2008 A6 3.2L BKH Engine 000772 - Cylinder 4, P0304 - 006 - Misfire Detected - MIL ON
BinsuJiro
Hudson Valley, USA
C?ID=63476
Several weeks ago my son's A6 started throwing the code listed in the title of this message along with a Camshaft Position Sensor Code. The vehicle also started running extremely rough especially when accelerating from idle. Once the vehicle reaches an RPM over 3,000 rpm the engine smooths out, but top speed seems to be limited by the ECU. Also, the EPC Light came on along with the Traction Control Icon.
Knowing about issues with coil packs I decided to replace the COIL Packs and install new Spark Plugs. When I started this work my son and I found a considerable amount of oil in the spark plug wells, because the Valve Covers were leaking. I ordered new Valve Cover Gaskets
The vehicle was worked on in the Spring by a local Audi dealership for a Check Engine Light. The dealer service rep knew I was strapped for cash, so he tried to save me a little and didn't add the new gaskets. The dealership found dirt clogging the Cam Adjuster Valve on Bank 2 which they cleaned out, reported no sludge build up in the Cylinder Heads, and no fault with the Timing Chain.
After replacing the Valve Cover Gaskets on both Cylinder Heads, Spark Plugs, Coil Packs, and the Camshaft Position Sensor at position G163, I obtained a new set of DTCs and the Misfire in Cylinder 4 remained.
The Partial First Engine Scan for only the Engine Address 01 was run before the vehicle was serviced by the Audi Dealer. The Second Scan was done after the dealer service and before any of the mentioned repairs were performed, the Partial Third Scan for only the Engine Address 01 was the first scan after completing my repairs today and the Forth Scan was what remained after several engine starts and the clearing of previous DTCs before I called it quits for the day.
I am at a loss, and need some advice about how to proceed from here.
I would appreciate any help. Thank you, Vincent
Address 01: Engine	Labels: None
	Part No SW: 4F2 910 559 H	HW: 4F1907559E
	Component: 3.2l V6 FSI          0040
	Revision: --H21---	Serial Number:
	Coding: 01050109190F0120
	Shop #: WSC 08213 444 195013
	VCID: 312586C7F0DB4A6B27ED1F5F63-8064
005491 - Left Engine Mount Solenoid Valve (N144)
	P1573 - 009 - Open Circuit
		Reset Counter: 40
		Mileage: 248205 km
		Date: 2016.08.31
		Time: 17:40:24
		RPM: 2112 /min
		Mass Air / Rev.: 299.8 mg/str
		Temperature: 69.0°C
		: Part Throttle
		Load: 47.5
		Speed: 25.0 km/h
000838 - Camshaft Position Sensor (G163)
	P0346 - 006 - Implausible Signal - MIL ON
		Fault Status: 11100001
		Reset Counter: 40
		Mileage: 264660 km
		Date: 2017.03.20
		Time: 15:58:40
		RPM: 896 /min
		Mass Air / Rev.: 119.9 mg/str
		Temperature: 85.5°C
		: Idle
		Bin. Bits: 00010000
000033 - Bank 2: Camshaft A (Intake)
	P0021 - 008 - Retard Setpoint not Reached (Over-Advanced)
		Fault Status: 00001000
		Reset Counter: 40
		Mileage: 264682 km
		Date: 2017.03.20
		Time: 16:55:48
		RPM: 2304 /min
		Mass Air / Rev.: 446.9 mg/str
		Temperature: 91.5°C
		: Part Throttle
		Bin. Bits: 00000000
		Steering Angle: 86.01°
	P0087 - 007 - Too Low - Intermittent
		Fault Status: 00000010
		Reset Counter: 40
		Mileage: 264688 km
		Date: 2017.03.20
		Time: 17:11:54
		RPM: 672 /min
		Mass Air / Rev.: 185.3 mg/str
		Temperature: 73.5°C
		: Idle
		Pressure: 35.7 bar
#hndoc:?docid=00003002&xt=hnh:F68DD19A1EBDDF6E3BDC276F7CA20D2A6A8F3D690135B8DE518998E412B01FB7
VCDS Mobile 0.4341.0.4
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 36 37 42 46 47 4F
	 52 53 55 56 61 62 65 67 6C 72 76 77
55-Xenon Range -- Status: Malfunction 0010
Address 01: Engine	Labels: 4F-01.clb
	VCID: 312586C7F0DB4A6B27ED1F5F75-8064
000772 - Cylinder 4
004874 - Cylinder Disabling
	P130A - 006 - Short to Plus
005715 - Please check DTC Memory of ABS Controller
	P1653 - 008 - Implausible Signal
004688 - Fuel Level too Low
	P1250 - 000 - -
Address 02: Auto Trans	Labels: 4F-02.lbl
	Part No SW: 4F5 910 156	HW: 09L927156C
	Component: AG6 09L 3.2 FSI USA  0010
	Revision: --H04---	Serial Number:        4409707
	Shop #: WSC 02325 785 00200
	VCID: E58DA297749356CB8BF5DBAF51-80B0
No fault codes found.
