Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 88
Thread: Central electric module 9 not responding 2014 GTI
  1. #41
    May 2014
    Quote Originally Posted by ag13 View Post
    unfortunately no change even restoring all items to oem status.
    ag13: so the storyline continues into yet another chapter!! When you say "restoring all items to oem status", do you mean restoring all items to the auto-scan that you posted on 21-aug-2014? Do you have any previous auto-scans (ideally, from before the RNS 510 retrofit)?
    Of course, autos-cans can only ratify the coding values for control modules. To confirm that the adaptation channels are kosher, did you ever find the missing CodingLog.txt file (perhaps in the Beta RT directory) for changes made to the car after 24 September 2014?
    Then there is Dana's suggestion about pulling the fuse and retesting the auto-scan. Was that done?
  2. Likes Uwe liked this post
  3. #42
    Aug 2014
    I only have in my system the new version of VCDS. I erased the other beta versions thinking that maybe that was the issue. Restored as in your breakdown as well as removing all lighting bulbs that I changed. Fuse(s) pulled no change.
  4. #43
    Aug 2014
    Should I just replace the bcm and start again?
  5. #44
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    I know that you intended to return everything to factory settings, but I think we should make sure that really happened/was accepted before you spend money on a BCM. Can you post for us:
    1) A *current* Auto-Scan, as of now.
    2) A *historical* Auto-Scan, from before you made any of these changes? Apparently RT Support/Dana have one from you if you don't have it anymore.
    Jason
  6. #45
    Aug 2014
    Thanks Jason will do.
    I know that you intended to return everything to factory settings, but I think we hould make sure that really happened/was accepted before you spend money on a BCM. Can you post for us:
    Jason
  7. #46
    Aug 2014
    I cant run the autoscan since it hangs up on module 9. I did find this in the ross-tech program file. Ignore last adaptation done today, was trying to see if dip mirror would work. Thanks,
    Address 17:5K6 920 973 C recoded (Long Coding) from 070901 to 270901  (01357/011/00200)  Saturday,01,November,2014,19:09:14:53396
    Address 17:5K6 920 973 C recoded (ADP-indicator_celebration) from active  to active   Saturday,01,November,2014,19:10:26:53396
    Address 17:5K6 920 973 C recoded (ADP-indicator_celebration) from active  to not active   Saturday,01,November,2014,19:17:18:53396
    Address 17:5K6 920 973 C recoded (ADP-indicator_celebration) from not active  to active   Saturday,01,November,2014,19:19:18:53396
    Address 19:7N0 907 530 AF recoded (Installation List) from ED807F064006120000 to ED807D064006120000  Sunday,02,November,2014,13:39:29:53396
    Address 17:5K6 920 973 C recoded (Long Coding) from 270901 to 170901  (01357/011/00200)  Sunday,02,November,2014,13:41:36:53396
    Address 17:5K6 920 973 C recoded (ADP-indicator_celebration) from active  to not active   Sunday,02,November,2014,13:43:13:53396
    Address 37:1K0 035 274 K recoded (ADP-Developer mode) from blocked  to Enabled   Sunday,02,November,2014,13:43:56:53396
    Address 37:1K0 035 274 K recoded (ADP-Developer mode (temporary)) from blocked  to Enabled   Sunday,02,November,2014,13:44:07:53396
    Address 16:5K0 953 507 AH recoded (Long Coding) from 189A140000 to 1892140000  (46056/001/104857)  Sunday,02,November,2014,13:49:15:53396
    Address 16:5K0 953 507 AH recoded (Long Coding) from 1892140000 to 189A140000  (46056/001/104857)  Sunday,02,November,2014,13:50:50:53396
    Address 08:7N0 907 426 BH recoded (ADP-Retention of driver's seat heater level) from not active  to active   Sunday,02,November,2014,13:52:51:53396
    Address 19:7N0 907 530 AF recoded (Installation List) from ED807D064006120000 to ED807F064006120000  Sunday,02,November,2014,13:55:26:53396
    Address 2E:5N0 035 342 G recoded (Long Coding) from 010100 to 010000  (01357/011/00200)  Sunday,02,November,2014,14:03:01:53396
