Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 88
Thread: Central electric module 9 not responding 2014 GTI
    Aug 2014
    I think this is what you meant? Also when I run the autoscan it gets hung up saying retrieving fault codes on 09. Its still on there as we email for the last few minutes.
    VCDS Version: Beta 14.7.2 (x64)
    Data version: 20140714
    Friday,22,August,2014,09:37:25:53396
    Gateway Installation List: 7N0 907 530 AF
  2. #12
    Aug 2014
    Anyone have a clue?
    Quote Originally Posted by ag13 View Post
  3. #13
    What happens if you just do [Select] -> [09-Cent. Elect.] ?
    What kind of computer are you using?
    Jun 2014
    Poland
    Driver door are open ? Open it and close few time, and keep open while reading
  5. #15
    Aug 2014
    Hp laptop running windows 7 and I have tried with and without mcafee on. Have done the door thing over and over nothing changes. If selecting 09 it starts to login and then gives me error unable to communicate with module do I have my doors unlocked, then nothing.
    Quote Originally Posted by Spacewalker View Post
  6. #16
    United States
    As Adrian mentioned, we exchanged a few emails to/from Support and this began as a RNS-510 Retrofit per a scan from Sunday,17,August,2014. The Auto-Scan included a whopping list of fault codes but we need to fill in the gaps prior to and after the retrofit because they may be directly related to the current condition.
    I suspect fuses were either missing at one point ... or the battery voltage was low enough to cause Terminal 30 open circuit DTCs in the BCM .. but that #09 controller was online and communicating in all of the Auto-Scans we have on file. Hopefully the Coding/Adaptation logs and the complete history add some clarity to the situation because bricked BCMs aren't very common (without Byte 18 shenanigans).
  7. Likes jakematic liked this post
  8. #17
    Aug 2014
    Hi Dana
    The retrofit was never a problem. I had full access to that module many times after the retrofit which was a simple plug and connect. There also is no missing or gap in history. One day I had access and then I didn't. The many codes were from me disconnecting the battery and moving the main fuse block because that was the only way to access right side light bulbs for replacement with sylvania silver stars. Again I had full access to the module after that. As you can see from the above a simple clearing of the codes cleaned up everything except 9.
    Module 9 communicates but when I run a scan it hangs and won't give me an error code for that module. The only way I can continue the scan is by hitting the done button when it hangs on 9 and then it continues. I am more than happy to pay for the live support to figure this out. Everything in the car is working without issues which makes this more confusing. How do I do the coding/adaptation logs? Thanks.
  9. #18
    United States
    Low voltage may explain the communication problem . Have you connected a battery charger prior to attempting to access 09 directly or scanned it with the engine running? Although this is not exactly a CAN Gateway communication problem, you may even want to turn the 4-way flashers on to see if that helps.
    You will find the CodingLog.TXT and AdpLog.TXT files in the C:\Ross-Tech\VCDS\Debug folder but make sure you check the Beta folder as well if you used both releases because the Debug folders are separate.
  10. #19
    Aug 2014
    Hi Dana,
    Still no luck. I have pasted below the files you suggested. Thanks!
    Address 42:5K0 959 701 H recoded (Short coding) from 0001204 to 0001204  (01357/011/00200)  Saturday,23,August,2014,10:53:53:53396
    Address 17:5K6 920 973 C recoded (Long Coding) from 070901 to 270F01  (01357/011/00200)  Saturday,23,August,2014,10:56:45:53396
    Address 17:5K6 920 973 C recoded (Long Coding) from 270F01 to 070F01  (01357/011/00200)  Saturday,23,August,2014,11:09:51:53396
