Results 1 to 10 of 12
Thread: 2004 VW Touareg V10 Brain Dead and No Start
    Jun 2017
    I've posted this call for help on the ClubTouareg forum, but figured that I would get some helpful input from here as well.
    Looking for some assistance and advice regarding a non-starting and brain dead 2004 V10 (I've already read every existing thread on ClubTouareg and several on here related to this issue from start to finish).
    The symptoms began as intermittent non-starting: with key on only some of the dash would come to life (not all of the gauges would work), and turning the key to starting position would result in nothing happening. Sometimes the key would not be released from ignition and shifter could not be moved into neutral. Time and/or several tries later and eventually it would start.
    Currently with the key on, only some of the dash comes to life: the screen comes up, but does not show all of the typical pre-start icons (like glow plugs), and non of the gauges come on. Turning the key to start does nothing. The shift lever is usable and the key can be removed.
    There must have been a constant parasitic draw on the batteries because eventually they went dead. Both batteries are less than 1 year old (sized properly according to threads on here) and have been removed from the vehicle and load tested as good. They have been re-charged and re-installed.
    I have attached a vagcom scan (done prior to steps taken below). This is my first time using one so I could use help interpreting it. The main issue appears to be that there is no communication with the ECM at all. I understand that many/most of the dtc's are probably related to the dead battery. But, due to the lack of communication with the ECM, I do not know how to clear all of them in order to run a new scan. Help?
    What has been tried so far:
    1) All fuses checked (drivers side, passenger side, and in engine bay).
    2) Wiring harness under driver's floor board carpet checked. No visible sign of corrosion, but all splices were re-spliced.
    3) Batteries load tested, re-charged, and re-installed.
    4) Clean dirt and debris away from wiper area.
    5) Removed and inspected ECM's- no visible sign of water or damage on plugs (did not open cases). Cleaned electrical plugs on both.
    5) Checked starting requirements to start - found bad brake light switch and replaced.
    6) Checked door handles- passenger door black button does not work. Plan on disconnecting wire harness to all door handles if necessary, but not done yet.
    7) Kessy removed and repaired. The two MOSFETs were replaced (they appeared to be stuck open, but not burned up). The resistors all checked OK.
    Re-installed the repaired Kessy, the new brake light switch, and the re-charged batteries. No change in status- still brain dead and vagcom says no communication with ECM.
    Now the stock alarm system is acting up. While working on the car with the driver's door open and the key sitting on the seat the alarm has been arming itself and locking the doors. This is the first time it has ever done this.
    Any input to help me get this beast running would be greatly appreciated!
    --------------------------------   I cleared the dtc's but none in the engine controler becuase of lack of communication so still no start.
    Chassis Type: 7L - VW Touareg (2003 > 11/2006)
    Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
              37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
       Part No: 09D 927 750 L
       Component: AL 600 6Q           0447
       Coding: 0004153
       Shop #: WSC 31414 000 00000
       VCID: 377633F44522CFF918-5102
    01314 - Engine Control Module ????????????????????????????????
       Part No SW: 3D0 909 135 M    HW: 5WK 470 26
       Component:    Kessy            6400
       Coding: 0131304
       VCID: 2F660B94BD72073940-5102
    11 Faults Found:
    00180 - Access/Start Authorization Antenna; Passenger Side (R135)
    00179 - Access/Start Authorization Antenna; Drivers Side (R134)
    00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
    00955 - Key 1
    00087 - Terminal 30 for Starting Relevant Consumers************************************?
                009 - Open or Short to Ground
    00185 - Control Circuit; Relay for Supply Voltage Terminal 15
    00184 - Control Circuit for Engine Start/Stop Switch****************************?
    01314 - Engine Control Module*******************************************?