Address 03: ABS Brakes	Labels: 4F0-910-517.lbl
	Part No SW: 4F0 910 517 AD	HW: 4F0614517AA
	Component: ESP8 quattro    H01  0070
	Revision: 00000000	Serial Number: 00000000000000
	Coding: 0020895
	VCID: 668F259B0995DDD302FF64DBC4-8033
	013 - Check DTC Memory
Address 05: Acc/Start Auth.	Labels: 4F0-910-852.clb
	Part No SW: 4F0 910 852 A	HW: 4F0837220AA
	Component: FBSAUDIC6 ELVSG H01  0040
	Revision: 09010701	Serial Number: 10601600968241
	Coding: 0000007
	Shop #: WSC 02323 785 00200
	VCID: 240B7F93BF29EFC3DC6B8EA322-8071
	Subsystem 1 - 	Part No SW: 4F0-910-131-L
	Component: FBSAUDIC6 EZS   H46  0080
	Subsystem 2 - 	Part No SW: 4F0-910-335
	Component: FBSAUDIC6 KSG   H27  0080
	Subsystem 3 - 	Part No SW: 4F0-910-220-G
	Component: FBSAUDIC6 IDG   H01  0060
Address 07: Control Head	Labels: 4F0-910-7xx-07-H.clb
	Part No SW: 4F0 910 732 D	HW: 4F1919611N
	Component: Interfacebox    H43  4140
	Revision: 00000000	Serial Number: 361AQ087519661
	Coding: 0000003
	Shop #: WSC 02335 785 00200
	Subsystem 1 - 	Part No SW: 4F0-910-609-E
	Component: Bedienteil MMIC6H01  0060
	Serial Number: 00000000959202
01964 - Control Module for Seat & Steering Column Memory (J136)
01327 - Control Module for Parking Aid (J446)
Address 08: Auto HVAC	Labels: 4F0-910-043.clb
	Part No SW: 4F0 910 043 A	HW: 4F1820043AG
	Component: KLIMABETAETIGUNGH30  0020
	Revision: 00000053	Serial Number: 00000030315871
	Coding: 0524326
	VCID: 1C7B47738759D703641B36439A-8049
Address 09: Cent. Elect.	Labels: 4F0-910-279.lbl
	Part No SW: 4F0 910 279 J	HW: 4E0955559E
	Component: ILM Fahrer      H18  0250
	Revision: 00000000	Serial Number: 4F0907279
	Coding: 0113123
	VCID: 302383C3FBD1436328E3125386-8065
	Subsystem 1 - 	Part No SW: 4F1-910-113-C	Labels: 1Kx-955-119.clb
	Component: Wischer AudiC6  H05  0210
	Coding: 0064784
	Subsystem 2 - 	Part No SW: 4E0-910-557-B	Labels: 8K0-955-559.clb
	Component: REGENLICHTSENSORH13  0100
	Coding: 0146221
Address 0E: Media Player 1	Labels: 4E0-910-111.lbl
	Part No SW: 4E0 910 110 C	HW: 4E0035110A
	Component: MP3-Changer     H46  0350
	Revision: 00046007	Serial Number: AUZ5ZBG3524659
	VCID: 18735B637361BB2340F30A33CE-804D
Address 0F: Digital Radio	Labels: 4E0-910-593-SIR.lbl
	Part No SW: 4E0 910 593 K	HW: 4E0035593F
	Component: SDAR SIRIUS     H07  0140
	Revision: 00000000	Serial Number: AUZ4Z7G0232398
	Coding: 0000100
	VCID: 2F2180BFE6EF5C9B31D9092793-807A
Address 15: Airbags	Labels: 4F0-910-655-8R.clb
	Part No SW: 4F0 910 655 F	HW: 4F0959339B
	Component: 6N AIRBAG AUDI8RH30  0300
	Revision: 15H30000	Serial Number: 00359D0GB9XD
	Coding: 0013902
	VCID: 2A1791ABDD0D39B3E6A7D0EBD0-807F
	Subsystem 1 - 	Part No SW: 4F0-910-339-B
	Component: BF-Gewichtsens. H03  0060
	Serial Number: 6332CSME37334135X
	Subsystem 2 - 	Serial Number: 6342CSME34332E1F7
	Subsystem 3 - 	Serial Number: 6352QSME4932162DH
	Subsystem 4 - 	Serial Number: 6362QSME4B741B2DV
	Subsystem 5 - 	Serial Number: 63734SME4C074A0D8
	Subsystem 6 - 	Serial Number: 63834SME4C123367/
Address 16: Steering wheel	Labels: 4F0-910-549.lbl
	Part No SW: 4F0 910 549 A	HW: 4F0953549D
	Component: J0527                0410
