Results 1 to 6 of 6
Thread: 2018 VW Arteon 2.0TDI DFGA
    Verified VCDS User aus's Avatar
    Tartu, Estonia
    Here is scan from brand new VW Arteon from dealer from a test drive.
    Saturday,15,July,2017,20:47:53:36026
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VirtualBox)
    VCDS Version 17.6.0.2 (x64)  HEX-NET CB: 0.4346.4
    Data version: 20170602 DS274
    Dealer/Shop Name: LeVWFreaks.eu
    VIN: WVWZZZ3HZJE******   License Plate:
    Chassis Type: 3H (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 29 2B 39 42 44 4B 52 5F
              6C 75 A5 BB BC D6 D7
    VIN: WVWZZZ3HZJE******   Mileage: 141km-87miles
    Address 01: Engine (J623-DFGA)       Labels: None
       Part No SW: 04L 906 026 KD    HW: 04L 907 309 P
       Component: R4 2.0l TDI   H25 4798
       Revision: B4H25---
       Coding: 0125041203641D083000
       Shop #: WSC 05311 115 00312
       ASAM Dataset: EV_ECM20TDI01104L906026KD 005005
       ROD: EV_ECM20TDI01104L906026KD.rod
       VCID: 76A02D94C94B87F7EB-8023
    Address 02: Auto Trans (J743)       Labels: None
       Part No SW: 0GC 300 042 H    HW: 0GC 927 711 G
       Component: GSG DQ381     H06 1404
       Revision: 00H06V07
       ASAM Dataset: EV_TCMDQ381061 001
       ROD: EV_TCMDQ381061_VW48.rod
       VCID: 2B16CCE042898A1F44-807F
       Revision: 00000000    Serial number: 61377000003369
       Coding: 0DEC6A9434200B6C4780060240C849B0562CD0E2600292753862F078C222420000000012121212B835351919323200
       Shop #: WSC 00015 115 08193
       ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
       VCID: 77BE2090CE41FEFFF0-8023
       Component: VWKESSYMQB    037 0906
       Revision: 00037000    Serial number: 0441733983
       Coding: 1F20000723
       VCID: 3E30F5B4A1FB0FB7F3-806B
       Part No SW: 5G0 907 044 DP    HW: 5G0 907 044 DP
       Component: Climatronic   H04 2001
       Revision: 00001K10
       Coding: 14020104202110011115500C00101922
       ASAM Dataset: EV_ACClimaBHBVW37X 006146
       ROD: EV_ACClimaBHBVW37X_006_VW27.rod
       VCID: 78BC23ACC35FF187F9-802D
       Part No SW: 5Q0 937 086 BL    HW: 5Q0 937 086 BG
       Component: BCM PQ37BOSCH 034 0242
       Revision: --------    Serial number: 865819051700NQ
       ROD: EV_BCMBOSCH_018.rod
       VCID: 05425A5884AD9C6FF2-8051
       Component: WWS    170414  042 0607
       Serial number:         170508135327
       Serial number: 20263364X81A955547A0
       Coding: 00006E
       Light switch:
       Subsystem 3 - Part No SW: 3G8 941 633     HW: 3G8 941 633
       Serial number: 22 02 2017  10000409
       Serial number: 000000000ZY171080RE9
       Serial number: 00000000000069673730
    15360256 - Component Protection
              U1101 00 [008] - Active
                        Reset counter: 41
                        Mileage: 16 km
                        Date: 2017.07.08
                        Time: 13:01:46
       Serial number: 000308418617146
       Coding: 0471151811
       Shop #: WSC 05311 115 00069
       ROD: EV_EPHVA18AU3700000.rod
       VCID: 4BD6AC60E249AA1F64-801F
       Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
       Component: ACC BOSCH MQB H10 0654
       Coding: 32017F4251FFC728949C812481400600000000000000000000
       ASAM Dataset: EV_ACCBOSCHVW416 002006
       ROD: EV_ACCBOSCHVW416.rod
    201226 - Databus
                        Reset counter: 41
                        Mileage: 16 km
                        Date: 2017.07.12
                        Time: 11:11:58
                        Dynamic environmental data: 02 8D
                        Control Module temperature: 31 °C
                        Voltage terminal 15: 14.4 V
                        Velocity_vehicle_reference: 0.03 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.12 m/s²
