- Joined
- Aug 25, 2015
- Messages
- 51
- Reaction score
- 17
- Location
- Birmingham, England
- VCDS Serial number
- C?ID=253973
I had Audi A8 D3 for some tweaks today. First thing first I did full scan which is as below:
The battery died half way through when I was trying to clear the faults. Had to jump start the vehicle and did the scan today and clear the faults. Kept the engine running this time and on MMI battery meter was like 0% which eventally showed 100%
need advise what could be the cause of battery drain, also I couldn't do any changes for some reason.
Saturday,22,July,2017,17:59:56:25423
VCDS Version: 17.1.3.0
VIN: WAUZZZ4E36N001868 License Plate:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 11 31 13 15 16 17 18 19 1D 1E 25 28
34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 65 67 69 72 76
77
VIN: WAUZZZ4E36N001868 Mileage: 173890km-108050miles
1D-Driver Ident. -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Malfunction 0010
57-TV Tuner -- Status: Malfunction 0010
65-Tire Pressure -- Status: Not registered 0011
67-Voice Control -- Status: Malfunction 0010
Part No SW: 4E0 910 409 H HW: 4E0 907 409 C
Component: 4.0L V8TDI A000AGMª0010
Revision: --H01--- Serial number: AUX3Z0E3362460
Coding: 0010773
Shop #: WSC 02313 785 00200
VCID: 285FA89A9B90540181-807C
17861 - Exhaust Gas Temp Sensor 1 (G235)
P1453 - 000 - Open or Short to Plus
Torque: 19.5 Nm
Duty Cycle: 0.4 %
Voltage: 8.59 V
Temperature: 690.2°C
Temperature: 110.2°C
Inj. Quantity: 0.0 mg/str
Readiness: 0 0 1 1 1
Part No SW: 4E1 910 156 L HW: 09E 927 156 A
Component: AG6 09E 4,0LTDI RdW 0020
Revision: --H01--- Serial number: 0056576
VCID: 2C57548A8F68782165-8078
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Fault Status: 00110000
Reset counter: 22
Mileage: 173580 km
Date: 2017.07.13
Time: 10:12:52
RPM: 992 /min
RPM: 960 /min
RPM: 608 /min
(no units): 3.0
(no units): 48.0
Temperature: 55.0°C
T.B. Angle: 21.2°
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU - Intermittent
Reset counter: 22
Mileage: 173580 km
Date: 2017.07.13
Time: 10:12:52
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008557
Shop #: WSC 02313 000 00000
VCID: 224BBAB2FDACBE51DF-8076
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 A
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0E3362460
Coding: 0265216
Shop #: WSC 01223 210 182671
VCID: 58BFD85AEB702481F1-800C
Component: ELV XXXX
Fault Frequency: 0
Reset counter: 114
Mileage: 173888 km
Date: 2017.07.22
Time: 00:04:28
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H08 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
VCID: 2345BFB6E2B6B759D4-8076
Reset counter: 114
Mileage: 173892 km
Date: 2017.07.22
Time: 00:00:55
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 730 F HW: 4E0 035 729 A
Component: Interfacebox H43 1110
Revision: 00000000 Serial number: 300D9057550044
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000095911
Subsystem 3 - Serial number: 0128.03.120000000100010021ÿ
Subsystem 4 - Serial number: 010021ÿ
Reset counter: 114
Mileage: 173894 km
Date: 2017.07.22
Time: 00:00:46
Part No SW: 4E0 910 043 B HW: 4E0 820 043 D
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000064940
Coding: 1136817
Shop #: WSC 02311 785 00200
VCID: 1C37844ADFC888A115-8048
00066 - Rear Right Footwell Heater (Z43)
Fault Status: 00101100
Reset counter: 110
Mileage: 170445 km
Date: 2017.03.29
Time: 15:33:26
Voltage: 13.30 V
00532 - Supply Voltage B+
Reset counter: 106
Mileage: 173648 km
Date: 2017.07.14
Time: 18:56:05
Voltage: 8.60 V
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 L HW: 4E2 955 113 B
Component: ILM Fahrer H12 0210
Coding: 0143121
VCID: 316945FEA84A15C956-8064
Subsystem 1 - Part No: 4E2 910 113 B
Component: Wischer WWS D3 H50 0420
Coding: 00000037
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Coding: 00139548
Shop #: WSC 02313
Reset counter: 114
Mileage: 173894 km
Date: 2017.07.22
Time: 00:09:05
Reset counter: 114
Mileage: 173894 km
Date: 2017.07.22
Time: 00:09:05
Address 11: Engine II Labels: Redir Fail!