	Revision: 00H03000	Serial Number: 90055073550173
	Coding: 0012041
	VCID: 2711689FCE1F04DBF989B1C70B-8072
	Subsystem 1 - 	Part No SW: XXX-XXX-XXX-XX
	Component: E0221           H02  0030
Address 17: Instruments	Labels: 4F-17.clb
	Part No SW: 4F0 910 900 C	HW: 4F0920951A
	Component: KOMBIINSTR. M73 H16  0240
	Revision: 00200000	Serial Number: 64871L618
	Coding: 2129288
	Shop #: WSC 43388 001 1048576
	VCID: 20037383AB31F3E3B843629356-8075
Address 19: CAN Gateway	Labels: 4L0-910-468.clb
	Part No SW: 4L0 910 468 A	HW: 4L0907468B
	Component: J533__Gateway   H06  0060
	Revision: 00H06000	Serial Number: 1100B07C2980D4
	Coding: F5D5DE77707A0600
	Shop #: WSC 08213 444 10341
	VCID: 2D1D9AB7ECE32E8B03C5F30FB9-8078
Address 1E: Media Player 2  (R199)	Labels: 4E0-035-785.lbl
	Part No SW: 4E0 035 785 F	HW: 4E0 035 785 C
	Component: SG ext.Player H20 0850
	Revision: 00000000
	VCID: 2B1994AFD2F7A0BB1DB1DD17C7-807E
Address 36: Seat Mem. Drvr	Labels: None
	Part No SW: 4F0 910 760	HW: 4F0959760
	Component: Sitzmemory FS   H04  0050
	Revision: 00000000	Serial Number: 00000000896400
	Coding: 0082954
	VCID: E185B68760BB3AEB77CDAF9F85-80B4
Address 37: Navigation	Labels: 4E0-910-88x-37.lbl
	Part No SW: 4E0 910 888 M	HW: 4E0919887D
	Component: MNS US          H48  1100
	Revision: 00000000	Serial Number: 313HZ077525886
	Shop #: WSC 08213 444 75013
	VCID: 3833BBE313A19B2360336AB32E-806D
Address 42: Door Elect, Driver	Labels: 4F0-910-793-42.lbl
	Part No SW: 4F0 910 793 E	HW: 4F0959793E
	Component: TSG FA          H12  0210
	Revision: 00000000	Serial Number: ƒ7
	Coding: 0051947
	Shop #: WSC 02327 785 00200
	VCID: 2C1B97B3D7F9278314BBE603CA-8079
Address 46: Central Conv.	Labels: 4F0-910-289.lbl
	Part No SW: 4F0 910 289 J	HW: 4F0907289J
	Component: Komfortgeraet   H26  0210
	Revision: 02100026	Serial Number: 01090183420000
	Coding: 4618269
	Subsystem 1 - 	Part No SW: 1K0-951-605-C
	Component: LIN BACKUP HORN H03  1301
02199 - Bulb for Tail Light 2; Right (M50)
	009 - Open or Short to Ground
01506 - Bulb for Rear Fog; Right (L47)
Address 47: Sound System	Labels: 4F0-910-223-BO.lbl
	Part No SW: 4F0 910 223 J	HW: 4F0035223G
	Component: DSP-High C6     H10  0240
	Revision: PROD_01 	Serial Number: 00000000066837
	Coding: 0000026
	VCID: 250D6297B41316CBCB759BAF11-8070
Address 4F: Centr. Electr. II	Labels: 4F0-910-280.lbl
	Part No SW: 4F0 910 280	HW: 4F0907280C
	Component: ILM Beifahrer   H12  0100
	Revision:         	Serial Number: 00000000047694
	Coding: 0002014
	VCID: DEFF8D7B51C505134AAF8C7BBC-808B
Address 52: Door Elect, Pass.	Labels: 4F0-910-793-52.lbl
	Part No SW: 4F0 910 793 E	HW: 4F0959792E
	Component: TSG BF          H12  0210
	Revision: 00000000	Serial Number: P9
	Coding: 0051947
Address 53: Parking Brake	Labels: 4F0-910-801.clb
	Part No SW: 4F0 910 801 C	HW: 4F0907801A
	Component: EPB  CDEC0080   H04  0080
	Revision: --H04---
	Coding: 0005022
	Shop #: WSC 02145 785 00200
Address 55: Xenon Range	Labels: 4F0-910-357.lbl
	Part No SW: 4F0 910 357 F	HW: 4F0907357F
	Component: AFS 1           H01  0020
	Revision: 00000001	Serial Number:
	Coding: 0000016
