Results 1 to 10 of 18
Thread: No response from controller 5F after retrofitted MIB2 for MK7 GTI 14
    Jul 2017
    Saudi Arabia
    Unhappy No response from controller 5F after retrofitted MIB2 for MK7 GTI 14
    I own golf gti mk7 2014 ROW with engine code:CHHB
    and today I just upgraded my infotainment system from MIB1 unit with 6.5 inch screen to a MIB2 unit with 8 inch screen, and this is the part No. 3G0035043
    (All equipments are OEM)
    But when I try connecting to vcds 5F controller, it's says (no response from controller) BTW all other controllers work fine.
    What should I do to fix this??
    See the AutoScan:
    https://drive.google.com/open?id=0B9...0dJSmNTNm9LSjA
    Aug 2016
    The Hague, NL
    Does the infotainment itself work?
    Tuesday,25,July,2017,01:49:00:05443
    VCDS Version: 17.1.3.0 (x64)
    VIN: WVWFK2AU5EW053492 License Plate: MYGTI
    Mileage: 115294km-71640mi Repair Order:
    Chassis Type: AU (5Q0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F A9
    VIN: WVWFK2AU5EW053492 Mileage: 115294km-71640miles
    Address 01: Engine (J623-CHHB) Labels: 06K-907-425-V1.clb
    Part No SW: 5G0 906 259 HW: 06K 907 425 B
    Component: 2.0l R4 TFSI H13 0009
    Revision: --H13---
    Coding: 091D1032442404083000
    ASAM Dataset: EV_ECM20TFS0215G0906259 001013
    ROD: EV_ECM20TFS0215G0906259.rod
    VCID: 6BD598AF8290B3192C-803E
    17178 - Databus
    Mileage: 115158 km
    Date: 2017.07.22
    Time: 00:01:44
    Engine speed: 839.50 /min
    Normed load value: 5.5 %
    Coolant temperature: 74 °C
    Intake air temperature: 57 °C
    Voltage terminal 30: 12.304 V
    Unlearning counter according OBD: 36
    Drivetrain coordinator: ACC fault status-ACC: Not active: although TSK passive
    Drivetrain coordinator: ACC fault status-Start and stop request: Set at stopping
    speed
    Drivetrain coordinator: ACC fault status-Bit 2: Not transmitted simultaneously
    Drivetrain coordinator: ACC fault status-Bit 3: Does not reactivate after
    DTC-induced shutdown
    Drivetrain coordinator: ACC fault status-Bit 4: Not active when limiter active
    Drivetrain coordinator: ACC fault status-Bit 5: Transmits no undefined signals
    Drivetrain coordinator: ACC fault status-Bit 6: Not active when main switch off
    Drivetrain coordinator: ACC fault status-Bit 7: Not active when driver braking
    Drivetrain coordinator: ACC fault status-Bit 8: Not active during the EPB emer.