Component: 4.0L V8TDI A000AGSª0010
Coding: 0010773
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4E0 910 561 F HW: 4E0 907 561 F
Component: ABSTANDSREGELUNGH03 0020
Coding: 0011155
VCID: 2541A1AEEC824969BA-8070
013 - Check DTC Memory - Intermittent - MIL ON
Fault Status: 10111101
Reset counter: 114
Mileage: 173892 km
Date: 2017.07.22
Time: 00:02:00
Temperature: 28.0°C
Voltage: 8.45 V
Bin. Bits: 00100000
Fault Status: 11111101
Reset counter: 74
Mileage: 173892 km
Date: 2017.07.22
Time: 00:02:00
Temperature: 28.0°C
Voltage: 12.29 V
Bin. Bits: 00100000
Reset counter: 74
Mileage: 173892 km
Date: 2017.07.22
Time: 00:02:00
Fault Status: 10110010
Reset counter: 114
Mileage: 173892 km
Date: 2017.07.22
Time: 00:09:00
Temperature: 27.0°C
Voltage: 7.42 V
Bin. Bits: 00100000
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655 G
Component: Airbag 8.4E+ H10 0940
Coding: 0431707
VCID: 63C5FFB6A236F75994-8036
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Coding: 0112151
VCID: 65C1E1AEAC0289697A-8030
Component: Lenkradmodul H07 0080
Reset counter: 114
Mileage: 173894 km
Date: 2017.07.22
Time: 00:09:09
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 980 N HW: 4E0 920 980 N
Component: KOMBIINSTR. VDO H70 0400
Revision: D01 Serial number: AUDID3E3000186
Coding: 0016413
Shop #: WSC 39809 067 57207
VCID: 326B4AF2AD4C2ED12F-8066
Reset counter: 114
Mileage: 173894 km
Date: 2017.07.22
Time: 00:03:55
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 815 069 E
Component: Heizgeraet H07 0100
Revision: 0000000B Serial number: 00000009006406
VCID: 1A3B8252D5FCF69107-804E
Address 19: CAN Gateway Labels: 4E0-910-468.clb
Part No SW: 4E0 910 468 B HW: 4E0 907 468 F
Component: Gateway H10 0080
Revision: 10 Serial number: 1800405322004E
Coding: FFFFFFDE2B7504
VCID: 275DABA6968E5B7988-8072
Fault Status: 01100010
Reset counter: 74
Mileage: 173894 km
Date: 2017.07.22
Time: 00:10:55
Reset counter: 74
Mileage: 173894 km
Date: 2017.07.22
Time: 00:10:55
Address 1D: Driver Ident. Labels: 4E0-910-218.lbl
Part No SW: 4E0 910 218 A HW: 4E2 905 218 B
Component: FPI_1 H01 0010
Revision: 01000101 Serial number: 31012005175649
VCID: 1F4DB346CEDE93B9F0-804A
Fault Frequency: 0
Reset counter: 114
Mileage: 173888 km
Date: 2017.07.22
Time: 00:03:38
Fault Frequency: 0
Reset counter: 114
Mileage: 173888 km
Date: 2017.07.22
Time: 00:11:20
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBE7145383
VCID: 1B358756DAC68F991C-804E
Reset counter: 114
Mileage: 173894 km
Date: 2017.07.22
Time: 00:10:04
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0265216
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Fault Frequency: 0
Reset counter: 114
Mileage: 173888 km
Date: 2017.07.22
Time: 00:04:28
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 A
Component: KLIMA-STG. FOND 015 0220
Revision: 00000018 Serial number: 00000000026399
Coding: 0000000
VCID: 61C9F5BEB82AE54986-8034
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015520
Shop #: WSC 00011 888 06946
VCID: 2A5B5292859C661197-807E
01598 - Drive Battery Voltage
Reset counter: 114
Mileage: 173894 km
Date: 2017.07.22
Time: 00:05:02
Component: Sitzmemory FS H08 0060
Coding: 4063342
Reset counter: 114
Mileage: 173892 km
Date: 2017.07.22
Time: 00:00:55
Part No SW: 4E0 910 887 L HW: 4E0 919 887 C
Component: MNS ECE H44 0690
Revision: 00000000 Serial number: 305DM057583037