	VCID: 29156EA7D80B32ABEF9DC7FFED-807C
	Subsystem 1 - 	Part No SW: 4F0-941-329-D	Labels: 3D0-941-329.clb
	Component: AFS-Modul links H01  0010
	Subsystem 2 - 	Part No SW: 4F0-941-329-D	Labels: 3D0-941-329.clb
	Component: AFS-Modul rechtsH01  0010
02627 - Dynamic Cornering Light Motor; Left (V318)
Address 56: Radio	Labels: 4E0-910-541.lbl
	Part No SW: 4E0 910 541 Q	HW: 4F0035541L
	Component: TUNER EU/US/RDW H42  0620
	Revision: 00000000	Serial Number: 394AZ087849910
	VCID: 2E1F9DBBE1E555933ACFFC3BAC-807B
Address 61: Battery Regul.	Labels: 4F0-910-181.lbl
	Part No SW: 4F0 910 181 F	HW: 4F0915181B
	Component: J0644 BEM       H12  0760
	Revision: 00000000	Serial Number: 00000000060909
	Coding: 0000000
	Shop #: WSC 58730 000 1048576
	Subsystem 1 - 	Part No SW: 4F0-915-105-D
	Component: von VA0  1234567890
02272 - Quiescent Current Stage 1
02276 - Quiescent Current Stage 5
02274 - Quiescent Current Stage 3
Address 62: Door, Rear Left	Labels: 4F0-910-795.lbl
	Part No SW: 4F0 910 795 E	HW: 4F0959795E
	Component: TSG HL          H21  0210
	Coding: 0051754
Address 65: Tire Pressure	Labels: 4F0-910-273-BA.lbl
	Part No SW: 4F0 910 273 B	HW: 4F0907273A
	Component: Reifendruck 3   H05  0100
	Revision: 00050100	Serial Number: 00000600061746
	Coding: 0062221
	VCID: 2207798BA53DE1F3AE57788B48-8077
Address 67: Voice Control	Labels: 4E0-910-75x-67.lbl
	Part No SW: 4E0 910 754 Q	HW: 4E0035753A
	Component: SDS 3501 US     H46  0630
	Revision: 00000000	Serial Number: 00000801070246
	Shop #: WSC 12336 024 394758
	VCID: 342B8FD30FC97F434C0B3E6352-8061
Address 6C: Back-up Cam.	Labels: 4L0-910-441.clb
	Part No SW: 4F0 910 441	HW: 4L0907441A
	Component: J772__Rearview       0050
	Revision: --H12---	Serial Number: 525PA8-J7Z20L4
	Coding: 1000304
	VCID: DDFD8A775CC31E0B53A5834FC9-8088
02203 - Audio / Video Input 1
Address 72: Door, Rear Right	Labels: 4F0-910-795.lbl
	Part No SW: 4F0 910 795 E	HW: 4F0959794E
	Component: TSG HR          H21  0210
	Coding: 0051754
Address 76: Park Assist	Labels: 4Fx-910-283.lbl
	Part No SW: 4F0 910 283 F	HW: 4F0919283F
	Component: Parkhilfe 4-Kan H09  0060
	Revision: 00H09000	Serial Number: 06230800903993
	Coding: 0021206
Address 77: Telephone	Labels: 4E0-910-336.lbl
	Part No SW: 4F0 910 336 E	HW: 4E0862335
	Component: Handyvorb2      H18  0950
	Revision: 00000000	Serial Number: 00000005020299
	Coding: 0010900
004180 - Bank2; Exhaust Cam Adjustment Valve 2 (N319)
	P1054 - 009 - Open Circuit
		Fault Status: 00010100
		Reset Counter: 40
		Mileage: 277474 km
		Date: 2017.07.14
		Time: 15:31:41
		RPM: 704 /min
		Temperature: 85.5°C
		: Idle
		Load: 30.6
000772 - Cylinder 4
		Fault Status: 01010001
		Reset Counter: 40
		Mileage: 277474 km
		Date: 2017.07.14
		Time: 15:31:51
		RPM: 832 /min
		Mass Air / Rev.: 152.6 mg/str
		Temperature: 87.0°C
		: Idle
		Time: 947.2 s
		Reset Counter: 40
		Mileage: 277474 km
		Date: 2017.07.14
		Time: 15:31:51
		RPM: 832 /min
		Mass Air / Rev.: 190.8 mg/str
		Temperature: 87.0°C
		Time: 0.00 s
		Reset Counter: 40
		Mileage: 277474 km
		Date: 2017.07.14
		Time: 15:31:51
		RPM: 928 /min
		Temperature: 87.0°C
		: Part Throttle