    Address 08:7N0 907 426 BH recoded (Long Coding) from 0010001002 to 0010000002  (01357/011/00200)  Sunday,02,November,2014,14:04:05:53396
    Address 37:1K0 035 274 K recoded (ADP-Maximum vehicle speed for destination entry) from 6 km/h to 250 km/h  Sunday,02,November,2014,14:08:09:53396
    Address 37:1K0 035 274 K recoded (Long Coding) from 040004210400060000008000 to 040004210400060400008000  (01383/790/50316)  Sunday,02,November,2014,14:08:47:53396
    Address 17:5K6 920 973 C recoded (ADP-indicator_celebration) from not active  to active   Sunday,02,November,2014,14:10:36:53396
    Address 17:5K6 920 973 C recoded (ADP-indicator_celebration) from active  to not active   Sunday,02,November,2014,14:11:51:53396
    Address 37:1K0 035 274 K recoded (Long Coding) from 040004210400060400008000 to 040100210100060400008000  (01383/790/50316)  Thursday,06,November,2014,17:40:08:53396
    Address 37:1K0 035 274 K recoded (ADP-Developer mode (temporary)) from blocked  to Enabled   Thursday,06,November,2014,17:41:46:53396
    Address 17:5K6 920 973 C recoded (Long Coding) from 170901 to 070903  (01357/011/00200)  Thursday,06,November,2014,17:46:50:53396
    Address 17:5K6 920 973 C recoded (ADP-indicator_celebration) from not active  to active   Thursday,06,November,2014,17:47:37:53396
    Address 08:7N0 907 426 BH recoded (Long Coding) from 0010000002 to 0010001002  (01357/011/00200)  Thursday,06,November,2014,17:52:14:53396
    Address 37:1K0 035 274 K recoded (Long Coding) from 040100210100060400008000 to 040600210100060400008000  (01383/790/50316)  Friday,07,November,2014,20:17:58:53396
    Address 37:1K0 035 274 K recoded (Long Coding) from 040600210100060400008000 to 040000210100060400008000  (01383/790/50316)  Friday,07,November,2014,20:18:19:53396
    Address 37:1K0 035 274 K recoded (Long Coding) from 040000210100060400008000 to 040100210100060400008000  (01383/790/50316)  Friday,07,November,2014,20:18:51:53396
    Address 37:1K0 035 274 K recoded (Long Coding) from 040100210100060400008000 to 040600210100060400008000  (01383/790/50316)  Friday,07,November,2014,20:19:06:53396
    Address 37:1K0 035 274 K recoded (Long Coding) from 040600210100060400008000 to 040000210400060400008000  (01383/790/50316)  Friday,07,November,2014,20:19:39:53396
    Address 37:1K0 035 274 K recoded (Long Coding) from 040000210400060400008000 to 040004210400060400008000  (01383/790/50316)  Friday,07,November,2014,20:20:18:53396
    Address 37:1K0 035 274 K recoded (Long Coding) from 040004210400060400008000 to 040000210400060400008000  (01383/790/50316)  Friday,07,November,2014,20:20:38:53396
    Address 37:1K0 035 274 K recoded (Long Coding) from 040000210400060400008000 to 040004210400060400008000  (01383/790/50316)  Friday,07,November,2014,20:21:02:53396
    Address 08:7N0 907 426 BH recoded (Long Coding) from 0010001002 to 0010000002  (01357/011/00200)  Tuesday,11,November,2014,17:16:20:53396
    Address 01:1K0 907 115 AT recoded (Long Coding) from 040301081C070160 to 040301081C070360  (01357/011/00200)  Tuesday,11,November,2014,17:19:52:53396
    Address 52:5K0 959 702 H recoded (Short coding) from 0001204 to 0001460  (01357/011/00200)  Friday,21,November,2014,09:46:36:53396
    Address 42:5K0 959 701 H recoded (Short coding) from 0001204 to 0001460  (01357/011/00200)  Friday,21,November,2014,09:46:59:53396
    Address 37:1K0 035 274 K recoded (ADP-Developer mode (temporary)) from blocked  to Enabled   Friday,21,November,2014,09:48:41:53396
    Address 17:5K6 920 973 C recoded (Long Coding) from 070901 to 170901  (01357/011/00200)  Monday,24,November,2014,21:05:49:53396
    Address 17:5K6 920 973 C recoded (Long Coding) from 070901 to 170901  (01357/011/00200)  Monday,24,November,2014,21:05:54:53396
    Address 17:5K6 920 973 C recoded (Long Coding) from 070901 to 170901  (01357/011/00200)  Monday,24,November,2014,21:06:27:53396
    Address 52:5K0 959 702 H recoded (Short coding) from 0001460 to 0001460  (01204/011/00200)  Monday,24,November,2014,21:06:50:53396
