Results 1 to 3 of 3
Thread: 2009 Mk6 Golf DSG intermittent transmittion fault
    Jul 2017
    Ireland
    Hi Guys,
    Complete newbie to VCDS here. Bought it as have been having issues with my DSG gearbox on my golf. It is a LQV code gearbox. Car has 103KW CBAB engine if that's of relevance. Car has been losing drive, will be traveling along as normal in "D" when drive is cut and ESP/ABS lights flash on the dash. "D" is also flashing beside the selector. I have scanned the car and its come back with a long list of codes. Some like the number plate light(LED number plate lights) and air-con pressure are fine but its the transmission control module and incorrect coding of CAN gateway ones I know very little about. I'm guessing, or should I say hoping that the rest are all knock on issues from the CAN gateway and transmission ones. Here is the scan I done the other evening, have cleared them and will re-scan in a day or 2 to see which come back
    Wednesday,19,July,2017,19:13:00:56033
    VCDS Version: 17.6.0.2  HEX-V2 CB: 0.4341.4
    Data version: 20170602 DS274
    VIN: WVWZZZ1KZAW______   License Plate:
    Mileage: 218550km-135800mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZAW028658   Mileage: 218550km-135800miles
    02-Auto Trans -- Status: Sporadic communication error 1000
    Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 LB    HW: 03L 906 022 G
       Component: R4 2,0L EDC G000AG  3894
       Revision: 13H02---    Serial number:
       Coding: 0001078
       Shop #: WSC 00191 264 15243
       VCID: 70BAD9A306AEBD97BF1-8024
    008213 - Intake Manifold Flap Position Sensor (Bank 1)
                   P2015 - 000 - Implausible Signal - Intermittent
                        Fault Frequency: 7
                        Mileage: 218493 km
                        Date: 2011.11.28
                        Time: 23:11:38
                        Load: 0.0 %
                        Lambda: 11.8 %
                        Lambda: 2.4 %
                        Voltage: 0.380 V
                        Bin. Bits: 00000001
    008504 - Accelerator Position Sensors (G79) / (G185)
                   P2138 - 000 - Implausible Correlation - Intermittent
                        Mileage: 218242 km
                        Date: 2011.11.15
                        Time: 17:00:13
                        RPM: 1472 /min
                        Speed: 75.0 km/h
                        Load: 0.0 %
                        Voltage: 13.83 V
                        Voltage: 0.912 V
                        Voltage: 0.608 V
                        Bin. Bits:  0 01  0
    049409 - No Communication with Transmission Control Module
                   U0101 - 000 -  - Intermittent
                        Fault Frequency: 6
                        Mileage: 218527 km
                        Date: 2011.12.06
                        Time: 17:09:09
                        RPM: 782 /min
                        Temperature: 14.4C
                        Voltage: 13.53 V
                        Bin. Bits: 00000000
                        Torque: 0.0 Nm
                        Temperature: 29.7C
       Part No SW: 02E 300 052     HW: 02E 927 770 AJ
       Component: GSG DSG AG6     440 1913
       Revision: 00044002    Serial number: 00000905150468
       VCID: 51FC7C27ADE4949F90F-8004
       Part No SW: 1K0 907 379 AP    HW: 1K0 907 379 AP
       Component: ESP MK60EC1   H45 0107
       Revision: 00H45001
       Coding: 163B400D09240002681102E9902100823500
       VCID: 005A89633A0EAD174F1-8054
                        Fault Frequency: 6
                        Reset counter: 121
                        Mileage: 218259 km
                        Date: 2011.11.15
                        Time: 17:37:45
                        Count: 32782
                        Count: 12800
                        Count: 8195
                        Count: 49408
                        Count: 55040
       Part No SW: 3C8 907 336 H    HW: 3C8 907 336 H
       Component: Climatic      H13 0203
       Revision: 00006001
       Coding: 0000000000
       ASAM Dataset: EV_Climatic A01001
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 323E13ABC4A2CF87895-8066
              B10AB F0 [009] - Too Low
                        Reset counter: 81
                        Mileage: 218547 km
                        Date: 2017.07.18
                        Time: 19:23:21
       Part No SW: 1K0 937 086 C    HW: 1K0 937 086 C
       Component: BCM PQ35  M   103 0537
       Revision: 00103 AC
       Coding: 48180A3A9825F1C044080080140081E443510088536D8160648000200000
       VCID: 303A19A3CA2EFD97FF1-8064
       Component: Wischer 26050  21  0501
       Coding: 009795
       Component: RLS 090609 05  54  0402
       Coding: 0330AD
       Subsystem 4 - Part No: 1K0 951 605 D
       Component: LIN BACKUP HO  H08 9001
