Results 1 to 4 of 4
Thread: How does VCDS find the engine code in log file?
    Stoke on Trent, England
    Hi guys/gals.
    How does VCDS find the engine code in log file, from the ecu?
    When I scan my Golf GTD it shows:
    Address 01: Engine (CBB) Labels: 03L-906-022-CBA.clb
    I know its abbreviated from CBBB. It shows CBB on the timing belt cover again why do VW abbreviated it?
    Older vehicle scans all show:
    2005 Audi Q7 TDI V6
    Even though it shows a few error codes.
    2006 Seat Leon 1.9 TDI
    Address 01: Engine Labels: 038-906-019-ARL.lbl
    2004 Audi A3 2.0 TDI
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    2008 Skoda Octavia 1.9 TDI
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    I know I can send you the file with Redir Fail! with a map.
    I see a lot of engine codes in AutoScans on here.
    New User Keith
    In the case of label files, it looks up the ECU's part number. With the crazy proliferation of engine codes that VW undertook starting in the mid 2000's, it's often the case that one label file covers numerous different engine codes, so the name of the label file may not match the actual engine code.
  3. Likes drennie599 liked this post
    I've just seen another one 2017 Audi Q7 Address 01: Engine (J623-CREC) Labels: None
    Why does it show Engine Control Module (ECM) (J623)?
    Manufacturer: Audi, Date(s) Used: 01/2015-, Model: Audi Q7, Engine Code: CREC, 245Kw, 333PS, 3.0 Ltr, 6 Cyls, Remarks: V6
    With loads of other Audi models.
    New User Keith
    Many newer ECUs know their own J-number and Engine Code, in which case VCDS reads that info directly from the ECU.