    Address 42:5K0 959 701 H recoded (Short coding) from 0001460 to 0001460  (01204/011/00200)  Monday,24,November,2014,21:07:08:53396
    Address 08:7N0 907 426 BH recoded (Long Coding) from 0010000002 to 0010001002  (01357/011/00200)  Monday,24,November,2014,21:08:28:53396
    Address 09:5Q0 937 085 S recoded (Long Coding) from 04141A42C041227541C04004510007000000000000000000000000000000 to 04141A46C041227541C04004510007000000000000000000000000000000  (06385/790/00016)  Monday,24,November,2014,21:16:41:53396
    Address 19:5Q0 907 530 Q recoded (Installation List) from 01503C0000000000400C1000 to 01503C0000000000400C1000  Monday,24,November,2014,21:20:36:53396
    Address 19:5Q0 907 530 Q recoded (ADP-Increase idle speed request) from Mode not active  to Stage 1   Monday,24,November,2014,21:21:33:53396
    Address 19:5Q0 907 530 Q recoded (ADP-Increase idle speed request) from Mode not active  to Stage 2   Monday,24,November,2014,21:21:41:53396
    Address 42:5Q0 959 393 B recoded (Long Coding) from 00100F204100048000000002 to 00100F204D00048000000002  (06385/790/00016)  Monday,24,November,2014,21:24:53:53396
    Address 5F:8V0 035 844  recoded (ADP-Developer mode) from not activated  to activated   Monday,24,November,2014,21:25:55:53396
    Address 03:5Q0 907 379 AA recoded (ADP-Brake booster) from 4  to 3   Monday,24,November,2014,21:27:38:53396
    Address 03:5Q0 907 379 AA recoded (ADP-Brake disk drying) from Weak  to not activated   Monday,24,November,2014,21:27:53:53396
    Address 17:8V0 920 960 B recoded (Long Coding) from 07F519092B80A7050208AA00180000 to 07F519092B80A7000100EA00180000  (06385/790/00016)  Monday,24,November,2014,21:33:30:53396
    Address 09:5Q0 937 085 S recoded (Long Coding) from 04141A46C041227541C04004510007000000000000000000000000000000 to 04141A42C041227541C04004510007000000000000000000000000000000  (06385/790/00016)  Monday,24,November,2014,21:36:15:53396
    Address 19:5Q0 907 530 Q recoded (Installation List) from 01503C0000000000400C1000 to 01503C0000000000400C1000  Monday,24,November,2014,21:37:43:53396
    Address 17:8V0 920 960 B recoded (Long Coding) from 07F519092B80A7000100EA00180000 to 07F519092B80A7000100AA00180000  (06385/790/00016)  Monday,24,November,2014,21:39:22:53396
    Address 37:1K0 035 274 K recoded (Long Coding) from 040004210400060400008000 to 040104210400060400008000  (01383/790/50316)  Monday,01,December,2014,16:24:11:53396
    Address 37:1K0 035 274 K recoded (Long Coding) from 040104210400060400008000 to 040604210400060400008000  (01383/790/50316)  Monday,01,December,2014,16:24:53:53396
    Address 37:1K0 035 274 K recoded (Long Coding) from 040604210400060400008000 to 040604210100060400008000  (01383/790/50316)  Monday,01,December,2014,16:25:16:53396
    Address 37:1K0 035 274 K recoded (Long Coding) from 040604210100060400008000 to 040504210100060400008000  (01383/790/50316)  Monday,01,December,2014,16:25:43:53396
    Address 37:1K0 035 274 K recoded (Long Coding) from 040504210100060400008000 to 040904210100060400008000  (01383/790/50316)  Monday,01,December,2014,16:26:08:53396
    Address 37:1K0 035 274 K recoded (Long Coding) from 040904210100060400008000 to 040004210100060400008000  (01383/790/50316)  Monday,01,December,2014,16:26:35:53396
    Address 37:1K0 035 274 K recoded (Long Coding) from 040004210100060400008000 to 040004210400060400008000  (01383/790/50316)  Monday,01,December,2014,16:43:09:53396
    Address 42:5K0 959 701 H recoded (Short coding) from 0001460 to 0001460  (01204/011/00200)  Sunday,07,December,2014,17:12:52:53396
    Address 52:5K0 959 702 H recoded (Short coding) from 0001460 to 0001460  (01204/011/00200)  Sunday,07,December,2014,17:13:18:53396
    Address 62:5K0 959 703 D recoded (Short coding) from 0001168 to 0001168  (01357/011/1012552)  Sunday,07,December,2014,17:13:38:53396
    Address 72:5K0 959 704 D recoded (Short coding) from 0001168 to 0001168  (01357/011/1012552)  Sunday,07,December,2014,17:13:57:53396
