2006 A3 can't program remotes
danix
I picked up a used 2006 Audi A3 for my daughter which has the original keys. Both keys start the car and unlock the doors. The remotes do not work.
Easy fix, I replaced the batteries. No joy...
I read about the manual procedure to program with one key in the ignition, doing the other, tried that and it didn't work.
Then I tried VCDS following the same procedure here:
https://www.youtube.com/watch?v=jdakPlMnDr4
After clearing the remotes (group 000), setting group 001 to 2, I can click on the unlock button of each remote and the turn signals flash.
Yay, it worked right? No. Neither remote will work.
I've tried the procedure with key in the ignition, key out of the ignition (once the VCDS is done) and always within the 15 sec limit.
What am I missing here? Thanks.
OP: Danix
Hello and welcome to the VCDS forum .........please post an auto-scan & so someone can help you.
Try erasing all fobs and start over after a battery reboot.
danix
Tuesday,18,July,2017,16:12:54:11378
VCDS Version: 17.1.3.0 (x64)
VIN: WAUNF78PX6A130091   License Plate: A3
Mileage: 121790km-75676mi   Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 62 72
VIN: WAUNF78PX6A130091   Mileage: 121790km-75676miles
08-Auto HVAC -- Status: Malfunction 1010
Address 01: Engine        Labels: 06F-907-115-AXX.clb
   Part No SW: 8P0 907 115 B    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0080
   Revision: --H14---    Serial number: AUX7Z0EDFNJ0CF
   Coding: 0103010A1C070160
   Shop #: WSC 26149 444 69282
   VCID: 316291BFA80528C956-8064
   Part No SW: 02E 300 043 C    HW: 02E 927 770 AE
   Component: GSG DSG         070 1125
   Revision: 04507000    Serial number: 00000512021246
   Shop #: WSC 06314 000 00000
   VCID: 142C382B3757FDE15D-8040
Address 03: ABS Brakes        Labels: 1K0-614-517-MK60AT.clb
   Part No SW: 1K0 614 517 AC    HW: 1K0 614 517 AC
   Component: ESP FRONT MK60-AT   0102
   Revision: 00H13001
   Coding: 0053890
   VCID: 68D43CDB5B5FA90141-803C
   Part No SW: 8P0 820 043 P    HW: 8P0 820 043 P
   Component: KlimavollautomatH18 0260
   Revision: 040970      Serial number: 8P0820043P
   VCID: 3972A99F7075E089EE-806C
00796 - Fan for Interior Temp Sensor (V42)
                    Fault Status: 00101011
                    Reset counter: 52
                    Mileage: 120033 km
                    Date: 2016.12.17
                    Time: 08:21:04
                    Voltage: 14.30 V
                    Temperature: 3.5∞C
Address 09: Cent. Elect.        Labels: 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 F    HW: 8P0 907 279 F
   Component: Bordnetz-SG     H43 1201
   Revision: 00H43000    Serial number: 00000005355806
   Coding: F18C5F81C014100000181800180000000028FE175A1500
   Shop #: WSC 06314 000 08192
   VCID: 4084C47B13AFB141A9-8014
   Subsystem 1 - Part No: 8P1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H01 0130
   Coding: 00062736
   Shop #: WSC 06314
   Component: REGENLICHTSENSORH11 0050
   Coding: 00150573
   Shop #: WSC 06314
                    Reset counter: 71
                    Mileage: 121643 km
                    Date: 2017.07.15
                    Time: 10:43:00
                    Voltage: 12.00 V
Address 15: Airbags        Labels: 8P0-959-655-94.lbl
   Part No SW: 8P0 959 655 A    HW: 8P0 959 655 A
   Component:    Airbag 9.41  H12 3890
   Revision: 91H12389    Serial number: 0035W000B5U0
   Coding: 0032605
   Shop #: WSC 26149 444 84581
   Subsystem 1 - Part No: 8P0 910 339
   Component: BF-Gewichtsens. 001 0020
   Subsystem 2 - Serial number: 34MFP
   Subsystem 3 - Serial number: 0001.01.000000100000000000ˇÜ63
   Subsystem 4 - Serial number: 000000ˇÜ6332DRB40298892F-ˇÜ63
   Subsystem 5 - Serial number: 8892F-ˇÜ6342DRB4029891A1OˇÜ63