VCID: 366376E2412432F103-8062
00003 - Control Module
014 - Defective
Fault Status: 01101110
Reset counter: 0
Mileage: 173894 km
Date: 2017.07.22
Time: 00:15:56
Bin. Bits: 0100
Reset counter: 0
Mileage: 173894 km
Date: 2017.07.22
Time: 00:15:56
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H02 0090
Serial number: 00000504700025
Coding: 0036038
VCID: 1D31894EC4D281A9E2-8048
00308 - Supply Voltage for Motors for Sunroof/sunroof Shade
Reset counter: 114
Mileage: 173892 km
Date: 2017.07.22
Time: 00:05:00
Reset counter: 114
Mileage: 173892 km
Date: 2017.07.22
Time: 00:09:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 B
Component: Türsteuer.FS BRM003 0060
Coding: 0028462
VCID: 204FB0BAF3A0AC41C9-8074
02111 - Motor for Window Regulator
Fault Frequency: 0
Reset counter: 114
Mileage: 173888 km
Date: 2017.07.22
Time: 00:06:06
Fault Frequency: 0
Reset counter: 114
Mileage: 173888 km
Date: 2017.07.22
Time: 00:06:06
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040504050026
Coding: 0004317
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H03 0020
Reset counter: 114
Mileage: 173894 km
Date: 2017.07.22
Time: 00:12:40
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 K HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0440
Revision: PROD_01 Serial number: 00000000013092
Coding: 0000011
Reset counter: 114
Mileage: 173772 km
Date: 2017.07.18
Time: 00:00:58
Reset counter: 114
Mileage: 173772 km
Date: 2017.07.18
Time: 00:00:58
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000059086
Coding: 0010101
VCID: 1E338E42C9D49AB1FB-804A
Fault Status: 00110010
Reset counter: 114
Mileage: 173892 km
Date: 2017.07.22
Time: 00:07:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 B
Component: Türsteuer.BF BRM003 0060
Coding: 0028462
Fault Frequency: 0
Reset counter: 114
Mileage: 173888 km
Date: 2017.07.22
Time: 00:07:62
Fault Frequency: 0
Reset counter: 114
Mileage: 173888 km
Date: 2017.07.22
Time: 00:07:62
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000431
Shop #: WSC 00383 210 80878
Reset counter: 114
Mileage: 173888 km
Date: 2017.07.22
Time: 00:09:17
Voltage: 7.04 V
Count: 200
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0020
Coding: 0000018
VCID: 2643A6A291844271B3-8072
Subsystem 1 - Part No: 4F0 941 329 A
Component: AFS-Modul links H05 0010
Subsystem 2 - Part No: 4F0 941 329 A
Component: AFS-Modul rechtsH01 0010
Reset counter: 40
Mileage: 173896 km
Date: 2017.07.22
Time: 00:07:57
02233 - Left Headlight Power Output Stage (J667)
Reset counter: 40
Mileage: 173896 km
Date: 2017.07.22
Time: 00:07:57
Reset counter: 40
Mileage: 173896 km
Date: 2017.07.22
Time: 00:07:57
Part No SW: 4E0 910 541 F HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 396DR057507702
Reset counter: 114
Mileage: 173894 km
Date: 2017.07.22
Time: 00:01:39
Reset counter: 114
Mileage: 173894 km
Date: 2017.07.22
Time: 00:01:39
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 E HW: 4E0 919 146 B
Component: TV analog TUNER H13 0270
Revision: 00000010 Serial number: 00000000001317
Coding: 0001003
Reset counter: 114
Mileage: 173894 km
Date: 2017.07.22
Time: 00:08:42
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: ENERGIEMANAGER H12 0480
Revision: 00000000 Serial number: 00000000005469
Shop #: WSC 00958 210 51185
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 300410A23L