       Part No SW: 3Q0 959 655 BR    HW: 3Q0 959 655 BR
       Component: Airbag VW21   006 0702
       Revision: --------    Serial number: 003WEP54TUJW
       Coding: 98CCC0C00C0000005C5400CF000840000065
       Shop #: WSC 05314 000 00001
       ROD: EV_AirbaVW21TS6VW48X_VW27.rod
       VCID: 0F6E7870D6D1D63F48-805B
       Subsystem 1 - Part No SW: -----------    HW: 454 000 905 17
       Serial number: 3570000000060D7D252K
       Subsystem 2 - Part No SW: -----------    HW: 454 001 205 17
       Serial number: 35800000000CF1F0E42-
       Subsystem 3 - Part No SW: -----------    HW: 454 802 105 17
       Serial number: 3510061A983100000004
       Subsystem 4 - Part No SW: -----------    HW: 454 802 305 17
       Serial number: 352003E04EA10000000D
       Subsystem 5 - Part No SW: -----------    HW: 454 801 504 17
       Serial number: 355005E89FF0F0000008
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 454 801 605 17
       Component: PedP_Sensor_D  304 0149
       Serial number: 228000E58E810000000J
       Subsystem 7 - Part No SW: -----------    HW: 454 801 605 17
       Component: PedP_Sensor_P  304 0149
       Serial number: 22900FE4FE810000000+
       Pedestrian Protection Center:
       Subsystem 8 - Part No SW: -----------    HW: 454 801 605 17
       Component: PedP_Sensor_C  304 0149
       Serial number: 23000899BC110000000D
       Subsystem 9 - Part No SW: -----------    HW: 454 002 804 17
       Component: PedP_Sens_D_2  008 0887
       Serial number: I0M00000000B1290842Y
       Subsystem 10 - Part No SW: -----------    HW: 454 002 804 17
       Component: PedP_Sens_P_2  008 0887
       Serial number: I0N0000000011290842P
       Part No SW: 5Q0 953 521 FE    HW: 5Q0 953 569 B
       Component: Lenks.Modul   100 0225
       Revision: FF034034    Serial number: 20170514500870
       Coding: 0810
       Shop #: WSC 00015 115 00001
       ASAM Dataset: EV_SMLSVALEOMQBLRH 001009
       ROD: EV_SMLSVALEOMQBLRH_VW37.rod
       VCID: 7AB839A4FD53E3978F-802F
    291104 - Temperature Sensor for Heated Steering Wheel
              B1455 01 [008] - Electrical Failure
                        Fault Frequency: 221
                        Reset counter: 43
                        Mileage: 15 km
                        Date: 2017.07.04
                        Time: 15:07:46
                        Ubat 30 Voltage: 12.40 V
                        Internal error state: 0
                        LIN_Temp: 254
                        Isense: 0
                        Max.Leistung: 110
                        PWM: 0
                        Offset: 238
                        Slope: 134
                        kp: 13
                        OUT: 50
                        Temperatur Statisch: 30
                        Tsoll Wert 0: 39.00 °C
                        Tsoll Wert 1: 43.00 °C
                        Tsoll Wert 2: 47.00 °C
       Part No SW: 3G0 920 741 C    HW: 3G0 920 741 C
       Component: KOMBI         202 0310
       Coding: 07A4111B6F84000801806B031001000800000000
       VCID: 240427DC2F57456785-8071
       Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
       Component: GW MQB High   518 5304
       Serial number: 15051710522741
       Coding: 0B0300045F087300FB00025A1C0F00010001070000000000000000000000
       ROD: EV_GatewNF_VW27.rod
       VCID: 3326D4809AB9D2DF0C-8067
       Serial number: 46170001360160097205
       Coding: 2FFFFF
       Serial number: 75886000001705112486
       Power Converter DC AC:
       Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
       Component: U13DCAC  H26 0780
       Serial number: 0049388
       Analog clock:
       Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