    braking
    Drivetrain coordinator: brake fault status-ESP: no error
    Drivetrain coordinator: brake fault status-Deceleration controller: Available
    Drivetrain coordinator: brake fault status-TSK/ESP handshake: no error
    Drivetrain coordinator: brake fault status-Bit 1: no error
    Drivetrain coordinator: brake fault status-Bit 3: Not malfunction due to inaccurate
    engine torque
    Drivetrain coordinator: brake fault status-Bit 4: No indication of TSK message
    consistency error
    Drivetrain coordinator: brake fault status-Bit 6: Automatic engagement OK
    Drivetrain coordinator: brake fault status: 4
    Drivetrain coordinator: brake function status-Parking Brake: not active
    Drivetrain coordinator: brake function status-ACC: Not braking
    Drivetrain coordinator: brake function status-ESP: Not invoking TSK braking
    Drivetrain coordinator: brake function status-Driver: Not braking
    Drivetrain coordinator: brake function status-Hill descent control: passive
    Drivetrain coordinator: brake function status-ASR: no intervention
    Drivetrain coordinator: brake function status-MSR: no intervention
    Drivetrain coordinator: brake function status-ADS: no intervention
    Drivetrain coordinator: brake function status-ABS: no intervention
    Drivetrain coordinator: brake function status-EDL: no intervention
    Drivetrain coordinator: brake function status-ASP: no intervention
    Drivetrain coordinator: brake function status-AWV2: No warning pressure
    Drivetrain coordinator: brake function status-Bit 4: no intervention
    Drivetrain coordinator: brake function status-Bit 11: not passively cycled
    Drivetrain coordinator: brake function status-Bit 12: not passively cycled
    Drivetrain coordinator: brake function status-Bit 13: Standstill not detected
    Part No SW: 0D9 300 040 L HW: 02E 927 770 AN
    Component: DQ250-6F MQB H52 4025
    Revision: 05652104 Serial number: TFK01305221548
    ROD: EV_TCMDQ250021.rod
    VCID: 204FBF833BD6A041C9-8074
    Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
    Component: ESC H31 0457
    Revision: 00000000 Serial number: 61713000000B52
    Coding: 01FA6BA13425096F037B0609C1C5A980D62C90C0608395B70040503AC109
    VCID: 7BF5A8EFF2F02399BC-802E
    0297 - Steering angle sensor
    B1168 16 [008] - Voltage Too Low
    Reset counter: 237
    Mileage: 115158 km
    Date: 2017.07.22
    Time: 00:01:43
    4214 - Auto-Hold Switch
    C10CE 29 [008] - Signal Implausible
    Reset counter: 198
    Mileage: 115204 km
    Date: 2017.07.23
    Time: 14:10:32
    16390 - Display for Tire Pressure Monitoring
    C1146 02 [008] - Signal Failure
    Reset counter: 237
    Mileage: 115158 km
    Date: 2017.07.22
    Time: 00:01:54
    Revision: 00021000 Serial number: 0193829980
    Coding: 030C1C
    Shop #: WSC 12345 123 61029
    VCID: 3A7B6DEBBD4ADA91E7-806E
    Part No SW: 5G0 907 044 AA HW: 5G0 907 044 AA
    Component: Climatronic H02 0705
    Revision: 00001K06
    Coding: 00020014100100000005004012101800
    VCID: 66C3E99B99728E7173-8032
    Air quality sensor:
    459025 - Databus
    Reset counter: 237
    Mileage: 115098 km
    Date: 2017.07.22
    Time: 02:38:51
    Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
    Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AA
    Component: BCM MQBAB H H14 0137
    Serial number: 00011317901358
    Coding: 00151A46C04122FB4BE44000000C07001800000000000000000000000000
    ROD: EV_BCMBOSCH_013.rod
    VCID: 000FDF039B164041E9-8054
    Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels:
    5QX-955-119-V1.CLB
    Component: WWS 130619 042 0551
    Serial number: 130621030704
    Component: RLFS 024 0042
    Serial number: Y13M07D03H03M09S36S1
    Coding: 06A8DD
    Sun Roof:
    Subsystem 3 - Part No SW: 8V3 959 591 HW: 8V3 959 591
    Component: J245 PS73.013 H02 0007
    Serial number: WOO2265142$
    Coding: 181801
    197644 - Control Circuit for Fuel Tank Flap
    B1263 01 [009] - Electrical Failure
    Reset counter: 198
    Mileage: 115211 km
    Date: 2017.07.23
    Time: 16:59:52
    Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
    Part No SW: 5Q0 919 298 A HW: 5Q0 919 298
    Revision: -------- Serial number: 61131317700833