    Address 17:5K6 920 973 C recoded (Long Coding) from 070F01 to 270901  (01357/011/00200)  Saturday,23,August,2014,20:41:53:53396
    Address 17:5K6 920 973 C recoded (Long Coding) from 270901 to 170901  (01357/011/00200)  Saturday,23,August,2014,20:55:27:53396
    Address 17:5K6 920 973 C recoded (Long Coding) from 270901 to 170901  (01357/011/00200)  Saturday,23,August,2014,20:55:46:53396
    Address 17:5K6 920 973 C recoded (Long Coding) from 270901 to 070901  (01357/011/00200)  Saturday,23,August,2014,20:56:02:53396
    Address 17:5K6 920 973 C recoded (Long Coding) from 270901 to 070901  (01357/011/00200)  Saturday,23,August,2014,20:56:26:53396
    Address 17:5K6 920 973 C recoded (Long Coding) from 270901 to 070901  (01357/011/00200)  Saturday,23,August,2014,20:58:03:53396
    Address 16:5K0 953 507 AH recoded (Long Coding) from 189A140000 to 189A100000  (46056/001/1048576)  Saturday,23,August,2014,21:00:27:53396
    Address 16:5K0 953 507 AH recoded (Long Coding) from 189A100000 to 189A140000  (46056/001/104857)  Saturday,23,August,2014,21:00:58:53396
    Address 56:1K0 035 188 C  channel 0 adapted from --- to 000  Sunday,24,August,2014,15:46:51:53396
    Address 19:7N0 907 530 AF  channel 0 adapted from --- to 000  Sunday,24,August,2014,16:02:14:53396
    Address 56:1K0 035 188 C  channel 0 adapted from --- to 000  Sunday,24,August,2014,16:25:24:53396
    Address 03:1K0 907 379 BL  channel 55 adapted from 1 to 0  Monday,01,September,2014,14:41:04:53396
    Address 19:7N0 907 530 AF recoded (Long Coding) from 350002 to 000002  (45081/001/104857)  Sunday,24,August,2014,09:53:10:53396
    Address 19:7N0 907 530 AF recoded (Long Coding) from 000002 to 460002  (45081/001/104857)  Sunday,24,August,2014,09:53:47:53396
    Address 19:7N0 907 530 AF recoded (Long Coding) from 460002 to 350002  (45081/001/104857)  Sunday,24,August,2014,09:54:35:53396
    Address 17:5K6 920 973 C recoded (Long Coding) from 070901 to 170901  (01357/011/00200)  Sunday,24,August,2014,09:55:29:53396
    Address 77:7P6 035 730 K recoded (Long Coding) from 0A10040000010100 to 0A10040000010000  (01357/011/00200)  Sunday,24,August,2014,09:56:16:53396
    Address 77:7P6 035 730 K recoded (ADP-Microphone sensitivity) from 0 dB to -4 dB  Sunday,24,August,2014,09:56:46:53396
    Address 77:7P6 035 730 K recoded (Long Coding) from 0A10040000010000 to 0A10040000010100  (01357/011/00200)  Sunday,24,August,2014,09:57:27:53396
    Address 25:5K0 953 234  recoded (Long Coding) from 000000 to 000002  (01357/011/00200)  Sunday,24,August,2014,10:37:03:53396
    Address 25:5K0 953 234  recoded (Long Coding) from 000002 to 000000  (01357/011/00200)  Sunday,24,August,2014,10:37:22:53396
    Address 17:5K6 920 973 C recoded (Long Coding) from 170901 to 370901  (01357/011/00200)  Sunday,24,August,2014,11:08:22:53396
    Address 17:5K6 920 973 C recoded (Long Coding) from 370901 to 170901  (01357/011/00200)  Sunday,24,August,2014,11:08:50:53396
    Address 16:5K0 953 507 AH recoded (Long Coding) from 189A140000 to 1892140000  (46056/001/104857)  Sunday,24,August,2014,16:04:37:53396
    Address 16:5K0 953 507 AH recoded (Long Coding) from 1892140000 to 189A140000  (46056/001/104857)  Sunday,24,August,2014,16:06:50:53396
    Address 56:1K0 035 188 C recoded (Long Coding) from 00000000000000 to 00006612312345  (00066/123/12345)  Sunday,24,August,2014,16:32:42:53396
    Address 56:1K0 035 188 C recoded (Long Coding) from 00000000000000 to 00006612312345  (//)  Sunday,24,August,2014,16:32:51:53396
    Address 56:1K0 035 188 C recoded (Long Coding) from 00000000000000 to 00006612312345  (00006/123/12345)  Sunday,24,August,2014,16:33:10:53396
    Address 56:1K0 035 188 C recoded (Long Coding) from 00000000000000 to 00006612312345  (00006/123/12345)  Sunday,24,August,2014,16:34:24:53396
    Address 56:1K0 035 188 C recoded (Long Coding) from 00000000000000 to 00006612312345  (000006/123/12345)  Sunday,24,August,2014,16:34:29:53396
