Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: 2008 A6 3.2L BKH Engine 000772 - Cylinder 4, P0304 - 006 - Misfire Detected - MIL ON
  1. #21
    Hudson Valley
    A big "THANK YOU" to Jack!
    I just spent a very enjoyable afternoon with Jack, and learned a vast amount of information about my 2008 A6, and about proper diagnostic procedure. It has been a long time since I have enjoyed an afternoon of technical conversation and learned so much.
    I know that Jack and I got off to a rocky start on the forum, but Jack knows his stuff, and I have even confidence that his information is rock solid.
    Jack has laid out a roadmap of how to proceed with diagnosing the problem with my son's 2008 A6 with the 3.2L engine, and I will follow the plan, and report back here when all of the testing is done so that everyone can learn from my experience with this problem. With work and all, I should be getting back to the forum early next week after the 31st, and hopefully I will have some answers to the Cylinder 4 Misfiring and the other DTCs reported here.
    Once again, Jack, thank you for a delightful afternoon of facinating conversation.
    Best, Vincent
  2. Likes NZDubNurd, Uwe, Jack@European_Parts, Eric liked this post
  3. #22
    Thank you Vincent for being so kind and most of all thank you for your past service to this country.
    Looking forward to the solution.
    What a fun weekend with new friends, donuts and good coffee!
    Please tell your wife thank you too.
  4. Likes Uwe, Eric liked this post
  5. #23
    Hudson Valley
    Good evening Jack!
    I conveyed your appreciation to my wife. It was indeed an enjoyable afternoon.
    I got the compression tester, and this evening before it got too dark outside I did a first run of compression testing.
    The results are depressing [and a bit erratic...I think there were a different number of revolutions on some cylinders]. So here are the readings,
    Cylinder 1 [Right/front] = 193 psi,
    Cylinder 2 [Right/Middle] = 195.5 psi
    Cylinder 3 [Right/Rear] = 185 psi
    Cylinder 4 [Left/Front] = 003psi
    Cylinder 5 [Left/Middle] = 185.5 psi
    Cylinder 6 [Left/Rear] = 240 psi
    I may have had my helper crank a bit longer for the last measurement, or it may have been just getting used to a new tool and developing a consistent technique.
    With the compression in Cylinder 4 being so abysmal, clearly there is a mechanical problem. I also got a leak down gage and will do that test over the weekend to isolate where the Cylinder 4 Compression leak is occurring.
    I was unable to unplug the T6 and T14 connectors to disable the injectors and was at a loss for finding the correct fuse to remove to disable them. So, against my better judgement, I ran the compression test anyway. I wanted to have some information about what was wrong and it was getting dark.
    I'll keep you posted on the next test result, and if you could make a suggestion of how to disable the injectors, I would appreciate having a way to do that. If I must, I could lubricate the connectors [dare I say] with ArmorAll, and see if that helps to disengage the T6 and T14 connectors.
    Best regards,
    Vincent
  6. Likes Eric, Uwe, Jack@European_Parts liked this post
  7. #24
    Good evening Jack!
    Best regards,
    Vincent
    Shit that sucks ........but that is why we do basics first.
    Time for tear down........after you do the test in # 4 one last time, just to be sure!
    Pull VC and see if a lifter bank looks dropped as apposed to others indicating a sucked or dropped valve.
    This is done with cam lobes facing up......... if a visual gap is present, it's time for complete head removal.
    "Connectors" ............dental pick works well as does a micro flat tip screwdriver.
  8. #25
    http://forums.ross-tech.com/showthre...l=1#post105250
    Based on tests that Vincent reported to me a few weeks ago I believe he has a hole in # 4 piston or a burnt exhaust valve.