    Coding: 0031161011
    ROD: EV_EPHVA2CAU3700000_003_VW37.rod
    VCID: 3D7166F7AC64EDA9C2-8068
    13637426 - Databus
    Reset counter: 237
    Mileage: 115158 km
    Date: 2017.07.22
    Time: 00:01:44
    Part No SW: 5Q0 959 655 C HW: 5Q0 959 655 C
    Serial number: 003F5R063YKR
    VCID: 408F1F03DB968041A9-8014
    Subsystem 1 - Part No SW: ----------- HW: 480 002 406 13
    Serial number: 357670000007C1705D0U
    Subsystem 2 - Part No SW: ----------- HW: 480 002 406 13
    Serial number: 35867000000551705D0M
    Subsystem 3 - Part No SW: ----------- HW: 480 402 006 13
    Serial number: 3516502AF107446482C9
    Subsystem 4 - Part No SW: ----------- HW: 480 402 106 13
    Serial number: 3526502C110CBDD240BH
    Subsystem 5 - Part No SW: ----------- HW: 480 401 806 13
    Serial number: 35565029B106FA4130FF
    Part No SW: 5Q0 953 507 BK HW: 5Q0 953 549
    Revision: -------- Serial number: 27061304221015
    Coding: 0400
    Shop #: WSC 40195 333 37120
    ROD: EV_SMLSKLOMQB_VW37.rod
    Part No SW: 5G6 920 870 HW: 5G6 920 870
    Component: KOMBI 314 2210
    Coding: 07AD09182B90000801087E00040000
    VCID: 6CD79BB3879EB42125-8038
    16777018 - Function Restricted due to Interrupted Communications
    U1110 00 [008] - -
    Reset counter: 237
    Mileage: 115098 km
    Date: 2017.07.22
    Time: 02:38:45
    U1110 00 [008] - -
    Reset counter: 237
    Mileage: 115098 km
    Date: 2017.07.22
    Time: 02:38:45
    Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
    Component: GW MQB High 125 1144
    Revision: -------- Serial number: 0000693654
    Coding: 0101000820085900FF00022A1C0F00000001000000000000000000000000
    ROD: EV_GatewLear_009.rod
    VCID: 3B7568EFB270E399FC-806E
    Subsystem 2 - Part No SW: 5G0 959 442 M HW: 5G0 959 442 M Labels: 3C8-959-537.CLB
    Component: E221__MFL-DC1 H06 0101
    Serial number: 27130000649500103245
    Coding: 29FFFF
    66052 - Infotainment CAN Bus (SAE Bus E)
    U0065 00 [008] - Performance
    Reset counter: 238
    Mileage: 115098 km
    Date: 2017.07.22
    Time: 01:15:38
    Supply voltage: Terminal 30: 12.6 V
    Terminal 15: OFF
    U1101 00 [009] - Active
    Reset counter: 200
    Mileage: 115158 km
    Date: 2017.07.22
    Time: 00:01:45
    Terminal 15: On
    Part No SW: 5Q0 905 861 HW: 5Q0 905 861
    Component: ELV-MQBA H06 0010
    Revision: 00000000 Serial number: 13000124237003
    Coding: 4900000000000000
    ASAM Dataset: EV_ELVMarquMQB 003008
    ROD: EV_ELVMarquMQB_003.rod
    VCID: 73E580CFDAA06BD9E4-8026
    Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
    Component: TSG FS 012 0006
    Serial number: 19061301101050
    Coding: 001F13205C00040000001000
    VCID: 3F8D1CFFA668FFB9D0-806A
    Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels:
    5QX-959-81X-V1.CLB
    Serial number: 00000000000001876174
    Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
    Component: EPS_MQB_ZFLS 505 5063
    Coding: 0302
    Shop #: WSC 21627 002 1048576
    ROD: EV_SteerAssisMQB_VW31.rod
    VCID: 397972E7B84CD189EE-806C
    Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
    Component: TSG BFS 012 0006
    Serial number: 23061304080633
    Coding: 001F11205C00040000801000
    VCID: 3E7361FBA162F6B1DB-806A
    Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels:
    5QX-959-81X-V1.CLB
    Serial number: 00000000000001863768
    Coding: 090000
    Part No SW: 7P6 907 357 A HW: 7P6 907 357 A
    Component: AFS-ECU H07 0080
    Coding: 021A01000B000200
    Subsystem 1 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
    Component: LeiMo links H05 0012
    Coding: 2E0000
    Subsystem 2 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
    Component: LeiMo rechts H05 0012
    Coding: 2E0000
    Part No SW: 5G0 907 159 HW: 4H0 907 159 A
    Component: SAS-GEN 2 H06 0011
    Serial number: 130514202066
    End-------------------------(Elapsed Time: 04:02)--------------------------
  3. Likes Dana liked this post
    Quote Originally Posted by Golfmania View Post
    This is an upgrade that is usually fraught with problems, most people give up, why? Because the infotainment is locked to the vehicle, so a change of infotainment needs unlocking usually by a dealer .