       Part No: 7L0 959 760
       Component: Sitzverstellung     0701
       VCID: 77F6F3F405A20FF9D8-5102
    Address 08: Auto HVAC        Labels: 7L6-907-044.clb
       Part No: 7L6 907 044 F
       Component: CLIMAtronic 2+2   X 2715
       Coding: 0001030
       Subsystem 1 - Part No: 7L6 907 049 C
       Component: CLIMAtronic FOND  X 0306
    00352 - Terminal 30A
    Address 09: Cent. Elect.        Labels: 7Lx-937-049-V1.clb
       Part No: 7L6 937 049 L
       Component:                     2703
       Coding: 0111839
       Shop #: WSC 23344 444 00889
       VCID: 458A493C0FCEAD699A-5102
    9 Faults Found:
    00062 - Suspension Function Request
    00070 - Starting Battery Voltage
    00668 - Supply Voltage Terminal 30 *************************************
    00576 - Terminal 15 ************************************************
    01517 - Control Module for Trailer/Towing Sensor (J345)
                014 - Defective
    02196 - Fuse for Control Module for Power Supply to Vehicle Battery (S287)   **************************
       Part No: 7L6 953 549 E
       Component: Lenksäulenmodul     3301
       Coding: 0000232
       VCID: 41825D2C1BE68149A6-5102
    00532 - Supply Voltage B+
    Address 18: Aux. Heat        Labels: 7L6-819-008.lbl
       Part No: 7L6 819 008 B
       Component: Standheizung  E1MAC 0235
       Coding: 0000030
       VCID: 356A39FC5F2E3DE90A-5102
    00667 - Ambient Temperature Signal
    00664 - Fuel gauge
    01126 - Engine Speed Signal
    01177 - Engine Control Unit *****************************************************
    Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
       Part No: 7L6 919 879
       Component: JCI PathPoint       1600
       VCID: 040C943844745461CD-5102
    00926 - Terminal 30
       Part No: 0AD 927 755 BE
       Component: TRANSFERCASE        0122
       VCID: 7F061BD42D9237B990-5102
    Address 29: Left Light        Labels: 3D0-909-157.lbl
       Part No: 3D0 909 157
       Component: EVG GDL+AutoLWR(l)  X012
       Coding: 0000003
       VCID: 66C8AEB05208867173-5120
    00492 - Body Pitch Angle from Level Control Module
    Address 32: Differential Locks        Labels: None
       Part No: 0AC 927 771 B
       Component: SG-Quersperre       5018
    6 Faults Found:
    02412 - Differential Lock Rear
                003 - Mechanical Failure
    01312 - Powertrain Data Bus
                014 - Defective
    02053 - Control Module for Transfer Case (J646)
                013 - Check DTC Memory
    Address 37: Navigation        Labels: 7L6-919-887-CD.lbl
       Part No: 7L6 919 887 B
       Component:      Navigation     0627
       Part No: 3D0 909 158
       Component: EVG GDL+AutoLWR(r)  X012
       Coding: 0000003
       VCID: 67D6A3B455029F7948-5102
       Part No: 7L0 959 933 E
       Component: 2N HSG              0201
       Coding: 0000085
       VCID: 3E7826D06A18FEB1DB-FFFE
       Subsystem 1 - Part No: 7L0 959 701 B
       Component: Tuersteuergeraet FS 0201
       Subsystem 2 - Part No: 7L0 959 702 B
       Component: Tuersteuergeraet BF 0201
       Subsystem 3 - Part No: 7L0 959 703 B
       Subsystem 4 - Part No: 7L0 959 704 B
    22 Faults Found:
    00927 - Terminal 30 (Right)
    01516 - Terminal 30; Left
    00926 - Terminal 30
    00576 - Terminal 15
    00893 - Switch for Trunk Handle (E234)
    00325 - Rear Window Opening Button (E361)
                000 -  -  - Intermittent
    01134 - Alarm Horn (H12)
    00486 - Front Passengers Outside Door Handle Central Locking Button (E370)
                014 - Defective
    00487 - Rear Left Outside Door Handle Central Locking Button (E371)
    00488 - Rear Right Outside Door Handle Central Locking Button (E372)
    Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
       Part No: 7L6 035 466
       Component: 12K-AUDIOVERST      0108
       VCID: 71E2CDEC6BC651C916-50E6
    Address 56: Radio        Labels: 7L6-035-186-CD.lbl
       Part No: 7L6 035 186 A
       Component:        Radio        0627
       Coding: 0005077
       Shop #: WSC 00001 552 00000
       VCID: 31620DECAB4611C956-5102
    00857 - CD Changer Unit (R41)
    Address 65: Tire Pressure        Labels: 7L6-907-273.lbl
       Part No: 7L6 907 273 B
       Component: Reifendruckueberw.  0053
       Coding: 0110320
    02757 - Learning Tire Pressures
                000 -  -  - MIL ON
    Address 68: Wiper Electr.        Labels: 7L0-955-119-V1.clb
       Part No: 7L0 955 119 F
       Component: Front Wiper         2416
       Coding: 0000004
       Shop #: WSC 31414 000 376832
    Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
       Part No SW: 7L0 907 383 G    HW: 7L0 907 383 G
       Component: ANHAENGERELEKTRONIK 8854
       VCID: 387430C8483CC08111-50E6
    Address 6E: Ctrl Head Roof        Labels: None
       Part No: 7L6 919 044 G
       Component: DACHDISPLAY         0530
       Revision: 00600530    Serial number: 2009268.03
       VCID: 3B7E2FC4790AEB99FC-5102
    Address 75: Telematics        Labels: 3D0-035-617.lbl
       Part No SW: 3D0 035 617 B    HW: 3D0 035 617 B
       Component: Telematik NAR1      0104
       Coding: 0076510
       Shop #: WSC 07403 444 00051
       VCID: 1F46FB54CDD297B9F0-5102
       Part No: 7L0 919 283 F
       Component: 0J Einparkhilfe     1108
       VCID: 397235CC7336D989EE-5102
    End-------------------------(Elapsed Time: 08:50)--------------------------
    Address 02: DTCs cleared
    Address 05: DTCs cleared
    Address 06: DTCs cleared
    Address 08: DTCs cleared
    Address 09: DTCs cleared
    Address 16: DTCs cleared
    Address 18: DTCs cleared
    Address 1C: DTCs cleared
    Address 22: DTCs cleared
    Address 29: DTCs cleared
    Address 32: DTCs cleared
    Address 36: DTCs cleared
    Address 37: DTCs cleared
    Address 39: DTCs cleared
    Address 46: DTCs cleared
       Coding: 0004153
       Coding: 0131304
       VCID: 2F660B94BD72073940-50E6
    01314 - Engine Control Module *******************************
    01321 - Control Module for Airbags (J234)*********************
       Coding: 0001030
       VCID: 377633F44522CFF918-50E6
       Component:                     2703
       Coding: 0111839
       Coding: 0000232
       Coding: 0000030
       VCID: 356A39FC5F2E3DE90A-50E6
       VCID: 7F061BD42D9237B990-5120
       Coding: 0000003
       VCID: 377633F44522CFF918-5120
       Coding: 0000003
       VCID: 67D6A3B455029F7948-5120
       Coding: 0000085
    22 Faults Found:
    00927 - Terminal 30 (Right) ****************
    00926 - Terminal 30
    00576 - Terminal 15
                014 - Defective
    Control Module Part Number: 7L6 937 049 L
      Component and/or Version:                     2703
               Software Coding: 0111839
                Work Shop Code: WSC 23344 444 00889
    00576 - Terminal 15
                014 - Defective
  2. Likes Boki Ar, ivagp liked this post
  3. #2
    Oct 2014
    Arandjelovac, Serbia
    Welcome aboard !
