 02:36:02
       Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
       Component:    IMMO         042 0383
       VCID: 397DCA3670F1068ACE-806C
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
    02823 - Requirements for Locking the Steering Column Lock not met
                000 -  -  - Intermittent
                        Fault Frequency: 7
                        Reset counter: 101
                        Mileage: 63699 km
                        Time: 14:27:52
    02827 - Wake-Up request via ESP
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 52
                        Mileage: 63673 km
                        Time: 15:04:09
                        Fault Frequency: 6
                        Reset counter: 101
                        Mileage: 63699 km
                        Time: 14:27:53
       Component: J386  TUER-SG FT    1123
       Revision: 32008001    Serial number: 00000078969106
       Coding: 0000181
       VCID: 3B71D03E7ACD349ADC-806E
                        Fault Status: 00100101
                        Reset counter: 89
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.132 H07 1806
       VCID: 3463FB025793FBE21D-8060
    00625 - Vehicle Speed Signal
                        Mileage: 63660 km
                        Temperature: 36.0°C
                        Voltage: 12.20 V
                        Voltage: 12.00 V
    02546 - Steering Limit Stop
                        Mileage: 63760 km
                        Temperature: 33.0°C
                        Voltage: 12.50 V
                        Voltage: 12.30 V
                000 -  -
    Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
       Component:    KSG PQ46 ELV 042 0472
       Coding: 00910A0001860E763004941570084F0B607CA0
       Component: J387  TUER-SG BT    1123
       Revision: 32008001    Serial number: 00000580069110
       Coding: 0000180
       VCID: 3C73D3227FC333A2D5-8068
       Revision:   013
       Coding: 0000012
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Reset counter: 61
                        Mileage: 63760 km
                        Time: 20:27:41
                        Voltage: 12.32 V
                        Count: 170
                        Fault Status: 11101101
                        Reset counter: 61
                        Mileage: 63760 km
                        Time: 20:27:41
                        Voltage: 12.32 V
                        Count: 236
    02779 - Databus for Electric Parking Brake
                        Reset counter: 101
                        Voltage: 10.04 V
                        Count: 221
    02839 - Wake-Up Line from Control Module for Electrical Parking Brake
                        Fault Status: 00101001
                        Reset counter: 101
                        Mileage: 63760 km
                        Time: 20:15:31
                        Voltage: 12.01 V
                        Count: 51
       Part No: 1K0 035 186 T
       Component: Radio GR0       020 0023
       Revision: 0002006S    Serial number: VWZ2Z2F1231442
       Coding: 0040400
       VCID: 3779CC0E46E510FA38-8062
       Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
       Component: J388   TUER-SG HL   1113
       Revision: 11005001    Serial number: 00000000882671
       Coding: 0000144
       VCID: 3D75DE2664D93AAAE2-8068
       Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
       Component: J389   TUER-SG HR   1113
       Revision: 11005001    Serial number: 00000000884392
       Coding: 0000144
       VCID: 3E77D92A69DF21B2FB-806A
    End-------------------------(Elapsed Time: 02:11)--------------------------
    You did an Auto-Scan before you changed the parking brake module, right? Please post that scan too.
    Egypt
    the car come to me by this situation , and i dont have an old auto scan , it will be easier if i have an old autoscan i will copy the code number , but if this will help , the old control module is 3C0907801E
    and the new one is 3C0907801B
    and i checked them by etka and they are correct
    thanks in advance
    Egypt
    could you help me with correct code ?
    Feb 2017
    Italy
    If you still have the old control module, just connect it back and make an autoscan to get the code. Otherwise maybe ross tech will help you.
  6. #6
    Egypt
    the old control is missed, thanks for your response
  7. #7
    Hey Mo..... try this!
    Coding: 0013710
  8. #8
    Egypt
    I tried it abs the fault of code still appeared and not able to be cleared
  9. #9
    Feb 2017
    Italy
    if you coded it and accepted and you still have the error, than you might have multiple problems. Wires from ecu to abs module, to parking module. Defective abs/epb module.. Post a new autoscan after you code the module. Delete all the errors and post the autoscan after deleting them so we know what errors remain
  10. #10
    Tartu, Estonia
    I'm gonna make my post short and effective.
    1) This epb module swap was problably useless. Why was it changed? It needs sw update not changing the module. It even has now lower sw then it had before.
    2) Coding helper for this abs is very effective. Use that to create new coding.
    3) Cycle the ignition with 30sec. pause. It might not accept the coding directly after plugging the module in.
  11. Likes Jack@European_Parts liked this post