    Address 56:1K0 035 188 C recoded (Long Coding) from 00000000000000 to 01234512312345  (12345/123/12345)  Sunday,24,August,2014,16:34:53:53396
    Address 56:1K0 035 188 C recoded (Long Coding) from 00000000000000 to 12345123123450  (12345/123/12345)  Sunday,24,August,2014,16:35:14:53396
    Address 56:1K0 035 188 C recoded (Long Coding) from 00000000000000 to 01234512312345  (12345/123/12345)  Sunday,24,August,2014,16:35:24:53396
    Address 56:1K0 035 188 C recoded (Long Coding) from 00000000000000 to 12345612312345  (123456/123/12345)  Sunday,24,August,2014,16:35:57:53396
    Address 56:1K0 035 188 C recoded (Long Coding) from 00000000000000 to 12345012312345  (123456/123/12345)  Sunday,24,August,2014,16:36:02:53396
    Address 56:1K0 035 188 C recoded (Long Coding) from 00000000000000 to 12345012312345  (123450/123/12345)  Sunday,24,August,2014,16:36:06:53396
    Address 09:1K0 937 086 T recoded (Long Coding) from 6F180A3890272AC4008800C1700085E448810388435D8D60648020240040 to 6F180A3890272AC4008800C1300085E448810388435D8D60648020240040  (01357/011/00200)  Sunday,24,August,2014,16:40:50:53396
    Address 17:5K6 920 973 C recoded (Long Coding) from 170901 to 170F01  (01357/011/00200)  Sunday,24,August,2014,16:44:45:53396
    Address 17:5K6 920 973 C recoded (ADP-Volume to be replenished) from No  to Yes   Monday,01,September,2014,10:00:54:53396
    Address 09:5Q0 937 085 S recoded (Long Coding) from 04141A7EC041227541C04004510007000000000000000000000000000000 to 08141A46C041227541C04004510007000000000000000000000000000000  (06385/790/00016)  Monday,01,September,2014,10:18:27:53396
    Address 09:5Q0 937 085 S recoded (Long Coding) from 08141A46C041227541C04004510007000000000000000000000000000000 to 08141A42C041227541C04004510007000000000000000000000000000000  (06385/790/00016)  Monday,01,September,2014,10:19:58:53396
    Address 5F:8V0 035 844  recoded (ADP-Microphone sensitivity) from 6 dB to 0 dB  Monday,01,September,2014,10:49:26:53396
    Address 03:5Q0 907 379 AA recoded (ADP-Brake booster) from 4  to 2   Monday,01,September,2014,10:50:58:53396
    Address 03:5Q0 907 379 AA recoded (ADP-Brake disk drying) from Weak  to not activated   Monday,01,September,2014,10:51:18:53396
    Address 03:5Q0 907 379 AA recoded (ADP-Brake disk drying) from Weak  to not activated   Monday,01,September,2014,10:53:47:53396
    Address 03:5Q0 907 379 AA recoded (ADP-Counter steer support) from Medium  to Strong   Monday,01,September,2014,10:54:38:53396
    Address 17:8V0 920 960 B recoded (ADP-Display depiction) from Not available  to Version 1   Monday,01,September,2014,11:04:18:53396
    Address 19:7N0 907 530 AF recoded (Installation List) from ED807F064006120000 to ED807D064006120000  Monday,01,September,2014,14:34:57:53396
    Address 19:7N0 907 530 AF recoded (Installation List) from ED807D064006120000 to ED807F064007130000  Monday,01,September,2014,14:37:19:53396
    Address 19:7N0 907 530 AF recoded (Installation List) from ED807F064007130000 to ED807F064006130000  Monday,01,September,2014,14:38:04:53396
    Address 19:7N0 907 530 AF recoded (Installation List) from ED807F064006130000 to ED807F064006120000  Monday,01,September,2014,14:38:30:53396
    Address 77:7P6 035 730 K recoded (ADP-Microphone sensitivity) from -4 dB to 0 dB  Monday,01,September,2014,14:44:25:53396
    Address 17:5K6 920 973 C recoded (Long Coding) from 170F01 to 170901  (01357/011/00200)  Monday,01,September,2014,14:46:43:53396
    Address 37:3C0 035 684 C recoded (Long Coding) from 04000400010000A100 to 04000400040000A300  (00066/444/00010)  Monday,01,September,2014,14:49:10:53396
    Address 37:3C0 035 684 C recoded (Long Coding) from 04000400040000A300 to 04000400040000A100  (00066/444/00010)  Monday,01,September,2014,15:03:37:53396
  11. #20
    Aug 2014
    Do you folks think I should unplug the module and let it sit for a few minutes without power to reset it?