		Load: 27.5
		Fault Status: 01011000
		Reset Counter: 40
		Mileage: 277475 km
		Date: 2017.07.14
		Time: 15:34:20
		RPM: 3456 /min
		Mass Air / Rev.: 659.5 mg/str
		Temperature: 91.5°C
		: Part Throttle
		Bin. Bits: 00000000
		Steering Angle: 91.96°
#hndoc:?docid=0000309E&xt=hnh:31B0524FF3EFB8CC32D8AF9094A2FD529403B581E087B5CD02C6D61BD2095A09
VIN: WAUDH74F48N099614
		Reset Counter: 40
		Mileage: 277477 km
		Date: 2017.07.14
		Time: 17:00:14
		RPM: 1792 /min
		Temperature: 94.5°C
		: Part Throttle
		Load: 19.6
		Reset Counter: 40
		Mileage: 277477 km
		Date: 2017.07.14
		Time: 17:00:15
		RPM: 1728 /min
		Mass Air / Rev.: 114.5 mg/str
		Temperature: 94.5°C
		: Part Throttle
		Load: 19.2
000772 - Cylinder 4
		Reset Counter: 40
		Mileage: 277477 km
		Date: 2017.07.14
		Time: 17:00:21
		RPM: 704 /min
		Mass Air / Rev.: 147.2 mg/str
		Temperature: 94.5°C
		: Idle
		Time: 1075.2 s
		Reset Counter: 40
		Mileage: 277477 km
		Date: 2017.07.14
		Time: 17:00:22
		RPM: 768 /min
		Temperature: 94.5°C
		Time: 0.00 s
	Coding: 0020895
		Fault Status: 01101101
		Fault Frequency: 42
		Reset Counter: 246
		Mileage: 277154 km
		Date: 2017.06.22
		Time: 15:47:16
		Hex Value: 0x02C0
		Hex Value: 0x4092
		Hex Value: 0x0025
		Hex Value: 0x01A2
		Hex Value: 0x00FF
		Reset Counter: 23
		Mileage: 277277 km
		Date: 2017.06.26
		Time: 15:58:12
		Hex Value: 0x0000
		Hex Value: 0x4282
		Hex Value: 0x0024
		Hex Value: 0x0190
		Hex Value: 0x00FF
	Coding: 0000007
	Coding: 0000003
		Reset Counter: 24
		Mileage: 277277 km
		Date: 2017.06.26
		Time: 15:52:00
		Reset Counter: 3
		Mileage: 276522 km
		Date: 2017.06.17
		Time: 21:09:05
	Coding: 0524326
	Coding: 0113123
	Coding: 0064784
	Coding: 0146221
		Fault Status: 00101011
		Reset Counter: 30
		Mileage: 262136 km
		Date: 2017.04.04
		Time: 12:08:00
	Coding: 0000100
		Reset Counter: 91
		Mileage: 270984 km
		Date: 2017.05.14
		Time: 01:16:15
	Coding: 0013902
	Coding: 0012041
	Coding: 2129288
	Revision: 00000000
	Coding: 0082954
	Coding: 0051947
	Coding: 4618269
		Fault Status: 01101001
		Reset Counter: 246
		Mileage: 263605 km
		Date: 2017.03.14
		Time: 18:45:57
		Reset Counter: 246
		Mileage: 264771 km
		Date: 2017.03.21
		Time: 06:54:50
	Coding: 0000026
	Coding: 0002014
	Coding: 0051947
	Revision: --H04---
	Coding: 0005022
	Coding: 0000016
		Fault Status: 11101010
		Reset Counter: 246
		Mileage: 265000 km
		Date: 2017.04.04
		Time: 12:08:34
	Coding: 0000000
		Mileage: 270535 km
		Date: 2017.05.11
		Time: 10:01:48
		Mileage: 270535 km
		Date: 2017.05.11
		Time: 10:05:14
		Mileage: 277277 km
		Date: 2017.06.26
		Time: 12:07:01
		Mileage: 277277 km
		Date: 2017.06.26
		Time: 12:07:10
		Mileage: 277277 km
		Date: 2017.06.26
		Time: 12:07:20
	Coding: 0051754
	Coding: 0062221
	Coding: 1000304
		Reset Counter: 250
		Mileage: 276261 km
		Date: 2017.06.15
		Time: 22:29:30
		: Term 15 On
		: Reverse OFF
		Count: 3
	Coding: 0051754
	Coding: 0021206
	Coding: 0010900
BinsuJiro
Hudson Valley, USA
C?ID=63476
Oil PSI/Volume inadequate to retard set point of cam or the cam chain has been set wrong or jumped way advanced due to lack of lube.