       Component: Analoguhr  111 1004
       Serial number: 0202201700010069
    Address 29: Left Light (J1018)       Labels: None
       Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
       Component: LCM_MLBevoH08 0014
       VCID: 45C29A58C42D5C6FB2-8011
       Serial number: 17000133492008
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB_VW37.rod
       VCID: 71AA1E88A025A0CF3E-8025
    Address 39: Right Light (J1023)       Labels: None
       Serial number: 0000258277673
       Coding: 00355A02D000020000001000
       VCID: 47DE9050FE214E7F40-8013
       Coding: 1107
       Shop #: WSC 00015 115 00312
       ROD: EV_SteerAssisMQB_013_VW37.rod
       VCID: 3A38F9A4BDD32397CF-806F
       Serial number: 19051710800843
       Coding: 000000050100044A01102F01020000000000000000000000000000000000
       Shop #: WSC 05311 000 08193
       ROD: EV_MultiModulContiVW48X_VW27.rod
       VCID: 72A81184A5239BD7C7-8027
       Serial number: 0000258747227
       Coding: 00355002DE00020000001000
       VCID: 46C09D54F92B5777BB-8013
       Part No SW: 3Q0 035 846 B    HW: 3Q0 035 846 B
       Component: MU-S-N-ER     851 0842
       Coding: 02840301FF0000005111000100080A001F0500C4012001008E
       ROD: EV_MUStd4CDELP_VW26.rod
       VCID: 302CDB8C6BAFE9C771-8065
       Component: ABT_Std-2_Nav  H50 8120
       Serial number: VWZ6ZHT1171242
       Subsystem 2 - Part No SW: 3G0 919 866 BC    HW: -----------
       Component: ECE1 2017/18  --- 0820
       Coding: 0184030162002017000040
       VCID: 393AE6A8B8D5288FC6-806D
       Part No SW: 5NA 035 284 B    HW: 5NA 035 284 B
       Component: OCULowMQBLGE  H17 0717
       Revision: --------
       Coding: 02840301EA42180D3F1CBE000045400382E608
       ASAM Dataset: EV_OCULowMQBLGE 004044
       ROD: EV_OCULowMQBLGE_004_VW25.rod
       VCID: 3C34FFBCB7E71DA7DD-8069
       Part No SW: 3Q0 980 654 J    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H07 0273
       Serial number: 11051712K20051
       Coding: 0004080400000401002213448140A90094000E300000
       ROD: EV_MFKBoschMQBB_VW36.rod
       Part No SW: 5Q4 959 595 E    HW: 5Q4 959 595 B
       Component: TSG HFS       012 0032
       Serial number: 0000259453978
       Coding: 000050020100020000001000
       ASAM Dataset: EV_DCURearDriveMAXCONT 006001
       ROD: EV_DCURearDriveMAXCONT_VW37.rod
       VCID: 49DA9668E835B80F56-801D
       Component: TSG HBFS      012 0032
       Serial number: 0000259453975
       ASAM Dataset: EV_DCURearPasseMAXCONT 006001
       ROD: EV_DCURearPasseMAXCONT_VW37.rod
       ROD: N/A
       VCID: 16600D14E90B27F70B-8043
    No ASAM data for: "EV_LEDModLeftMELCOAU736" (VW52)
       ROD: N/A
    No ASAM data for: "EV_LEDModRightMELCOAU736" (VW52)
    End----------(Elapsed Time: 02:08, VBatt start/end: 12.3V/12.3V)-----------
    My motion is 4 motion
    Le VW Freaks
    - 4 guys who are in fond of what Volkswagen has to offer - OEM-retrofit, software updates, projects etc. Check our Facebook and webpage.
  2. Likes golfi_vend, Uwe, Eric, jyoung8607, NEtech, Dana liked this post
  3. #2
    Brand-new (141 km) and 3 modules with fault codes in them. Way to go, VW.
  4. Likes Ashraf6119 liked this post
  5. #3
    Tartu, Estonia
    How is it possible that modules have label file, but no asam
    The world is my oyster...
  6. #4
    Looks like it's a question of chassis/project.. Same part number modules are used in this Q7, where VCDS gives them AU49 data...
    New User
    Oct 2018
    Czech Republic
    Anyone know how to turn off the Arteon Start / Stop system? All instructions are for CAN Gateway 5Q0, but there is CAN Gateway 3Q0.
    Jun 2014
    Poland
    one of the "lowline " for middle...middle class