Coding: 34453039313531303541205641303330303431304132334C
Shop #: WSC 00383 210 83674
02276 - Quiescent Current Stage 5
Mileage: 173894 km
Date: 2017.07.22
Time: 00:09:51
02274 - Quiescent Current Stage 3
Mileage: 173894 km
Date: 2017.07.22
Time: 00:09:51
Mileage: 173894 km
Date: 2017.07.22
Time: 00:09:51
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0060
Coding: 0028462
Fault Frequency: 0
Reset counter: 114
Mileage: 173888 km
Date: 2017.07.22
Time: 00:09:44
Fault Frequency: 0
Reset counter: 114
Mileage: 173888 km
Date: 2017.07.22
Time: 00:09:44
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010028 Serial number: 00000700031509
Coding: 0202328
VCID: 5FCDF3468E5ED3B9B0-800A
Fault Status: 10100010
Reset counter: 114
Mileage: 173894 km
Date: 2017.07.22
Time: 00:10:43
Voltage: 8.20 V
(no units): 42.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01477 - System Switched Off
Reset counter: 114
Mileage: 173894 km
Date: 2017.07.22
Time: 00:10:43
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 D HW: 4E0 035 753 A
Component: SDS 3502 UK H45 0560
Revision: 00000000 Serial number: 00000503300059
Shop #: WSC 12336 024 394758
Reset counter: 114
Mileage: 173894 km
Date: 2017.07.22
Time: 00:09:31
Address 69: Trailer Labels: 4E0-910-383.lbl
Part No SW: 4E0 910 383 B HW: 4E0 907 383 B
Component: ANHAENGERELEKTR 003 0040
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0060
Coding: 0028462
Fault Frequency: 0
Reset counter: 114
Mileage: 173888 km
Date: 2017.07.22
Time: 00:10:58
Fault Frequency: 0
Reset counter: 114
Mileage: 173888 km
Date: 2017.07.22
Time: 00:10:58
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: 06.00.57 Serial number: 00067808720509
Coding: 0111108
VCID: 2149B5BEF8AAA549C6-8074
Reset counter: 114
Mileage: 173894 km
Date: 2017.07.22
Time: 00:10:23
Part No SW: 4E0 910 336 C HW: 4E0 862 335
Component: Handyvorb2 H10 0120
Revision: 00000000 Serial number: 00000007548564
Coding: 0010900
Reset counter: 114
Mileage: 173894 km
Date: 2017.07.22
Time: 00:12:02
End-------------------------(Elapsed Time: 04:00)--------------------------
Saturday,22,July,2017,18:15:32:25423
77
1D-Driver Ident. -- Status: OK 0000
65-Tire Pressure -- Status: Not registered 0001
Coding: 0010773
RPM: 651 /min
Torque: 89.7 Nm
Duty Cycle: 0.4 %
Voltage: 13.53 V
Temperature: 145.0°C
Inj. Quantity: 8.2 mg/str
Coding: 0008557
Coding: 0265216
Component: ELV XXXX
Coding: 4063328
Coding: 1136817
Part No SW: 4E0 910 279 L HW: 4E0 907 279 L
Coding: 0143121
Coding: 00000037
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Coding: 0010773
Coding: 0011155
Reset counter: 74
Mileage: 173892 km
Date: 2017.07.22
Time: 00:34:00
Temperature: 30.0°C
Voltage: 13.95 V
Bin. Bits: 00100100
Coding: 0431707
Coding: 0112151
Coding: 0016413
Reset counter: 74
Mileage: 173894 km
Date: 2017.07.22
Time: 00:26:15
Coding: 0265216
Component: ELV XXXX
Coding: 0000000
Coding: 0015520
Coding: 4063342
Coding: 0036038
Coding: 0028462
Coding: 0004317
Coding: 0000011
Coding: 0010101
Coding: 0028462
Revision: AV1C1010
Coding: 0000431
Coding: 0000018
Coding: 0001003
Coding: 0028462
Coding: 0202328
Reset counter: 74
Mileage: 173894 km
Date: 2017.07.22
Time: 00:32:21
Temperature: 19.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 0028462
Coding: 0111108
Coding: 0010900
End-------------------------(Elapsed Time: 03:46)--------------------------