That wasn't dirt ............that's called sludge!
You could benefit from a JPPSG protocol process.
http://forums.ross-tech.com/showthr...essional-Problem-Solver-Guide-quot-JPPSG-quot
Dear Jack,
First – It may have been sludge or it may have been something else that the dealer technician found...I did not see the screen that was blocked myself, but it was cleared.
Second – The scans represent different times over a several month period, and what appears to me to be two separate issues.
Third – The Camshaft Position Sensor issues that first appeared in the earlier scans, is no longer present, since the sensor has been replaced.
Fourth – I have inspected what was visible of the Valve-Train, the interior passages of the Valve Covers, the oil passages and cavities of the Cylinder Head and found no reductions in diameter or evidence of sludge.
Fifth – All of the new DTCs represented in the last scan appear to be electrical in nature.
Sixth – I tried to provide a sequence of scans, service and repairs very similar to what you describe on the page that you linked, but that process seems to have directed you to the wrong conclusion. Your observation relates more to the pre-dealer service issue than to the current issue. And, relative to that, having worked on a 2000 A6 2.8L Quattro Avant which hadn't had an oil change in several years, prior to my work on the current vehicle, I didn't find any Sludge in the 2000 A6 vehicle either, even after tearing down the Oil Pan, inspecting the Oil Take-up Pipe, the Oil Pump and the Valve-Train, removing the Chain Tensioner and draining the oil from the Tensioner. The oil in the Chain Tensioner on the 2008 vehicle was clean, but the screens were loose, because the method of attaching them is faulty and will not last as long as the tensioners.
The fact is that the issue with the 2000 A6 2.8L Quattro Avant was electrical, a bad Camshaft Position Sensor, but I was thrown off to Oil Distribution as the problem by the initial Dashboard Warning Light, the very large OIL CAN Icon .
So, If you have a relevant suggestion, I would be grateful if you could share it with me instead of smuggly sending me to your linked page. I have had enough aggravation over this particular vehicle and have no patience for unresponsive replies, which is similar to the way you treat people who stop in at your shop on 17K.
Thank you,
Vincent
Dear Jack,
Thank you,
Vincent
Actually your scans have no dates nor did your data indicate that this was an event leading up to as you have defined in your 1-6 steps until after the JPPSG & you editing your post that I recalled while I was writing a response in the buffer.
So the..........ah, what you consider smug response to the JPPSG....... has actually added such clarity which was needed & maybe I was tired last night or misread your post just looking at the scan data half asleep.
I am located in the Hudson Valley too, so I understand why you would assume such an attitude........maybe it's just geographic! :p
You are the one who indicated an FOD in the adjuster and described it as dirt not me and unless the kids were dumping stuff down the oil fill I believe I answered correctly out of concern for the sump and DTC's exhibited.
The over advanced code is usually a dead giveaway of a serious underlined condition for timing or in the sump for contaminated oil or floaters & which take time to plug the oil pump screen, while further running as engine operation time continues as you described.
If oil sludge or FOD have made its way past the oil pump pickup screen and then past the oil filter & to the tiny micron screen at adjuster, that's a problem even though it may not appear contaminated in the head, VC area!
It also is what usually causes or contributes a solenoid to go open from the ECU constantly trying to compensate for an out of sync cam.
Why are you mixing years of different vehicle's in this post to rationalize, it only causes confusion and they are entirely different engine's!
If all you have now is a bad adjuster or wiring to it than get the WD and trace the tracks while further testing the solenoid of the adjuster but don't discredit the FOD warnings because of what happened in a 2000 A6
More than likely reported that way to not have to offer goodwill for free since it is fact a problem as are chains + adjusters due to sludge in this car.