    I would love to change the MIB1 Amundsen in my Skoda Octavia to a MIB2, but having done the research and consulted several experts have given up on the idea.
    Jul 2017
    Saudi Arabia
    Revision: --H13---
    17178 - Databus
    Mileage: 115158 km
    Date: 2017.07.22
    Time: 00:01:44
    speed
    braking
    engine torque
    consistency error
    Reset counter: 237
    Mileage: 115158 km
    Date: 2017.07.22
    Time: 00:01:43
    Reset counter: 198
    Mileage: 115204 km
    Date: 2017.07.23
    Time: 14:10:32
    Reset counter: 237
    Mileage: 115158 km
    Date: 2017.07.22
    Time: 00:01:54
    Coding: 030C1C
    Revision: 00001K06
    Air quality sensor:
    459025 - Databus
    Reset counter: 237
    Mileage: 115098 km
    Date: 2017.07.22
    Time: 02:38:51
    5QX-955-119-V1.CLB
    Coding: 06A8DD
    Sun Roof:
    Coding: 181801
    Reset counter: 198
    Mileage: 115211 km
    Date: 2017.07.23
    Time: 16:59:52
    Coding: 0031161011
    13637426 - Databus
    Reset counter: 237
    Mileage: 115158 km
    Date: 2017.07.22
    Time: 00:01:44
    Coding: 0400
    U1110 00 [008] - -
    Reset counter: 237
    Mileage: 115098 km
    Date: 2017.07.22
    Time: 02:38:45
    U1110 00 [008] - -
    Reset counter: 237
    Mileage: 115098 km
    Date: 2017.07.22
    Time: 02:38:45
    Coding: 29FFFF
    Reset counter: 238
    Mileage: 115098 km
    Date: 2017.07.22
    Time: 01:15:38
    Terminal 15: OFF
    Reset counter: 200
    Mileage: 115158 km
    Date: 2017.07.22
    Time: 00:01:45
    Terminal 15: On
    5QX-959-81X-V1.CLB
    Coding: 0302
    5QX-959-81X-V1.CLB
    Coding: 090000
    Coding: 2E0000
    Coding: 2E0000
    Yes the infotainment itself does work including the car-play & performance monitor
    Jul 2017
    Saudi Arabia
    When I bought it they asked me to give them my VIN in order to unlock it I guess
    Sounds like this is one of those eastern-European hacked-up MIB-IIs that deliberately has diagnostics disabled. Ask the supplier please.
  8. Likes PetrolDave, Dana, Eric liked this post
    Mar 2015
    Australia
    You need to go into green engineering mode on the MIB unit and disable DAB, and enable diagnostics for next 5 reboots, then it will be contactable at address 5F
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist|BCM Retrofit|HBA/FLA
  10. Likes Dana, PetrolDave liked this post
  11. #8
    Jul 2017
    Saudi Arabia
    Not it's not hacked they confirmed to me it's not. (^^,)
  12. #9
    Jul 2017
    Saudi Arabia
    Quote Originally Posted by kamold View Post
    what should I choose after I entered green engineering mode?
    this is what it looks from inside (see the picture)
  13. #10
    Mar 2015
    Australia
    Nope, don't see the picture...