   Subsystem 6 - Serial number: 891A1OˇÜ63528RB400D635C5OˇÜ63
   Subsystem 7 - Serial number: 635C5OˇÜ63628RB400D55D7E ˇÜ63
   Subsystem 8 - Serial number: 55D7E ˇÜ63729RB400E42463GˇÜ63
   Subsystem 9 - Serial number: 42463GˇÜ63829RB400E4242EOˇ
   Subsystem 10 - Serial number: 4242EOˇ
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H34 0070
   Coding: 0012142
   VCID: 4182C17F18A5B849A6-8014
   Component: E0221           H07 0090
01304 - Radio
   Part No SW: 8P0 920 981 E    HW: 8P0 920 981 E
   Component: KOMBIINSTR. VDO H80 0420
   Revision: D06         Serial number: 224DED06008061
   Coding: 0000263
   Shop #: WSC 03864 864 180628
   VCID: 3A70B6937573EB91E7-806E
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 G    HW: 1K0 907 951
   Component: J533__Gateway   H10 0140
   Revision:   H10       Serial number: 3000105C0983BC
   Coding: 7F3F034807002102
   VCID: 2B5E83D78A2942196C-807E
                    Fault Frequency: 60
                    Reset counter: 33
                    Mileage: 121643 km
                    Date: 2017.07.15
                    Time: 10:41:50
                    Fault Frequency: 60
                    Reset counter: 33
                    Mileage: 121643 km
                    Date: 2017.07.15
                    Time: 10:41:50
01304 - Radio
                    Fault Frequency: 60
                    Reset counter: 33
                    Mileage: 121643 km
                    Date: 2017.07.15
                    Time: 10:41:52
                    Fault Frequency: 60
                    Reset counter: 33
                    Mileage: 121643 km
                    Date: 2017.07.15
                    Time: 10:41:52
   Revision: D06         Serial number: AUX7Z0EDFNJ0CF
   Shop #: WSC 26149 444 123932
Address 37: Navigation
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN2.lbl
   Part No: 8P0 959 801 H
   Component: Tuer-SG         020 0090
   Coding: 0001177
   Part No: 1K1 909 144 K
   VCID: 336E9BB752191AD924-8066
   Part No: 8P0 959 433 D
   Component: 02 KSG          H04 0050
   Coding: 9AC003382D08850FC88F047300
   VCID: 3D7ABD8F645DDCA9C2-8068
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN2.lbl
   Part No: 8P0 959 802 H
   Coding: 0001177
00936 - Electric Window Switch in Front Passenger Door (E107).
   Part No: 8P0 907 357 F
   Coding: 0000012
Address 56: Radio
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No: 8P4 959 801 D
   Component: Tuer-SG         020 0070
   Coding: 0001176
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No: 8P4 959 802 D
   Coding: 0001176
End-------------------------(Elapsed Time: 02:02)--------------------------
danix
Please note:
I have the navi unit out of the car as well as the drivers side door panel (unrelated work) which are the cause of the errors above.
I've tried the same procedure before, when the panel and navi were in place.
There are no faults with the central convenience module.
Yes, this is a licensed VCDS, I'm a former reseller as well :)
0x46-10-00 clear save.........
0x46-10-001 insert remote count and save + marry remotes.
It seems like you have the correct procedure.
What happens if you try to only match one remote? Try each remote, but only matching one.
danix
Thanks for the reply. As I said above, already tried that.
So the procedure is correct. The remotes are functional (turn signals flash when pairing them). But they don't work.
Trust me, I'm as stumped as you are, and was hoping for something like "Oh, on the 2006 you have to have the gas flap open too". :banghead:
Well it seems correct. ;)
My son now has my old 2006. I'll try to verify either later this evening when I'm home or tomorrow morning.
danix
I like the theory. Since you have to pair the set, if you are asking for two and one doesn't work, perhaps neither will work.