As for the micron screens I remove them because I find they do more harm than good at the adjuster.
As for what happens in a 2000 A6 shouldn't be your basis for how you deal with a 2008 3.2 & entirely different engine with chains.
I'm sorry you feel I was being smug or abrasive............it wasn't my intent, however, I think your thought process for diagnosis did suck......... still does and you should change it. :rolleyes:
Signed the asshole of the century NostraJackAss!
Mr. M
Leicestershire, UK
C?ID=256600
Hi Vincent,
Maybe you have more than one issue causing your problems.
Have you carried out a compression test? It is a little strange that you only have a misfire on cylinder 4 if the problem is cam timing related. Does it sound like the engine is only running on 5 cylinders at all times from start up? May be worth checking the misfire counters in MVBs after a DTC clear.
I would run a function test on the cam adjustment valves using the output tests function in VCDS, but try this with the engine both hot and cold. You should be able to hear the valves clicking on and off. If a problem is found you may be able to verify it by checking the resistance of the valve's solenoid, but be aware that the problem may be intermittent so you may not see it with a multimeter!
I would also suggest making sure your battery is fully charged - it won't cause cam timing problems but will cause other problems elsewhere.
Mr. M
Yeah I second that Mr.M ......basics! :D /\
Hear that Vinnie?
Do compression check and leak down test..........don't assume because the 2000 A6 was okay that this should be a reason to negate it here....... :banghead:
BinsuJiro
Hudson Valley, USA
C?ID=63476
Dear Jack,
Thank you for detailed response!
I was doing some further testing this morning and the codes were changing. After a test drive I decided to look at the Sensor and Valve in question from the Codes.
What I found was the following: The Exhaust Cam Adjustment Valve 2 (N319) at first glance looked normal. Just incase the cleaning fluids I used cause current to short in the connector, I blew it out with compressed air. Upon doing so the red/purple Locking Bar of the Locking Connector 8K0 973 702 D for the Exhaust Cam Adjustment Valve 2 (N319) blew out. I looked with a magnifying glass, and found that the interior portion of the connector had split at the point where the Locking Bar secures the contacts in the connector.
Therefore, upon replacing the connector after the Valve Cover Gasket replacement, the contacts were just pushed up as the connector was pushed down. Upon further examination I found the interior portion of the connector that actually holds the contacts in the proper orientation and locks them in after the Locking Bar is inserted, lodged on the valve connector. I retrieved it and am now trying to make a temporary repair until I can order a new Locking Connector 8K0 973 702 D.
If the temporary epoxy compound repair to the internal portion of the connector works, I I will be able to properly orient the contacts and place the connector on the Exhaust Cam Adjustment Valve 2 (N319) until the replacement arrives.
Finally, I don't believe my diagnostic procedures and processes are nearly as flawed as you think. And, I understand that the two engines are different, but if the "abused engine showed no sludge then an engine that had been maintained properly should by inference at the very least be in better condition than the abused engine.
I do like your idea about removing those troublesome screens, since as you, I feel they have the potential to do more harm. However, I would not remove them without some corroborating opinion which I now have.
Sorry for being so irritable, but a friend is having an 80th Birthday celebration today and my son is in NYC with our only other car.
Vincent
BinsuJiro
Hudson Valley, USA
C?ID=63476
Mr. M,
I have not tried a compression test, and you are the third person to suggest that today. I will conduct that test as soon as possible. And, thanks for the other suggestions. I proceed accordingly.
Thank you,
Vincent
BinsuJiro
Hudson Valley, USA
C?ID=63476
Yes, Jack, I did hear that and will do the test. But, please be aware that when you respond to questions, there are people like me who work on their cars when something goes wrong [and have for over fifty years], but don't work on Audi and VWs every day. I don't have the hours to devote to the practice of Audi repair that you have devoted to the task.
I have been told by a mutual acquaintance in the Town of Wallkill that you are a top notch Audi expert and very capable. I respect your knowledge and skills, but don't like being treated with disdain or apparent disdain for trying to learn more about repairing my vehicle. If I could afford your prices, at 72, I'd much prefer to have the work done by an expert and not be out on a dirt driveway with no lift and half the tools that I need to do the job.
So, please consider the questions from the perspective of others. Fortunately, a friend lent me his car today and I was honored to attend my friend's 80th birthday celebration, and the stress of getting the A6 back on the road has been somewhat relieved.
Thanks again for your responses,
Vincent
Ah whatever ...It didn't nor does it cost anyone a dime to deal with my crap for free here.