    Address 19:7N0 907 530 AF recoded (Installation List) from ED807F064006120000 to ED8007064006120000  Sunday,07,December,2014,17:23:49:53396
    Address 19:7N0 907 530 AF recoded (Installation List) from ED8007064006120000 to ED807F064006120000  Sunday,07,December,2014,17:27:04:53396
    Address 17:5K6 920 973 C recoded (ADP-Activating and deactivating all development messages) from not active  to active   Sunday,07,December,2014,17:32:51:53396
    Address 17:5K6 920 973 C recoded (ADP-Automatic door locking) from Yes  to No   Sunday,07,December,2014,17:33:12:53396
    Address 17:5K6 920 973 C recoded (ADP-Automatic door locking) from No  to Yes   Sunday,07,December,2014,17:34:24:53396
    Address 17:5K6 920 973 C recoded (ADP-Activating and deactivating all development messages) from active  to not active   Sunday,07,December,2014,17:34:39:53396
    Address 17:5K6 920 973 C recoded (Long Coding) from 070901 to 270B01  (01357/011/00200)  Sunday,07,December,2014,17:36:04:53396
    Address 17:5K6 920 973 C recoded (Long Coding) from 270B01 to 170901  (01357/011/00200)  Sunday,07,December,2014,17:39:32:53396
    Address 52:5K0 959 702 H recoded (Short coding) from 0001460 to 0001716  (01204/011/00200)  Wednesday,17,December,2014,08:02:17:53396
    Address 19:7N0 907 530 AF recoded (Installation List) from ED807F064006120000 to ED807F864006120000  Wednesday,17,December,2014,08:03:17:53396
  8. #47
    Aug 2014
    If I am looking at this correctly, it appears that all mods I did to module 9 are not showing?
  9. #48
    I would try this:
    Change Coding of [42] / [52] back to: 0001204
    Change Coding of [17] back to: 070901 (probably not necessary, but anyway)
    Correct changes in [19] Gateway Installation list, check value in above file, becomes this: ED807F064006120000 (as you did dec. 7)
    After this, take battery ground connection off, for about 30 minutes.
  10. Likes jyoung8607, Uwe, Dana liked this post
  11. #49
    Cincinnati, OH
    The coding and adaptation logs are good to have, but in your case, they don't have history before November 1st. They also don't show whether the attempt to change coding was actually successful. You started the thread about this problem back in August. I think we should firmly establish the state of the car before the changes that might be causing problems, and the state of the car as it is now, and figure out how to get back. The data you've shared isn't really enough to do that.
    For a current Auto-Scan, you've said earlier you can press Done while it's hung on 09 and it continues. Can you do that to get a current scan?
    For your historical Auto-Scan, can you dig up one that worked before your changes, or give Dana permission to share the one you sent to Ross-Tech support?
    Niels just shared some coding stuff he'd like you to try. He has access to research resources that I don't, so it's worth trying. If it doesn't work, we're back to trying to figure out how to roll back your changes to restore 09 functionality, and for that we need data.
    Jason
  12. Likes Eric, Uwe, Dana liked this post
  13. #50
    May 2014
    Ag13: I posted a copy of a more user friendly version of your CodeLog.txt file here . It might be better to download the spreadsheet (some odd formatting when viewed on dropbox). NEtech has probably done the same thing (my apology Mr NEtech)
    Anyhow, there is only two changes to the BCM, both happened on 24 November 2014. You changed byte 03 and then rolled back to the original setting (looks pretty innocuous)
    The real problem is that your 2nd CodeLog.txt file is AFTER the previous version that you posted (i.e. the 1st file had dates in Aug/Sept 2014 and the one above has activities in Nov/Dec 2014). From your description of events, I assume that your problems were encountered BEFORE the first CodeLog.txt file date.
    PS: You appear to have been fairly persistent in trying to change the coding string for address 37! It's not related to your problem, but just out of interest, why?
  14. Likes Uwe liked this post