Unfortunately, I tried each key individually just now, first clearing the remotes (group 0 to 0 and save) then group 1 to 1. No joy.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
It looks like your remotes antennas are damage , so it will need need new remote.
MK5 Jetta /Golf will do same thing, it will do same thing.
On A3 is little difficult since A3 has one piece key , can not be separate like Jetta/Golf .
In reality you will have to replace whole key and do programing of immobilizer and remote. But if you handy , you can open key and replace only remote board.
I suggest hunt for good used A3 Key with same part number and try adopt remote to car. If it works , then you can swap just remote board in your car.
danix
I buy that. However, when programming the key, it flashes the lights. Why does the antenna work well enough to program but not to lock/unlock? It should be the same signal.
Yeah I was thinking of finding another remote to use as a test anyway. Thanks.
My son and I just checked in his 2006 A3.
Verified both remotes working fine, both functionally and in MVB 010 (key number, and each button).
Went to 46 -> Adaption, Group 0, [Read] -> [Save], exit module, turned off ignition. Verified car did not respond to either remote.
Turned ignition back on, 46 -> Adaption, Group 0, made New Value 2, [Read] -> [Save]. Pressed unlock button on one remote for a bit, waited for flash, waited another second or so. Pressed unlock button on other remote for a bit, waited for flash, waited another second or so. Exited module, turn off ignition, verified both remotes working again.
Not sure what else to say. Doors, hatch, and fuel flap were all closed while we did this. ;)
danix
Uwe, thanks for the extra effort. I'll report back if/when I figure out a solution.
If antennas are a concern........
You can take any compatible unmarried remote and verify if it is broadcasting anything in VCDS advance measuring blocks and should be your first step before trying the process again.
Are the LED lights flashing on the remote when you press a button.........is the battery possibly in upside down?
Have you tried the reboot process after clearing defaults to the controller after a battery reset and then seeing that the value was saved as cleared zero?
Sometimes in needs to be done a couple of times because the controller won't erase the key count.
I strongly encourage recoding the controller with an alternate WSC and then also trying again.
danix
No, as I said when I pair the remotes the turn signals flash. Battery is in right, remote lights up.
I did notice that after setting group 0 to 000, the number of remotes still shows as 1 after saving. Tell me more about this reboot process?
I'm not sure how to do that. Is it via adaptation? Feel free to point me to a doc or wiki page.
Edit - found this: http://www.ross-tech.com/vcds/tour/recode_screen.php
Thanks for the feedback guys!
http://forums.ross-tech.com/showthread.php?3147-What-is-Jack-talking-about-0x01-08-000
0x46-10-00 save clear all defaults.
0x46-10-001 change to zero and save.
0x46-07- code with same data but configure your tester in config of VCDS for tester # Importer ID and WSC & with anything other than zero!
Let me know when you get a field of zero in 0x46-10-001 and then let's proceed after we know the remotes are cleared & the new WSC is displayed in main screen of 0x46......
Jetta 97
C?ID=81680
Thanks.
I have no idea WHY, but they do that. I had at least 10 cars with same problem, and after adopt other remote , it worked perfect.
Nope it's because the new data isn't saved yet & it was never cleared.........if you default the module & clear the data all is usually well after a fresh eeprom value.
Dana
Western PA, USA
I agree with Marin, you can have a faulty or incorrect remote that confirms (lights flash) but will not actually learn and work. If the OP hasn't tried a new remote I would do so next. If this is the key type where the remote is all in one with the key ... that will complicate things due to the Immo system.
Jetta 97
C?ID=81680
Jack ,
I am not talking just because I want to be popular on Forums.
I am talking form my experience , and even happen on my own car exactly same thing what OP experiencing now. After adopting other good used remote all start working. Then I went back and adopt my old remote and it did not work, and it flash hazards when I save it in VCDS.