Anyone that frequents here, knows that I am genuinely trying to help them and the collective to follow a path so that things are done with some continuity.
I work with plenty of people that have much less than you and personally I dont feel I am belittling them or you.
It's called breaking balls through a term of endearment.
It's not like you paid me, so come on loosen up & have fun or just set me to ignore. Just because you are an old guy doesn't mean you have to be a stick in the spokes.
BinsuJiro
Hudson Valley, USA
C?ID=63476
Well Jack, you did make me chuckle. I'll try to loosen up.:thanks:
That's the spirit............:rolleyes:
I'll tell you what "hover round" I will give you one on one walk on water action & at my shop, "at no charge" other than coffee and donuts from D&D, than we can sit down and discuss anything you want for 1 hour about your car or the RTFB.
So have your notebook and questions ready and your appointment written via email & in order substantiating your human race papers.
If that's not American than IDK WTF is........!
This should be your pic in the forum /\
https://s11.postimg.org/5kiokwbtv/N319_hover_round_HV.png
https://postimg.org/image/dtrknp7wf/
https://s11.postimg.org/5bi4jd1dt/N319_hover_round_HV2.png?dl=1
BinsuJiro
Hudson Valley, USA
C?ID=63476
Dear Jack,
That is very generous of you and I would love to take you up on this offer. What kind of Donuts do you like and how would you like your coffee?
Thank you,
Vincent
Cream and sugar & chocolate frosted..... :rolleyes:
The contact form at my website is where we start for policy forms to identify you and the car via the JPPSG.
Do you have a factory repair manual?
Have swapped plug, coil pack, or injectors to see if misfire moved from existing location?
Did you do leak down compression test?
Did you check intake for false air leak at this location?
Have the intake valves or port been checked for FOD or carbon?
BinsuJiro
Hudson Valley, USA
C?ID=63476
Hi Jack,
I have downloaded the VIN specific electronic manual from erWi.Audi.com.
The Spark Plugs and Coil Packs are new.
The Valve Cover Gasket is new and there are no leaks at the Cover Bolts or around the COVER.
I'm waiting for the Locking Connector 8K0 973 702 D for the Exhaust Cam Adjustment Valve 2 (N319) to be delivered. It was broken and not seating properly.
I have not checked the injector at that location yet. I don't currently have the tools for working on the injectors. But, that was on my list.
Let me add some historical information here: After the vehicle was repaired at the Audi dealership, it was running fine. Some time after that my son filled up the fuel tank with economy grade gasoline by mistake, and shortly after that the error codes started appearing with the very rough idle and the misfiring in Cylinder 4. It may have been simple coincidence that the trouble started after the refueling with cheap gas. I just thought I should mention this.
I'm ordering the tools for the compression and leak down test, so I have not done that yet.
I have not checked for false air leak at this location. If I understand this question correctly, are you speaking of an air leak at the injector?
And, regarding the intake valves and valve ports, I'll need to order replacement gaskets and "o" rings to reseal everything after checking them.
Thank you, Jack!
Vincent
No but air anywhere between MAF and combustion chamber.
You should try enhancing the grounds and power to the #4 coil.
I am sending you an email response now for your credentials and JPPSG.
JPPSG VIA email is incomplete for possible weekend special appointment please rectify it and provide your credentials requested to further identify you & the vehicle so I may do research.
Thank you
You have a direct short and it must be corrected.............
Reset Counter: 40
Mileage: 277477 km
Date: 2017.07.14
Time: 17:00:22
RPM: 768 /min
Temperature: 94.5°C
Time: 0.00 s
Short to plus.............http://wiki.ross-tech.com/wiki/index.php/P130A/04874
[h=1]P130A/04874[/h][h=3]From Ross-Tech Wiki[/h]
Jump to: navigation, search
[h=2]P130A/04874 - Hide cylinder / Cylinder Disabling[/h][h=4]Possible Causes[/h]
  • Excessive Misfiring
[h=4]Possible Solutions[/h]
  • Correct the root cause of the Excessive Misfiring
[h=4]Special Notes[/h]
  • This DTC indicates that the Engine Control Module (ECM) has seen 'Excessive Misfiring' and the the ECM has switched 'OFF' fuel injector(s) to prevent engine and exhaust catalyst damage
  • To clear this fault code, it will be necessary to correct the root cause of the misfires and this code will then be able to be cleared.
Engine mount also shares a power bus with the N319.............N144 which you also had a legacy DTC for.........isolate it and try swapping the N319 with N208 next to it and see if the DTC moves.
