Results 1 to 3 of 3
Thread: Lighting Parameter Jetta 2016 issue (BYTE 18)
    New User
    Jul 2017
    Brazil
    I changed Byte 18 of my Jetta 2016...the 00 on the default code is not the code of Lighting Parameter (masked) so we need to discover the original Byte to change it...
    Please do not change the Byte 18 of your car, it is not necessary unless you change the lighting for xenon, etc...
    The dealer can't back the original parameters, so probably they will need to order a new module...BUT I would like to try a little bit because I changed some number today and have some progress...
    This link can be useful to you, https://yadi.sk/d/hbRU3MpsVCTPs...
    Now I need to know which code I need to input on my BCM, anyone could assist me on it?
    Here are the full scan of my car...
    Friday,07,July,2017,20:47:54:47443
    VCDS Version: 17.1.3.0
    VIN: 3VWLV6160GM032925   License Plate: JETTA
    Mileage: 5744   Repair Order:
    Chassis Type: 16 (7N0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 25 2B 42 44 46 4F 52 55 5F
              62 72
    Address 01: Engine (J623-CPLA)       Labels: 06K-907-425-V2.clb
       Part No SW: 06K 906 071 M    HW: 06K 907 425 C
       Component: R4 2.0l TFS   H13 9064
       Revision: --H13---
       Coding: 001D0012242400121000
       Shop #: WSC 00066 790 00187
       ASAM Dataset: EV_ECM20TFS02006K906071M 001004
       ROD: EV_ECM20TFS02006K906071AD.rod
       VCID: 354FF85F94F825E90A-8060
    17178 - Databus
    15045 - Fuel Metering Valve 1 Control Difference
              P228C 00 [096] - Pressure too Low
    15059 - Fuel Rail/System Pressure
              P0087 00 [096] - Too Low
    15027 - Fuel Level too Low
              P1250 00 [032] - -
    26384 - Databus
              U1123 00 [096] - Received Error Message
       Part No SW: 02E 300 063 P    HW: 02E 927 770 AL
       Component: GSG DSG AG6     531 4909
       Revision: 06253104    Serial number: 00001511261409
       VCID: 236B3607E26CAB59D4-8076
    28907 - No Communications with Cruise Control (Front) Distance Sensor
                U0235 - 000 -  - Intermittent
                        Reset counter: 39
                        Mileage: 5697 km
                        Date: 2015.14.09
                        Time: 11:09:36
       Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
       Component: ESP MK60EC1   H46 0175
       Revision: 00H46001
       Coding: A43B60F8092500FC251406E6901E004121180013
       VCID: 75CF385FDC7865E9CA-8020
    Address 05: Acc/Start Auth.
       Part No SW: 1K8 907 044 BF    HW: 1K8 907 044 BF
       Component: Climatronic   H07 0405
       Revision: 00001K04
       Coding: 001000C002
       Shop #: WSC 00066 790 00319
       ROD: EV_ClimaAutoBasis_VW32.rod
       VCID: 74C9055BDF027CE1FD-8020
       Part No SW: 5K0 937 087 AG    HW: 5K0 937 087 AG
       Component: BCM PQ35 H+   122 0183
       Revision: BF122001
       Coding: 48000A2E882DE3D0408800802400096C0374000875A08DB0E4C40000A040
       VCID: 7AD52B63F5660A91A7-802E
       Component: RLS 080116 05  54  0403
       Coding: 02300A
       Subsystem 2 - Part No: 5C0 951 171
       Component: Sensor, DWA 0  005 0502
                000 -  -  - Intermittent
                        Reset counter: 221
                        Mileage: 5697 km
                        Date: 2015.14.09
                        Time: 11:41:16
                        Voltage: 12.00 V
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
       Part No SW: 1K8 919 472 B    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0479
       Revision: --------    Serial number: 39391535607082
       Coding: 0031051011
       ASAM Dataset: EV_EPHVA18VW364GP00 001006
       ROD: EV_EPHVA18VW364GP00.rod
       VCID: 364DFF5389FE2EF103-8062
       Part No SW: 5C0 959 655 AF    HW: 5C0 959 655 AF
       Component: AirbagVW10    015 0614
       Serial number: 003S2M07LJK-
       Coding: 00004333
       ASAM Dataset: EV_AirbaVW10SMEVW360 001032
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 76CD3F53C97E6EF1C3-8022
       Serial number: 3572MSME6C022B56ZZZ.