    00332 - Control Circuit for Tank Flap
                007 - Short to Ground
                        Fault Status: 01100111
                        Fault Frequency: 161
                        Reset counter: 75
                        Mileage: 177440 km
                        Date: 2010.08.25
                        Time: 16:50:53
                            Term 15 Off
                        Voltage: 12.10 V
                            Term 50 Off
                        Fault Frequency: 6
                        Reset counter: 121
                        Mileage: 218259 km
                        Date: 2011.11.15
                        Time: 17:37:45
                            Term 15 On
                        Voltage: 13.65 V
                            Term 50 Off
                        Fault Status: 00101110
                        Fault Frequency: 21
                        Reset counter: 106
                        Mileage: 210976 km
                        Date: 2011.07.17
                        Time: 18:18:55
                            Term 15 On
                        Voltage: 11.50 V
                            Term 50 Off
       Part No SW: 5K0 959 655     HW: 5K0 959 655
       Component: AirbagVW10    033 0604
       Serial number: 003C2RA03UHI
       Coding: 00003230
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 77A8E2BF6F40EAAF7EB-8022
       Component: S.Sens.Fahr.V  U01 ----
       Serial number: 4F741248ZZZZZZZZZZZZ
       Component: S.Sens.Beif.V  U01 ----
       Serial number: 5E343048ZZZZZZZZZZZZ
       Serial number: 262E2864ZZZZZZZZZZZZ
       Serial number: 3A512D3BZZZZZZZZZZZZ
       Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
       Component: J0527           055 0111
       Coding: 0001532
       VCID: 76B6EFBB64CA93A765D-8022
       Subsystem 1 - Part No: 3C8 959 537 B  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAP   H4 0021
       Coding: 00000226
       Part No SW: 5K0 920 970 J    HW: 5K0 920 970 J
       Component: KOMBI         H05 0206
       Coding: 470B00
       VCID: 353428B735CCD8BFAC7-8060
    12648704 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Fault Frequency: 6
                        Reset counter: 121
                        Mileage: 218259 km
                        Date: 2017.06.24
                        Time: 17:37:43
       Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
       Component: J533  Gateway   H07 0081
       Revision:   H07 01    Serial number: 100609F1000722
       Coding: ED807F06000212000003
       VCID: 6696BFFB346A6327D5D-8032
                        Fault Status: 00110100
                        Fault Frequency: 6
                        Reset counter: 121
                        Mileage: 218259 km
                        Date: 2011.11.15
                        Time: 17:37:45
                000 -  -  - Intermittent
                        Mileage: 201000 km
                        Date: 2011.03.23
                        Time: 11:59:48
    Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
       Component: IMMO          H05 0206
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
       Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
       Revision: A1001003    Serial number: 7667728859
       VCID: 2616FFFBF8EAA32715D-8072
       Part No SW: 5K0 959 701 C    HW: 5K0 959 701 C
       Component: Tuer-SG         009 2110
       Coding: 0004790
       VCID: 323E13ABC822CF87895-8066
       Part No: 1K0 909 144 H
       Component: EPS_ZFLS Kl. 70     2901
       Revision: 00H15000
       VCID: 2F381ADFDB10E26FE6B-807A
       Part No SW: 5K0 959 702 E    HW: 5K0 959 702 E
       Component: Tuer-SG         009 2124
       Coding: 0005046
       VCID: 353428B7394CD8BFAC7-8060
       Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
       Component: Radio RCD310  013 0036
       Revision: 01000000    Serial number: VWZ1Z2I6172531
       Coding: 0100040004
       VCID: 6594B8F7C56C683FDC7-8030
       Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
       VCID: 343215B33236C1B79B9-8060
       Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
       Coding: 0000144
    End----------(Elapsed Time: 01:04, VBatt start/end: 12.2V/12.2V)-----------
    Any help or insight would be greatly appreciated.
    Jason
    Several other control modules have faults like "Transmission Control Module -- No Signal/Communication -- Intermittent". This is indicative of your TCM itself going off-line, either due to some external cause like a bad electrical connection, or due to an internal fault.
    Jul 2017
    Ireland
    OK I'm going over to a friend's house later to put the car up on his lift so will check electrical connections. So you reckon that my TCM appears to be the main issue. Guess I'll start there then.
    Thanks Uwe