  5. #3
    Yes welcome....
    I seriously request you remove the master ecu and see if the slave wakes up.
    Please verify the internals of the ECU's in addition to ecu supply relays and load reduction relays + ignition switch.
    Verify terminals 15 & 30 & ground 31 @ controllers directly and K lines using WD in RTFB.
    0x17 & 0x19 for cluster and gateway are also offline so these must be checked first as a combination unit.
  6. Likes Uwe, Boki Ar liked this post
  7. #4
    Jun 2017
    Jack- thank you for the help!
    I've got a question about the ECU's- I was under the impression that the horizontally mounted one was the master and the vertically mounted one was the slave. However there is a hand written note in sharpie on the horizontally mounted one that says "slave". Can you please help me confirm which one is supposed to be the master?
    You indicate to check the supply and load reduction relay. Are there instructions somewhere for how to test a relay?
  8. #5
    All in the RTFB but you could unplug one ecu at a time and query each ECU in VCDS until you rule it out.
    0x01 verse 0x11
  9. #6
    Jun 2014
    Have you checked the relay under the driver's seat for copper showing thru the sight glass?
    Also, Bentley has dire warnings about electrical system damage on 2004's if proper seguence of batt connection is not followed. They say front batt must be first disconnected and last reconnected.
  10. #7
    Jun 2017
    I'm in need of some brain power from the fantastic collective that is this forum.....
    The current diagnosis is that the two ECM's are not being powered/activated at all. Based on this, the thought is that the ignition and/or the kessy is bad.
    The kessy has been "repaired" by replacing the bad mosfets, however that should only fix the door handle portion of the kessy - if there is a more serious problem with it related to start/activation/immobilization then it would most likely need to be replaced.
    Due to these items being tied to the key programming, any of this work will now have to be done by a dealer. The dealer claiming that if they replace both of those they would need to replace the cluster, both pcms, door locks etc.
    Am I correct that there is a way around the requirement of having to replace the door locks. They could simply be unplugged behind the door panel (deactivating the touch/unlock function), correct? As long as the key fob could still be used to lock/unlock the car, I am fine with that.
    Are they correct that both PCMs would have to be replaced (I am assuming these are what I've been referring to as ECM's). Is there some work around for that?
    How about the cluster? Any work around for that?
  11. #8
    Nope what they state is BS and yeah there is indeed work around.
    Immo defeat of ECU set Master/Slave for one.
    Data transfer of kessy existing to new or used unit supplied or one purchased.
    What is condition of ECU fuses and ecu supply relay terminal 15 and 30 & at the ecu's directly?
    WHY?
  12. #9
    Jun 2017
    Jack- I always seem to have a hard time deciphering your responses!
    I do not understand this one at all. I'm not familiar enough to know what "immo defeat" is or means nor the master/slave part. Could you explain/clarify what I need to know regarding this in order to have a semi-intelligent conversation with the dealer about it?
    I will find out if the dealer is capable and willing to do this.
    All of the fuses in the dirver's, passenger's, and engine bay firewall driver's side were OK. Are there other specific ECU fuses that need to be checked? If so, where are they located? Let me find out regarding the supply terminals.
  13. #10
    Master ( Main engine ecu 0x01 )
    Slave ( Second engine ecu 0x11 )
    Immo defeat will not be offered at a "dealer", nor "data transfer", so no point in that conversation with them.
    Immobilzer defeat is when we program the ECU set to ignore the high security key crap and Kessy and just run.
    The Repair manual ( RTFB ) and using wire diagram ( WD ) to identify power sources/terminal identifiers or grounds.
    DINS
    Sorry don't mean to be cryptic.
    JPPSG
    http://forums.ross-tech.com/showthre...ut-0x01-08-000
    www.bosch-classic.com/media/en/bosch_classic/.../klemmenbezeichnungen.pdf
    https://en.wikipedia.org/wiki/DIN_72552