       Serial number: 3582MSME7F022B56ZZZ%
       Serial number: 3516KSME3006693BZZZR
       Serial number: 3526KSME7308693BZZZ.
    Address 16: Steering wheel
    Address 17: Instruments
       Part No SW: 7N0 907 530 BF    HW: 7N0 907 530 AM
       Component: J533  Gateway H55 1673
       Revision:   H55       Serial number: 27011603010020
       Coding: 351032
       Component: IMMO          H04 1009
       Coding: 000007
       VCID: 6AF51B238DC6BA1157-803E
    Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
       Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
       Component: ELV-PQ35      H22 0240
       Revision: 00000000    Serial number: 15000270919008
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 3147CC4F609009C956-8064
       Part No SW: 561 959 701 C    HW: 3C0 959 793 J
       Component: TUER-SG FT    002 0631
       Revision: 12100010    Serial number: 0010059073
       Coding: 0410BF
       Shop #: WSC 00066 790 00080
       ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
       ROD: EV_TSGFPQ35BRFVW46X.rod
       VCID: 1E1D07F3010E86B1FB-804A
       Slave Driver:
       Subsystem 1 - Part No SW: 6R0 959 811 T    HW: 6R0 959 811 T
       Component: J388__TSG_HL  019 1467
       Serial number: 14102745160128083148
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 70     3501
       Revision: 00H22000
       VCID: 3957F46F70E0C189EE-806C
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AM
       Component: EZE_2         H55 1673
       Coding: 01030100
       VCID: 6FC30A37BE245F3900-803A
       Subsystem 1 - Part No SW: 5K0 959 591 A    HW: 6R0 959 591 D
       Component: J245 PS41.402  H03 0004
       Serial number: 0000FST000QGV0100000
       Coding: 180000
       Part No SW: 561 959 702 C    HW: 3C0 959 792 J
       Component: TUER-SG BT    002 0631
       Revision: 14100010    Serial number: 0010098104
       Coding: 0411BE
       ASAM Dataset: EV_TSGBPQ35BRFVW46X A04004
       ROD: EV_TSGBPQ35BRFVW46X.rod
       VCID: 1F633AF706048FB9F0-804A
       Slave Passenger:
       Subsystem 1 - Part No SW: 6R0 959 812 T    HW: 6R0 959 812 T
       Component: J389__TSG_HR  019 1467
       Serial number: 14102744160127194207
    Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
       Component: AFS-ECU       H05 0111
       Coding: 081200000B000200
       Shop #: WSC 01383 790 50316
       ROD: EV_HeadlRegulVWAFSPt_VW32.rod
       VCID: 3753F2578EF4D7F918-8062
       Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0004
       Coding: 860000
       Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0004
       Coding: 860000
    Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
       Part No SW: 5C0 035 680 B    HW: 5C0 035 680 B
       Component: MU-S-N-ER     H22 0245
       Serial number: VWZAZ2S8177061
       Coding: 02630103FF00000011220001001828001F0100C400200100C7
       ROD: EV_MUStd4CTSAT_VW26.rod
       VCID: 2061390B3B7AB041C9-8074
       Subsystem 1 - Part No SW: 3G0 919 866 P    HW: -----------
       Component: MRM2 2016  --- 0521
    End-------------------------(Elapsed Time: 02:40)--------------------------
    Thanks a lot and good luck for us...
    New User
    Jul 2017
    Brazil
    Guys,
    I can suggest the best way to back the parameter...try using the doc on the link
    My parameter appears to be 44, no error as soon I coded it and surprise, the functions of light back to default...YEEEEEEEEEEEEEEEEEEEEEESSSSSSSSSSSSSSSSS S
    Dealer here in Brazil doesn't know anything...I hate them...
    So just checking if any other parameter will fit, anyway, if someone have any suggestion, please let me know...
    I will post a new question about rear windows...I went to a dealer that made a online check, and after it stopped to work...
    Thanks for everyone.
    Best Regards
  3. Likes Dana liked this post
    United States
    I do not have any further suggestions so it may be best to leave it set to HEX 44. This post has a small list and most are tested/proven: http://forums.ross-tech.com/showthre...ll=1#post29310
